POV-Ray : Newsgroups : povray.binaries.images : Cylindrical greebles (+code) Server Time
29 Nov 2026 16:24:47 EST (-0500)
  Cylindrical greebles (+code) (Message 1 to 15 of 15)
Subject: Cylindrical greebles (+code)
Date: 21 May 2006 13:25:55
Message: <4470a2a3@news.povray.org>
I had to do this with a lot of triangles, because doing it with intersections of
cylinders was way too slow.
parse time: 17 seconds
render time: 3 minutes 50 seconds
Comments welcome :)
(oh, I also attached an image made with the latest update of the
polygon-greeble-macro :))
cu!
Download 'cilinder-greeble.pov.txt' (8 KB) Download 'polygongreebles-update.jpg' (35 KB) Download 'cylinder-greeble.jpg' (64 KB)
Preview of image 'polygongreebles-update.jpg'
Preview of image 'cylinder-greeble.jpg'
Subject: Re: Cylindrical greebles (+code)
Date: 21 May 2006 13:36:48
Message: <4470a530@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> a écrit dans le message de
news: 4470a2a3@news.povray.org...
intersections of
> Comments welcome :)
That's very cooool 8-)
Here is the actual outside of Rama
Marc
Date: 21 May 2006 13:58:02
Message: <4470aa2a$1@news.povray.org>
"M_a_r_c" <jac### [at] wanadoofr> wrote in message
news:4470a530@news.povray.org...
had to look that one up :-/
seems like just a cylinder, without greebles? :) probably because of the size :)
cu!
Date: 21 May 2006 14:30:57
Message: <4470b1e1@news.povray.org>
That is very cool, man :)
>intersections of cylinders was way too slow.
> Comments welcome :)
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Date: 21 May 2006 16:23:12
Message: <4470cc30$1@news.povray.org>
That's really good. The texture is so fantastic, though, that I wonder how
good the greebles would look without it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 May 2006 16:40:28
Message: <4470d03c@news.povray.org>
When are you starting to build your first Battlestar Galactica?
Your greebles are so perfect, meanwhile, that they can make out of simple
shapes complete full detailed and - most important - very impressive
battleships!
Zeger, I have started to develop space guns for battleships, please see the
images inside the thread "SF: Preview 11+: Imperial Carrier". If you like,
you could have your macro adding them on top of the low cylinders of your
greeble. Let me know.
Greetings,
Sven
Date: 21 May 2006 17:42:18
Message: <4470deba@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:4470d03c@news.povray.org...
oh, I'm having way too much fun creating the macros at the moment :)
Next stop: changing cylindrical greebles into conical greebles. After
that, it's time for spheres :)
oh, and I'll probably rewrite parts of the polygon-version, also using
triangles, so it'll render faster
simple
> battleships!
:) thank you !
see the
like,
your
should be possible, but I think it would be better to have a seperate
(set of) macro(s) for doing things like that
cu!
Date: 21 May 2006 17:42:40
Message: <4470ded0$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:4470cc30$1@news.povray.org...
> That's really good.
thank you!
well, I attached the source with the image, so you can try it out for
yourself :)
Actually, first I wanted to post a version without the texture, but
although it looked good (imho), it looks 10 times bigger with the
texture
cu!
Date: 21 May 2006 19:50:32
Message: <4470fcc8$1@news.povray.org>
"Stefan" <azy### [at] hotmailcom> wrote in message
news:4470b1e1@news.povray.org...
tnx :)
Date: 22 May 2006 01:22:11
Message: <44714a83$1@news.povray.org>
> Comments welcome :)
> cu!
Excellent work.
They could both pass as space ships already. The texture and lighting
really add to the feel of it.
How many different types of greeble are used?
Dave.
Date: 22 May 2006 03:03:47
Message: <44716253@news.povray.org>
"David Brickell" <d.b### [at] nospamgmailcom> wrote in message
news:44714a83$1@news.povray.org...
> Excellent work.
thank you :)
well, every "greeble-cell" has up to 5 cylindrical components
(superellipsoids), up to 5 box-like components (triangle mesh), up to 5
horizontal tubes (also a mesh) and up to 5 vertical tubes (cylinders and
spheres).
that makes 4 types of greeble :)
cu!
Date: 22 May 2006 07:38:13
Message: <4471a2a5$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:4470a2a3@news.povray.org...
> Comments welcome :)
Really, really nice work.  I hope you don't mind if the community steals--
er, learns from... your techniques!
- How
Date: 22 May 2006 08:34:42
Message: <4471afe2$1@news.povray.org>
"How Camp" <hac### [at] gmailcom> wrote in message
news:4471a2a5$1@news.povray.org...
thank you :)
In the contrary! that's why I also attached the source :)
cu!
Date: 22 May 2006 22:26:29
Message: <pan.2006.05.22.20.26.20.362472@localhost>
Best space ship type greebls I've seen.  Nice.
to all the companies who wait until a large user base becomes
dependent on their freeware, then shafting said happy campers with
mandatory payment for continued usage. I spit on your grave.
Date: 23 May 2006 01:55:01
Message: <web.4472a354df4917d0ff6989d80@news.povray.org>
> Comments welcome :)
> cu!
They both look awesome! What is the CPU speed and amount of RAM for those
times?
