How can I make this look cool?
(Text = CSG. The S in particular was very hard; it involves 4 cylinders
and 2 cubes. (?!) Lighting is radiosity (bluish) + 1 light sournce
("sun", yellowish). Hmm...)
Download 'invisible03.jpg' (62 KB)
Preview of image 'invisible03.jpg'
A touch of color would help. And so would cleaning up the edges of the
letters. N is horrible. V is dodgy. The S is good.
DLM
"Orchid XP v2" <voi### [at] dev null> wrote in message
news:446c54de@news.povray.org...
Instead of using boxes, use prisms with linear_spline to make the letters.
This will make it easier to clean up the 'N'.
The 'S' could be done with a prism using bezier_spline to get both flat &
curved surfaces, but you need to know a thing or two about where to put the
control points. If you post the code for the 'S' I can do a bezier
version...
Beyond that, using photons & dispersion could make quite a difference.
Radiosity won't have much effect on the 'glass' letters. Unless you plan to
put more plain-coloured (not transparent or too reflective) objects in the
scene it would be quicker to leave it out.
> version...
Gaaarrhhh! What am I talking about?
Just use the text{} object in Povray.
Come to think of it, why aren't you using it?
Orchid XP v2 nous apporta ses lumieres en ce 18/05/2006 07:05:
Ever considered using a text object?
That apart, you may want to intersect your leters with a box. It will help removing
the extra edges
on the "N".
Use a merge instead of an union for the "N" and "V" to remove those internal surfaces.
Try to change the camera position so that we can see the whole thing.
As is, radiosity looks like it's a waste of time. Using photons can have a dramatic
effect. Set your
transparent objects as target with refraction on, reflection on may not be useful. Add
some dispersion.
Adding a faint coloration to the substance of your leters may help, use fade_color
color
fade_distance 4 to 10 times the thickness of the leters to keep it faint and
fade_power some value
to control it. It's place is in the interior{...} block.
Don't take life too seriously, you won't get out alive.
Hmm... that could work.
> curved surfaces
Nah. I'm already quite happy with the S.
Quicker without radiosity, certinaly. But then the scene is vastly too
dark...
I was thinking about adding some photos.
Well, I was *planning* to bevel all the letters in 3D... but I never got
round to it. :-\
Yes, but I *was* going to make all the edges curved. (In fact, I still
hope to. It's just that doing it requires about 12x as many objects...)
> help removing the extra edges on the "N".
Yeah, I think you might be right there. Either that or use a prism...
> internal surfaces.
Already using merge.
Technically, you already can. (I haven't moddled the remaining letters yet!)
Image is far too dark without it.
> Using photons can have a dramatic effect.
Yeah. As I say, the original plan was to curve all the corners. If I
manage to do that, photons are really gonna be good!
> Add some dispersion.
Sounds slow... LOL!
> fade_color color fade_distance 4 to 10 times the thickness of the leters
> to keep it faint and fade_power some value to control it. It's place is
Mmm, OK. I'll try that...
Use a fading light (fade_power 2) close to the text.
Make it an area light. Use photons.
Just those, and it will look a lot better.
news:446d7faf$1@news.povray.org...
> round to it. :-\
Hmm, doesn't Elefont bevel text for you?
http://www.armanisoft.ch/webdesign/elefont/Elefont.html
- How
Orchid XP v2 nous apporta ses lumieres en ce 19/05/2006 04:22:
You can simply increase the light value. If rgb 1 is to low, there is nothing that
prevent you from
using a larger value. If you have some media above the scene, try using extinction
with a value less
than 1.
I drive way too fast to worry about cholesterol.
>> round to it. :-\
> - How
Fine if you're using windows :-)
Someone did post a macro a while back that would bevel any object,
I think it was done with a merge of many copies translated by a
set of equal length vectors in various (all) directions. The bigger
your set of vectors, the smoother the bevelling. Something like
that anyway.
Bill Hails
http://billhails.net/
Photons. Lots of photons.
Dispersion. Use a value less than 1.0 for a physically incorrect and
totally cool effect.
The macro Beveled_Text() in shapes.inc is slow and leaves some distracting
artifacts, but it's available until you program (or borrow) something
better.
"Bill Hails" <me### [at] billhails net> wrote in message
news:446edf68@news.povray.org...
Whoops, sorry!
> that anyway.
Ah, hmm. I think shapes.inc has a 'Bevelled_Text' macro. Is this what
you're talking about?
- How
"How Camp" <hac### [at] gmail com> wrote in message
news:4471a51f$1@news.povray.org...
Oh, never mind me. Cousin Ricky already mentioned this. serves me right
for not reading all the new posts first...
- How
