POV-Ray : Newsgroups : povray.binaries.images : Placing random spheres (~330k in attachments) Server Time
13 Oct 2026 23:22:07 EDT (-0400)
  Placing random spheres (~330k in attachments) (Message 1 to 32 of 32)
Subject: Placing random spheres (~330k in attachments)
Date: 15 May 2006 16:48:16
Message: <4468e90a@news.povray.org>
Inspired by a post I made to another group, I thought if I could find
a fast way to create a large amount of randomly-placed spheres on a plane
so that they don't intersect each other.
  In these images I created 5000 spheres randomly placed inside an area
between <-10, 0, -10> and <10, 0, 10>. The locations of each sphere is
individually calculated with just a honest
MinCoords+(MaxCoords-MinCoords)*<rand(Seed), 0, rand(Seed)>
ie. no cheating by creating repeating patterns which just look random
or anything. The location of each sphere is honestly calculated by
with that line.
  In the first image the radius of the spheres is 0.2 and it took
17 seconds to parse in my P4 3.4GHz. In the second image the radius
is 0.23 and it took a lot longer because the space fills faster and
it's harder to find places for new spheres: 2 minutes 44 seconds.
  The naive way of doing this (which I posted in that another group)
took more than 7 minutes to place the spheres of radius 0.2 (compared
to the 17 seconds of my optimized method). I don't know how much longer
than 7 minutes it is because I got bored of waiting and stopped it.
  The scene which created these images is 76 lines long (written in
a nice, indented way, no obfuscation nor artificial shortening, and
it even prints its progress during the calculations).
  If you want a small challenge, try replicating this result.
Download 'randspheres_radius0.2.jpg' (160 KB) Download 'randspheres_radius0.23.jpg' (164 KB)
Preview of image 'randspheres_radius0.2.jpg'
Preview of image 'randspheres_radius0.23.jpg'
Subject: Re: Placing random spheres (~330k in attachments)
Date: 15 May 2006 18:24:05
Message: <4468ff85$1@news.povray.org>
That's neat. Would it be much more difficult to put them on the surface of a
sphere rather than a plane? And what if you want to make sure that they are
as equally spaced as possible -- that they sort of repel each other. I bet
that would take longer.
Date: 15 May 2006 21:44:40
Message: <44692e88@news.povray.org>
   Not really. It would even be as fast to calculate (well, approximately
at least).
   That would be a bit more complicated and naturally will take longer.
Date: 16 May 2006 00:35:36
Message: <44695698$1@news.povray.org>
When faced with this problem, I usually take the easy way out and put
them into rows and columns, with jitter to make it look random.
John
Date: 16 May 2006 05:13:31
Message: <446997bb$1@news.povray.org>
Oops, I had an error in my description: It was the *diameter*, not
the radius of the spheres which were 0.2 and 0.23.
   Anyways, with a small change I got the time for the spheres of
diamater 0.2 reduced to 15 seconds and the time for the ones of
diamater 0.23 to 1:50.
Date: 16 May 2006 05:14:42
Message: <44699802$1@news.povray.org>
   But as I said, I don't use any fakery. The location of every single
sphere is calculated randomly accross the entire area. :)
Date: 16 May 2006 07:46:10
Message: <4469bb82@news.povray.org>
Hi Warp,
Here's the result from a file I set up a while ago, using your radii.
On a P3, 933MHz the parsing for the 0.1 radius was 41s, for the 0.115
radius it was 10m20s (620s).
I wonder if we're using the same technique ...
Mike.
> with that line.
Download 'array_fill1.jpg' (69 KB) Download 'array_fill2.jpg' (67 KB)
Preview of image 'array_fill1.jpg'
Preview of image 'array_fill2.jpg'
Date: 16 May 2006 08:17:53
Message: <4469c2f1$1@news.povray.org>
news:446997bb$1@news.povray.org...
quite a difference :)
best I could come up with, is more or less the naive way, where I, in a
way, let POV-Ray itself check the intersections, instead of doing the
checks in POV-SDL:
-- begin code --
 location <1,8,4>*2
 look_at 0
light_source {<75,180,500> rgb 1}
#declare Seed=seed(354);
#declare MinCoords=<-10,0,-10>;
#declare MaxCoords=<10,0,10>;
#macro Location()
 #local R=MinCoords+(MaxCoords-MinCoords)*<rand(Seed), 0, rand(Seed)>;
 R
#declare TestTexture=sphere {MaxCoords*10,.01}
#declare Count=5000;
#declare Radius=.1;
#while (Count>0)
 #local Loc=Location();
 #if (inside(TestTexture,Loc)=0)
  sphere {Loc,Radius pigment {rgb <rand(Seed),rand(Seed),rand(Seed)>}
finish {ambient .25 specular 1}}
  #declare TestTexture=union {object{TestTexture} sphere
{Loc,Radius*2}}
  #declare Count=Count-1;
  //#debug concat(str(Count, 0, 0)," to go\n")
-- end code --
takes 1'30" for a diameter of .2 and 6'51" for a diameter of .23
(but I only have an athlon xp 2500+ :))
cu!
Date: 16 May 2006 08:44:29
Message: <4469c92d@news.povray.org>
Ran it on an Athlon dualcore 3800 (64bit Linux)
33 sec for 0.2 diameter
230 sec for 0.23 diameter
Ger
Date: 16 May 2006 09:06:43
Message: <4469ce63$1@news.povray.org>
"Ger" <No.### [at] ThankYou> wrote in message
news:4469c92d@news.povray.org...
hmm, huge difference, I think it's time for a new pc :)
cu!
Date: 16 May 2006 09:37:58
Message: <4469d5b6@news.povray.org>
Hi Warp,
I like your smart programming.
But here is my question:
Let's say, I intend to place a ramdom-generated pattern of spheres (such as
yours) on an unequal surface (maybe a heightfield or a union of objects).
How, then, would the code look alike? Can you help me?
Greetings,
Sven
Date: 16 May 2006 10:35:20
Message: <4469e328$1@news.povray.org>
   My method can actually be used for any distributions of spheres,
not just a plane. You only have to come up with a formula which
calculates a random placement for the spheres in whatever shape
you want (eg. the surface of an object). Of course with certain
shapes calculating an even distribution may not be as trivial
as a simple <rand(S), rand(S), rand(S)> (for example distributing
points about evenly on the surface of a sphere requires a function
slightly more complicated).
   If you want to place spheres on the surface of an object you'll
have to use trace to get points on that object and figure out a
way to distribute these points approximately equally on the surface
of the whole object (with a spherical surface it's rather easy but
with other more irregular surfaces it can be more difficult).
   The naive approach is to simply store the locations of the spheres
already created in an array and then when a new sphere is created,
check it against each coordinate in this array (iow. check if the
center of the sphere you just created is closer than the diameter
of the sphere to any of the coordinates in the array; if it is closer
to any of the points, then it's not ok and you have to create another
location for the new sphere; after you successfully create it, add
its center coordinates to the array).
   My optimized method uses this basic approach but I figured out a
rather simple way of speeding up the check a *lot*.
   The good thing about this approach is that you can have *any*
distribution for the spheres you like (eg. on the surface of any
object or whatever), and this algorithm will never produce spheres
which are intersecting.
   I can post a description of my simple method in povray.general if
people are interested. (It's probably nothing new and other people
have probably already thought of it, but perhaps my specific approach
is more resource-friendly than most other attempts.)
Date: 16 May 2006 11:05:47
Message: <4469ea4b@news.povray.org>
Well I've got 15 seconds for the 0.2 diameter spheres, but I'm currently up
at 3 minutes 53 seconds for  the 0.23 diameter ones (on a 1.8GHz machine).
Chris B.
Date: 16 May 2006 11:55:01
Message: <web.4469f4b2f5b1f07d6c4803960@news.povray.org>
Running 3.6 on a 1.8GHz laptop with 512MB RAM:
0.2  = 0:08
0.23 = 1:26
(note: this is with the centers constrained to <-10,0,-10><10,0,10>)
-tgq
Date: 16 May 2006 12:27:17
Message: <4469fd65@news.povray.org>
> 0.2  = 0:08
> 0.23 = 1:26
   I guess we use the same technique but you optimized the SDL more
to be faster. Or perhaps you use something really innovative?
Date: 16 May 2006 12:50:01
Message: <web.446a028af5b1f07d6c4803960@news.povray.org>
> > 0.2  = 0:08
> > 0.23 = 1:26
Depends, I haven't seen yours yet... but based on the times, I would assume
they are similar.  I don't think I did anything really innovative, just
tweaked my algorithm to try to minimize the calcs required as much as
possible.  Actually I started with a bit higher times for the 0.23, but
made some algorithm optimizations to speed it up, then made some SDL
optimizations for further speeding.
-tgq
Date: 16 May 2006 13:02:26
Message: <446a05a2$1@news.povray.org>
Greetings, and thanks for your answer.
Yes, I would be interested to see how the code for the object distribution
would be. I tried on my own, a few successless times before, but had not
even the right beginning idea.
And to be honest, if you could show me how to trace the surface(s) of an
object on which the objects should be distributed, I would appreciate it a
lot! I am asking, because I also have no idea how to do that.
Thanks,
Sven
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:4469e328$1@news.povray.org...
>> as yours) on an unequal surface (maybe a heightfield or a union of
>> objects).
Date: 16 May 2006 13:52:22
Message: <446a1156$1@news.povray.org>
94 seconds on an Athlon Xp-1700.  The first iteration gave me about 3
minutes, the second got me to that.  Once I figured what it was, the
only thing I could say was "Doh!"
...Chambers
Date: 16 May 2006 14:35:00
Message: <web.446a1aecf5b1f07d6c4803960@news.povray.org>
> > > 0.2  = 0:08
> > > 0.23 = 1:26
> -tgq
One further refinement in the algorithm
0.2  = 0:08 (no significant change)
0.23 = 1:11
-tgq
Date: 16 May 2006 14:55:00
Message: <web.446a1f9ef5b1f07d6c4803960@news.povray.org>
Interestingly if you constrain the entire sphere volume to the given area
(20x20) rather than the center positions, the parse time triples...
-tgq
Date: 16 May 2006 16:44:35
Message: <446a39b3$1@news.povray.org>
Do you have problems with it turning into an O(n^2) problem, or is there
some kind of shortcut to make things go faster?
John
Date: 17 May 2006 10:06:33
Message: <446b2de9@news.povray.org>
   AFAIK the method I use is faster than O(n^2), although it might not
be immediately obvious from the code.
   (Although don't quote me on that. Trying to prove that claim is
actually quite difficult... :P )
Date: 17 May 2006 10:08:49
Message: <446b2e71$1@news.povray.org>
   Well, the POV-Ray documentation answers that question. Just look for
trace() in the docs.
Date: 17 May 2006 12:22:19
Message: <446b4dbb@news.povray.org>
> -tgq
Rather than do that, why not just decrease the size of the Min and Max
coordinates?  Ie, instead of using +/- <10,0,10>, use +/- <9.9,0,9.9>?
I'd think that would be faster, and cleaner.
...Chambers
Date: 17 May 2006 12:55:01
Message: <web.446b544ef5b1f07d6c4803960@news.povray.org>
> > -tgq
> ...Chambers
Actually this is what I did to test it.  Just making a comment on how filled
up the area is getting that that small of a change in area(~2.3%) has that
much of an impact on the parse time.
-tgq
Date: 17 May 2006 13:16:20
Message: <446b5a64$1@news.povray.org>
Hash: SHA1
>> there some kind of shortcut to make things go faster?
	I would bet O(n.log(n) although I can't prove it either ;)
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFEa1pkd0kWM4JG3k8RAg88AJ960Ua77/qWgcukC9/FRKq9T5C4wACgjsGX
cEof8uIXFGlWrcdfw3wL+r0=
=aDFv
-----END PGP SIGNATURE-----
Date: 18 May 2006 14:08:52
Message: <446cb834$1@news.povray.org>
Even if you constrain by contracting the bounding box by 1D?
DLM
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.446a1f9ef5b1f07d6c4803960@news.povray.org...
> -tgq
Date: 18 May 2006 14:30:00
Message: <web.446cbcc9f5b1f07d6c4803960@news.povray.org>
> DLM
> > -tgq
Yes,  i just happens that at these parameters, the area is fairly filled up,
so randomly finding a usable location gets more difficult, so much so that a
such a small change in area has a large impact on the search time.  Perhaps
this is why Warp chose these parameters to test in the first place (or
perhaps it's just a coincidence)
-tgq
Date: 22 May 2006 07:29:32
Message: <4471a09c$1@news.povray.org>
I did a macro package some time ago that does that in various
configurations:
http://sibylone.free.fr/index.php?sub=repartition&lang=en
Enjoy ! :-)
> with that line.
Date: 22 May 2006 21:50:04
Message: <44726a4c$1@news.povray.org>
> configurations:
   Does what?
   My point was not how to do it, but how to do it *fast*.
Date: 25 May 2006 07:45:57
Message: <447598f5$1@news.povray.org>
Ah, OK, mine just does it. :-)
When talking about efficiency, I think that external programming (C++,
Java ...) will be much faster.
Warp wrote:
>> configurations:
>   Does what?
Date: 26 May 2006 09:03:51
Message: <4476fcb7@news.povray.org>
   With less than 70 lines of code? I don't think so.
