POV-Ray : Newsgroups : povray.binaries.images : A little visit to Escher space Server Time
18 Oct 2026 23:09:00 EDT (-0400)
  A little visit to Escher space (Message 1 to 19 of 19)
Subject: A little visit to Escher space
Date: 25 Feb 2006 05:05:07
Message: <44002bd3@news.povray.org>
Indeed, this has been done before, but for a little story I have in my mind,
I wanted to test a couple of tricks in Moray. The result is rather nice I
believe, so I thought I would share.
Download 'eschertriangle.jpg' (54 KB)
Preview of image 'eschertriangle.jpg'
Subject: Re: A little visit to Escher space
Date: 25 Feb 2006 05:14:58
Message: <44002e22$1@news.povray.org>
Ah yes, the power to bend the mind...
Not the colours I would have chosen, but still. ;-)
I wonder how long it will be before somebody animates this stuff? :-P
Date: 25 Feb 2006 05:52:08
Message: <440036d8@news.povray.org>
   The shadow does not match the figure too well.
   Perhaps you should create a fake shadow which at least seems to
match the figure?
Date: 25 Feb 2006 08:41:23
Message: <44005e83@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:440036d8@news.povray.org...
> match the figure?
True for the third branch of the triangle... There is already one fake
shadow present here. The third one is not easy, but feasible, yes.
Date: 25 Feb 2006 08:46:09
Message: <44005fa1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> schreef in bericht
news:44002e22$1@news.povray.org...
Ah, colours! Well, I want the triangle to be wood anyway. The tiles can be
anything.
Hmm... not easy because you have to align correctly two aspects of the
triangle at the same time in reference to the camera: The alignment of the
branches, and the cutting plane that creates the illusion. I won't try that!
To complicated for my shaky capabilities :-)
Date: 25 Feb 2006 08:59:19
Message: <440062b7$1@news.povray.org>
If you animate it, the parallex will show how far each point *really* is
from the camera. I'd like to see somebody pull _that_ off without
breaking the illusion. ;-)
Date: 25 Feb 2006 09:21:02
Message: <440067ce@news.povray.org>
I had been following another stream of thoughts, but this fools the eyes
much better!!!
Download 'eschertriangle.jpg' (47 KB)
Date: 25 Feb 2006 09:23:07
Message: <4400684b@news.povray.org>
news:440062b7$1@news.povray.org...
Yes indeed, and I think you will have to adapt the "thickness" of the limbs
continuously too...
Date: 25 Feb 2006 12:28:23
Message: <qm26d3-na7.ln1@badulaque.unex.es>
Among other things, Thomas de Groot saw fit to write:
> mind, I wanted to test a couple of tricks in Moray. The result is rather
> nice I believe, so I thought I would share.
Hmm... looks familiar[*]
As Warp mentioned, the shadows are a bit strange, but I don't know if you
can have realistic shadows for an impossible object. Anyway it seems you're
using a perspective camera, and that's a good thing.
[*] See signature ;-)
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 25 Feb 2006 12:46:17
Message: <440097e9$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:440067ce@news.povray.org...
> much better!!!
Does indeed. A well done illusion. I wonder of the shadow of the short
horizontal piece could actually be moved away at the right side? The other
half of its illusion would put it into the air instead of being flat against
the tabletop. I'm probably not thinking of a good alternate placement for
that shadow though. It looks fine to me now.
Bob H
Date: 25 Feb 2006 14:01:32
Message: <4400a98c$1@news.povray.org>
That's one of my favorite Linux screen savers.
     "I think these anchovies are spoiled.
      They're not flat."
Date: 26 Feb 2006 03:05:19
Message: <4401613f$1@news.povray.org>
"Jellby" <me### [at] privacynet> schreef in bericht
news:qm2### [at] badulaqueunexes...
Nice!
Date: 26 Feb 2006 03:18:58
Message: <44016472@news.povray.org>
Thomas de Groot spake:
> Thomas
Yikes - that really strains the eye...
Stefan Viljoen
Polar Design Solutions
Date: 26 Feb 2006 03:37:14
Message: <440168ba@news.povray.org>
"Bob Hughes" <omniverse@charter%net> schreef in bericht
news:440097e9$1@news.povray.org...
against
What about this, Bob? I moved the light, and hence the shadows.
Date: 26 Feb 2006 03:44:47
Message: <44016a7f@news.povray.org>
"Stefan Viljoen polard.com>" <spamnot@<removethis> schreef in bericht
news:44016472@news.povray.org...
<grin>
It does! See the other versions above. More strain!
Date: 26 Feb 2006 04:46:01
Message: <440178d9@news.povray.org>
news:440168ba@news.povray.org...
That seems the best way to do the shadow, with the horizontal tabletop
piece's shadow being almost non-existant it helps to keep the illusion.
Although, I wasn't talking about moving it that way. Now that I've taken
your image into a drawing program and moved the shadow lines around I can
see that my idea was wrong. It would have made the illusion worse.
The problem with having a shadow in there at all seems to be that it
requires two different ones, since the object itself is actually supposed to
be seen two different ways anyhow. So a single shadow only messes with the
illusion unless you hide part of it, like you've now done. And looking back
at your first posted image, it obviously would have been okay, except that
it seemed the wood pieces mostly laid down across the table instead of being
mostly in the air. That shadow really makes the mind think of a predominate
way it's oriented all depending on how the shadow is used. Ultimately it
introduces another dimension into the whole thing so you've got to be clever
to add that in as right as possible.
At least, I sure couldn't decide on any better way of going about it after a
little puzzling over the picture a while.
Bob H.
Date: 26 Feb 2006 09:31:52
Message: <4401bbd8@news.povray.org>
news:440178d9@news.povray.org...
to
back
being
predominate
clever
a
It is a subtle process. There are different ways in which you can decide to
show the object: As an "impossible" one, with "wrong" shadows (in fact, with
the real shadows); as an "impossible" one, with "right" shadows; or as
something in between. In my first image, I followed a combination of 1 and
3, adding a fake ground shadow to the upper horizontal bar. In all images,
the lower horizontal bar shadow is real, but hiding it makes the object
stand out better.
Date: 1 Mar 2006 12:20:00
Message: <web.4405d75c2118025b47d3ae5e0@news.povray.org>
Very cool image indeed!
I have been thinking about doing this type of image myself,
but it never has been more than a thought. Now I know it can be done!
Again, kewl!
Date: 3 Mar 2006 08:01:02
Message: <44083e0e@news.povray.org>
"RusHHouR" <gee### [at] mailnu> schreef in bericht
news:web.4405d75c2118025b47d3ae5e0@news.povray.org...
> Again, kewl!
Thank you!
Yes, it can be done. However, it is easiest in a modeller program (like
Moray) because you see what you are doing, and positioning has to be done
very carefully.
