I just did a quick google through the newsgroups but couldn't find an answer
to this. Here's a really simple scene, with fog turned off the cylinder
appears solid black, because it's a black & transparent checker containing a
dense black media. But with fog turned on the media parts become lighter
*regardless of how dense the media is*.
fog {
fog_type 1
rgb x
distance 3
background { rgb z }
cylinder {
-y, y, .3
translate z*2
hollow on
checker
rgb 0,
rgbt 1
scale <.3,.3,100>
interior {
media { //media so dense that without fog it looks identical to the opaque
bits.
absorption 1
density { rgb 100 }
Try increasing the media density, you'll see it doesn't get any darker.
Is this a known bug with media & fog? Is there any solution? It's screwing
up the smoke in my volcano image :(
Tek
http://evilsuperbrain.com
And this time, with a picture (doh!)
You shouldn't be able to see those checks, and increasing the media density
doesn't make them darker.
Tek
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:43f78692@news.povray.org...
>answer
> a
> fog {
> fog_type 1
> rgb x
> distance 3
> cylinder {
> -y, y, .3
> translate z*2
> hollow on
> pigment {
> checker
> rgb 0,
> rgbt 1
> scale <.3,.3,100>
> interior {
> opaque
> bits.
> absorption 1
> density { rgb 100 }
> Tek
Download 'fog-media-bug-test.jpg' (11 KB)
Preview of image 'fog-media-bug-test.jpg'
No solution, but you have made me aware of a (possible) problem.
In my Alien Cliff scene, I have added a media for simulating the spray at
the base of the waterfall. The image is (still) rendering (off and on), but
I have the feeling that something similar to you is happening... Maybe there
is an incompatibility, indeed?
This is an image (like Tek's) showing what is happening when media and fog
interact.
The container is, however, hardly or not visible when in front or
intersecting a textured surface/object. In my Alien Cliff image, I cannot
see it against the cliff.
Download 'Media_mist_test.jpg' (20 KB)
Preview of image 'Media_mist_test.jpg'
"Thomas de Groot" <t.d### [at] inter nl net> wrote in message
news:43f970b9@news.povray.org...
> interact.
Transparent objects mixing with fog is an old issue. It could be remedied,
somewhat, by increasing the transmit or filter value a little beyond 1.0.
Unfortunately, now I can't remember if that is really a solution at all. If
anything, an imperfect one probably. Wish I could say more about it with
more assurance as to what or how it was dealt with in the past or in the
current version(s).
The original question here is apparently more an issue of the fog being in
front of the media container object. That 'distance 3' causes the camera to
see that fog color between it and the cylinder, which is at <0,0,0> and
<0,0,2> (less 0.3 radius) respectively.
Hope that is of some help.
Bob H
"Bob Hughes" <omniverse@charter%net> wrote in message
news:43f9a13a$1@news.povray.org...
>> fog
>> interact.
Hey Thomas, I tried a test render in both 3.6 and the latest beta of 3.7
just to make sure I was on the right track about my reply to you. The media
container is invisible amid fog, also not seen in ground type, so I'm
wondering if you could have rendered that from version 3.5 or something
other than POV for Windows which I am using here. Just wasn't sure with
absolute certainty if that had changed in the later versions.
Anyway... I still think I was right about Tek's (AKA evil super brain) media
container being obscured by the fog between the camera and cylinder. It
could never be completely black with a red fog color there, right? Not
unless the container object surface is next to the camera, or the camera
within it. ;)
Bob H
"Bob Hughes" <omniverse@charter%net> schreef in bericht
news:43f9c077$1@news.povray.org...
media
I used MegaPOV 1.21 (which uses 3.6.1) for Windows.
Perhaps I should include the used code:
The fogs:
fog {
fog_type 2
distance 15
color rgb 0.6 // gray
fog_offset 0.05 // below this level the fog is constant
fog_alt 0.29 // halving distance
turbulence 1
fog {
fog_type 2
distance 800
color rgb <0.8, 0.8, 0.8>
fog_offset 0.1 // below this level the fog is constant
fog_alt 15.00 // halving distance
turbulence 0.1
And the media:
#declare Scattering =
sphere {
0, 10
pigment { rgbt 1 }
interior {
media {
samples 10, 100
scattering {1, <0.9, 0.9, 0.9, 0.0, 0.9> extinction 3} // higher
extinction = more transparant media
intervals 1
density {
spherical
poly_wave 5
scale 2
warp { turbulence <T,T/2,T/1> }
scale 2
warp { turbulence <T,T/2,T/2> }
scale 2
warp { turbulence <T,T/2,T/3> }
scale 2
warp { turbulence <T,T/2,T/4> }
scale 0.3*exp(pow(T,0.5))/(1+T)
hollow
scale <1,1,1>
object {Scattering
scale <0.3, 0.6, 0.3>
translate <1.75, 0, 2.0>
Maybe an important issue:
I have used tone_mapping.inc, and then: Clip_Colors() in the
global_sttings, for tone mapping for antialiasing like in version 3.5
(smoother transitions)
I shall test without this to see if there is a difference
Actually that's different to my problem, my media container is invisible but
the smoke media from my volcano gets more fogged than the top of the volcano
does at the same distance.
I've managed to work round the problem by an extremely elaborate means:
First, I tried using a global media instead of the fog, but that did exactly
the same thing. So then I replaced it with a huge box of media in front of
the camera, differenced with the smoke-media's container. And I added a copy
of the air-media to the inside of the smoke media's container. All of this
meant that pov finally got the message and gave me the result I was after,
though it's a ludicrously elaborate work-round.
Tek
> interact.
> Thomas
"Thomas de Groot" <t.d### [at] inter nl net> schreef in bericht
news:43f9e7f5$1@news.povray.org...
....No. No difference :-(
"Tek" <tek### [at] evilsuperbrain com> schreef in bericht
news:43fa041a$1@news.povray.org...
but
volcano
exactly
copy
Yes it's different, but somehow I cannot convince myself that there is not a
common problem here which concerns media and fog...
Subject: Re: media-fog bug? intersecting with isosurface
Date: 21 Feb 2006 04:40:11
Message: <43fadffb@news.povray.org>
This is not true unfortunately :-(
I looked acrefully at my image and saw strange patches that shouldn't be
there. So I made a new test with the fog, the media, and an isosurface
representing the cliff. This is the result. Note that the horizontal plane
does not show any artifact!!
Download 'Media_mist_test2.jpg' (17 KB)
Preview of image 'Media_mist_test2.jpg'
Thanks for giving the partial script earlier, Thomas. I just now got a look
at a rendering of that here and saw the container bubble this time. I was
going to ask if you had POV 3.6.1a or the 3.6.1b but I guess that's not the
reason anyhow.
I didn't know you were using two fogs together before this point in time,
thinking it was only media and one fog. I have no idea why the two fogs
cause the media container to appear.
Bob H
Date: 21 Feb 2006 08:52:28
Message: <43fb1b1c@news.povray.org>
news:43fae38b$1@news.povray.org...
look
the
> reason anyhow.
Thank you Bob, for taking time to look into this. Which shows again, by the
way, that it is always important to give complete information. Small details
(like one or two fogs) can easily be overlooked when just asking questions.
In fact, in the latter case, it is not the fog which causes the container to
appear! The container is carved out of the isosurface whether there is a fog
or not! I am puzzled because I cannot find any document treating this
matter. But I may be overlooking the obvious (I wouldn't be surprised).
So I end up with two problems.
1. interaction media and 2 fogs
2. interaction media and isosurface
I've been having a play with this, and I have a couple of conclusions.
It's not the media. It appears to be a fog problem - if you take out the
interior block, the (now totally invisible) container object still shows up
if you use more than one fog. Unless someone knows a way around this, I
guess you'll have to fake one of the fogs with media (!).
Again, it's the container object intersecting the isosurface that seems to
cause the problem. Try raising the accuracy of the isosurface (i.e., use a
lower accuracy value). That worked with my tests.
Hope that's of some use
Bill
Oh, isosurface has a keyword for that, it's all_intersections. Won't help
the fog bubble any but should eliminate those empty places where another
object is in contact with a isosurface. There's also a way to give it a
certain number of possible "intersections", the Help tells something about
it. I wasn't paying any attention to those arches in that last image and
only looked for the media container bubble. ;)
Bob H
Date: 22 Feb 2006 02:46:53
Message: <43fc16ed@news.povray.org>
news:43fb7e31$1@news.povray.org...
to
a
Thanks a lot, Bill and Bob, for these thought.
Accuracy it is! I had forgotten that I had changed the default value for
faster render. Did not realise that it would also influence other things.
Very stupid... I had tried already increasing max_trace (or
all_intersection) but to no avail, so I was on the wrong track.
Remains the transparant object/fogs problem. Replacing one of the fogs by a
media is tricky to say the least, and will bring down my already very slow
render speed even more. I shall first try to leave it out altogether and see
what the image is like.
Again, thanks both of you for your help!
Date: 22 Feb 2006 03:09:14
Message: <43fc1c2a@news.povray.org>
news:43fc16ed@news.povray.org...
Good to know there was an explanation. :) Wish you much luck getting that
cliff scene done.
I tend to change accuracy only for changing effect of how textures appear,
something I noticed early on when isosurfaces were first being implemented
in POV or to see how the it's surface differs at varying values of accuracy.
I leave it alone most of the time now.
Bob H
Date: 23 Feb 2006 03:59:13
Message: <43fd7961@news.povray.org>
news:43fc1c2a@news.povray.org...
things.
> cliff scene done.
accuracy.
Thanks Bob. The scene will be finished eventually. :-) I have noted that,
against the cliff, the media container is invisible (the fog is probably too
thin thin) so I left my two fogs in place. Started rendering again....
I mainly change accuracy for render speed or to test how different
isosurface settings looks, although I admit it doesn't change speed that
much in general. To avoid forgetting to set things back to normal, I should
leave it alone...
