POV-Ray : Newsgroups : povray.binaries.images : Snow candle #3 (~125KB) Server Time
14 Oct 2026 02:17:32 EDT (-0400)
  Snow candle #3 (~125KB) (Message 1 to 13 of 13)
Subject: Snow candle #3 (~125KB)
Date: 18 Feb 2006 12:12:41
Message: <43f75589@news.povray.org>
The latest version of my snow candle.
Texture of the candle itself is Gail Shaw's suggestion, with a few
modifications. (I scaled it to match the scene. Also turned off the
ambient term. Looks more like snow with it on - but then the lighting
looks *very* odd!)
Wood and stone textures are from the standard includes. In fact, there
is now virtually nothing original about the whole composition now. (3
points to the first person who can figure out which textures I used...)
I tried a large number of different wood and stone textures. I'm pretty
happy with the wood, but I'm still not convinced that's the right stone
texture... (I rendered the entire scene with several different ones...
none of them looks quite right.)
I am still unhappy with the lighting. The walls seem far too bright, yet
the floor is too dark.
The ice crystals are also wrong; they don't look like ice. They manage
to be simultaneously not transparent enough to show any refraction, yet
too transparent to show up much. (The ones in the middle are almost
totally lost.) The ones on the floor look more like metal than ice.
Don't know whether to make them more shiny (to look like smooth ice) or
less shiny (to look snow-like).
Apart from that... it's just perfect. :-/
Now I remember why I never entered the IRTC before...
Download 'candle-ip-03+stone13.jpg' (122 KB)
Preview of image 'candle-ip-03+stone13.jpg'
Subject: Re: Snow candle #3 (~125KB)
Date: 18 Feb 2006 14:37:27
Message: <43f77777@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:43f75589@news.povray.org...
   Andrew, try this code below. It's a fantastic flame, and a flame that I
might even try [again] even though it's getting late now for the IRTC...
   This flame gives off its own light, and you might be pleasantly surprised
with it.
   #version 3.5;
camera{location <0,1,-8>
look_at <0,1.5,0>
angle 20
// flame (MegaPov needed, as is)
#declare FlameMedia=
 sphere {0,1.1
   pigment {rgbf 1}
        interior {
                media {
                method 2 intervals 2 samples 3,3  // megapov, or increase
intervals and samples
                absorption <.33,.5,.67>*2 emission <.33,.5,.67>*1.67
                scattering {2,<.75,.67,.5>*2 extinction .133}
                density {spherical turbulence <.1,.2,.15>*1.5
                        density_map {
                        [0 rgb 0]
            [.15 rgb <1.5,1,.5>*3]
            [.5 rgb <1.25,.5,.75>*2]
            [.7 rgb<0,.05,.5>*6]
                        } scale <.85,.9,.85> translate -.25*y}
                media {
                absorption <.36,.33,.167>*3 emission <.25,.5,.75>*1.133
                scattering {1,<.25,.33,.75>*3 extinction .67}
                density {spherical turbulence <.1,.2,.15>*.5
                        density_map {
                        [0 rgb 0][.3 rgb <0,.05,1.15>*6]
                        } scale <.7,.3,.7> translate -.9*y}
  scale <.9,3,.9>*.25 rotate 45*y translate .225*y
 hollow
#declare SmallFlame=
 light_source { .5*y, <.75,.5,.25>
       area_light <.5,0,0>,<0,1,0>,3,3 jitter adaptive 1
    orient circular  // megapov only
  looks_like {FlameMedia}
   media_interaction on media_attenuation on
   fade_distance 6 fade_power 2
  translate 1.075*y
SmallFlame // you have to include this line in pov sdl for it to work
  Give it a try.
  ~Steve~
Date: 18 Feb 2006 17:22:29
Message: <43f79e25@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> a écrit dans le message de
> looks *very* odd!)
Did you give some transmit to the candle pigment?
It still looks very opaque
Marc
Date: 19 Feb 2006 00:05:01
Message: <web.43f7fc06e974b8fbc8947640@news.povray.org>
> looks *very* odd!)
Actually, I like the lighting the way it is.  The floor in the shadow of the
large candle edges.  The colour of the candle light still needs some yellow
or orange tingin to it though.  And to make your candle more convincing (I
don't mind the shape or texture of the candle itself) you need a slight
waxy hollow in the top where the flame has started to melt the wax.  (and a
better flame).   Overall, you have a good scene composition, all you need is
a little tweaking on the lighting, and  little  more on some of the
texturing.  For the background texturing of the box itself, the textures
you have been using may be fine, but you need to scale them down in size to
give the scene better overall scale perspective.
-tgq
Date: 19 Feb 2006 06:07:33
Message: <43f85175$1@news.povray.org>
I haven't tried that yet...
Date: 19 Feb 2006 06:10:46
Message: <43f85236@news.povray.org>
You're probably right. Adding the extra blue light makes the floor less
dark and the candle less brown, but also makes the light it casts look
less yellowish. (And the dark brown wood probably doesn't help.)
Getting the balance of warm to cold colours is proving to be a challenge...
> better flame).
The flame is probably the easiest part to fix. (Which is why I haven't
bothered with it yet.)
A pool of molten wax would be good, but I'm really not sure how to
achieve it. (It took me hours to figure out the equation to make a
round-topped cylinder!)
The candle and box are supposed to be quite small...
Date: 19 Feb 2006 06:42:20
Message: <43f8599c@news.povray.org>
news:43f85175$1@news.povray.org...
Gail's material implies pigment is somewhat transparent to show the interior
Marc
Subject: Snow candle - Alternate version (~115KB)
Date: 19 Feb 2006 16:55:44
Message: <43f8e960@news.povray.org>
I can't decide which marble fits the scene best...
Download 'candle-ip-03+pinkalabaster.jpg' (115 KB)
Preview of image 'candle-ip-03+pinkalabaster.jpg'
Subject: Snow candle - Alt. ver. #2 (~125 KB)
Date: 19 Feb 2006 16:57:06
Message: <43f8e9b2@news.povray.org>
Maybe this one? (Bit dark perhaps...)
Download 'candle-ip-03+stone10.jpg' (123 KB)
Preview of image 'candle-ip-03+stone10.jpg'
Subject: Snow candle - alt. ver. #3 (~140KB)
Date: 19 Feb 2006 16:58:36
Message: <43f8ea0c@news.povray.org>
Maybe this marble? (Now this is perhaps too bright... not much of a
pattern either.)
Download 'candle-ip-03+stone15.jpg' (138 KB)
Preview of image 'candle-ip-03+stone15.jpg'
Subject: Snow candle - Alt. ver. #4 (~125KB)
Date: 19 Feb 2006 17:00:04
Message: <43f8ea64@news.povray.org>
Last one!
Well, this certainly has a pattern to it... Looks a bit rubbish though.
Download 'candle-ip-03+whitemarble.jpg' (121 KB)
Preview of image 'candle-ip-03+whitemarble.jpg'
Date: 22 Feb 2006 11:54:55
Message: <43fc975f$1@news.povray.org>
You used an isosurface for it?  That is something that would probably be
OK with a little CSG.
As for the pool, maybe a blob shape with a small scale value along the Y
axis?
...Chambers
Date: 22 Feb 2006 11:57:19
Message: <43fc97ef$1@news.povray.org>
After seeing your alternate marbles, I think I like this one the best :)
One quick note, it seems to me that the shadows on the ice below the
candle are too harsh - it looks completely solid (that *is* supposed to
be ice that it's on, and not stone, right?).  I would make it completely
transparent, and fill it with a dense media instead (in fact, that's how
I would do the candle as well).
...Chambers
