Well I've been putting a lot of work into the volcano, though I've hardly
touched anything else in the scene. As you can see I've incorporated a lot
of the great suggestions from folks round here, thanks everyone! The only
problems I have with the volcano now are: it's still too dark - I didn't
realise until after this lengthy render, and there's lava touching snow in
the foreground which is obviously complete nonsense! Next I'm going to work
on the smoke and under-sea area.
My favourite bit in this is the lava rivers, which work using a really
simplistic particle system that basically rolls a particle down the volcano
leaving a trail of blobs behind it. Slight adjustments to the start position
and random seed make it take radically different paths, which actually looks
pretty realistic.
Anyway I thought I'd post this for further comments, and so you can see how
much better it's got!
Tek
http://evilsuperbrain.com
Download 'volcano.jpg' (313 KB)
Preview of image 'volcano.jpg'
This just keeps getting better and better. My suggestion (worth every
penny) would be to scrap the undersea section, extend the water to the
bottom of the picture, and add some icebergs or a frozen shoreline.
You've just about got the "fire" part working but I think the "ice" part
needs work.
Awesome picture!
> pretty realistic.
The top part is starting to look half way decent now. The mountain looks
good, the clouds are good, the lava isn't quite right yet. (Good shape,
lighting looks wrong.)
The underwater part still needs work.
> volcano leaving a trail of blobs behind it. Slight adjustments to the
> start position and random seed make it take radically different
> paths, which actually looks pretty realistic.
That's a neat trick. It might look more realistic if the lava streams were
brighter maybe?
> work on the smoke and under-sea area.
> start position and random seed make it take radically different paths,
> how much better it's got!
Coming along neatly, but ( sorry, there's always one of those ) :)
4 things above the water that caught my eye
No distinct column of smoke/dust/ash over the vent
The boulders/rocks that come flying out of the volcano all are(look like)
the same size.
No smoke/dust plumes where they hit the ground
No steam where the lava touches the water
under water
The bulging lava doesn't seem connected to the volcano
Ger
It's great to see this progressing so nicely. Really dig those clouds.
How about an "air glow" above the volcano's spout? And perhaps some more
yellow (and/or "crustiness") in the lave streams? As lava cools, it shows
dark crusty spots on top.
Thanks for keeping us updated!
Ken
I'd expect the lava streams to be broader at the bottom of the mountain.
And I love Spock's idea with the ice on the water instead of the cooling
lava.
Aside from that - Great progress!
Florian
Ok, forget my earlier comments partly. I'm still disturbed about that
there's _one_ glowing lava drop underwater, but not another even near.
And the mountains at background are still exported from Egypt :). All
other things I mentioned you seem to have maintained with honour.
But maybe there should be steam (and boiling?), where the lava river
gets into the water?
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
Weirdly, when lava hits water, it doesn't seem to boil much. Just tones
of steam. (Which is maybe why you can't see any bubbling?) Strange but
true...
I rephrase: in the videos I've seen, that's how it looks.
PS. Every time I see "lava" I keep thinking "Java"... I need help!!
"Orchid XP v2" <voi### [at] dev null> wrote in message
news:43dcc0de@news.povray.org...
> true...
Probably because boiling involves small abouts of water changing to steam
beneath the surface and bubbling to the surface. When lava (few hundred
degrees C) hits water the water turns en-mass to steam instantly. There
isn't time to boil.
My guess, not scientific proof.
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:43dbaf21@news.povray.org...
Very nice.
I'll echo a couple of others. Scrap the underwater and just focus on above.
At the moment it's a split image with two disconnected points of focus.
Some ice on the water, steam where the lava hits the ocean, glow around the
top and it'll look very nice.
The bit underwater is just a placeholder! if you compare it to the first WIP
you'll see it hasn't changed, honestly it's just a bunch of spheres I threw
down there to remind me to come back later and put something in. I should
probably have mentioned that!
The other suggestions are good though, I'm going to try to do all of them.
Tek
"Ger" <No.### [at] Thank You> wrote in message news:43dbfbb9@news.povray.org...
>> lot
>> in
> the same size.
> under water
> Ger
I think I explained all this in an earlier post, though I should have said
when I posted this picture, allow me to reiterate:
1/ The mountains and undersea areas are just placeholders (cones and
spheres) until I get round to working on them, frankly I'm amazed people
keep commenting on them! To me they look so obviously unfinished.
2/ That isn't a drop of lava underwater, it's one of those underwater lava
vents where lava's escaping through a small crack underwater and solidifying
on the outside almost immediately, but the pressure of the lava keeps
cracking the solid surface so more of it can break through. This is why it's
so far from the volcano, it hasn't fallen there it's come up from
underground.
Tek
"Eero Ahonen" <aer### [at] removethis zbxt net invalid> wrote in message
news:43dcaf24$1@news.povray.org...
>> how
> Eero "Aero" Ahonen
> http://www.zbxt.net
I'm going to keep disagreeing with people about the underwater area until I
get round to working on it. Personally I think it's the most important part
of the whole image because it shows the cold beating the lava, which
balances out what's happening above.
I guess I should work on that next so people can see what it's supposed to
look like and see if they still disagree with me :)
Tek
"Gail Shaw" <gshaw AT sentechsa com> wrote in message
news:43dccf35@news.povray.org...
> Very nice.
> above.
> the
news:43dd383a@news.povray.org...
> I get round to working on it. Personally I think it's the most important
> part of the whole image because it shows the cold beating the lava, which
Tek,
Expect to see a lot of boiling at the undersea vent.
For form google 'black smoker' - those chimneys are heaps of fun... and a
modelling challenge.
http://images.google.com/images?q=black+smoker&hl=en&btnG=Search+Images
D
"dlm" <me### [at] address invalid> a écrit dans le message de
news:43dd5795$1@news.povray.org...
> Tek,
> D
I think Tek intents that kind of cushion lava
http://satftp.soest.hawaii.edu/space/hawaii/vfts/pele/page.s2.html
As you can see water pressure and temperature conditions prevents water to
boil further than 1 inch away the forming crust.
Steam condensates and bubbles shrink as soon as formed.
Marc
It's looking real good...
Quick thought: The lava will cool as goes downhill. That should make it
change from yellow to red and from bright to dim as it gets farther away
from the heat source.
Jon
I thought it's not even near of finishing, but I guessed that you'd want
visions of the image (I would've). My apologies, if I was so wrong.
> underground.
Ah. For my eye, it looked like a stone for my eye. But after all, I
didn't even realize that those cracks exist (thou it's logical, while
thinking it now).
Eero "Aero" Ahonen
http://www.zbxt.net
Nice! Now, even I can see (and understand) what's the underwater part
about :).
Eero "Aero" Ahonen
http://www.zbxt.net
"Marc Jacquier" <jac### [at] wanadoo fr> a écrit dans le message de
news:43ddf200@news.povray.org...
Pillow should be better than cushion.
Marc
Yup that's exactly what I mean! I found a good reference site:
http://www.pmel.noaa.gov/vents/nemo/explorer/concepts/pillows.html
There's an awesome video at the bottom of that page, makes me wish I was
doing an animation!
Tek
"Marc Jacquier" <jac### [at] wanadoo fr> wrote in message
news:43de87b7@news.povray.org...
> Marc
It is doing that already but the effect's too subtle so it just looks like
lighting, I'll crank it up a bit :)
Tek
"Jon Buller" <jon### [at] bullers net> wrote in message
news:web.43de751c9c2a5cdebe920ef30@news.povray.org...
> Jon
> true...
That's the case for ones I've seen.
A few pictures I took in Hawaii
http://www.geocities.com/ramayer/pics/smoke0.jpg
http://www.geocities.com/ramayer/pics/smoke2.jpg
And the steam glows really cool at night:
http://www.geocities.com/ramayer/pics/fire.jpg
You also get really cool cracks in the ground where the Lava shows
through the rocks.
http://www.geocities.com/ramayer/pics/lavaeyes.jpg
Such cracks might look cool in the foreground.
(sorry for the links to pics; but I can't render anything that cool)
Yeah, that's what it looks like in real life.
"Orchid XP v2" <voi### [at] dev null> schreef in bericht
There are lots of mighty volcanoes on Java :-)
Wait... I thought Java *is* a volcano?!
and here I was only thinking it was a class-based programming language.
~Mike
Things! Billions of them!
...or a full-flavoured coffee. :-P
