POV-Ray : Newsgroups : povray.binaries.images : sunrise atmospheric effects Server Time
29 Nov 2026 17:31:04 EST (-0500)
  sunrise atmospheric effects (Message 1 to 9 of 9)
Subject: sunrise atmospheric effects
Date: 14 Jan 2006 06:22:07
Message: <43c8dedf@news.povray.org>
I'm just working on a nice earth-like atmosphere for a possible IRTC entry
and I rendered this test image to see how it looked at sunset. I thought I'd
share it because it's a nice wallpaper image :)
The atmosphere is a blue colour, but extinction makes it turn orange & red
at shallow angles to the sun.
Tek
http://evilsuperbrain.com
Download 'sunrise.jpg' (70 KB)
Preview of image 'sunrise.jpg'
Subject: Re: sunrise atmospheric effects
Date: 14 Jan 2006 06:33:41
Message: <43c8e195@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> a écrit dans le message de
news:43c8dedf@news.povray.org...
I'd
> Tek
It way better than all my lame attempts, I hope you'll share your parameters
(after IRTC of course)
method 1?
Marc
Date: 14 Jan 2006 06:49:21
Message: <43c8e541@news.povray.org>
It's really pretty simple, I don't mind sharing the code now because this is
very early WIP stuff. Here's the bit that does the atmosphere, I've
simplified it a little but it should look about the same:
//planet
sphere { 0, 6000 }
  //atmos
  difference {
   sphere { 0, 6050 }
   sphere { 0, 6000 }
   hollow on
   pigment { rgbt 1 }
   interior {
    media {
     scattering {
      1, rgb <.05,.17,1>
      extinction 1
     density {
      function { exp( -(sqrt(x*x+y*y+z*z)-6000)/4 ) }
     density_map {
       [0 rgb 0]
       [1 rgb .1]
Tek
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:43c8e195@news.povray.org...
>> entry
> I'd
>> red
>> Tek
> parameters
> method 1?
> Marc
Date: 14 Jan 2006 07:15:07
Message: <dqaps7$cq0$1@chho.imagico.de>
Nice but it somehow does not really look like an earth-like planet.
Maybe it would help to make the view less directly against the light so
you could actually see something of the planet surface (this would also
be more realistic since with the sun in the field of view you would
probably hardly see the relatively dark planet in reality).
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 14 Jan 2006 09:52:32
Message: <43c91030$1@news.povray.org>
news:43c8e541@news.povray.org...
That's the function I couldn't work out!
Thank you
Date: 14 Jan 2006 10:46:38
Message: <43c91cde$1@news.povray.org>
Tek nous apporta ses lumieres en ce 14/01/2006 06:22:
Very nice and realistic. I've seen the same effect, maybe less obvious, in actual
photos taken from
space.
Stoicism: This shit is good for me.
Date: 14 Jan 2006 15:28:59
Message: <43c95f0b$1@news.povray.org>
news:43c91030$1@news.povray.org...
Well I have a friend with a PhD in astrophysics, which means whenever I have
astronomical/planetary questions I usually ask him, then he tells me he
doesn't have a clue and goes off and looks it up for me :)
The formula is just an exponential decrease in density away from the earth's
surface, which is close enough to accurate to look pretty nice.
Tek
Date: 14 Jan 2006 15:34:13
Message: <43c96045@news.povray.org>
I totally agree, the light position here was just a technical test to see
how my sunset colours looked, I was just surprised to get a pretty image out
of it. My final image will probably feature much more conventional lighting
of the planet.
However, that sun position corresponds to the light position (well except
the light is directional and the object isn't infinitely far away, but the
direction is the same relative to the camera). The amount of darkness we see
is mostly just due to perspective, it's quite a wide angle shot so the lit
part of the surface becomes very small compared to the dark side. Do not
underestimate the power of the dark side, etc.
Tek
news:dqaps7$cq0$1@chho.imagico.de...
>> entry and I rendered this test image to see how it looked at sunset. I
>> thought I'd share it because it's a nice wallpaper image :)
>> red at shallow angles to the sun.
> Nice but it somehow does not really look like an earth-like planet. Maybe
> it would help to make the view less directly against the light so you
> could actually see something of the planet surface (this would also be
> more realistic since with the sun in the field of view you would probably
> Christoph
Date: 14 Jan 2006 15:35:21
Message: <43c96089@news.povray.org>
Yeah I like to exagerate the effect because it looks cool :)
Tek
"Alain" <ele### [at] netscapenet> wrote in message
news:43c91cde$1@news.povray.org...
> actual photos taken from space.
> Alain
