POV-Ray : Newsgroups : povray.binaries.images : Australia. Server Time
29 Nov 2026 18:19:08 EST (-0500)
  Australia. (Message 1 to 27 of 27)
Subject: Australia.
Date: 13 Nov 2005 21:25:50
Message: <4377f5ae@news.povray.org>
Her's the Earth, looking at Australia.
Tim Cook
Version: 3.12
Download 'earthlightingau.jpg' (134 KB)
Preview of image 'earthlightingau.jpg'
Subject: Re: Australia.
Date: 14 Nov 2005 00:57:51
Message: <4378275e@news.povray.org>
Tim Cook spake:
I'm impressed! NASA maps?
Stefan Viljoen
Polar Design Solutions
Date: 14 Nov 2005 03:09:57
Message: <43784655$1@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> a écrit dans le message de
news:4377f5ae@news.povray.org...
Oh yes  I remember, it was  such a sunny day  d;-)
Marc
Date: 14 Nov 2005 06:50:00
Message: <437879e8$1@news.povray.org>
Yup.  The new Blue Marble dataset...5400x2700 version, June.  I'd really
like to play with the 500m/pixel set, but don't have any way of doing
so.  Would be nice if POV 4 were able to use very large images without
loading the whole thing into memory...by that time there'll probably be
1m/pixel dataset available hehe.
Tim Cook
Version: 3.12
Date: 14 Nov 2005 07:34:48
Message: <43788468@news.povray.org>
Would it be possible to array multiple images? Have a whole pile of
sphere segments each with it's own sub image? Or will that have the same
problem? If so, what about just rendering the visible earth and not
loading anything more than one grid unit around the other side?
Cheers!
Rick Measham
Date: 14 Nov 2005 09:01:58
Message: <437898d6@news.povray.org>
No idea, I don't know how to make a sphere segment whose surface is an
entire image rather than the image being mapped to the entire sphere,
necessitating loading an image that covers the whole sphere.
Tim Cook
Version: 3.12
Date: 14 Nov 2005 09:29:19
Message: <dla6vk$olk$1@chho.imagico.de>
Well - lighting does not fit that time of the year... ;-)
> I'd really
Obviously you can't use image data without loading it, that's trivial.
Accessing parts of an image without reading it as a whole in advance
would be quite straight away (at least for uncompressed image formats)
but only of very limited use:  If your render accesses only small parts
of the image you should only use a reduced size image in the first
place.  If your render really needs the full image that is larger than
your memory you will suffer significant performace penalties with this.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 14 Nov 2005 09:46:36
Message: <4378a34c$1@news.povray.org>
Better than the ultimate performance penalty of not being able to use an
image larger than your memory at all...;)
Tim Cook
Version: 3.12
Date: 14 Nov 2005 11:19:20
Message: <dladf9$qel$1@chho.imagico.de>
>> If your render really needs the full image that is larger than your
No.  you can already use that large images right now - your OS swapping
and address space permitting.  You don't do this though because the
performance loss makes it unfeasible. This isn't different with
'on-demand' reading of image data from disk (except parsing might be a
bit faster in the latter case).
Date: 14 Nov 2005 15:06:03
Message: <4378ee2b$1@news.povray.org>
No, I literally don't have any software that can read such a large
image.  ^^;  Paint Shop Pro, GIMP, Photoshop, and so forth, can't read
images larger than a certain size, I think around 32768 for either
dimension, which the 500 m/pixel set definitely exceeds, horizontally...
Tim Cook
Version: 3.12
Date: 14 Nov 2005 15:08:47
Message: <4378eecf$1@news.povray.org>
Also if you don't have enough memory to load the entire image, you can't
use it at all.
Tim Cook
Version: 3.12
Date: 14 Nov 2005 16:04:19
Message: <dlau41$ull$1@chho.imagico.de>
>> swapping and address space permitting.  You don't do this though
>> because the performance loss makes it unfeasible. This isn't different
>> with 'on-demand' reading of image data from disk (except parsing might
>> be a bit faster in the latter case).
Actually GIMP should be able to deal with large images without problems
with its tile cache:
http://www.gimp.org/unix/howtos/tile_cache.html
(at least if it is built with large file support which is default with
current versions i think).
And there are various other programs able to process large image files
- one was mentioned in p.g. in reply to you:
Subject: Re: Callling all Earth renderers - Blue Marble "next generation"
Date: Sat, 22 Oct 2005 04:41:30 EDT
Newsgroups: povray.general
And as noted in
http://www.imagico.de/pov/earth_bm.html
GDAL is also predestinated for this - after adding an appropriate ppm
header to the raw data:
P6
86400 43200
255
Finally the 500m images are also available in 21600x21600 tiles.
Date: 14 Nov 2005 16:20:00
Message: <web.4378ff6df94adb4da8399d8d0@news.povray.org>
Just tried to copy-paste a 3500 pixels wide image in MS-Paint (XP-prof)
today:
No warnings, just a nice crash :-) repeatable on other systems as well...
(that's with 1.5GB of memory) On the other hand, the new notpad in XP will
load files larger than 64kb (it will take an hour or so, and actually using
it after that is next to impossible.)
Date: 14 Nov 2005 21:52:57
Message: <43794d89$1@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:4378ee2b$1@news.povray.org...
The maximum image size supported by Photoshop is 300 000 x 300 000 pixels.  The
maximum file size is 4 GB for PSD and TIFF files, and 100 GB for PSB
(Photoshop's new "large document" format).  Obviously RAM will be a limiting
factor here, in terms practicality.  It's possible to get Photoshop to use
around 3 GB of RAM on 32-bit XP, and more on 64-bit XP (though Photoshop limits
the amount of RAM it uses to around 4 GB, and if you have a system with more RAM
than that then it will use it for cache data before writing to the Photoshop
scratch disk files).  If you don't have a lot of RAM, the HDD access is going to
slow things to a crawl.
There's some information about this here:
http://www.adobe.com/support/techdocs/320005.html
and here:
http://www.adobe.com/support/techdocs/331372.html
However, this is assuming you have Photoshop CS2.  And unless you're rendering
to very large output sizes, having the higher resolution maps may make no
noticeable difference to the result anyway.
By the way, nice image, I think I can see my house from here :)
Lance.
thezone - thezone.firewave.com.au
Date: 15 Nov 2005 00:52:02
Message: <43797781@news.povray.org>
Tim Cook spake:
Hmm - are you rendering in Windows?
IMHO if you try Linux Pov you might have better stability and performance
when memory gets tight - in my inexperienced opinion (Christoph should know
more about this) Linux is more reliable than Windows when you start to page
lots of RAM to disk (such as when working with something that takes up all
available RAM, and more).
I have once or twice managed on my older PC's to use about 1.5 times
physical RAM in Pov when rendering - no problems, while on XP it got
incredibly slow and crashed regularly for the same .POV file... but that
was long ago on older architecture (400 MHz machine with 128MB).
Anyway! If your Windows rendering experience gets crappy when using all RAM
or close to it, try Linux.
Stefan Viljoen
Date: 15 Nov 2005 01:51:51
Message: <43798587$1@news.povray.org>
Hmm...well I guess I might be able to do it after all, then...HOLY CRAP
the 500 m dataset is 65 GB?!  Barely have enough hard drive space for
that...*fear*
Anyhow my hope was to make an animation, from surface-to-space...or the
other way 'round...
Tim Cook
Version: 3.12
Date: 15 Nov 2005 01:53:55
Message: <43798603@news.povray.org>
Er...must be a new ability, I have an older version of PS and it wasn't
able to make the 21600x21600 hemisphere image of the first BM version
43200 wide so I could add the other hemisphere to it...
Tim Cook
Version: 3.12
Date: 15 Nov 2005 02:11:40
Message: <43798a2c$1@news.povray.org>
Hmm, and it's 21600x21600 chunks, too...how do I make an isosurface that
applies an image as a radius modifier to a section of a sphere so that
the entire image maps to a 45x45-degree segment?
The code I have for the entire image to the whole sphere is
#include "functions.inc"
#declare fn_EarthPigm1=function{
   pigment{
     image_map{
       jpeg "srtm_ramp2.world.5400x2700.jpg"
       map_type 1
       once
       interpolate 4
#declare EarthIso=isosurface{
   function{f_sphere(x, y, z, 0.633)-(fn_EarthPigm1(x,y,z).red*0.006)}
   contained_by{sphere{0,0.7}}
   texture{pigment{rgb 1}}
   scale  <-1,1,1>
   rotate <90,0,-90>
...I'm guessing there's a way to apply fn_EarthPigm1 to only part of the
sphere?  But how?
Tim Cook
Version: 3.12
Date: 15 Nov 2005 03:04:18
Message: <dlc4j1$j5d$1@chho.imagico.de>
That's wrong.  One full data set is exactly 3x86400x43200=11197440000 bytes.
Date: 15 Nov 2005 03:09:18
Message: <dlc514$jbm$1@chho.imagico.de>
Just map it accordingly - using a mapping warp or manually using the
f_th()/f_ph() functions:
#local fn_Spherical=
   function {
     fn_Flat(1-(f_th(x,z,y)+pi)/(2*pi), f_ph(x,-z,y)/pi, 0)
Date: 15 Nov 2005 07:04:01
Message: <4379ceb1@news.povray.org>
> bytes.
Yes, but the complete dataset has one set for each month, plus
topography plus bathymetry...
Tim Cook
Version: 3.12
Date: 15 Nov 2005 08:00:54
Message: <4379dc06$1@news.povray.org>
Trying out the mapping warp on the texture to get a feel for the method,
but not sure how to make the image occupy a different sector of the
sphere... warp{spherical orientation z dist_exp 1} scale <-0.5,0.5,0.5>
rotate 90*x gives a segment from 90 degrees 'south' to the 'equator',
and 0 to 180 degrees 'west'...changing the rotation only changes the
position of that wedge, and I want to have the image occupy, for
instance, 0 degrees to 45 degrees north and 90 degrees to 135 degrees
west.  The documentation doesn't seem to elaborate on this aspect.
Tim Cook
Version: 3.12
Date: 15 Nov 2005 08:21:45
Message: <4379e0e9$1@news.povray.org>
Ah, there it is!
Sebastian
Date: 15 Nov 2005 11:11:21
Message: <437a08a9$1@news.povray.org>
Wa ha, figured it out...use translate before the warp.  :3
Tim Cook
Version: 3.12
Date: 15 Nov 2005 13:00:00
Message: <web.437a20d8f94adb4dd61e8c370@news.povray.org>
Funny,
I'm going to leave the discussion topic a bit, but
just by chance I downloaded the 8km/pixel file of July before I read this
thread. And as all these Blue Marble pictures are Mercator projections, I
thought it was a good idea to...
Well, two continents one thought...
The original satellite image was more a _Black_ Marble to me, so I made it a
bit lighter (Photopaint).
But when I saw your image I thought: "Hey let's give the NZers a chance!",
and changed from my home coordinates:
       //rotate -90 * y  //   -> 0°N und 0°E
       // Latitude
       //rotate 9.93948843330146 * y  // East is Plus
       // Longitude
       //rotate -53.584204427898 * x  // North is Minus
To the coords of Christchurch
        //  Christchurch ~  43.5°S   172.66°E
        rotate (-90 + 172.66) * y
        rotate 43.5 * x
But anyway, I've got two questions:
These deep sea trenches west of Australia won't show up. Did you made them
afterwards?
And how did you do the athmosperic rim - a second sphere filled with media?
Yours,
Bu.
Download 'nzers.jpg' (30 KB)
Preview of image 'nzers.jpg'
Date: 15 Nov 2005 13:54:03
Message: <437a2ecb@news.povray.org>
They're not Mercator projections, they're spherical.  (Mercator
projections are progressively distorted vertically as you approach the
poles, and approach infinity at the poles themselves.)
> afterwards?
I made a second function of the bathymetric data and added that to the
earth isosurface, where the function with the topography is subtracted,
since they're two files each with a full 256 shades of grey and it's a
shame to not use that full amount by trying to combine the two images
into one, which would reduce the vertical resolution by half.
Yep.  I outline the important particulars in my 'not oops' post dated
2005-11-10 08:53.
Tim Cook
Version: 3.12
Date: 18 Nov 2005 11:40:13
Message: <ch1v43-d22.ln1@badulaque.unex.es>
Among other things, Tim Cook saw fit to write:
Some time ago, before this new Blue Marble appeared, I got a full
bathymetric and elevation data file frome somewhere (I don't remember the
URL or the resolution, but it was acceptable[*]). The original data was a
binary no-header 16-bit file, which I converted to pgm with some effort
(involving using sox for getting the correct byte ending), as at that time
POV-Ray didn't support reading 16-bit PNG files... This all goes to say
that you can in theory combine everything in a 16-bit file without losing
resolution, or even get the whole thing with higher resolution.
[*] I may have the file somewhere and could put it in a server if someone is
interested.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
