POV-Ray : Newsgroups : povray.binaries.images : New Planting Method Server Time
6 Jan 2026 20:39:53 EST (-0500)
  New Planting Method (Message 1 to 10 of 32)
Subject: New Planting Method
Date: 10 Sep 2005 19:12:21
Message: <43236855@news.povray.org>
This demo scene shows three effects useful for planting many things like
grass, trees, rocks or stones.
1. If you want to show a dense forest from near to a far distance, you may
need millions of tree copies. Even povray has problems with millions of
mesh2 copies.
But if you show only the visible ones, you need only 75000 trees like in
this demo file.
The trick is to define random vectors from the camera position, which point
only to visible parts and to use them in the trace command.
2. The problem with this method is that parts far away seem less dense
populated as nearer parts.
The solution is to find the maximum distance to be populated. Then you  can
use the inverse quadratic relationship to plant with equal density despite
different distances.
3. I always wanted to draw directly on a test image and to use it for
different planting effects. This would give maximum control over the result.
The second image shows the POV logo's image used in the demo scene.
I'll post an (unoptimized) demo file at binaries.scene-files.
Norbert Kern
Download 'Tree_Logo.jpg' (259 KB) Download 'pov_logo.jpg' (49 KB)
Preview of image 'Tree_Logo.jpg'
Preview of image 'pov_logo.jpg'
Subject: Re: New Planting Method
Date: 10 Sep 2005 19:43:55
Message: <43236fbb$1@news.povray.org>
Quit postiing photog...
*is impressed by the shiny shiny image, then notices that the trees
have...patterns*
heyyyyyyy
o.o
Tim Cook
Version: 3.12
Date: 10 Sep 2005 19:44:00
Message: <43236fc0$1@news.povray.org>
Nice image! I was going to comment on the strange regularity of the tree
colors until I read your third point. =)
can
But since you don't know where that maximum distance occurs, you still have
to shoot the same density of rays everywhere. Do you then use 1/distance^2
as a probability for discarding the ray?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 10 Sep 2005 19:45:00
Message: <43236ffc$1@news.povray.org>
By the way, what's your water texture?
 - Slime
Date: 10 Sep 2005 20:08:49
Message: <43237591$1@news.povray.org>
yes, exactly. In effect I use that code:
 #if (pow (vlength (cam_loc-Inter) / max_dist, 2) > rand (r4))
Of course it would be possible to set max_dist to something very big.
But then generating the tree coordinates would take much more time.
Norbert Kern
"Slime" <fak### [at] emailaddress> schrieb im Newsbeitrag
news:43236fc0$1@news.povray.org...
> have
> - Slime
Date: 10 Sep 2005 20:12:32
Message: <43237670@news.povray.org>
news:43236ffc$1@news.povray.org...
For this demo I used a water material from Gilles Tran.
I included a link in the demo at povray.binaries.scene-files.
Norbert Kern
Date: 10 Sep 2005 23:36:57
Message: <4323a659@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:43236855@news.povray.org...
> mesh2 copies.
> this demo file.
> point
> can
> result.
Really NICE photo!  (tho not sure it's allowed here) hehe.
Still trying to figure out what you're saying here.. cause I'm a novice with
POV-Ray.  Sounds like you're trying to define only those trees that are in
view, and not ALL the trees.... when I ran the veg_many_things_WRITE
script... I gave up waiting for it to finish, and I think it did only 300
trees.  Not sure this shortcut of yours is anything short at all.
Date: 11 Sep 2005 02:25:01
Message: <dg0ifb$2oi$1@chho.imagico.de>
> mesh2 copies.
Could you elaborate?  Lots of mesh instances of course take memory (much
less than copying the mesh though) but this should scale without
problems as long as you have enough memory and the performance should be
O(log n) as long as the trees do not overlap too much.
> this demo file.
Interesting idea this 'image space object placement' - it has a few
problems though:
- Esp. with lower tree density you have the problems that trees with
their bottom below visibility (only the top looking above a mountain
ridge for example) don't get placed.
To avoid this but still keep the number of trees placed low you can use
the normal scene space placing and trace a 'visibility ray' to the
camera location to check if to actually place the tree.  If you trace
this ray from the top of the tree this will solve the issue.  The major
disadvantage is of course this is very slow (lots of unsuccessful tests,
two traces per test)
- it only works for camera types you have written a mapping function
for.  For this might be good to have scene language support for image
space/scene space transformation.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 11 Sep 2005 02:38:05
Message: <4323d0cd@news.povray.org>
Nice image and interesting technique. I guess I'll try something similiar a
the near future, though I'd probably go the longer and more complicated way
as Christoph described it. You can't have trees just stop behind a hill...
I'd probably use my Surcoat-Macros, and an idea I just had: if I'd place a
parallel lightsource in place of the camera and view from above, the hills
should throw shadows onto the terrain itself. So I only get bright spots
(where placing of objects will take place) where the camera sees it. If I
then "grow" a rim around that area, I'd have a little more space in all
directions... Hm. Need to think about this more.
Anyways, how did you create the tree? POV-Tree, or did you do it yourself?
Tim
"Tim Nikias v2.0"
Date: 11 Sep 2005 03:56:06
Message: <4323e316@news.povray.org>
sorrry, I should have mentioned the time needed.
It takes about 10 minutes with a 2.7 GHz P4 system to complete the
coordinate finding for the 75000 trees.
You need an aspect ratio of 2:1 like in +w800 +h400 despite ending with a
black image.
After you generated the tree coordinates once parsing the Tree_Logo.pov file
needs only 20 seconds.
Norbert Kern
"EagleSun" <nomail@nomail> schrieb im Newsbeitrag
news:4323a659@news.povray.org...
>> may
>> mesh2 copies.
>> this demo file.
>> point
>> can
>> despite
>> result.
> with POV-Ray.  Sounds like you're trying to define only those trees that
> are in view, and not ALL the trees.... when I ran the
> veg_many_things_WRITE script... I gave up waiting for it to finish, and I
> think it did only 300 trees.  Not sure this shortcut of yours is anything
> short at all.
