POV-Ray : Newsgroups : povray.binaries.images : Pole/zero plot [~50k] Server Time
29 Nov 2026 19:15:19 EST (-0500)
  Pole/zero plot [~50k] (Message 1 to 13 of 13)
Subject: Pole/zero plot [~50k]
Date: 14 Aug 2005 06:18:46
Message: <42ff1a86@news.povray.org>
Hi folks.
This took a supprisingly long time to render... not entirely sure why.
The mosiac preview was fast enough; I guess it's just AA slowing it down.
Anyway, the (z-domain) transfer function for a 2-pole notch-reject filter...
Download 'z1.jpg' (45 KB)
Preview of image 'z1.jpg'
Subject: Re: Pole/zero plot [~50k]
Date: 14 Aug 2005 06:37:18
Message: <42ff1ede$1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> schrieb im Newsbeitrag
news:42ff1a86@news.povray.org...
> Hi folks.
> filter...
Cool, i like filter design and this stuff, though i'm still at FIR-filters
and haven't played with z-transforms yet.
How does it sound? :)
Thies
Date: 14 Aug 2005 07:00:41
Message: <42ff2459$1@news.povray.org>
With a fixed cutoff frequency... almost inaudable. But if you *sweep*
the cutoff frequency, it sounds mostly like a phaser.
FIR filters are much easier to design, and can give a more exact
frequency responce.
IIR filters are harder to design, and don't give quite such exact
frequency characteristics... but they run *much* faster! (For example,
the above filter requires 5 multiplies and 4 additions per sample to
filter a signal. A 5-point FIR couldn't possibly produce such a narrow
reject band.)
Anyway, I learned everything I know here:
http://www.dspguide.com/
Enjoy. ;-)
Date: 14 Aug 2005 08:46:43
Message: <42ff3d33$1@news.povray.org>
news:42ff2459$1@news.povray.org...
>> FIR-filters
> With a fixed cutoff frequency... almost inaudable. But if you *sweep* the
Nice, i like to 'explore' a sound with filters like that, afterwards
it's easier to identify the different sources from which the sound is built
> FIR filters are much easier to design, and can give a more exact frequency
> responce.
i especially was stunned by the idea that you can make up an arbitrary
freq.-response and get the corresponding filter-kernel by FFT-ing it.
> frequency characteristics... but they run *much* faster! (For example, the
> above filter requires 5 multiplies and 4 additions per sample to filter a
> signal. A 5-point FIR couldn't possibly produce such a narrow reject
> band.)
yes, the feedback-idea behind IIRs is cool. i have to learn more about
that some time.
i know this book, it's a real gem, i have never seen the basics of
convolution, fft, etc. explained clearer than in this one
> Enjoy. ;-)
Thanks, i have :)
i just had an idea for your picture, i think it would be nice to
have circles around the origin of the complex plane, especially
the unitcircle, that would be useful for stability analysis, etc..
(you probably know more about that than i). and perhaps radial rays
so that you can see the angle. or briefly said: i think polar coords.
would be more useful than rectangular coordinates
Thies
Date: 14 Aug 2005 08:57:16
Message: <42ff3fac$1@news.povray.org>
Yes... I'm currently building a realtime Java IIR filter system which
will hopefully let me filter arbitrary sounds and see what happens...
[This is assuming it ever works!]
>>responce.
Indeed. It looks so complicated, but it's really so simple... I love it
when that happens in mathematics! ;-)
Of course, the numbers you put into an inverse FFT are for frequency
*bands*. So while the whole band is guaranteed to total up to the number
you demand, individual frequencies within that band might be above or
below the requested gain... herein lies the complexity of designing
FIRs. It's not as simple as it looks. ;-)
[Of course, usually the answer is just "use more points"... :-/  ]
> that some time.
 From FIRs we know that longer impulse responce = better. So you would
imagine that an *infinite* impulse responce would be the best! :-D
But, alas, feedback can only create certain waveforms. In particular,
the impulse responce for a "perfect" low-pass filter would be an
infinite sinc function - basically a sine wave that decays as the
reciprocol of time. Using IIRs, I can make a sine wave that decays
*exponentially* with time... which is close... but not *quite* the same...
(Close enough that a 5-pole Butterworth IIR filter utterly kicks bottom
compared to any 5-point FIR you could design. But different enough that
a very big FIR filter works better, if you have the CPU power.)
I have played with the FFT a lot. This book explains *why* it does some
of the strange things it does...
Yes, you're exactly right.
I only used grid cordinates because it looks cooler. ;-)
Now, if this were the s-domain...
[Side note: Actually, if you take away the gridlines, it's quite hard to
see the zero next to the front pole. It just looks like a patch of
shadow that shouldn't exist. With the gridlines there, you can see that
it's actually a dip in the surface.]
Date: 14 Aug 2005 10:13:33
Message: <42ff518d$1@news.povray.org>
Orchid XP v2 nous apporta ses lumieres en ce 2005-08-14 06:18:
> Hi folks.
> filter...
Isosurface with prety big gradients = slow.
Date: 14 Aug 2005 10:22:16
Message: <42ff5398$1@news.povray.org>
Well, yes... POV-Ray wanted me to use max_gradient 2860 or something.
But I actually used 120, which seems to work perfectly. (Clearly the
steepest part of the function is nowhere near the surface...)
I imagine the poles create the high gradient...
(Note that this is actually the *logarithm* of the transfer function, if
you want to be technical about it.)
Date: 14 Aug 2005 11:00:31
Message: <42ff5c8f$1@news.povray.org>
news:42ff3fac$1@news.povray.org...
>> built
> Yes... I'm currently building a realtime Java IIR filter system which will
> hopefully let me filter arbitrary sounds and see what happens... [This is
Oh nice, you could do a nice z-plane-GUI to position the poles and zeros
in Realtime, too =)
another possible way would be to write a VST-plugin in C, and use it
with a VST-Host-application. Tha advantage is, that you can focus on the
audiofilter part of the code, the disadvantage that you need a host-
application to use the plugin.
>>>frequency responce.
yes, me too :)
some time ago i had the idea to use the deconvolution idea (that is also
described a bit in the 'dspguide') to undo the blur in photos that is
the result from jiggling the camera during the exposure. I think if you
knew the motion of the camera you could guess a blurring filterkernel
from that, which can emulate the camwiggling. now just use to deconvolution
on the blurred image with that filterkernel and perhaps you can regain
most of it's original sharpness back (that is, what the noise didn't eat..)
> below the requested gain... herein lies the complexity of designing FIRs.
the power of brute force :D
>> that some time.
> But, alas, feedback can only create certain waveforms. In particular, the
> impulse responce for a "perfect" low-pass filter would be an infinite sinc
> function - basically a sine wave that decays as the reciprocol of time.
> Using IIRs, I can make a sine wave that decays *exponentially* with
ah, thanks for the explanation. That sounds like an interesting
optimization-task to tune the IIR-coefficients though i fear someone
has already done this before me..
> compared to any 5-point FIR you could design. But different enough that a
> I have played with the FFT a lot. This book explains *why* it does some of
Another book which i really like is
  'Digital Filters' from R.W. Hamming, Dover Publications
it's also a small introductory book, which is a bit more focused on the
math behind it than the dspguide, but still gets the ideas across in a
great way so that it's directly applicable on realworld-problems.
If you don't know it already have a look at it.
hehe ;)
> see the zero next to the front pole. It just looks like a patch of shadow
> that shouldn't exist. With the gridlines there, you can see that it's
Date: 14 Aug 2005 11:22:50
Message: <42ff61ca$1@news.povray.org>
> in Realtime, too =)
Yeah, something like that. ;-)
In my lunch break at work, I built a little thing out of Tcl then allows
you to pick pole and zero coordinates, and then launches GNUplot and
graphs it for you. :-D (Sadly, GNUplot itself can't create filters with
an arbitrary number of poles because there's no looping capabilities.)
It could then also spit out the IIR coeficients, and even get GNUplot to
graph the impulse and frequency responce. (Again, GNUplot can't run the
filter to get the impulse responce because that requires looping. As
would doing an FFT. So Tcl does that and writes it to file, than GNUplot
graphs it.)
I'm currently attempting to do the same thing with Java...
Another advantage of IIRs over FIRs is that you can *change* the
frequency responce quickly and easily - just gotta change a handful of
coeficients. (An FIR would require an entire FFT step for this!) Plus
they can emulate the old analogue synthesiser sound. (All analogue
filters are IIRs!)
In fact, IIRs are *so* fast that it's quicker to take a pure sawtooth
tone and IIR filter it down than it is to calculate half a dozen sine
waves from the Fourier series and add them all together... [Well, in
trueth, there will be come crossover point at which one becomes better
than the other. But I wouldn't think it would take too long to reach!]
Much bigger problem: that would require C. ;-)
> yes, me too :)
...and the ADC quantinization noise, and the JPEG compression. ;-)
You could probably *improve* the image significantly. However, if the
original convolution actually _eliminated_ any frequencies, you aren't
going to get them back, no matter /how/ high the gain. Deconvolution is
effectively passing the signal through a filter who's frequency responce
is the reciprocol of the first one - and taking the reciprocol of zero
isn't wise. ;-)
As I said, it's all down to pole-zero plots. (The incredible thing is
that somebody figured out that if you take the problem and put it
through the Laplace transform, it becomes very much simpler!)
Thanks for the tip.
Date: 15 Aug 2005 12:35:00
Message: <4300c434$1@news.povray.org>
news:42ff61ca$1@news.povray.org...
>> in Realtime, too =)
> graphs it for you. :-D (Sadly, GNUplot itself can't create filters with an
> filter to get the impulse responce because that requires looping. As would
> doing an FFT. So Tcl does that and writes it to file, than GNUplot graphs
> it.)
a realtime update of the impulse- and freq.response would be very cool.
Be sure to post someting in p.o-t about it, when you've made progress
> Another advantage of IIRs over FIRs is that you can *change* the frequency
> responce quickly and easily - just gotta change a handful of coeficients.
> (An FIR would require an entire FFT step for this!) Plus they can emulate
> the old analogue synthesiser sound. (All analogue filters are IIRs!)
that's definately a good argument to use them in virtual analog
synthesizers.
i wonder if we would choose the FIR-sound as more 'natural' if analog
filters sounded like FIRs or if it's really because we sense the sound
itself as more pleasing to the ear..
> In fact, IIRs are *so* fast that it's quicker to take a pure sawtooth tone
> and IIR filter it down than it is to calculate half a dozen sine waves
> from the Fourier series and add them all together... [Well, in trueth,
> there will be come crossover point at which one becomes better than the
that brings us to additive synthesis. I remember there actually was a
hardwaresynth that took this approach and could generate the first 64
harmonics in realtime AFAIR and control each harmonic with it's own
envelope but apparently it sounded not too different or special to get
wide attention. I think the main problem was that it's not easy to
make an easy interface to control so many oscs in parallel in a way
that gives interesting results. Without noise to spice it up it
sounded rather sterile.
>> yes, me too :)
>> deconvolution
>> eat..)
> isn't wise. ;-)
yeah, that's the problem. I think i should just try it to see if
the zeros in the freq-response of a realworldcase render deconvolution
useless or not.
>>>sinc function - basically a sine wave that decays as the reciprocol of
>>>time. Using IIRs, I can make a sine wave that decays *exponentially* with
> As I said, it's all down to pole-zero plots. (The incredible thing is that
> somebody figured out that if you take the problem and put it through the
yes, the laplace transform is really a cool idea.
Take a differential equation and get an algebraic equation in return,
it's always great to find such unexpected relations in math.
where would we be now without all those 17th/18th century
mathematicians...? :D
Date: 16 Aug 2005 00:56:49
Message: <43017211$1@news.povray.org>
High!
Is it just me or are the two peaks in fact slightly tilted? In a
representation of a function, they shouldn't!
See you in Khyberspace!
Yadgar
Now playing: Beim Zahnarzt (Ihre Kinder)
Date: 16 Aug 2005 15:24:44
Message: <43023d7c$1@news.povray.org>
I'm working, I'm working! ;-)
> synthesizers.
Quite. Might build one of them too...
A FIR can sound like *anything*. Even an IIR. (If you give it enough
points - but, uh, why?) But it does give more control.
Yeah - nice idea, but... how to control it all?
FM synthesis generates lots of frequencies, but you don't have to
control them individually. (They're controlled by some heavy-metal
mathematics involving Bessel functions and such things.)
>>isn't wise. ;-)
> useless or not.
OK, a basic 3x3 pixel "blur" is basically a 2D version of an "averaging"
FIR. Since the kernel is all 1s (well, actually scaled for unity gain,
but...) the frequency responce is a sinc function. (Remember - the time
and frequency domains are "duals" of each other! The perfect lowpass
filter has a sinc kernel to the exact same reason.)
Now this sunc function will have a couple of zeros across the frequency
spectrum - the more points you average, the more zeros you have. A 3x3
blur would have 2 zeros in each direction - that means your
deconvolution would tend to have 2 poles in it's frequency responce.
IOW, it will try to insert waves which may or may not have been there in
the first place. Oh dear...
Now, if you had an uneven "blur" - like if the camera slipped in one
direction during the shot - the frequency responce on each axis would
have "holes" in it in different places. That at least admits the
possibility that you *might* be able to do "something" with it...
I read about the Laplace transform to design IIRs. But apparently, it
turns differential and difference equations into polynomials (which are
*much* easier to solve), and integration and differentiation become
multiplication and division. (Again, *much* easier.) Also, rather like a
logarithm, multiplication becomes addition...
BTW... apparently named after Laplace, but invented 100 years earlier. :-|
...the 16th century? ;-)
The Orchid - converting povray.binaries.images into povray.freaky.maths :-D
Date: 16 Aug 2005 15:26:06
Message: <43023dce$1@news.povray.org>
It's the camera angle - or rather, a perspective distortion. (Makes it
look more "3D" though.) If you switch to othographic camera and point it
parallel to the axis, they are quite straight.
