POV-Ray : Newsgroups : povray.binaries.images : Tunnel Server Time
29 Nov 2026 19:15:18 EST (-0500)
  Tunnel (Message 1 to 11 of 11)
Subject: Tunnel
Date: 1 Aug 2005 19:07:58
Message: <42eeab4e@news.povray.org>
I like this better and better.
Download 'AtmosphericMedia2a.jpg' (53 KB)
Preview of image 'AtmosphericMedia2a.jpg'
Subject: Re: Tunnel
Date: 1 Aug 2005 20:01:35
Message: <42eeb7df$1@news.povray.org>
Wow, this sure has changed since the first time I saw it. I really like the
way only a few of the lights are on. Very contrasty now, too.
Not sure if you noticed on your monitor that there is a ladder rung artifact
where the hatchway door is at, looks like either media sampling caused it,
or maybe the area_light + media. My LCD screen shows it up easily when
tilted.
I still think the sky (or whatever is above) should be brighter, since eyes
would adjust to the darkness in this tunnel and the light beaming through
the gratings would probably appear artificially intensified. Thing is, if
that were done it would likely need an overglow added.
Subject: Re: Tunnel
Date: 1 Aug 2005 23:03:37
Message: <42eee289$1@news.povray.org>
Me too! Massive improvement over the original. The lighting is great. I
agree with Bob that the sky (and maybe the sun light source) still needs to
be brighter.
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Tunnel
Date: 2 Aug 2005 00:12:15
Message: <42eef29f$1@news.povray.org>
so I increase the samples to get rid of that ladder effect?
"Slime" <fak### [at] emailaddress> wrote in message
news:42eee289$1@news.povray.org...
> to
> be brighter.
> - Slime
Subject: Re: Tunnel
Date: 2 Aug 2005 02:15:36
Message: <42ef0f88$1@news.povray.org>
Worth a shot.
 - Slime
Subject: Re: Tunnel
Date: 2 Aug 2005 10:20:01
Message: <42ef8111$1@news.povray.org>
the Samples was already set at 50,400, but I can bump that up again...
news:42ef0f88$1@news.povray.org...
> Worth a shot.
>  - Slime
Subject: Re: Tunnel
Date: 2 Aug 2005 13:02:14
Message: <42efa716$1@news.povray.org>
"Bryan Valencia" <pov### [at] spamgourmetcom> wrote in message
news:42eeab4e@news.povray.org...
infinitely better than your original posting. nice progress!
Subject: Re: Tunnel
Date: 2 Aug 2005 15:20:24
Message: <42efc778@news.povray.org>
If you're using sampling method 3 (the default), the 400 is irrelevant and
you can replace that with "samples 50".
 - Slime
Subject: Re: Tunnel
Date: 2 Aug 2005 21:00:00
Message: <web.42f0167bf03c7d14a175d1920@news.povray.org>
You should! Much, much improved from where you started.
Subject: Re: Tunnel (samples 100)
Date: 3 Aug 2005 15:37:40
Message: <42f11d04@news.povray.org>
This is with "samples 100"
news:42efc778@news.povray.org...
>  - Slime
Download 'AtmosphericMedia2b.jpg' (48 KB)
Preview of image 'AtmosphericMedia2b.jpg'
Date: 3 Aug 2005 16:16:10
Message: <42f1260a$1@news.povray.org>
Looks like it fixed the artifacts.
I'm glad you made the sunlight brighter. You might want to reduce the media
density to compensate (so that the actual beams of light aren't so bright).
Also, I think I see banding in your area light shadows; maybe you should
bring up the sample count.
 - Slime
