So, going with Steve's suggestion, I've added some atmosphere. This also
required a change in the light's position, which in turn affected the wet
reflection of the sadguy standing there. Might have to fiddle a little with
it to get the reflection back, but I wanted to show the progress.
Tim
"Tim Nikias v2.0"
Download 'rainyday_b.jpg' (44 KB)
Preview of image 'rainyday_b.jpg'
> Regards,
> Tim
I love it !!! But it's still a bit too dark, and the picture should be
more centered on the man (don't let this big blank at the top of the
picture)
Dark Skull Software
http://www.darkskull.net
A+
On Tue, 26 Jul 2005 13:58:58 +0200, "Tim Nikias"
It is calling out for a lamppost and a song :-)
Nice work Tim.
Regards
Like it.
> picture)
As for the darkness, that might be a monitor thingy, it's quite fine on
mine. It also explains why you think there's a big blank at the top, there
are actually darkblue waterdrops there. On a 1024x768 version there are only
100 lines of blackness, until waterdrops begin to appear.
As for centering on the man: that's an no-no. As a rule of thumb: try
*never* to put the point of interest into the *exact* center of the image.
Also, in this image, you feel like he's too low, which is what I want to
express: he's down. The image-ratio also helps to create a direction where
to look: you just have to look downwards to see him.
So its all intentional and not by accident. :-)
"Tim Nikias v2.0"
I actually was wondering about a lamppost. I just might model one and look
and how it adds to the image. But a song? "Singing in the rain" comes to
mind, but this guy is sad.
> Nice work Tim.
Thanks! :-)
"Tim Nikias v2.0"
> Like it.
Thank you for the brief, but approving comment. :-)
"Tim Nikias v2.0"
PS: But I'll look and try if I can adjust it a little bit. :-)
"Tim Nikias v2.0"
On Tue, 26 Jul 2005 16:58:43 +0200, "Tim Nikias"
Yes but the object of being sad is to be happy, just as the object of
being wet is to be dry. I look at the half full glass :-)
If you want sad, make the figure stand dejected and downcast. (Easy
for me to say:-)
Still, it has an inner depth.
Regards
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> schreef in
bericht news:42e64faa$1@news.povray.org...
A lamppost with a broken bulb... adds to the sadness.
as for a song, something in a minor scale comes to mind, especially music by
Dowland. Maybe you could add music bars in the background, hardly seen, and
going downwards at the same time they would disappear in the darkness.
Just a thought.
But it is a nice piece of work, as is!
I have had a funny experience with this image (with take 1 in fact, but
it's the same). I first had a look at the picture on my usual computer,
with Ifranview, which shows the image in a large window with a black
background. As the background of your image is also fully black, I
thought that the pic was the full window showed by Ifranview, with an
aspect ratio that is wider than it is high (4/3-ish), and with the
character and the light occupying only ~1/3 of the pic, on the left (the
rest being all black). Then, on another computer, I saw the image with
its true apesct ratio.
I am allowed to say that I prefer the wide aspect ratio ;-) ? I find it
reinforces the loneliness feeling in the pic. Anyway, it likes the
picture very much ! Simple and effective.
Cheers,
Thibaut
Well, the wide aspect, though placing him very lonely, would not get as much
"downward" feeling to it. Additionally, an image filled with black space...
You see, when you use it as a wallpaper, black can be the default color, and
there you go: saved some memory. :-)
Thanks for the comment nontheless.
"Tim Nikias v2.0"
Tim,
I have a niggling worry about the conservation of matter. The splash seems
just too dense - like someone dumped a bucket of water on the brolly - or
sad-bag's standing under a downspout. However the rain density above the
umbrella is relatively low - it seems it should just produce a melancholy
dripping off the edge. Perhaps I'm missing an element of melodrama here?
DLM
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in
message news:42e6258e@news.povray.org...
> with
> Regards,
> Tim
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
Nah. There's a particle system that drops rain from above. The only problem
with the umbrella is, how to set it up properly to have the water more or
less pour down the umbrella. What I do is almost completely negate the
velocity, so the drops get very slow and roll off the umbrella. But since
they move slower, they cluster up more easily. Might have to work a little
on that, though I kinda like it.
"Tim Nikias v2.0"
