POV-Ray : Newsgroups : povray.binaries.images : Subject: Re: First Post. Server Time
9 Jan 2026 14:07:31 EST (-0500)
  Subject: Re: First Post. (Message 1 to 9 of 9)
Subject: Subject: Re: First Post.
Date: 15 Jul 2005 03:55:39
Message: <42d76bfb@news.povray.org>
I managed to create a procedural version that has the black grout lines
between the tiles. The "scale 1.0472" was determined by trial and error,
looking at a region 5000 units away from the origin to magnify the
discrepancies. I guess that 1.0472 should really be some expression
containing things like pi and sin(pi/3), but I can't work it out.
Download 'HexTiles.jpg' (155 KB)
Preview of image 'HexTiles.jpg'
Subject: Re: Subject: Re: First Post.
Date: 15 Jul 2005 03:58:04
Message: <zhK$3DABy21CFw+X@econym.demon.co.uk>
The source (with the "1.0472" to which I was referring) looks like this:
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <0,20,-30> look_at <0,0,0> angle 40}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#include "stones.inc"
#include "functions.inc"
#declare T1 = texture {T_Stone20 scale 5} // Texture for hexagons
#declare T2 = texture {T_Stone17 scale 2} // texture for triangle centre
#declare T3 = texture {pigment {rgb 0}}   // texture for grout
// combined triangle and grout
#declare T4 =   texture {function {f_hex_y(x,z,y,0)}
  texture_map {[0.03 T3][0.03 T2]}
  rotate y*30
  scale 1.0472
#declare S=sin(pi*1/3);
#declare C=cos(pi*1/3);
plane {y,0
  texture {function {(sin(x-pi/2) * sin(x*C+z*S) * sin(x*C-z*S))/2}
    texture_map { [0.5 T1][0.5 T4] }
Mike Williams
Gentleman of Leisure
Date: 15 Jul 2005 09:55:01
Message: <web.42d7bee7105a1265437d093a0@news.povray.org>
I haven't sat and pondered your geometry, but it's probably worth noting
that pi/3 = 1.04719755.   :)
  -Ed
Date: 15 Jul 2005 10:07:07
Message: <42d7c30b$1@news.povray.org>
Wow, when you scroll the message up and down you get an zoom effect.
First I thought I've had too much coffee. %-)
So long,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 15 Jul 2005 10:56:11
Message: <42d7ce8b$1@news.povray.org>
"Bonsai" <bon### [at] b0n541net> wrote in message
news:42d7c30b$1@news.povray.org...
> So long,
> Bonsai
that's what I was just doing :) but havn't had any of my coffee yet.
Date: 15 Jul 2005 11:10:07
Message: <42d7d1cf$1@news.povray.org>
>>So long,
>>Bonsai
it nearly made me spill my coffee
Date: 15 Jul 2005 13:20:00
Message: <web.42d7efb1105a1265df8b4fdf0@news.povray.org>
Wow! Once again I am amazed what those of you with experience can do to an
image. The tiles look amazing, much better than mine, and the source is
much easier. Thanks for making the image, it helped me learn a new
technique.
~ James
Date: 18 Jul 2005 03:05:02
Message: <web.42db534a105a1265ad93754b0@news.povray.org>
> between the tiles.
I also managed to create a version with grout, and I found a cute way to get
a nice curved normal by using the negative reciprocal of your function.
I'll post the results tonight, if I get time.
These stones.inc textures look pretty, but they aren't much good for anims,
since they contain crand. :(
Date: 18 Jul 2005 05:10:01
Message: <web.42db70b2105a12654307bcfb0@news.povray.org>
Here's my version.
// Persistence of Vision Ray Tracer Scene Description File
// Tile pigment & normal from a function. Based on code from:
// From: Mike Williams
// Subject: Re: First Post.
// Date: 13 Jul 2005 18:23:50
// Message: <F1Q### [at] econymdemoncouk>
// -f -a0.4 +AM2 +R2
// -D +A0.1 +AM2 +R3
// -D +A0.15 +AM2 +R4
#version 3.6;
global_settings {
  assumed_gamma 1.0
  max_trace_level 10
#include "stones1.inc"
// ---Textures-----------------------------
#declare Ang = pi*2/3;
#declare S=sin(Ang);
#declare C=cos(Ang);
#declare f_Tile = function {sin(x-pi/2) * sin(x*C+z*S) * sin(x*C-z*S) / 4}
#declare GW = 0.0025;
#declare NTile = normal{function{-0.75*GW/abs(f_Tile(x,y,z))}}
//------------- White Marble with gray veining. Note: some of these textures
contain crand!!!
#declare T_Stone17 =
texture{T_Grnt20 scale <1, 2, 2> rotate <0, 0, -30>
        finish{ambient 0.2 diffuse 0.9} normal{NTile 2 scale 1/2 }
texture{T_Grnt8a scale <2.5, 4.5, 3.5> rotate <0, 0, 40>
        finish{phong 1.0 phong_size 90}
texture{T_Crack3 scale <1, 2, 1.4> rotate <10, 0, -20>
        finish{phong 1.0 phong_size 90  reflection 0.1}
//------------- Brown & Olive Marble. Now without white veining
#declare T_Stone20 =
texture{T_Grnt27 scale <0.7, 0.99, 0.7> rotate <0, 0, 40> normal{NTile 5
scale 1/5 }}
texture{T_Grnt12a scale <1, 1.3, 2> rotate <0, 0, 40>}
texture{T_Crack1 scale <1, 0.6, 1> rotate <10, 0, -20>
#declare TGrout =
texture{
  pigment{rgb 1.125}
  finish{ambient 0.05 diffuse 0.95}
  normal{granite .2 scale .080 bump_size .275}
#declare T0 = texture {TGrout scale 1 }  // texture for grout
#declare T1 = texture {T_Stone20 scale 5 }  // Texture for hexagons
#declare T2 = texture {T_Stone17 scale 2 }  // texture for triangles
#declare TFloor =
  function{f_Tile(x,y,z)}
  texture_map { [.5-GW T2][.5-GW T0][.5+GW T0][.5+GW T1] } phase .5
#declare TMetal =
  pigment {rgb <0.95,0.95,1.0>*.9}
  finish{
    diffuse 0.15 ambient 0.0
    specular 0.50 roughness 1e-5
    reflection {0.55,0.65 metallic}
    conserve_energy
// ---Objects------------------------------
#declare Floor =
plane {y,0
    //TGrout
    TFloor
    scale .5
// reflective post
#declare BRad = 0.25;
#declare PY = 5;
#declare Post = cylinder{0, y*PY*BRad, BRad texture {TMetal}}
// ---Scene--------------------------------
  location  <0.0, 4, -8> * 1
  look_at   -y*.5
  angle 36
  right     x*image_width/image_height up y
  direction z
light_source {<-30, 30, -30> rgb 1}
#if(0)
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
object{Floor}
//object{Post}
Download 'functileb1.jpg' (131 KB)
Preview of image 'functileb1.jpg'
