Opinions sought.
http://www21.brinkster.com/jrcsurvey/Temp/index.html
The link is to some test renders permutating different
combinations for background, specular, and roughness.
Constants:
pigment { rgb 0 }
diffuse 1
reflection { .075 .15 fresnel metallic 0 }
Which looks best?
Subject: Re: bg/specular/roughness and black leather
Date: 8 Apr 2005 03:50:48
Message: <425637d8@news.povray.org>
Jim Charter wrote:
> Which looks best?
23
Cheers!
Rick Measham
I took a look, then came back later and took another look, and I would have
to agree with Rick. #23 looks best to me, especially if you're looking for
shiny leather.
> pigment { rgb 0 }
I've found that I get better results when I use a very small RGB value,
rather than 0. You might want to experiment with that as well. RGB 0 can
look very strange when placed with other objects, in my experience. Perhaps
something like "rgb <0.001, 0.001, 0.001>" or for a slightly bluish tint
"rgb <0.001, 0.001, 0.003>"
> diffuse 1
Jaime recently mentioned "diffuse + reflection = 1". From looking at some
of his code, it appears that he always uses the first reflection component,
which would give you a diffuse of 0.925. Not a huge difference, but it
might make a subtle difference.
Would the bottom (base?) of the shoe have a different specular component?
Just some thoughts.
Jeremy
www.beantoad.com
Date: 8 Apr 2005 11:08:25
Message: <42569e69@news.povray.org>
> shiny leather.
>>pigment { rgb 0 }
>>diffuse 1
> Just some thoughts.
I think the diffuse component is irrelevent for rgb 0. I think it is
basically the product of the two values, rgb and diffuse, and the angle
of the lightray, that are used to calculate shadow. So if you go rgb 0
you loose all capacity to get non-lighted shadows and instead have to
rely on specular and/or reflection to mold the surface. So, as you say,
adding a little color gives "diffuse" something to work with. The
trouble is that just about the time that adding color starts to make a
difference, it starts to look like grey, not black, material.
Yes I remember Jaime's suggestion too, though I thought he was talking
about specular. I also remember that a long time ago there were often
threads discussing such formulas. Alas, am I now just catching up? Well
not quite. For a long long time I typically adjusted
diffuse/specular/reflection as some sort of loosely conceived division
up of a unit whole. Then it came as something of a revelation to me
when I freed myself from that discipline. Now, while Jaime's statement
comes as a sobering remainder to keep it sane, I am still not convinced
that a formulaic relationship between these elements always makes sense.
I was introducing my daughter to raytracing just the other night. We
were giving a sphere, with no finish specified, different colors just to
demonstrate how the color vector worked. I was trying to get her to
guess how to get yellow by introducing the concept that yellow is really
not-blue. So first I had to demonstrate that white is <1,1,1>. We did
the render. "It doesn't look white, it looks grey", was her immediate
reaction. :(
With a low rgb, radiosity also is neutralized. So the only way to get
any tones into the shadows is reflection. But even the slightest amount
of reflection gives a hard-shiny look.
About the bottom of the shoe. ("Bottom" is the correct term.) Yes, if it
was made of leather it would show wear and have tan patches. If not,
then it would be some homogenous material other than leather and
therefore show different surface characteristics. It is an important
question because it may be true that the solution to the problem has to
do with providing massive amounts of minute surface detail. After all,
shiny, homogenous, black patent leather is favored by some precisely for
its "dark liquid", form-denying properties.
So the hunt goes on. But I was interested to peoples reactions to gross
adjustments of these factors across the scene in general.
"Jim Charter" <jrc### [at] msn com> wrote in message
news:42569e69@news.povray.org...
> basically the product of the two values, rgb and diffuse, and the angle of
> the lightray, that are used to calculate shadow. So if you go rgb 0 you
> loose all capacity to get non-lighted shadows and instead have to rely on
> specular and/or reflection to mold the surface. So, as you say, adding a
> little color gives "diffuse" something to work with. The trouble is that
> just about the time that adding color starts to make a difference, it
Very true. Though in some cases, I've had rgb 0 objects show up like black
holes in the middle of a picture, and giving it a very small value still
makes it appear black, without making it look like there's black hole in the
picture. But if it looks ok in relation to other objects, no reason to
change it.
> diffuse/specular/reflection as some sort of loosely conceived division up
> of a unit whole. Then it came as something of a revelation to me when I
> freed myself from that discipline. Now, while Jaime's statement comes as
> a sobering remainder to keep it sane, I am still not convinced that a
I'm not convinced either, but Jaime's lighting is always better than mine,
so I don't argue. Plus it makes my life simpler (biggest reason). ;-)
Incidentally, I looked up a demo scene of his, and he goes by the 2nd
component of reflection (which is usually the highest), which would make it
diffuse 0.85 in your case. But with rgb 0, I don't think it matters, as
you've already stated.
> I was introducing my daughter to raytracing just the other night. We were
> demonstrate how the color vector worked. I was trying to get her to guess
> not-blue. So first I had to demonstrate that white is <1,1,1>. We did the
> reaction. :(
Some day, when you grow up, you'll realize that there is no such thing as
rgb 0 and rgb 1, just various shades of rgb 1*A, where A is a value between
0 and 1, non-inclusive*. ;-)
> With a low rgb, radiosity also is neutralized. So the only way to get any
> tones into the shadows is reflection. But even the slightest amount of
> was made of leather it would show wear and have tan patches. If not, then
> it would be some homogenous material other than leather and therefore show
> different surface characteristics. It is an important question because it
> may be true that the solution to the problem has to do with providing
> massive amounts of minute surface detail. After all, shiny, homogenous,
> black patent leather is favored by some precisely for its "dark liquid",
I was just thinking that the bottom might be made of a different material.
...or it might not...
If you have the time/patience/computing power, making rotating animations
can help point out flaws, especially for things such as specular. From
certain angles, specular reflections may appear ok, but from others, you
realize they are too high / too rough / too etc.
Just mentioning some tricks that I've learned.
*I'm thinking of making that my sig. :-)
Jeremy
www.beantoad.com
> so I don't argue.
Exactly.
I will have to study this matter further.
Sometimes brutally so. I used that technique for my first ever IRTC
entry. I was inexperienced at placing objects then.
Gawd, not specular too.
Date: 8 Apr 2005 18:30:43
Message: <42570613@news.povray.org>
>> Jaime recently mentioned "diffuse + reflection = 1". [...]
> up of a unit whole.
Now that you mention it, I was just thinking about specular, and also
phong, having the same "relation" with diffuse. Re-reading the part of
the docs about diffuse, seems it accounts for anything that is not
direct light reflection. As specular and phong both simulate reflection
of the light sources, seems that also diffuse+specular or diffuse+phong
should be 1. But we use traditionally specular or phong coupled with
reflection, so I really don't know what to do with all this...
Oh... I almost forgot about the original post: I prefer 22 or 23,
both look very convincing.
Jaime
23 is the best (if I had to buy one pair)
24,25,30 and 31 are very "disco"
27,28 found at Chelsea flea market !
Rene
http://rene.bui.free.fr - online portfolio
Date: 9 Apr 2005 10:06:43
Message: <4257e173@news.povray.org>
Sold!
They pulse.
Two for one! They do look a little rusted over.
> Rene
Interesting.
20 shows a sort of starting point with all settings low.
22 shows an increase in roughness with specular still the same as in 20.
23 shows the increase in specular with roughness remaining the same as
in 20.
Jim Charter wrote:
> Opinions sought.
> Constants:
> pigment { rgb 0 }
> diffuse 1
> Which looks best?
21, 22 or 24. 24 was my first choice.
would like to see the final selection sometime.
news:425610d3$1@news.povray.org...
> Which looks best?
Blimey! I remember those things at school! All of a sudden, *that girl*
was either your height now, or was taller than you by three inches. Those
were the days.
23 for me. Although, I like 24 too.
I see a rainy night scene under an amber street light unfolding... :oO
~Steve~
Ross wrote:
> Jim Charter wrote:
>>Opinions sought.
>>Constants:
>>pigment { rgb 0 }
>>diffuse 1
>>Which looks best?
Based on the responses I am getting here: a strong favouring of 23, as
well as my own preferences: I like some of the liveliness of 24 too, I
will probably experiment with some interpolation such that, if
20.....23
21.....24
are vectors, then
X marks the likely settings:
20.....23
.....X
21.....24
