POV-Ray : Newsgroups : povray.binaries.images : Pool wip Server Time
14 Oct 2026 13:12:51 EDT (-0400)
  Pool wip (Message 1 to 19 of 19)
Subject: Pool wip
Date: 3 Apr 2005 17:07:15
Message: <42505b02@news.povray.org>
After a long time not poving I got an inspiration and started a scene.
Any suggestions how to continue? I don't want to start modelling too
complex objects but I would still like more details to the image.
Download 'pool.jpg' (98 KB)
Preview of image 'pool.jpg'
Subject: Re: Pool wip
Date: 3 Apr 2005 17:21:46
Message: <42505e6a@news.povray.org>
I'm not sure about the proper word for it, but what about a safety ring, one
of those floating thingies you throw in after someone goes overboard?
Or a rubber ducky. :-)
"Tim Nikias v2.0"
Date: 3 Apr 2005 18:36:43
Message: <42506ffb$1@news.povray.org>
> Any suggestions how to continue?...
It looks like this pool has a uniform depth -- how about tilting the
bottom to give deep & shallow ends. And maybe a diving board?
If it is supposed to be a swimming pool instead of just a backyard pond,
a change of scale might make it look a bit bigger.
I like the "bent" pole effect (just ior, of course), but I think the
ripples are too big to match the existing scale.  Just a couple of
personal thoughts...
     -=- Larry -=-
Date: 3 Apr 2005 19:18:27
Message: <425079c3@news.povray.org>
  It's supposed to be just a decorative pool, not a swimming pool.
Something a bit abstract.
Date: 3 Apr 2005 21:49:10
Message: <42509d16$1@news.povray.org>
My immediate inclination would be to elaborate on the tile-grid v
ripples-circle patterns somehow. Surround the pool with grass forced
into a grid arrangement? or a grid of tiles that contain circles? or
some other such play.
Alos right now there is quite a mystery about what is causing the
ripples.  Perhaps enclude other phenomena that seem to defy causality?
Date: 4 Apr 2005 14:45:52
Message: <3gr7i2-4nf.ln1@badulaque.unex.es>
Among other things, Warp saw fit to write:
I don't see the ripples' reflecting back from the walls, are they? I'm not
talking about light reflection, but surface waves reflection.
It also needs some insects flying around the lamp.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 4 Apr 2005 16:02:25
Message: <42519d51$1@news.povray.org>
Not sure where you intend to go with this, but a few thoughts:
What is the subject of the image? Is it the ripples? I'm wondering what
caused them. Ripples are generally a secondary effect, created by something
more important, so it's strange that they're the primary focus in this
image. Maybe that's what you're going for; if not, why not put something
else in there to hold the viewer's attention? What's the pool for, and
what's it being used for? The image creates a lot of unanswered questions.
And what's with the stick?
If you're going for realism, the grass needs some work and the fence could
benefit from a little more detail or variation (periodic fence posts, for
instance). Maybe also work on the transition from grass to pool edge (unless
you're going to cover that with some sort of grass mesh).
I have a hard time getting a sense of scale; judging by the fence, those
lights look like they're about knee high, the stairs look smaller than my
feet, and the pool looks about half a foot deep.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 Apr 2005 16:04:26
Message: <42519dca$1@news.povray.org>
The waves are calling for a reason to exists. While there's a clear,
certain center of them, it looks like some weird, invisible force is
moving the water. It can't be the stick, or there would be other waves
too (nearer to the stick).
IF you're heading realistic, I mean ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 4 Apr 2005 16:23:31
Message: <4251a242@news.povray.org>
  That's an interesting idea.
  My intention was really to create odd-looking, almost unnatural ripples.
All by themselves they don't work as I want. The viewer will only think
the modelling is crappy. However, if other things in the scene would
clearly also defy naturality, that would be a better hint.
  Any suggestions?
Date: 4 Apr 2005 16:24:05
Message: <4251a264@news.povray.org>
  They are. They just decay so fast that it's hard to see...
Date: 4 Apr 2005 16:26:10
Message: <4251a2e1@news.povray.org>
  I'll definitely try the fence posts and some grass...
  It's supposed to be a small decorative pond, not a swimming pool.
Granted, the tiles hint at a swimming pool, but they look so cool I would
not want to change them to anything else... :P
Date: 4 Apr 2005 16:26:50
Message: <4251a309@news.povray.org>
  Some unknown force it is... :P
Date: 4 Apr 2005 16:41:58
Message: <4251a696$1@news.povray.org>
news:4251a2e1@news.povray.org...
could
for
(unless
my
i havn't seen many small decorative ponds or pools that are just square.
Date: 4 Apr 2005 16:53:33
Message: <4251a94d$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> wrote in message
news:4251a696$1@news.povray.org...
> could
> for
> (unless
those
> my
would
I mean, a more interesting form for the pool would liven up the image a lot.
I didn't intend to be harshly critical of it.
Date: 4 Apr 2005 17:32:23
Message: <4251b267$1@news.povray.org>
...and it seems to be in a low-gravity environment, such as the Moon or
Titan... or is it instead filled with some slimy transparent jelly
rather than water?
See you in Khyberspace!
Yadgar
Now playing: Searching for the Spark, live 1978 (Steve Hillage)
Date: 4 Apr 2005 18:17:37
Message: <4251bd01$1@news.povray.org>
like jellby said, definately insects
one or two in the water
"Warp" <war### [at] tagpovrayorg> skrev i melding
news:42505b02@news.povray.org...
x]
Warp -
Date: 5 Apr 2005 04:06:06
Message: <425246ee@news.povray.org>
Very relaxing image ;-)
I remeber a friend's pool plenty of ladybugs, and he twice or thrice a day
dredged the pool with a butterfly net trying to save them.
Paolo
Date: 5 Apr 2005 08:36:36
Message: <42528654$1@news.povray.org>
I agree with all the comments that say the waves should have a reason to
exist...  this gives you a wide range of possibilities to choose from.
I think it is the stairs that lead most of us to believe this is a
swimming pool and added confusion about the scale.
Awesome start!  Looking forward to future revisions.
Date: 5 Apr 2005 11:53:26
Message: <4252B3F9.4020605@hotmail.com>
>   Any suggestions?
A mirror that reflects the pool without ripples? Possibly including
the object that should have made the ripples?
