POV-Ray : Newsgroups : povray.binaries.images : Liquid glass Server Time
19 Oct 2026 16:34:02 EDT (-0400)
  Liquid glass (Message 1 to 8 of 8)
Subject: Liquid glass
Date: 26 Mar 2005 12:44:13
Message: <42459f6d@news.povray.org>
An old trace, now with 75% more photons!
(I can send a 1600x1200 if you ask nicely)
Best,
    S.
Steven Pigeon, Ph. D.
ste### [at] stevenpigeoncom
ste### [at] videotronca
Download 'LiquidGlass 01 small.png' (350 KB)
Preview of image 'LiquidGlass 01 small.png'
Subject: Re: Liquid glass
Date: 26 Mar 2005 19:53:16
Message: <424603fc@news.povray.org>
Very nice, although tht quartz looks a little odd to me. Too clear and
dark, maybe.
-Xplo
Date: 26 Mar 2005 21:31:37
Message: <42461b09$1@news.povray.org>
I'm trying a trace with a lot more photons
I'll see what  it will look like.
"Xplo Eristotle" <xpl### [at] infomagicnet> wrote in message
news:424603fc@news.povray.org...
> dark, maybe.
> -Xplo
Date: 26 Mar 2005 23:04:32
Message: <424630d0$1@news.povray.org>
Lack of photons isn't the issue; the quartz is just too perfectly
glassy. It's not uncommon for it to have cloudy parts or other
imperfections; check out some photos (there are many online).
Of course, changing that might be more work than you want to put in,
especially when I did identify it. ;p
Also, is it using the IOR of quartz? (I don't remember the number
offhand, although I remember it being quite a bit higher than glass, and
it probably wouldn't make a big difference.. but it probably should use
quartz IOR, regardless.)
-Xplo
Date: 27 Mar 2005 00:58:42
Message: <42464b92$1@news.povray.org>
Can't remember the exact IOR right now,
but I think it's closer to glass anyway. Quartz
and diamond have IOR around 2.0
news:424630d0$1@news.povray.org...
> Lack of photons isn't the issue; the quartz is just too perfectly glassy.
> It's not uncommon for it to have cloudy parts or other imperfections;
> Also, is it using the IOR of quartz? (I don't remember the number offhand,
> although I remember it being quite a bit higher than glass, and it
> -Xplo
Date: 27 Mar 2005 08:39:38
Message: <4246b79a$1@news.povray.org>
Steven Pigeon nous apporta ses lumieres en ce 2005-03-27 00:58:
Quartz a little bit over 2
Diamond: 2.5
Date: 27 Mar 2005 09:05:49
Message: <4246bdbd$1@news.povray.org>
From my Material IORs chart:
Glass, Fused Silica        1.459
Glass, Pyrex™              1.474
Glass, Albite              1.489
Plexiglas™                 1.5
Glass, Crown, Zinc         1.517
Glass                      1.51714
Glass, Crown               1.52
Quartz                     1.544
Glass, Flint (29% Lead)    1.569
Glass, Flint (light)       1.58038
Glass, Flint (medium)      1.62725
Glass, Flint (heavy)       1.65548
Glass, Flint (dense)       1.66
Glass, Flint (55% Lead)    1.669
Glass, Flint (Lanthanum)   1.8
Glass, Flint (71% Lead)    1.805
Glass, Flint (heaviest)    1.89
Glass, Arsenic Trisulfide  2.04
Diamond                    2.417
Tim Cook
Version: 3.12
Date: 7 Apr 2005 14:45:00
Message: <web.42557cb6cc332c023d6ca37a0@news.povray.org>
> Diamond                    2.417
Correct, so why does consts.inc still have
#declare Diamond_Ior     = 2.47;
like it has since the days of DKBTrace? :(
Attached is an Ideal-Cut diamond with correct IOR, but the photons are not
quite realistic, although it does give a rather pretty effect, IMNSHO. :)
// Persistence of Vision Ray Tracer version 3.5 Include File
// File: brilliant5.inc
// Desc: The 'brilliant' gem-cut. Parameters from "Diamond Design" by
M.Tolkowsky
// Date: 2004.5.28
// Auth: PM 2Ring
// The "Brilliant" object is centered on the Origin, with girdle in the XZ
plane.
// INCLUDE FILE: DO NOT RENDER DIRECTLY!
#version 3.5;
//"Brilliant" parameters from "Diamond Design" by Tolkowsky. h:height,
r:radius, a:angle
#local htable =  0.324;
#local rtable =  0.550 * .89;
#local rgird  =  1.000;
#local hpav   = -0.862;
#local hculet = hpav+1/64;
#local acrown = -34.5;
#local astar = -20;
#local agirdhi = -39;
#local agirdlo = 42.75;
#local apav = 40.75;
#local ff=.9815;        //Fudge factor. Well, you know... :)
//Create MK facets, 'phase' K. Facet 0 passes through (X,Y,0) at angle A.
//N is facet (normal) direction: 1=face up, -1=face down.
#macro Facet(K, MK, X, Y, A, N)
  #local T=radians(A);
  //Find height of plane through (X,Y,0), with angle A to +ve X-axis
  #local H=N*(Y*cos(T) - X*sin(T));
  #while (K<MK)
    plane{N*y,H rotate <A,360*K/MK,0>}
    #local K=K+1;
//Brilliant cut
#local BBound = cylinder{hculet*y, htable*y, rgird}
//#local BBound = box{<-rgird,hculet,-rgird>, <rgird,htable,rgird>}
#declare Brilliant =
intersection{
  object{BBound}
  plane{y,htable}                         //Table
  Facet(0.5, 8, rtable,htable,astar, 1)   //Stars
  Facet(0.0, 8, rgird,0,acrown, 1)        //Crown
  Facet(0.5,16, rgird*ff,0,agirdhi, 1)    //Upper Girdle
  Facet(0.5,16, rgird*ff,0,agirdlo, -1)   //Lower Girdle
  Facet(0.0 ,8, 0,hpav,apav, -1)          //Pavillion
  plane{-y,-hculet}                       //Culet
  bounded_by{BBound scale 1.001}
//Conical Brilliant
#declare BrillCone =
merge{
  cone{0,rgird, y*htable,rtable}
  cone{y*hpav,0, 0,rgird}
Download 'diamondq2.png' (304 KB)
Preview of image 'diamondq2.png'
