POV-Ray : Newsgroups : povray.binaries.images : Rope macro - Work in progress Server Time
14 Oct 2026 15:05:43 EDT (-0400)
  Rope macro - Work in progress (Message 1 to 19 of 19)
Subject: Rope macro - Work in progress
Date: 28 Feb 2005 06:53:17
Message: <4223062d@news.povray.org>
I'm currently working on a rope macro that will generate a rope along a
spline.
The output is a mesh2 with a uv_map.
I'll make the macro available when it's finished.
Download 'Rope.jpg' (28 KB)
Preview of image 'Rope.jpg'
Subject: Re: Rope macro - Work in progress
Date: 28 Feb 2005 08:09:19
Message: <422317ff@news.povray.org>
Great!!
I buy it!
Marc
"Mike Williams" <nos### [at] econymdemoncouk> a écrit dans le message de
news:4223062d@news.povray.org...
> spline.
Date: 28 Feb 2005 08:44:00
Message: <+mbMmDAx$xICFwH$@econym.demon.co.uk>
The source code is now available at
http://www.econym.demon.co.uk/pov/rope.htm
Mike Williams
Gentleman of Leisure
Date: 28 Feb 2005 12:22:35
Message: <4223535b@news.povray.org>
Mike,
Best I've seen so far.
Rope technicalities - attention to detail.
A cabled rope is typically a 3-start helical bundle. And typically
right-handed.
A nice example is at
http://www.bestdock.com/pics/extras/Rope.JPG
Your rope looks like it has about 6 strands and is left-handed.
Also in the first bend (from the left) it appears to be unravelling (strands
are more parallel with main axis).
Keep up the good work.
DLM
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
> spline.
Date: 28 Feb 2005 12:38:09
Message: <biJFHHA5b1ICFwDs@econym.demon.co.uk>
Wasn't it dlm who wrote:
>Mike,
>right-handed.
This particular example has five strands, but the macro allows any
number not less than three.
The macro supports left handed rope by setting a negative value to the
Twistiness parameter.
I don't think it actually unravels, it's just an illusion caused by the
perspective.
Mike Williams
Date: 28 Feb 2005 13:29:34
Message: <kurtzlepirate-D1CEBE.19293428022005@news.povray.org>
In article <4223062d@news.povray.org>,
>>spline.
>>[Image]
>>end
very nice!
did my cables inspire you ? ;-)
good job, as usual.
Date: 28 Feb 2005 13:40:00
Message: <web.4223653064b7b8e68c7259570@news.povray.org>
As always, great, Mike, and thanks.  I learn more from your tutorials, and
examining your examples and macros, than about any other way.
Dave Matthews
Date: 28 Feb 2005 18:02:03
Message: <4223a2eb$1@news.povray.org>
I'd love to see an example of a three-strand rope with a left hand twist
to it .. there was something about this one that just didn't feel quite
right.
Then:
... your next mission, should you choose to accept it, is to create a
macro for a stranded 3-strand rope. Not sure of the specs, but each
strand in hemp ropes tends to be a twist of smaller strands ...
Cheers!
Date: 1 Mar 2005 03:19:44
Message: <422425a0@news.povray.org>
"Dave Matthews" <dma### [at] wrmnwestmnscuedu> schreef in bericht
news:web.4223653064b7b8e68c7259570@news.povray.org...
> Dave Matthews
Exactly! Would have said the same! Great work Mike!
Date: 1 Mar 2005 14:26:36
Message: <4224c1ec@news.povray.org>
> right.
> Then:
> .... your next mission, should you choose to accept it, is to create a
> Cheers!
> Rick
Why not directly implement a fractal rope, each smaller strand being a
twist of smaller strands being ... ? ;-)
Regis
Date: 2 Mar 2005 09:04:26
Message: <4225c7ea$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> schreef in bericht
> spline.
Would be nice if the mesh could be written to a file....  :-)
Date: 2 Mar 2005 10:17:52
Message: <Ya6F5DAwZdJCFwJu@econym.demon.co.uk>
>> spline.
Makemesh is supposed to be capable of that, and in fact it will write
such a file but for some reason it can't find it again afterwards in
order to re-use it. I didn't have that problem with SweepSpline.
I tried for a while, but couldn't work out what was going wrong. If you
want to try it, just add a Filename parameter to the Rope macro
definition
   #macro Rope(Track,Width,Strands,Twist,Fatness,U,V,Filename)
pass it onward to makemesh
   BuildWriteMesh2(Verts, Norms, UV, V, U-1, Filename)
and supply a filename when you call the macro
   Rope(Spline, 0.04, 5, 3, 1.5, 200, 50, "ropedata.inc")
If you happen to find out why that doesn't work, and how to fix it,
please let me know.
Mike Williams
Date: 3 Mar 2005 03:32:15
Message: <4226cb8f@news.povray.org>
news:Ya6### [at] econymdemoncouk...
> please let me know.
I had no problems, Mike!
I included the file name to the macros, then called the rope with the
following code (in Rope.pov, but could be in any other scene I guess):
#include "ropedata.inc"
object {Surface
  texture { uv_mapping
    pigment {gradient v-5*u
      colour_map {
        [0   rgb <1,0.8,0.7>]
        [0.5 rgb <1,0.8,0.7>*0.5]
        [1   rgb <1,0.8,0.7>]
      scale 0.003
  translate <0.5, 0, 0.5>
...and I got two identical ropes side by side (the original one, and the one
from ropedata.inc).
Date: 3 Mar 2005 05:10:49
Message: <IJyx9BASJuJCFw6g@econym.demon.co.uk>
>> please let me know.
>object {Surface
>      colour_map {
>        [0   rgb <1,0.8,0.7>]
>        [1   rgb <1,0.8,0.7>]
>      scale 0.003
>from ropedata.inc).
I said that bit works. The file gets saved correctly.
The bit that doesn't work is when makemesh checks to see if the file
already exists and is supposed to read the data rather than
recalculating it. When I used makemesh in the same way in my SweepSpline
macro it all worked.
Mike Williams
Date: 3 Mar 2005 07:37:10
Message: <422704f6@news.povray.org>
news:IJy### [at] econymdemoncouk...
Sorry, Mike, got it wrong!
indeed, recalculates each time...
Shall have a more specific look. Seems something for Ingo...
Date: 3 Mar 2005 07:52:56
Message: <opsm2bljvjcs6ysw@frogeater.bredbandsbolaget.se>
On Thu, 3 Mar 2005 10:09:22 +0000, Mike Williams
I downloaded rope.zip from your site and checked out makemesh.inc.
Although the comments preceding BuildWriteMesh2 say that the macro will
check if the file already exists, there doesn't appear to be any such
check in the actual macro.
FE
()  ascii ribbon campaign - against html mail
/\                        - against microsoft attachments
Date: 3 Mar 2005 09:19:22
Message: <eve$HGAdzxJCFwLZ@econym.demon.co.uk>
OK. I've added some code into Rope.inc that reads back the file
previously created by BuildWriteMesh2 if it already exists. The updated
version is now on the web page
<http://www.econym.demon.co.uk/pov/rope.htm>
(And I was wrong about it working for SweepSpline and have now made the
same change to it - I must have been confusing it with something else.)
Mike Williams
Date: 3 Mar 2005 15:50:01
Message: <web.422777a264b7b8e6a3fcf12a0@news.povray.org>
> spline.
Wow. That certailnly puts my rope attempts to shame:
http://www.hentschels.com:8000/~pictures/cgi-bin/album/index.cgi?dir=/2004/11November/Ropes
Great work! :-)
 - dan B hentschel
Date: 4 Mar 2005 02:59:46
Message: <42281572@news.povray.org>
Mike,
I have another version of makemesh where there is a CheckFileName(FileName)
macro. This seems to be missing in your (original) version.
When I run it, the file is not overwritten, but it is also not parsed from
the file...
