POV-Ray : Newsgroups : povray.binaries.images : Pinball fun... "Imminent" Server Time
29 Nov 2026 21:51:20 EST (-0500)
  Pinball fun... "Imminent" (Message 1 to 12 of 12)
Subject: Pinball fun... "Imminent"
Date: 3 Feb 2005 21:31:25
Message: <4202de7d@news.povray.org>
The amazing thing is that there is a full(ish) pin-table on the smaller
one...
  Everything was translated, rotated, scaled in PoV except for the main
table which obviously was produced in Wings. Wings can't do the 'whole scene
thing' unless you have some kind of super computer. It was a real headache
for six weeks work. 157 includes - (renamed *A,*B,*C, for the additional
tables). Needed lots more texture procedures though - dirt, grime, wear,
etc.
  Better motion blur on the balls too, (advice with this?)
   Hope you like the concept though.
    ~Steve~
Download 'imm2.jpg' (148 KB)
Preview of image 'imm2.jpg'
Subject: Re: Pinball fun... "Imminent"
Date: 3 Feb 2005 21:51:15
Message: <4202E323.80600@nomail>
Looks good .. only thing is the colors feel a bit oversaturated .. most
of the pinball machines I've used are darker more brooding colors. (2c)
Favorite feature: the airplane flypast!
Cheers!
Date: 4 Feb 2005 06:01:14
Message: <420355fa$1@news.povray.org>
St. nous apporta ses lumieres en ce 2005-02-03 21:29:
> one...
> scene thing' unless you have some kind of super computer. It was a real
> headache for six weeks work. 157 includes - (renamed *A,*B,*C, for the
> additional tables). Needed lots more texture procedures though - dirt,
> grime, wear, etc.
>    ~Steve~
About the motion blur, that's cartoon motion trail that you are using! That's no
motion blur.
Date: 4 Feb 2005 06:12:42
Message: <420358aa@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:420355fa$1@news.povray.org...
> That's no motion blur.
   Thanks for that. Now, how do you do motion blur then?
> Alain
Date: 4 Feb 2005 06:24:09
Message: <42035b59@news.povray.org>
Without MegaPOV, you've got to render several images with the object in
question moving, and then average those images. There's probably a more
precise model, as I guess that a real photo would receive most information
during the initial opening of the camera shot and gather less and less when
it reaches the end, as the photo-cells have already saturated or such. For a
digital camera though, my description should be sufficient. :-)
"Tim Nikias v2.0"
Date: 4 Feb 2005 06:43:39
Message: <42035feb$1@news.povray.org>
> grime, wear, etc.
   That would be very nice... I also agree with Rick about the colors.
   Hmmm... as it is just a sphere, perhaps a cylinder with a faked
texture would do the job.
   Great concept! And very detailed work (I liked the "recursive"
touch). If it is not taking too much long to render already, I will
increase a bit the rad quality. That plus working on the textures, can
lead to an even more impressive image.
Jaime
Date: 4 Feb 2005 06:50:14
Message: <42036176@news.povray.org>
> in question moving, and then average those images. There's probably a
> more precise model, as I guess that a real photo would receive most
> information during the initial opening of the camera shot and gather
> less and less when it reaches the end, as the photo-cells have
> already saturated or such. For a digital camera though, my
No, it should be sufficient for film too.  A shutter speed of 1/100 will
give you twice the exposure as a shutter speed of 1/200, on both film and
digital.  Of course this is assuming you don't over-expose any areas.
What *might* make a difference is the speed that the shutter opens.  If it
opens slowly relative to the "shutter speed" then the "weighting" of the
instantaneous image will be lower at the beginning and the end when the
shutter is only partially open.  But seeing as shutters can open at 1/4000
second, I doubt it would make much visible difference.
Date: 4 Feb 2005 07:26:54
Message: <42036a0e$1@news.povray.org>
Looks like a fun table to play.
I extually made a few pinball tables in pov and make them playable with
visual pinball.
look here:
http://emkaah.tripod.com/
If you know some VBS you could probably made this table playable too.
Would be fun :) .
Date: 4 Feb 2005 10:00:25
Message: <42038e09@news.povray.org>
"scott" <sco### [at] spamcom> a écrit dans le message de
news:42036176@news.povray.org...
Don't forget that curtain shutters don't expose the whole picture surface at
the same moment: at high speed, it is merely a narrow slot between 1st  and
2nd curtain that sweeps across the film window.
BTW isn't the eye model  with its Persistence Of Vision better than
photographic model?
Image fades smoothly from retina in roughly 1/25 sec so last image should be
stronger than 1st
Marc
Date: 4 Feb 2005 11:39:22
Message: <4203a53a$1@news.povray.org>
>> If it opens slowly relative to the "shutter speed" then the
>> "weighting" of the instantaneous image will be lower at the
>> beginning and the end when the shutter is only partially open.  But
>> seeing as shutters can open at 1/4000 second, I doubt it would make
> surface at the same moment: at high speed, it is merely a narrow slot
> between 1st  and 2nd curtain that sweeps across the film window.
> photographic model?
> should be stronger than 1st
Very true, I've never thought of that before!
Date: 4 Feb 2005 15:54:50
Message: <4203e11a@news.povray.org>
High!
> most of the pinball machines I've used are darker more brooding
> colors. (2c)
Obviously, it's an early 60s pinball machine... those psychedelic and
sci-fi themes, let alone gothic style (like on the "Haunted House"
machine of 1984) came up only in the 70s!
By the way, did you know that by the end of 2000, the last remaining
manufacturers (was it Gottlieb and Bally?) ultimately stopped building
pinball machines? Clearly outrivalled by PCs, Playstations and X-Boxes...
See you in Khyberspace!
Yadgar
Date: 8 Feb 2005 05:39:51
Message: <420896f7$1@news.povray.org>
> one...
If you release the code, I would be happy to try and animate this thing
from a "in the ball" view :)))
CJ
