POV-Ray : Newsgroups : povray.binaries.images : Look like copper? Server Time
29 Nov 2026 22:21:38 EST (-0500)
  Look like copper? (Message 1 to 19 of 19)
Subject: Look like copper?
Date: 7 Jan 2005 15:27:13
Message: <41def0a1@news.povray.org>
New wallpaper.
Yeah, I'm in a rut. Was a material test to begin with, evolved into this.
~Mike
Download 'copper.jpg' (168 KB)
Preview of image 'copper.jpg'
Subject: Re: Look like copper?
Date: 7 Jan 2005 16:14:47
Message: <41defbc7$1@news.povray.org>
Mike Raiford wrote:
> New wallpaper.
Nice! Bright, hard, cold, well polished copper spheres with some condensation on them.
Like those RSOC.
Date: 7 Jan 2005 17:06:56
Message: <41df0800$1@news.povray.org>
Really nice ... but I didn't see condensation ... I see tiny chips and
dings...
Neil
"Alain" <ele### [at] netscapenet> wrote in message
news:41defbc7$1@news.povray.org...
> Mike Raiford wrote:
> > New wallpaper.
this.
> Like those RSOC.
> Alain
Date: 7 Jan 2005 17:55:02
Message: <41df1346@news.povray.org>
"Neil Kolban" <kol### [at] kolbancom> wrote in message
news:41df0800$1@news.povray.org...
> dings...
  I see that too. The thing with copper is that it's 'very' soft and what I
would call 'draggy', (that metal 'moves'!) For me, the main copper sphere
had rolled down a tarmacced road for a little while, but having said this,
the weight of that sphere would also produce surprisingly larger dents too.
   ~Steve~
> Neil
Date: 7 Jan 2005 20:39:33
Message: <41df39d5$1@news.povray.org>
> what I would call 'draggy', (that metal 'moves'!)
I was thinking the same thing. Too hard. I've stripped enough copper
wire to know that you couldn't make a ball bearing out of it. Makes
great connecting rod bearings, however, but I'm getting off the point.
Color and finish look convincing.
  -Shay
Date: 7 Jan 2005 21:14:21
Message: <41df41fd@news.povray.org>
>> dings...
> I would call 'draggy', (that metal 'moves'!) For me, the main copper
> sphere had rolled down a tarmacced road for a little while, but having
> said this, the weight of that sphere would also produce surprisingly
> larger dents too.
Hmm, I need to work on scale, I think.... Anyone ever have a BB gun when
they were kids? This is sort of the inspiration... A close-up look at a
copper BB. As I remember they tended to get a bit knurled at times. So
yes -- not condensation, but dings (I think the normal was actually
called "chinks" in the source file.)
A BB is rather small, and doesn't have very good mass, I need to add a
bit of oxidation to the finish as well, I think.
Date: 7 Jan 2005 21:21:19
Message: <41df439f@news.povray.org>
Does copper really have such sharp reflections? Pennies sure don't.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 7 Jan 2005 22:02:53
Message: <41df4d5d$1@news.povray.org>
I think most of the time, no, but then we have those examples of early
Roman copper mirrors and so on.  It can be polished up. Just like brass.
  We used to do this to the copper plates we used for etching.  We used
brass cleaner.  It really creates a mirror-like and deeply luminous
surface.  Slightest oil smudges from your fingers would stand out.  But
surface dings would look less like pocks and more like gouges where you
could see the metal displaced.  True pocks would fill in with grunge.
Date: 8 Jan 2005 05:47:28
Message: <41dfba40@news.povray.org>
"Michael Raiford" <mra### [at] hotmailcom> wrote in message
news:41df41fd@news.povray.org...
> A BB is rather small, and doesn't have very good mass, I need to add a bit
     The oxidisation might be a tough one. If it's that kind of surface
you're looking for, then try a little green and grey in there too. Having
said that, it doesn't ring true for this image:
    http://crystalchild2.home.att.net/images/Copper.jpg
     I suspect though, that this sphere is an old beaten sphere that's been
lovingly handled through the years, and has kept a nice sheen. Still, it
gives a better idea of what your surface should look like.
    ~Steve~
Date: 8 Jan 2005 11:09:09
Message: <41e005a5$1@news.povray.org>
> dings...
> Neil
>>Mike Raiford wrote:
>>>New wallpaper.
> this.
>>Like those RSOC.
>>Alain
Maybe, but at first look, those specks made me think of tiny water droplets on the
balls surface.
Date: 8 Jan 2005 13:42:58
Message: <41e029b2$1@news.povray.org>
The little dings look similar to what happens to sterling silver rings -
they get covered with "texture" after awhile from being banged against other
items.  That part of the texture looks very convincing.
Date: 9 Jan 2005 07:18:17
Message: <41e12109$1@news.povray.org>
Mike:
Put a white plane up above the scene for the metal to reflect off of and
see what happens.  For a material to really look reflective, it has to
have something to ... uh ... reflect.  The bottom half of the spheres
look quite interesting, though.
Aaron
Date: 10 Jan 2005 08:49:03
Message: <41e287cf@news.povray.org>
Aaron Gillies wrote:
> Mike:
> Aaron
This is the same image, with white "sky", I did modify the texture a
bit. I've adjusted the scale and depth of the micro texture to blur the
relection a bit, all other things are the same. Blur samples were
increased slightly to give a bit cleaner looking image.
~Mike
Download 'copper2.jpg' (153 KB)
Preview of image 'copper2.jpg'
Date: 10 Jan 2005 10:50:00
Message: <web.41e2a381e6208fcca3fcf12a0@news.povray.org>
> > Mike:
> > Aaron
> ~Mike
The blurred reflection improves the appearance a lot. I thought the first
image looked a bit off, but I couldn't exactly put my finger on why I felt
that way. This new image looks very convincing.
 - dan B hentschel
Date: 10 Jan 2005 12:15:07
Message: <41e2b81b@news.povray.org>
Mike Raiford wrote:
> New wallpaper.
Gahh....
Had to pick by jaw off the floor after seeing this one. Very well done!
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Date: 11 Jan 2005 00:08:32
Message: <41e35f50@news.povray.org>
Well, maybe it's just me, but I like the first one  better - you mentioned
wallpaper so I am testing your image as my wallpaper.
The dark "sky" is what I prefer for my background - it shows icons well.
The white version looks great on the lower half of the image but way too
empty on the top half. Perhaps you can find something more interesting than
white (a checkered "sky" perhaps??).
Copper looks great.
Date: 11 Jan 2005 08:14:41
Message: <41e3d141$1@news.povray.org>
> Copper looks great.
> Stephen
I use the one with the black background. I think the checkered "sky"
would make it too busy for it to be practical as a wallpaper
~Mike
Date: 11 Jan 2005 21:17:36
Message: <41e488c0@news.povray.org>
"checkered sky" was a joke -- sorry for the confusion - I just meant that
the plain white sky - if it's meant to be sky - was too plain and
non-interesting to me. I was making a pun on the reflective sphere on a
checkered floor - i.e. a checkered sky.
The copper BB and wood textures are warm, rich and full of depth.
YES - I like the dark "sky" for my desktop. For a desktop, I like the black
or dark backgrounds with limited image or distracting colours - but then
again each to his and or her own.
Thanks for the image.
Would you be able to send me the copper texture, please?
signup42 at shaw dot ca
news:41e3d141$1@news.povray.org...
mentioned
than
> > Copper looks great.
> > Stephen
> ~Mike
Date: 12 Jan 2005 09:02:55
Message: <41e52e0f$1@news.povray.org>
> Stephen
> mentioned
> than
>>>Copper looks great.
>>>Stephen
>>~Mike
Look at p.t.sf
~Mike
