POV-Ray : Newsgroups : povray.binaries.images : Lame attempt at sub-surface scattering Server Time
29 Nov 2026 22:21:39 EST (-0500)
  Lame attempt at sub-surface scattering (Message 1 to 11 of 11)
Subject: Lame attempt at sub-surface scattering
Date: 31 Dec 2004 09:54:19
Message: <41d56813@news.povray.org>
(I cancelled a previous message, I forgot to reduce the filesize)
Does this look interesting?
It's just an isosurface filled with dense media. Standard lighting (no
radiosity), no antialiasing: 3 hours in a P4 3.2GHz. The yellow "spikes"
are probably due to the slightly filtering pigment (<1,1,0.95>).
I've tried a HF, but it's either too low resolution or gives some problem
(with the HF_Sphere macro, there seems to be an error somewhere, but the
"debug information" printed by povray is endless, it looks like the
generated file is just a few very long lines).
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Download 'test.jpg' (66 KB)
Preview of image 'test.jpg'
Subject: Re: Lame attempt at sub-surface scattering
Date: 31 Dec 2004 10:10:12
Message: <etqat09e0ji5id94ddr1oco9g4kbp847n5@4ax.com>
Yes, good opening to New Year of raytracing :-)
ABX
Date: 31 Dec 2004 10:51:38
Message: <41d5758a$1@news.povray.org>
Yep.  It's great!  I like the fungus growing on it.
Aaron
Date: 31 Dec 2004 12:26:04
Message: <41d58bac$1@news.povray.org>
Yes!  Looks like a waxy asteroid with settlement lights on the dark
side, about to collide with the galactic checkerboard phenomenon.
Oskar
Date: 31 Dec 2004 14:53:57
Message: <41d5ae55@news.povray.org>
Now that's a lime flavoured icecream, just out the freezer, slightly
frosted.
Alf
Date: 31 Dec 2004 14:59:59
Message: <41d5afbf$1@news.povray.org>
Which I now realize has familiar geography :/
Alf
Date: 1 Jan 2005 13:59:43
Message: <41d6f314@news.povray.org>
Two more views, now they're heightfields (meshes) and the antialiasing is
on, but that means they have less resolution. This is about as much as my
computer memory (512M) can hold, it's 4-8 times less detailed than the
isosurface :-/  I also added a little bit of colour, hope this helps. I
think the close-up looks like those ice sculptures they sometimes show on
TV...
Download 'test-2.jpg' (51 KB) Download 'test-3.jpg' (42 KB)
Preview of image 'test-2.jpg'
Preview of image 'test-3.jpg'
Date: 1 Jan 2005 23:25:00
Message: <web.41d7770b3bf057153ffc53560@news.povray.org>
> TV...
I'm interested in seeing the source code that made the bumps and how you got
that into a sphere....
Date: 1 Jan 2005 23:40:36
Message: <41d77b44$1@news.povray.org>
Something like...
#include "functions.inc"
#declare PlanetSize=6371.3
#declare PlanetRelief=200
#declare fn_PlanetBump=function{
   pigment{
     image_map{
       tiff "c:\imagemap.tif"
       map_type 1
       once
       interpolate 4
isosurface{
   function{f_sphere(x, y, z, PlanetSize)-fn_PlanetBump(x, y,
z).red*PlanetRelief}
   contained_by{sphere{0,(PlanetSize+PlanetRelief)*1.01}}
   pigment{
     color rgb 1
Tim Cook
Version: 3.12
Date: 2 Jan 2005 03:55:48
Message: <41d7b712@news.povray.org>
Entre otras cosas, EagleSun tuvo a bien escribir:
>> TV...
> got that into a sphere....
#declare Relief = function {
    image_map {
      png "terrainbase_4320.png"
      map_type 1
      interpolate 2
#declare fRelief = function { Relieve(x,y,z).grey }
#declare Radius = 3;
#declare Height = 2;
// Earth as an isosurface
#declare Earth = isosurface {
  function { f_r(x,y,z) - (Radius + (fRelief(x,y,z)-0.5)*Height) }
  contained_by{ sphere { <0, 0, 0>, Radius+0.1*Height } }
  open
  accuracy Height*0.5/65536
  evaluate 7, 1.15, 0.7
#include "shapes.inc"
HF_Sphere(fRelieve,0,0,<1080,1081>,1,"earth-ld.hf",<0,0,0>,Radius-Height/2,2)
// Earth as a mesh
#declare EarthHF = object {
  #include "earth-ld.hf"
Date: 2 Jan 2005 13:46:59
Message: <41d841a3$1@news.povray.org>
> TV...
   That close-up looks astonishing... the material looks like a mix
between wax and ice.
Jaime
