Hi,Maurice.
I think that the the map_type 7 is not "360 degrees views ".
I think that the problem is the seam of the map.
I tried this;
sphere {
0,200
pigment { image_map { hdr hdr_image once interpolate 2 map_type 7 } }
//pigment { image_map { hdr "hdr_env.hdr" once interpolate 2 map_type
1 } }
finish { ambient 1 diffuse 0 }
//scale <-1,1,1>
hollow
//rotate 120*y
Regards
miyoken
http://miyoken.at.infoseek.co.jp/http://miyoken.ifdef.jp/index.htm
miyoken wrote:
> Hi,Maurice.> I think that the the map_type 7 is not "360 degrees views ".> I think that the problem is the seam of the map.
I'm afraid that you are right.
> > I tried this;> > sphere {> 0,200> pigment { image_map { hdr hdr_image once interpolate 2 map_type 7 } }> //pigment { image_map { hdr "hdr_env.hdr" once interpolate 2 map_type> 1 } }> finish { ambient 1 diffuse 0 }> //scale <-1,1,1>
why comment this out?
> hollow> //rotate 120*y
So you just moved the "defect" out of sight. Makes sense.
Maurice
