Hi folks,
I wanted to improve my McIntosh image, mostly the table material and the
tubes filaments light emission.
I had to fiddle with radiosity settings. filaments are just high ambient
textured stacked tori, (20 ,2 per valve, arealights should take forever to
trace and point lights should be unrealistic)
I used save & load radiosity data (as found on Jaime's page
http://www.ignorancia.org/t_tips.php ) with higher ambient for the filaments
during the pretrace
I am still not quite satisfied: lighting by filaments is uneven.
Modeled with Moray with some Luis' DirectCode plugin additions and directly
exported and rendered in Megapov 1.1
A larger version can be found here:
http://marc.jacquier.free.fr/Pics/Stock/Autres/mcintoshhdri4.png
Comments & advices are welcome as usual :-)
Marc
here are my radiosity settings
#declare use_rad=2;
global_settings{
#if (use_rad)
radiosity{
// save settings: modified Outdoor settings from rad_def.inc
#if (use_rad=1)
brightness 1
count 1300
error_bound 1
gray_threshold 0.0
low_error_factor 0.6
minimum_reuse .015
nearest_count 5
recursion_limit 1
adc_bailout 0.05
max_sample -1.0
media off
normal on
always_sample 1
pretrace_start 0.08
pretrace_end 0.02
save_file "rad-save-load.rad"
#else
// load settings
pretrace_start 1 pretrace_end 1
load_file "rad-save-load.rad"
error_bound 1 // it's important to specify the same value used to save
data
recursion_limit 1 // also the same if specified
always_sample off // no more samples: specially useful with focal blur
Download 'mcintoshhdri4_800_600.jpg' (90 KB)
Preview of image 'mcintoshhdri4_800_600.jpg'
Marc Jacquier wrote:
> Hi folks,
> during the pretrace
> Marc
Nice version too. It seem that you remove the bump and changed the
texture of the table...
> Hi folks,
I must say i like the old version better. The wood pattern looks
somewhat strange in this one.
Your comment says it is important to use the same error_bound when
taking and reusing radiosity data - this is not necessarily the case
(and to avoid taking too many additional samples in the final trace it
makes sense to use a higher value there.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Dude, that is too cool...
Subject: Re: McIntosh in the Kitchen new version
Date: 30 Sep 2004 14:58:16
Message: <415c5748@news.povray.org>
I think the same about the wooden tecxture. It will be better to say
"mackintosh in the barn"
The rest is very great as usually with your posts Marc.
rémy
"Marc Jacquier" <nos### [at] wanadoo fr> a écrit dans le message de
news:415bbd67@news.povray.org...
> Hi folks,
to
filaments
> during the pretrace
directly
> Marc
> #declare use_rad=2;
> global_settings{
> #if (use_rad)
> radiosity{
> #if (use_rad=1)
> brightness 1
> count 1300
> error_bound 1
> gray_threshold 0.0
> minimum_reuse .015
> nearest_count 5
> recursion_limit 1
> adc_bailout 0.05
> max_sample -1.0
> media off
> normal on
> always_sample 1
> pretrace_start 0.08
> pretrace_end 0.02
> #else
> // load settings
save
> data
blur
> #end
> #end
Date: 30 Sep 2004 16:07:59
Message: <415c679f@news.povray.org>
Yeah, that's very good. Congratulations!!!!!
Best regards,
Oleguer
"Remy Closset" <rem### [at] tiscali fr> escribió en el mensaje
news:415c5748@news.povray.org...
> rémy
de
> > Hi folks,
> to
> filaments
> > during the pretrace
> directly
> > Marc
> > #declare use_rad=2;
> > global_settings{
> > #if (use_rad)
> > radiosity{
> > #if (use_rad=1)
> > brightness 1
> > count 1300
> > error_bound 1
> > gray_threshold 0.0
> > minimum_reuse .015
> > nearest_count 5
> > recursion_limit 1
> > adc_bailout 0.05
> > max_sample -1.0
> > media off
> > normal on
> > always_sample 1
> > pretrace_start 0.08
> > pretrace_end 0.02
> > #else
> > // load settings
> save
> > data
> blur
> > #end
> > #end
Date: 2 Oct 2004 06:40:32
Message: <415e85a0@news.povray.org>
"Christoph Hormann" <chr### [at] gmx de> a écrit dans le message de news:
cjgv55$apn$1@chho.imagico.de...
Well I am trying to improve that
Thanks, I still feel dumb in front of radiosity parameters, btw it is not my
comment but Jaime's comment, as I copy/pasted his code and fiddled with
values.
Marc
"Andrew the Orchid" <voi### [at] dev null> a écrit dans le message de news:
415c4bc4$1@news.povray.org...
Thank you
Marc
"Remy Closset" <rem### [at] tiscali fr> a écrit dans le message de news:
> rémy
Thank You Remy, I'll change this fuc4!ng table, LOL
Marc
Date: 2 Oct 2004 16:26:42
Message: <415f0f02@news.povray.org>
"LightBeam" <s.f### [at] tiscali fr> a écrit dans le message de news:
415bf059$1@news.povray.org...
> Nice version too.
Oh thanks, I missed your post
Yes indeed :)
Marc
