POV-Ray : Newsgroups : povray.binaries.images : Worn wood block (119kb jpeg) Server Time
15 Oct 2026 02:50:22 EDT (-0400)
  Worn wood block (119kb jpeg) (Message 1 to 15 of 15)
Subject: Worn wood block (119kb jpeg)
Date: 20 Aug 2004 23:58:45
Message: <4126C81A.6060907@hotmail.com>
Hello everyone! Thought I might as well post this one....
It's a wooden block made from six intersecting height_fields. The
texture  uses a proximity pattern derived from an averaged, randomly
translated object pigment of the same wood block. The proximity pattern
is like a blurred version of the object in 3d space; it can be used to
make physical edges appear chipped and scuffed through texture_mapping.
Questions and comments are always welcome~
-Sam
Download 'block.jpg' (119 KB)
Preview of image 'block.jpg'
Subject: Re: Worn wood block (119kb jpeg)
Date: 21 Aug 2004 02:59:57
Message: <4126f2ed@news.povray.org>
That's really awesome. I'm not sure I understand the proximity pattern bit.
Did you take an object pattern and then distort it with noise, and then use
a texture map based on that?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Aug 2004 03:22:15
Message: <4126f827@news.povray.org>
Brilliant!  After consulting the docs and rereading your post a few times...
I think I can grasp the concepts here.  Please do elaborate for us or post
the source.  The object pigment is being distorted and blurred and then
applied to the original shape to produce the affect right?  Its not the
height_field input itself being blurred and translated.  This should work on
meshes too, as long as they are solid/closed, right?
Skip
Date: 21 Aug 2004 08:01:41
Message: <412739a5$1@news.povray.org>
Yes, please post these.  :-)   My only suggestion on how to beautify this
image, would be to increase the camera "angle" because it almost looks
orthographic...
Hugo
Date: 21 Aug 2004 10:38:33
Message: <41275e69$1@news.povray.org>
> -Sam
Wow! This is awesome :)
George Pantazopoulos
http://www.gammaburst.net
Date: 21 Aug 2004 14:17:23
Message: <412791b3$1@news.povray.org>
Awesome. :-)
Date: 21 Aug 2004 16:35:56
Message: <4127B209.4020105@hotmail.com>
Skip Talbot wrote:
> Brilliant!
Thanks!
> the source.
I think a source posting is in order here.... I need to make a simpler
example that will work as a spring board for ideas.
The object pattern is blurred by averaging it with a pigment_map. Each
copy of the pigment is translated randomly. No distortion is performed,
but can be if needed. The resulting 3d texture can then be placed inside
a pigment_pattern{} block whenever I need it (typically pigment, normal
and texture staments).
 > Its not the height_field input itself being blurred and translated.
Nope.
> This should work on
> Skip
It works with *any* object you can declare.
-Sam
Date: 21 Aug 2004 16:36:59
Message: <4127B24A.2010903@hotmail.com>
Thank you.
Sort of.... see my reply to Skip.
-Sam
Date: 21 Aug 2004 16:38:01
Message: <4127B287.5050400@hotmail.com>
> orthographic...
I realized this... Sometimes the numbers can be a little touchy :)
-Sam
Date: 21 Aug 2004 16:38:23
Message: <4127B29E.6060706@hotmail.com>
George Pantazopoulos wrote:
> Samuel Benge wrote:
<snip>>>
Thanks ;)
-Sam
Date: 21 Aug 2004 16:38:33
Message: <4127B2A7.7080100@hotmail.com>
Darren New wrote:
> Awesome. :-)
Date: 21 Aug 2004 22:16:19
Message: <412801f3$1@news.povray.org>
Very interesting! Even the ground looks nice :)
Congrats,
Fernando
Date: 21 Aug 2004 23:57:24
Message: <41281982.9080806@hotmail.com>
> Congrats,
> Fernando
Thanks Fernando! The ground simply has a granite pigment and normal with
a few modifiers added.
-Sam
Date: 22 Aug 2004 11:39:06
Message: <4128be1a$1@news.povray.org>
> -Sam
Gawd I just got throught clapping my hands for Slime.  My arms are
getting tired.  That is an impressive effect and not the first time
you've taken and unexpected approach.  I have been trying to get similar
effects myself on my carving models.
Date: 22 Aug 2004 12:26:23
Message: <4128C90B.1020406@hotmail.com>
Thanks... I've got more coming. I might release some code today. I found
a very unfortunate feature while testing this code last night: the more
objects the feature uses, the slower everything becomes. I didn't expect
it to get as slow as it does... I guess using Round_Box_Union from
shapes.inc is out of the question for now....
-Sam
