Modelling and texturing study. Usual drill, Wings mesh, procedural
textures.
The mask actually has more parts to be added. Some metal hammered on the
front. It is of Western Sahara design. Bamana. I think I need to vary
the finish somehow.
Download 'img.10048.jpg' (24 KB)
Preview of image 'img.10048.jpg'
is it suposed to look like leather tightly wrapped on wood? or is it
supposed to be wood? the shine doesn't look right for wood that might be
really old. however it all looks pretty authentic.
Bare Wood. The problem is the normal I believe. It needs much more
irregular detail and crisper edges. I think a little variety in the
finish would also help. I thought I would just settle for a slightly
burnished patina on this cut before I spent the rest of my lifetime on it ;)
Even when examining the masks in the museum, I is often hard to tell if
it is covered in skin as you mention. Usually the peeling away around
the eyes is the only way to decide for sure. Then there is the various
layers of pigment, dirt etc. The photo reference I am using for this
one leaves no doubt that it is bare chiselled wood that has become
burnished with wear. But I could find nothing quite like it in the
museum to observe for real.
Fantastic, though it doesn't look like wood, but rather like very realistic
natural clay (still wet, perhaps). Very good.
Jim Charter nous apporta ses lumieres ainsi en ce 19/07/2004 14:46... :
> textures.
> the front. It is of Western Sahara design. Bamana. I think I need
> to vary the finish somehow.
Looks like wood for me. Some varieties, like ebony, do take such a
finish when polished with almost undistinguable grain. A litle light for
ebony tough, as ebony is almost black.
> it ;)
I would expect this to be a very hard wood, but your specular highlights
are too soft, more like a laquer. Try a very high phong_size to make it
harder. When I have worked with old wood that has that deeply burnished
worn-in shine, the specular highlights are very tight, often changing
with every line in the grain.
Very nice image though, great modeling.
RG
>> it ;)
>> if it is covered in skin as you mention. Usually the peeling away
>> around the eyes is the only way to decide for sure. Then there is the
>> various layers of pigment, dirt etc. The photo reference I am using
>> for this one leaves no doubt that it is bare chiselled wood that has
>> become burnished with wear. But I could find nothing quite like it in
>> the museum to observe for real.
> RG
Thanks. Yes you got the problem. The thing is, in order to raise the
specular and reduce the roughness keyword, and still get the desired
appearance, I think I need to increase the actual micro roughness of the
surface in order spread out the highlight, else it looks a little too
shiny and molten. The surface of the wood has a gentle scalloping and a
lot of random knicks like it was worked with a draw knife .
> textures.
> the finish somehow.
My mother and step-father collect these (only fakes). Their bedroom is
done in a safari theme. Elephants painted on the walls, African masks
and art, electric torches, etc.. This woman is up for a (National
Association of Home Builders) Prism award, and this is how she decorates
her bedroom. Your quiet render looks so mysterious and interesting (as
opposed to tacky) in comparison.
The mask material looks excellent to me. That is the same weird material
I run into occasionally that even on close inspection can only *just* be
identified as "some kind of wood". Maybe the finish is correct, but the
light source is too bright in relation to whatever "global" light is
present??? I've never seen one of these under a spotlight.
The model looks off to me where the ear attachers to the head. Is the
ear nailed on or carved into the mask?
-Shay
Shay wrote:
>> textures.
> -Shay
Yes the kitsch market in African masks is quite discouraging. I can
walk down West Broadway in the Soho area, (once the cradle of the Int'l
Art scene here in the sixties and seventies, now gone to seed and the
playland of Eurotrash, B&T's, and touristos ) and have my pick of little
African figurines etc. That and the fact that a genuine article would
still be a colonial product quite likely. That is why I cycle back to
this subject matter after long absenses. As you say, there is some
emotive potential that gets overlooked. And my time in Columbus OH
instilled some fledgling appreciation for folk art. For me, all of
this has to do with notions of sentience which, it stricks me, is the
grand design of CG anyway.
Yes, working from a photo reference is very deceiving. You don't know
what is the effect of lighting, what is the effect of the actual
material, and what is the effect of the photofinishing. I know for a
fact that the photos I am working from (Hamill Gallery in Boston) are
sometimes overexposed in order to show up detail but with the result of
completely distorting the color. For the sake of the current exercise I
will see how close I can get to certain aspects of the photo. Then
adjust from there. When I am done with this one I will link the photo
reference, though it wouldn't be hard to find. As I stated elsewhere I
still need to stick a bunch of metal on the face.
Yes the ear needs work on its modelling. All the joints are problematic
because in reality the edges are not clean. They are carved fairly
crudely, and are all of a piece. But the very regular filleting that
the mesh smoothing algorithm gives does not capture the look. It is too
regular and metallic looking. Instead, although the trasition is not
very sharp, the look is more angular and inconsistent. In many places
the carved faceting of the surface can be sensed. But if you let the
faceting of the polygons suggest this, it just looks like polygons. If
you use a scalloped crackle normal, it looks like a crackle normal, and
doesn't follow the logic of the shape.
I am having some thoughts about do these as iso's and applying the
textures for real. But I am doing the experimenting with mesh and
procedurals.
Having fun. Keeps me out of traffic.
Jim Charter a exposé le 19/07/2004 :
> Modelling and texturing study. Usual drill, Wings mesh, procedural textures.
> front. It is of Western Sahara design. Bamana. I think I need to vary the
> finish somehow.
Very good !!!! perhaps a little to shiny, but the modeling is perfect
Dark Skull Software
http://www.darkskull.net
A+
