POV-Ray : Newsgroups : povray.binaries.images : Bad antialiasing? Lower values problem [tiny jpeg] Server Time
30 Nov 2026 01:07:44 EST (-0500)
  Bad antialiasing? Lower values problem [tiny jpeg] (Message 1 to 11 of 11)
Subject: Bad antialiasing? Lower values problem [tiny jpeg]
Date: 14 Jul 2004 14:17:20
Message: <40f578b0$1@news.povray.org>
In the image you'll see a glassy blob object with a gray background plane. I
tried sky_sphere and background {}, with similar results, if the AA
threshold is 0.1 or lower. AA values typed onto the two examples. Once the
AA value is high enough the blocky artifact will disappear. Apparently gamma
related somehow.
Curiously, I hadn't noticed such a thing happen before. At first I thought
it was my LCD screen, working at no more than 18-bit color, or maybe the
video driver. Anyone else want to try confirming this as a possible problem?
Bob H.
A simpler SDL for testing is:
global_settings { assumed_gamma 1 } // no correction, no artifact?
camera { location -3*z }
light_source { -100*z, 1 rotate <45,45,0> }
background { 0.5 }
sphere { 0, 1 pigment { rgb 1 } }
/* be sure to use AA of 0.05 or thereabouts to see the affect */
Download 'bad_aa.jpg' (14 KB)
Preview of image 'bad_aa.jpg'
Subject: Re: Bad antialiasing? Lower values problem [tiny jpeg]
Date: 14 Jul 2004 14:31:29
Message: <40f57c01@news.povray.org>
In article <40f578b0$1@news.povray.org> , "Hughes, B."
> related somehow.
If you post an image to show artifacts, you should really not use a lossy
image format.  Please post this again as PNG, with JPEG it is impossible to
tell what you are talking about and what are just JPEG artifacts.
If possible, please mark the problem in the image as well.
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Jul 2004 15:41:43
Message: <40f58c77$1@news.povray.org>
"Hughes, B." <bob### [at] charternet> wrote in message
news:40f578b0$1@news.povray.org...
I
gamma
> related somehow.
problem?
> Bob H.
i just noticed the effect monday i think. though i didn't notice that
assumed_gamma was part to of it. also, i've only noticed that it happens
with +AM1 and not +AM2. there seemed to be a definate range of +A0.0x
settings that it occured in, and the size of the artifacts changed based on
the value for +A. i can't remember exactly off the top of my head, but it
was something like +A0.3 to +A0.0000897 or something crazy.
i was also using a sky_sphere. this was on the official 3.6 linux binary
version of pov.
-ross
Date: 14 Jul 2004 15:52:28
Message: <40f58efc$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:40f57c01@news.povray.org...
plane. I
the
gamma
> > related somehow.
to
>     Thorsten
having experienced this (or very similar) anomoly i can tell you that the
light grey area on the right and lower right is the artifact. my image also
had a lighter area to the right of an object which went away with different
+A value and or by setting +AM2
hope this helps a little.
Date: 14 Jul 2004 21:37:05
Message: <40f5dfc1@news.povray.org>
I've seen this myself, and also determined that it's related to
anti-aliasing. Especially the way that the problem extends to the right and
down indicates that it's related to AA.
However, that same fact makes me wonder: do these artifacts actually appear
on the outputted image, or only on the display screen?
Have you posted screenshots of the display window or the actual output?
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Bad antialiasing? [tiny png]
Date: 14 Jul 2004 23:49:57
Message: <40f5fee5@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:40f5dfc1@news.povray.org...
>8---8<
Rendered image files, which were pasted together into a single picture.
Here's a png of the simpler example, marked in red showing where the
blockiness appears always toward bottom right directions. AA options were
+a0.05 +am1 +j1.0 used. Contrast enhanced to make it show up better. And
yes, Ross is right, AA method 2 seems to be okay.
The original rendered file attached, also. All these images began as PNG, I
hadn't tried other formats until just now and see that it doesn't change the
artifact.
Bob H.
Download 'aa-gamma_artifact.png' (21 KB) Download 'aa_gamma-original.png' (8 KB)
Preview of image 'aa-gamma_artifact.png'
Preview of image 'aa_gamma-original.png'
Date: 15 Jul 2004 08:31:52
Message: <40f67938$1@news.povray.org>
>>8---8<
> artifact.
> Bob H.
Confirmed. It doesn't appear in 3.5, but does in 3.6, In fact.. when I
changed assumed gamma to 2.2, I could still see vestiges of the artifact.
I have to wonder if it has something to do with the change to do the
clipping after antialiasing ...
~Mike
Date: 15 Jul 2004 17:19:57
Message: <40f6f4fd@news.povray.org>
"Hughes, B." <bob### [at] charternet> schreef in bericht
news:40f5fee5@news.povray.org...
| >8---8<
| artifact.
| Bob H.
I'm using 3.6. I see no artifacts when I render it. -AA, +AA0.01, +AA0.05,
+AA0.3, +AA1, +AA10. All look okay, with no artefacts. I also tried the
settings you suggested (+A0.05 +AM1 +J1.0) no problemo :-\
Maurice
Date: 15 Jul 2004 18:24:31
Message: <40f7041f$1@news.povray.org>
"SomeOne" <ask### [at] yahoocouknospam> wrote in message
news:40f6f4fd@news.povray.org...
> | >8---8<
output?
were
PNG, I
the
> | artifact.
> | Bob H.
using what scene? were there a sky_sphere{...} or background{...} blocks?
Date: 16 Jul 2004 11:55:39
Message: <40f7fa7b$1@news.povray.org>
I used the scene provided in the original posting with no modifications.
"Ross" <rli### [at] everestkcnet> schreef in bericht
news:40f7041f$1@news.povray.org...
| > | >8---8<
| output?
| were
| PNG, I
| the
| > | artifact.
| > | Bob H.
Date: 16 Jul 2004 14:51:06
Message: <40f8239a$1@news.povray.org>
Same here in WinXP and 3.6 using your scene. Setting +a0.1246732808649
is a some sort of a boundary. Increasing aa makes the blocks disapear.
Also changing assumed_gamma higher than 1.0 helps.
-r
