POV-Ray : Newsgroups : povray.binaries.images : YALOTW Server Time
30 Nov 2026 01:07:40 EST (-0500)
  YALOTW (Message 1 to 11 of 11)
Subject: YALOTW
Date: 5 Jul 2004 12:53:50
Message: <40e9879e@news.povray.org>
my latest landscape, with vegetation this time ! :)
here are some statistics:
Triangles in one tree = 39492
4799 trees placed
height_field resolution: 3000*3000
Scene Statistics
  Finite objects:         4800
  Infinite objects:         18
  Light sources:             4
  Total:                  4822
Render Statistics
Image Resolution 800 x 600
Pixels:           510800   Samples:          924968   Smpls/Pxl: 1.81
Rays:            4141341   Saved:              3438   Max Level: 18/60
Ray->Shape Intersection          Tests       Succeeded  Percentage
Height Field                 102343896        15936575     15.57
Height Field Box             102343896       102237745     99.90
Height Field Triangle        288604284        16200433      5.61
Height Field Block           813843389       199128248     24.47
Height Field Cell           4778221068       153077426      3.20
Mesh                          74269244        35099963     47.26
Plane                        789249829        26707831      3.38
Sphere                      4078999410      2437258701     59.75
Bounding Box               12105860767      4327709585     35.75
Vista Buffer                  37400687        30267683     80.93
Function VM calls:         35552961
Calls to Noise:          2776439321   Calls to DNoise:      2283160132
Media Intervals:            3381581   Media Samples:           4240049 (1.25)
Shadow Ray Tests:         307244003   Succeeded:             240736548
Reflected Rays:              108479
Refracted Rays:               71539
Transmitted Rays:           3036355
Smallest Alloc:                  17 bytes
Largest  Alloc:             4718608 bytes
Peak memory used:         144730525 bytes
Total Scene Processing Times
  Parse Time:    0 hours  3 minutes 26 seconds (206 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   1 hours 50 minutes 26 seconds (6626 seconds)
  Total Time:    1 hours 53 minutes 52 seconds (6832 seconds)
CPU time used: kernel 56.38 seconds, user 6654.36 seconds, total 6710.73 seconds
Render averaged 71.53 PPS over 480000 pixels
on an Athlon XP 2500+ with 1GB dual channel DDR-SDRAM (333MHz), running Windows
XP
comments are very welcome! :)
cu!
Download 'ls-o.jpg' (85 KB)
Preview of image 'ls-o.jpg'
Subject: Re: YALOTW
Date: 5 Jul 2004 14:47:24
Message: <40e9a23c$1@news.povray.org>
   Great sense of depth. The "lake" looks fantastic, and the mountains
are much better now (less prehistoric ;). The work with the height_field
is very good.
   Only the clouds detract a bit due to the blur (is that an image map
with interpolation?), although they look good anyhow.
Jaime
Subject: Re: YALOTW
Date: 5 Jul 2004 15:12:13
Message: <40e9a80d$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:40e9a23c$1@news.povray.org...
> is very good.
thank you :)
no it's the stackered-sphere technique :)  There is a Clouds_Sharpness
parameter, but I can't seem to give it sharp edges without losing the
'fluffy-ness' clouds have... :-/
Maybe I need media, but that seems to be slower :(
anyway, I'll get there, eventually, I hope... :)
cu!
Subject: Re: YALOTW
Date: 5 Jul 2004 18:36:45
Message: <40e9d7fd$1@news.povray.org>
That's great looking!
I hope you share the source :p
Maybe you have to much ambient light ?
the shadows do not have that much constrast.
Best,
    S.
Steven Pigeon, Ph. D.
ste### [at] stevenpigeoncom
ste### [at] videotronca
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:40e9879e@news.povray.org...
> 4799 trees placed
> Scene Statistics
>   Light sources:             4
>   Total:                  4822
> Render Statistics
(1.25)
seconds
Windows
> XP
> cu!
> camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local
C=0
> ;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local
C=C+1
> ;#end#end
L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
> <.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)               // ZK
http://www.povplace.be.tf
Subject: Re: YALOTW
Date: 5 Jul 2004 18:43:44
Message: <40e9d9a0@news.povray.org>
"Steven Pigeon" <pig### [at] iroumontrealca> wrote in message
news:40e9d7fd$1@news.povray.org...
thank you :)
I plan to :)
there's no ambient light, but the sky-light_source and the fog might make it
look like there is an ambient factor
I know, more contrast is on my todo-list :)
cu!
Subject: Re: YALOTW
Date: 8 Jul 2004 12:19:45
Message: <40ed7421@news.povray.org>
Looks great.
Maybe the mountains are a bit dark (I mean tweaking light direction)
and the foreground gets a little blurred (less structured).
But I definitely like the trees in the valley.
Wolfgang
Subject: Re: YALOTW
Date: 8 Jul 2004 18:15:00
Message: <web.40edc6685ce1d578188ea9e80@news.povray.org>
That is so fantastic that I hate to be picky, but, well. . . .
On a lake, you usually only get foam on one side of the lake (the downwind
side.)  Coming from a place with lots of lakes and lots of wind, I've
noticed this ;-)
Dave Matthews (from western Minnesota)
Subject: Re: YALOTW
Date: 8 Jul 2004 19:57:07
Message: <40eddf53@news.povray.org>
"Dave Matthews" <dma### [at] wrmnwestmnscuedu> wrote in message
news:web.40edc6685ce1d578188ea9e80@news.povray.org...
> noticed this ;-)
Really? I didn't know that!  Shouldn't be too hard to fix this :)
thank you!
cu!
Subject: Re: YALOTW
Date: 8 Jul 2004 20:18:41
Message: <40ede461@news.povray.org>
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:40ed7421@news.povray.org...
> Looks great.
thank you! :)
fixed ! (see http://sad.nostalg1c.org/pov/landschap/ls-p.jpg )
that's just a matter of height_field resolution :)
tnx :)
cu!
Subject: Re: YALOTW
Date: 9 Jul 2004 05:38:42
Message: <40ee67a2$1@news.povray.org>
Hey man, like, WOW!
Subject: Re: YALOTW
Date: 9 Jul 2004 05:55:52
Message: <mn.4acb7d47afaabea5.14125@please.com>
Great !!!!!!!!!!!!!!!!
I love the trees !!!!!
Dark Skull Software
http://www.darkskull.net
A+
