POV-Ray : Newsgroups : povray.binaries.images : shoes on the patio Server Time
30 Nov 2026 01:07:43 EST (-0500)
  shoes on the patio (Message 1 to 3 of 3)
Subject: shoes on the patio
Date: 4 Jul 2004 00:01:12
Message: <40e78108@news.povray.org>
Using Jaime's new pseudo hdri #includes pretty much out of the box.
His image: sm_jvp_patio-2.jpg provides the background
Download 'upload1.jpg' (32 KB)
Preview of image 'upload1.jpg'
Subject: Re: shoes on the patio
Date: 4 Jul 2004 05:33:38
Message: <40e7cef2$1@news.povray.org>
   Hmmm... this technique gives better results with very reflective
textures. I think your shoes are more suited for a clasical setup with
area lights and moderate rad settings. You can also use a mixed setup,
creating the spherical map from a scene where you know the lights
placement (I've not tried this yet...).
Jaime
Date: 4 Jul 2004 11:54:53
Message: <40e8284d@news.povray.org>
Yes I expect you are right, partially reflective surfaces are poor
performers with radiosity, obviously, because you don't have the
specular component to help show the texture.  So far, I see that low
reflectivity will still show up the normal, if the hotspot sources are
directional enough.  HRI obviously gives so encompassing a stimulus that
the texture gets washed out. That is a vexing thing because the gentle
shading you can get is hard to give up on.  With a few, very directed
hotspots, the sense of shadowing then gets a little doubtful, perhaps.
Add too all of this the fact that the optical behavior of finished
leather is an elusive thing even when you are holding the actual leather
in your hand!  Of course the other side to that coin is that leather
comes in such a wide variety of textures.  Something I would exploit in
my paintings.  Suede was far and away the easiest texture to paint.  If
the show was really glazed calf, but everyone thought I'd done a
beautiful job portraying suede,...I took it!  But raytracing is not
painting.
Yes, in fact I was doing extensive testing of just that, and had pretty
much given up on HDRI until I could understand the effects of
directionality better.  But since you published your stuff I took a
little detour ;)  I needed a rest from looking at my little test losenge
shape anyway, lol.  I was interested the way you had made the image
pigment a function then applied the poly_wave.   I was testing with
something much more crude but along similar lines perhaps.  I guess I
was trying to determine how complex the stimulus could get before
loosing the effect of normal textures on the subject.
#local NumLights = 8;
#declare BgColor =
pigment { average
   pigment_map {
     #local A=0; #while(A<NumLights)
       #local IntensityFactor = 25+25*rand(S);
       #local F = rand(S);
       #local CVect = <(.4+F*.6),(.1+F*.6),(.5+(1-F)*.5)>;
       #local RVect = <30+(.5-rand(S))*90,0,(.5-rand(S))*90>;
       [ 1 cylindrical
	rotate <RVect.x, RVect.y, RVect.z>
         poly_wave IntensityFactor
         pigment_map{
           [0 rgb 0]
           [1 rgb CVector*IntensityFactor]
     #local A=A+1;#end
#declare BgFinish = "ambient 5 diffuse 1"
sphere { 0, 1 hollow
             clipped_by { plane { -y, -.2 } }
             pigment { BgColor }
             finish { Parse_String ( BgFinish ) }
             scale 2000
I was also testing with area lights in the hot spots as you meantion.
But nothing too exciting has emerged so far.
