POV folks:
Here is the latest iteration on my limes still life. I have incorporated
the suggestions that I got from the last couple of postings into this one.
The limes are a better color and shape, although the shape is not perfect.
I toned down the vivid red in the ceramic pot. I think I'm making some
progress ...
Download 'pov_limes_03.jpg' (54 KB)
Preview of image 'pov_limes_03.jpg'
Subject: Re: Still Life with Limes III (WIP)
Date: 31 May 2004 07:22:35
Message: <40bb157b@news.povray.org>
Program ended abnormally on 31/05/2004 07:06, Due to a catastrophic Aaron
Gillies error:
> POV folks:
> progress ...
Yummy!
That new texture for the lime is much better. If you pardon the nitpick, the
specular spot looks square - meaning the light is coming from a window - IMHO, I
think the surroundings shouldn't be completely black.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
Much better. Promising.
Great. Now just a "knob" on each end and some more "normal" to the skin.
"Aaron Gillies" <zap### [at] yow com> wrote in message
news:40bb11b6@news.povray.org...
> POV folks:
> progress ...
Aaron Gillies wrote:
Much improved. To be honest, I just don't get how you were having so much
trouble with the limes when the rest of the textures looked so nice.
I'm seeing stage spotlight rather than "Renaissance glow", however. Maybe my
monitor is too dark. Nothing wrong with the spotlight look anyway. Just
commenting on your earlier comment regarding glow.
-Shay
<snip>
To me, the limes do not seem to be touching the bottom of the bowl. If you
"trace" the level of the surface in this picture, and assume that the
thickness of the bottom of the bowl is about the same as the thickness of
the rim, they seem to be floating.
Cheers,
Peter
I actually just did a test render of the limes and the glass inner bowl and
the limes are actually touching the interior base. Must be a combo of the
camera angle and the outer bowl that makes it look like that ...
Thanks for the comments, guys. I guess I still have some work to do with
the total illumination of the scene. My home monitor is just about to give
out, so I'm not sure that the brightness and contrast levels are exactly how
you see them on well-calibrated screens.
Date: 31 May 2004 14:41:30
Message: <40bb7c5a@news.povray.org>
Not really following this thread closely... but this latest post looks
really very realistic. Nice work.
Andrew @ home.
> POV folks:
> progress ...
This is looking really good. For the composition of the piece I'm wondering
if you've cropped it to close at the top?
If there was a bit more 'empty space' above the limes, it might give a more
natural feel to the picture. Something to try out maybe.
> POV folks:
> progress ...
much better limes. the floor texture looks like it has less of a normal this
time. I like the version 2 floor better. maybe it's due to the change i
camera placement though.
I wonder how you could make the shadows of the limes to be the complimentary
color, like cezanne did so often in his still lifes.
Ross Litscher nous apporta ses lumieres ainsi en ce 2004/06/01 06:55... :
>>POV folks:
>>progress ...
A light_source with the projected_through property. Make a second
no_image copy of your object, flaten it perpendicular to the light,
locate it a bit behind the main object and have the project_through
light coincide with your primary light. Give that light the colour you
want for the shadow, like bright red.
Hmmm .... I changed the finish on the floor to be less reflective, because I
increased the intensity of one of the light sources and it made the floor
too "noticeable." I'll try to see what else I can do ...
As far as the Cezanne effect goes ... I am doing on variation on this, but
not with complimentary colors. One light source is yellow and the other is
blue ... The blue provides the "cooler" illumination in the shadow, but I
suppose something like this could be reversed ... It's very subtle, but
serves to "round out" the image in a way.
Aaron
this
complimentary
"Alain" <aze### [at] qwerty gov> wrote in message
news:40bd03a7@news.povray.org...
> >>POV folks:
incorporated
one.
perfect.
> >>progress ...
this
complimentary
> Alain
cool. i've never played with those features. thanks for the tip. i'm not
sure why you have to flatten the no_image copy. i guess i'll wait and see
when i get home :)
can multiple "projected_through { OBJECT }" statements be inside a
light_source, or would i have to declare a union {...} around all the
objects i want to use? Also, i'm curious why no_image is neccesary (again,
i've never used it). projected_through documentation states, "Any textures
or interiors on the object will be stripped and the object will not show up
in the scene."
of course, this all may become obvious later when i try it out.
Ross nous apporta ses lumieres ainsi en ce 2004/06/02 12:40... :
>>>>POV folks:
>incorporated
>one.
>perfect.
>>>>progress ...
>this
>complimentary
>>Alain
>when i get home :)
>light_source,
don't know... but
Puting all objects in an union will make it simpler for you, less
chances to make errors. It can also reduce memory use.
>in the scene."
OK, I forgot about that bit of information. So, you don't need to add
the "no_image" as it's added by the projected_through.
If you don't flaten the object, it can cause the projected_through light
to shine on some part of the visible object if those are behind any part
of the one used to do the projection. You may also keep only those
components that are the most away from the light_source.
