POV-Ray : Newsgroups : povray.binaries.images : Lighthouse new version Server Time
30 Nov 2026 02:03:38 EST (-0500)
  Lighthouse new version (Message 1 to 22 of 22)
Subject: Lighthouse new version
Date: 15 May 2004 11:37:50
Message: <40a6394e@news.povray.org>
For the foam I gave up  the object pattern trick because it is boolean and
not good at close-up
I tweaked a function based on the same image as the isosurface terrain.
This function fills the crackle pattern at hi values and let it empty at low
values.
As usual comments are welcome :-)
Marc
Download 'St_Mathieu.jpg' (110 KB)
Preview of image 'St_Mathieu.jpg'
Subject: Re: Lighthouse new version
Date: 15 May 2004 12:20:58
Message: <40a6436a$1@news.povray.org>
Marc Jacquier nous apporta ses lumieres ainsi en ce 2004/05/15 11:39... :
>values.
>Marc
Big improvement, a lot more realistic. Your water is great. Time to
concentrate on the ground.
Date: 15 May 2004 12:48:08
Message: <40a649c8$1@news.povray.org>
"Alain" <aze### [at] qwertygov> a écrit dans le message de news:
40a6436a$1@news.povray.org...
>Time to  concentrate on the ground.
It's in the *to do* next items :)
Marc
Date: 15 May 2004 13:04:19
Message: <40a64d93@news.povray.org>
That's the best sea I've seen anywhere - well done.
Mick
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:40a6394e@news.povray.org...
low
> values.
> Marc
Date: 15 May 2004 13:17:54
Message: <40a650c2@news.povray.org>
    Hi Marc, that's excellent! Great sea. I would have a go at adding
just a little hint of 'off-yellow', or 'cream' colour, if you will, to
*some* of your surf.
   ~Steve~
> Marc
Date: 15 May 2004 13:20:27
Message: <40a6515b$1@news.povray.org>
I also like the translucency of the waves just behind the surf. Spot
on!   :)
 ~Steve~
Date: 15 May 2004 13:36:04
Message: <40a65504@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> a écrit dans le message de
news: 40a64d93@news.povray.org...
Me flush
thanks Master
Marc
Date: 15 May 2004 13:44:55
Message: <40a65717@news.povray.org>
"St." <dot### [at] dotcom> a écrit dans le message de news:
40a650c2@news.povray.org...
Thanks
Good idea for the cream color at thickened zones of the foam (I think it
happens only when seawater is carrying plankton, though)
Marc
Date: 15 May 2004 15:55:47
Message: <40a675c3$1@news.povray.org>
40a6515b$1@news.povray.org...
> on!   :)
Hours in front of waves  waiting for the take off :)
Marc
Date: 15 May 2004 17:28:43
Message: <40a68b8b$1@news.povray.org>
> values.
> Marc
curiousity, how tall is a lighthouse typically ?
how tal are the walls around the field ?
do the two and the view angle look correct ?
stephen
Date: 15 May 2004 18:00:51
Message: <40a69313@news.povray.org>
> Me flush
> thanks Master
Are you cheating? Is the sea a photo?
Not the foam - that is obviously CG - but the sea looks suspiciously like a
photo of some sort.
Hugo
Date: 15 May 2004 18:23:49
Message: <40A69829.1050909@hotmail.com>
> values.
> Marc
Your image has some shocking realism present in it. The grass, though,
could use some improvement(IMO).
Is that ocean an isosurface? A height_field of that size might take up a
huge amount of memory...
Good work~
-Sam Benge
Date: 16 May 2004 02:53:38
Message: <40a70ff2$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> schreef in bericht
low
> values.
Impressive foam, Marc! Much better indeed than previous one. However, the
crackle pattern seems a little bit too angular to me...?
Date: 16 May 2004 04:15:38
Message: <40a7232a@news.povray.org>
"Hugo Asm" <hua### [at] post3teledk> a écrit dans le message de news:
40a69313@news.povray.org...
a
> photo of some sort.
> Regards,
> Hugo
LOL no thanks, the only bitmap in this scene is the one to generate the
terrain in an isosurface and the foam distribution.
The sea is an isosurface as well with combined unevenly scaled bozos (for
the swell) and f_ridged_mf function (for the ridges)
I'll post the code on p.b.s-f as soon as cleaned
Marc
Date: 16 May 2004 04:20:12
Message: <40a7243c$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> a écrit dans le message de news:
40A### [at] hotmailcom...
You're right grass is scheduled as "to do"
An isosurface of course
> Good work~
Thank you :-)
Marc
Date: 16 May 2004 04:24:29
Message: <40a7253d@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> a écrit dans le message de news:
40a70ff2$1@news.povray.org...
Thanks Tomas
Yes I think it needs to be scaled down a little and warp turbulence scaled
up so angles should vanish
MArc
Date: 16 May 2004 04:32:39
Message: <40a72727$1@news.povray.org>
"stephen parkinson" <ste### [at] zmemw16demoncouk> a écrit dans le message de
news: 40a68b8b$1@news.povray.org...
> stephen
This one is about 37m tall and the walls are about 0.5 to 1m.
Marc
Date: 16 May 2004 05:31:22
Message: <40a734ea$1@news.povray.org>
Master work!!!!
rémy closset
"Marc Jacquier" <jac### [at] wanadoofr> a écrit dans le message de
low
> values.
> Marc
Date: 16 May 2004 06:55:58
Message: <40a748be@news.povray.org>
"Remy Closset" <NOS### [at] tiscalifr> a écrit dans le message de
news: 40a734ea$1@news.povray.org...
> Master work!!!!
Thanks Remy, it is still a work in progress though :)
Marc
Date: 16 May 2004 14:07:35
Message: <40a7ade7@news.povray.org>
> the terrain in an isosurface and the foam distribution.
Heheh.. "You've been raytracing for too long when you begin to think CG look
like photos!"  ;o)
Thank you very much.
Hugo
Date: 16 May 2004 16:05:49
Message: <40a7c99d@news.povray.org>
> like photos!"  ;o)
"You've been playing FPS's too long when you go outside and marvel at
the parallax."
"You've been playing Quake too long when you go outside and see
cross-hairs."
"You've been playing Thief too long when you take a walk at night and
notice every streetlight shadow."
Date: 17 May 2004 04:51:32
Message: <40a87d14@news.povray.org>
40a7ade7@news.povray.org...
Done :)
Marc
