POV-Ray : Newsgroups : povray.binaries.images : Lighthouse Server Time
30 Nov 2026 02:03:38 EST (-0500)
  Lighthouse (Message 1 to 23 of 23)
Subject: Lighthouse
Date: 8 May 2004 07:22:47
Message: <409cc307@news.povray.org>
Hi!
an image I am working on with Moray>Pov
It's an existing lighthouse in Brittany
Photos here http://www.phareland.com/Mathieu.htm
I tried to make swell with an isosurface with combined bozo and f_ridged_mf
functions
I worked on backlit scattering in waves.
Foam is after Jaime's method but I'm not satisfied (not by the method but by
my use of it for close-up):
I wanted a sort of crackle pattern combined with turbulence to simulate
upwelling whirls close to rocks but I can't figure out how to implement it
in SDL
Comments,advices, critics are welcome a usual
Marc
Download 'Mathieu_houle001.jpg' (104 KB)
Preview of image 'Mathieu_houle001.jpg'
Subject: Re: Lighthouse
Date: 8 May 2004 07:34:48
Message: <409cc5d8$1@news.povray.org>
Excellent... Really nice work :-))
Date: 8 May 2004 07:36:48
Message: <Xns94E38A49E36DBraf256com@203.29.75.35>
jac### [at] wanadoofr news:409cc307@news.povray.org
> Hi!
wow grete see, how did You did it?
As for land/rocks... very nice, but... something is a bit wrong imho.. hmm
colors look a bit to flat IMHO... or like there was a median / oil paint
filter applied to texture
http://www.raf256.com/3d/
Computer Graphics
Date: 8 May 2004 07:37:21
Message: <Xns94E38A61AF125raf256com@203.29.75.35>
spa### [at] raf256com news:Xns94E38A49E36DBraf256com@203.29.75.35
sea
Computer Graphics
Date: 8 May 2004 07:40:24
Message: <409cc728@news.povray.org>
"LightBeam" <s.f### [at] tiscalifr> a écrit dans le message de news:
409cc5d8$1@news.povray.org...
Marc
Date: 8 May 2004 07:41:25
Message: <409cc765$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> a écrit dans le message de news:
Xns94E38A61AF125raf256com@203.29.75.35...
> sea
I'll post the  sea code on p.b.s-f as soon as I'm finished cleaning the code
Marc
Date: 8 May 2004 07:43:44
Message: <409cc7f0$1@news.povray.org>
Xns94E38A49E36DBraf256com@203.29.75.35...
 I quite agree: I meet some issue adding a normal pattern with a slope
pigmant pattern, I'm trying to find a workaround.
Maybe terrain will end as an isosurface as well
Marc
Date: 8 May 2004 08:17:54
Message: <409ccff2@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> a écrit dans le message de news:
409cc765$1@news.povray.org...
code
Done :)
Marc
Date: 8 May 2004 08:47:04
Message: <409cd6c8@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> schreef in bericht
news:409ccff2@news.povray.org...
news:
> code
> Done :)
Yipee!!!! Comes just in time for a scene I have in mind!!!!!  :-))
Otherwise, I like the picture, and I think the swell is well rendered.
Shouldn't the windphane on the lighthouse point landwards? Of course, the
wind may have changed, and waves are pretty conservative once they are in
motion :-0
What is particularly good is the green transparency in the background swell.
Date: 8 May 2004 10:45:00
Message: <kurtzlepirate-09EE8A.16445508052004@news.povray.org>
In article <409cc307@news.povray.org>,
  where to get infos of this method ??
  thanks
Date: 8 May 2004 11:23:51
Message: <409cfb87$1@news.povray.org>
"Kurts" <kur### [at] yahoofr> a écrit dans le message de news:
kurtzlepirate-09EE8A.16445508052004@news.povray.org...
>   thanks
I just quote Jaime's  april/29/2004 response in "My LOTW project" thread on
this group:
>    Casually, I'm just tweaking this texture. Now I simlified it a bit,
> removing the intersection. The same terrain itself translated a bit is
> enough. There is the relevant part:
>   #declare terrain_coast=object{terrain translate Foam_Level*y}
>   #declare m_water=
>   material{
>    texture{
>     pigment_pattern{object{terrain_coast rgb 0, rgb 1}}
>     texture_map{
>       [0 t_water]
>       [1 t_foam]
>     scale 100 warp{turbulence .3 lambda 3} scale 1/100
>     scale 1000 warp{turbulence .3 lambda 3} scale 1/1000
>    The translation amount depends on your scene scale and how much foam
> you want, and the same can be applied to the warps scale.
the trick is to use an object as pattern
either the calculated point is inside the object and the returned value is 1
or the point is outside and the value is 0
It is a boolean pattern
my complete code for the sea (including isosurface and material) is on the
p.b.s-f group
Marc
Date: 8 May 2004 11:35:06
Message: <409cfe2a@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> a écrit dans le message de news:
409cd6c8@news.povray.org...
I'm glad that can be usefull for somebody :-)
I look forward to see your scene.
> motion :-0
Or maybe the axle is solden by rust :-p
No seriousely I didn't think of that, thanks for noticing it. but it should
be pointing offshore as it is facing the wind.
swell.
Thanks I spent some time at tweaking the absorption and scattering colors
Marc
Date: 8 May 2004 11:54:22
Message: <409d02ae$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:409cfe2a@news.povray.org...
<snip>
should
Nah, those waves look as if they're being held up by an offshore breeze!
Dave.
Date: 8 May 2004 12:08:28
Message: <409d05fc$1@news.povray.org>
Marc Jacquier wrote:
> Hi!
> functions
> in SDL
> Marc
Holy sh*t. Excellent!!!
Respectfully,
Dan P
http://<broken link>
Date: 8 May 2004 13:04:54
Message: <409d1336$1@news.povray.org>
> functions
   Impressive! The waves shape and texture/interior is very natural looking.
   Well, the method isn't very good for close-up views. Perhaps it would
look a bit better with more transparency.
> in SDL
   That sounds *really* difficult to figure out... :)
Jaime
Date: 8 May 2004 13:35:02
Message: <c7j5h2$89b$1@chho.imagico.de>
> Hi!
I already saw this one in the french group, the waves look very nice but
they are not breaking of course although they should. :-)  The foam
could use some more structure, maybe some normal would be sufficient.
For the water shape a nonlinear scaling might be a good idea, the waves
should be very long at the coast but on the open sea they should be less
directed (it looks a bit strange at the horizon right now).  Or use two
functions and blend them.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 8 May 2004 13:35:41
Message: <409d1a6d@news.povray.org>
> Hi!
> functions
> in SDL
Ban for posting photos.
Okay, maybe not. But that water looks really good, and the lighting
works too.
-Xplo
Date: 9 May 2004 02:38:49
Message: <409dd1f9@news.povray.org>
news:
Patience! I just started on it! It will feature, by the way, also the ruined
bridge of Panta Rei, but more in the background...
should
Yes, of course! pointing offshore. That's what I mean. Just muddled up my
vocabulary.
Date: 9 May 2004 02:48:09
Message: <409dd429@news.povray.org>
Impressive!
The sea is excellent well done.
Mick
Date: 9 May 2004 04:00:55
Message: <409de537$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> a écrit dans le message de news:
409d05fc$1@news.povray.org...
LOL thanks :-)
Marc
Date: 9 May 2004 04:08:49
Message: <409de711@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> a écrit dans le message
de news: 409d1336$1@news.povray.org...
looking.
Thanks
I'm thinking  about blurring the edges with  several  randomly translated
and averaged instances of the pattern to return a distance dependent value
instead of a boolean
it
> > in SDL
I think of a function combination, still a lot of work !
Marc
Date: 9 May 2004 04:17:25
Message: <409de915$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> a écrit dans le message de news:
c7j5h2$89b$1@chho.imagico.de...
I agree, I'd like some shore break tubes (with foam of course!) but I'm not
a maths freak and can't figure out what kind of function could give that
>The foam  could use some more structure, maybe some normal would be
sufficient.
or more ridged_mf  everywhere...
I'll give it a try
Thanks
Marc
Date: 9 May 2004 04:18:49
Message: <409de969@news.povray.org>
"Xplo Eristotle" <xpl### [at] infomagicnet> a écrit dans le message de news:
409d1a6d@news.povray.org...
> works too.
Thank you
Marc
