POV-Ray : Newsgroups : povray.binaries.images : Two rings Server Time
15 Oct 2026 08:54:09 EDT (-0400)
  Two rings (Message 1 to 16 of 16)
Subject: Two rings
Date: 4 May 2004 17:36:58
Message: <40980cfa@news.povray.org>
Comments are welcomes...
Denis Bodor (aka Lefinnois)
"sudo kill -KILL -1  . . .   Le Kernel reconnaîtra les siens"
Download 'bague-14_800.jpg' (26 KB)
Preview of image 'bague-14_800.jpg'
Subject: Re: Two rings
Date: 4 May 2004 18:31:03
Message: <409819a7$1@news.povray.org>
Nice rings with well done shapes and textures, I like them :-))
Date: 4 May 2004 18:41:02
Message: <Xns94E06D2ED383raf256com@203.29.75.35>
lef### [at] lefinnoisnet news:40980cfa@news.povray.org
preciousssssssss
http://www.raf256.com/3d/
Computer Graphics
Date: 4 May 2004 20:12:51
Message: <40983183$1@news.povray.org>
Wow! Beautiful!
Just goes to show how even simple models can be stunning when you use
the right colors and reflections! :-)
Respectfully,
Dan P
http://<broken link>
Date: 4 May 2004 21:03:04
Message: <40983d48@news.povray.org>
Simple but beautiful. How did you model the rings? Isosurface? Quartic?
mesh?
Fernando
Date: 4 May 2004 23:34:45
Message: <409860d5@news.povray.org>
Very nice.  Have you tried upping the brilliance any?
Skip Talbot
Date: 5 May 2004 02:07:24
Message: <4098849c$1@news.povray.org>
> mesh?
Very simple, it's a scaled torus :)
Date: 5 May 2004 02:47:04
Message: <40988de8$1@news.povray.org>
Perfect and  eternal?
rémy
"Denis Bodor" <lef### [at] lefinnoisnet> a écrit dans le message de
news:40980cfa@news.povray.org...
Date: 5 May 2004 02:50:45
Message: <40988ec5@news.povray.org>
Awesome Rolex!! It has a very nice mood and the realism is stunning. I
suppose you've used HDRI for lighting? Pure rad and reflections?
The sky has a nice side-effect in this case...: It makes the rings look
almost as if they are shining; as if they have such a bright highlight, it
causes flares on the lens of the camera  = additional realism. You've been a
little lucky with that.
Hugo
Date: 5 May 2004 04:55:31
Message: <4098ac03@news.povray.org>
Very Nice, How'd you do the text?
Date: 5 May 2004 08:59:56
Message: <4098e54c@news.povray.org>
> preciousssssssss
Date: 5 May 2004 11:52:12
Message: <40990dac$1@news.povray.org>
HDRI of course
campus_probe.hdr from debevec's website, http://www.debevec.org/Probes/
highlight, it
been a
It took many try (textures, HDRI maps, lights) to get this result but,
yes, lucky i am :)
Denis Bodor
http://www.lefinnois.net                      Irc : Lefinnois
Date: 5 May 2004 12:01:24
Message: <40990fd4@news.povray.org>
Lettres are stored in an array and a while loop take each of them,
translate and rotate creating an union used in CSG's difference.
The problem is that each lettres don't use the same space ("i" take less
than "m") so i choose to create another array populated with rotation
values.
Here is a sample code (in hope that's clearer than my poor english) :
#declare MyArray = array[12];   #declare Mydecal = array[12];
#declare MyArray[0]="D";        #declare Mydecal[0] = 0;
#declare MyArray[1]="E";        #declare Mydecal[1] = Mydecal[0]+10;
#declare MyArray[2]="N";        #declare Mydecal[2] = Mydecal[1]+10;
#declare MyArray[3]="I";        #declare Mydecal[3] = Mydecal[2]+10;
#declare MyArray[4]="S";        #declare Mydecal[4] = Mydecal[3]+7.5;
#declare MyArray[5]="&";        #declare Mydecal[5] = Mydecal[4]+10;
#declare i = 0;
#declare nom = union {
#while(i<12)
text {
   ttf   "../TTF/courbd.ttf",  MyArray[i],  1,  0
   scale 0.2
   translate <0,0.182,0>
   translate <0,0,.521>
   rotate y*Mydecal[i]
#declare i = i+1;
Quite ugly but... it works :)
Denis Bodor
Date: 5 May 2004 15:19:52
Message: <noe.falzonPASDEPUB-2CB45D.21182305052004@news.povray.org>
In article <40980cfa@news.povray.org>,
Hello,
your rings are very nice indeed.
I suggest to make a render with the two rings mingled, interwined. Given
the fact that the two names on the rings are *probably* those of two
people in love, this could be a nice thing.
Noé
"Je ne deteste que les bourreaux" -- Albert Camus
Pour m'écrire un mail, veuillez retirer PASDEPUB de mon adresse ;)
Date: 6 May 2004 15:49:09
Message: <409a96b5@news.povray.org>
If only obtaining *real* gold rings with your names on them were as easy
(and as cheap)! ;-)
(For that matter, if only it could be a bit easier finding someone who
suitable to have their name put on a ring... *sighs longingly*)
Andrew @ home, alone.
Date: 12 May 2004 21:21:55
Message: <40a2cdb3$1@news.povray.org>
Beautiful Job
