POV-Ray : Newsgroups : povray.binaries.images : many cubes [75 KB] Server Time
15 Oct 2026 10:47:12 EDT (-0400)
  many cubes [75 KB] (Message 1 to 21 of 21)
Subject: many cubes [75 KB]
Date: 16 Apr 2004 14:36:53
Message: <408027c5@news.povray.org>
Hello,
This is my latest desktop wallpaper attempt. Is are 110592 cubes, placed my
an algoritm. This image has an "recursion-level"of 3, and i am currently
rendering one with level 4, which has 48 times as much cubes.
a large .jpg version [1600x1200] of both images will be available at
home.student.utwente.nl/j.w.a.vaandrager/background_L3g.jpg
change the L3g to L4g to view the "level-4" image when it's done.
Comments and critisism is welcome as usual.
Greetings,
JWV
Download 'background_L3.jpg' (73 KB)
Preview of image 'background_L3.jpg'
Subject: Re: many cubes [75 KB]
Date: 16 Apr 2004 15:04:20
Message: <40802e34@news.povray.org>
The level-4 render was to much for my laptop :-(. It used 2GB of memory
while parsing, and it wasn't finished jet.
I will post the source in p.b.sf if someone wants to give it a try on a
machine with a LOT of memory  :-).
Greetings JWV
"JWV" <jwv|at|planet.nl> wrote in message news:408027c5@news.povray.org...
> Hello,
my
> Greetings,
> JWV
Date: 16 Apr 2004 15:45:01
Message: <web.408037669e31cbafeba257cf0@news.povray.org>
> Greetings JWV
That looks cool!  I might give it a try if you post the source.
Date: 17 Apr 2004 05:08:02
Message: <4080f3f2@news.povray.org>
the source has been posted. You can change the recusion level by changing :
#while(cnt<4)
in line 19, into cnt<????
I is set to 4, which means recursion level 4, which was to much for my
laptop. So you might give it a try with level 3 first.
Greets,
JWV
"SunTzu2" <sun### [at] hotmailcom> wrote in message
news:web.408037669e31cbafeba257cf0@news.povray.org...
> > Greetings JWV
Date: 17 Apr 2004 13:07:26
Message: <4081644e$1@news.povray.org>
>>>Greetings JWV
i'm peeved / tee'd off
dual 2.8 xeon, 2gb ram, explicitly added 2gb of swap space above its
norm of 1gb and still ran out of space with recursion level of 4
anyone got a machine that can render it ?
stephen
Date: 17 Apr 2004 13:27:46
Message: <40816912@news.povray.org>
Thanks for trying it! The level 4 scene should have about 48^4=5.308.416
cubes. I am not sure how much memory is used for this amount, but it apears
to be quite a lot.
Greetings,
JWV
"stephen parkinson" <ste### [at] zmemw16demoncouk> wrote in message
news:4081644e$1@news.povray.org...
> >>>Greetings JWV
> stephen
Date: 17 Apr 2004 13:57:33
Message: <4081700d$1@news.povray.org>
> >>>Greetings JWV
I've got 1 gig RAM and 6 gig of page file.  I was watching the memory usage
and it claimed out of memory at 2gig.  I seem to recall hearing something
about a 2gig maximum of memory for an application regardless of the total
amount available (Windows).  Does anyone else know something about that?
Date: 17 Apr 2004 14:14:06
Message: <408173ee$1@news.povray.org>
> #while(cnt<4)
> Greets,
> JWV
>>>Greetings JWV
having read replies so far, is there a question of OS lurking ?
if so, linux originally libranet 2.8.1, now tracking sid istr, kernel 2.6.4
stephen
Date: 17 Apr 2004 14:55:59
Message: <opr6l6vjolzjc5hb@news.povray.org>
On Sat, 17 Apr 2004 10:57:27 -0700, Sun Tzu <sun### [at] nospamhotmailcom>
> usage
Win32 applications are limited to using approximately 2GB of memory. "Out
of memory" in this case really means "out of address space". The total
address space is 4GB, but applications are only allowed to use half of it.
Applications that work with data sets larger than that must take special
measures in order to do so.
FE
Date: 17 Apr 2004 15:54:53
Message: <40818b8d$1@news.povray.org>
Hash: SHA1
	It should be possible to decrease the amount of memory required
(divide it by 4). At the first iteration, since blok is a simple cube,
balk is equivalent to a box { <0, 0, 0>, <5, 1, 1> } although it is
done with 4 boxes. Even with that I don't have enough RAM to give it a
try from what you're all saying ("only" 512M) but some of you might
want to try it.
	Of course, this is only true so long as f is set to 1, with higher
values the results won't look the same...
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAgYuNqIYJdJhyixIRAtY8AKCPvNA3q/2eie6vUFSATB7U9P5O8QCgkBSE
tJrAJDRGPjd29WnMz9FE/h8=
=WXIA
-----END PGP SIGNATURE-----
Date: 17 Apr 2004 16:12:17
Message: <40818fa1$1@news.povray.org>
> done with 4 boxes.
I tried to  make the code work like that, but it was more complex.
That is the problem indeed.
I might try to make it work anyway. It should be possible by making the
first "blok" a union of 8 box{0, <5,1,1>}. Then setting the level to 3
will - should :-) - have the same effect as the level 4 in the old file.
But I will do that tommorow since i need some sleep now.
Greetings,
JWV
BTW, thanks to all of you for all the replies!
"Jérôme M. Berger" <jbe### [at] ifrancecom> wrote in message
news:40818b8d$1@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> want to try it.
> Jerome
> =WXIA
Subject: Re: many cubes [45 KB]
Date: 18 Apr 2004 07:59:23
Message: <40826d9b@news.povray.org>
Hash: SHA1
	Here it is at recursion 4...
		Jerome
iD8DBQFAgm2ZqIYJdJhyixIRAn7xAJ9GAPreW0mjdGtMkAtxAjit2cTTkQCfU42j
kVlZLwukg0ibNBmTNU1xEMQ=
=RbfS
Download 'blok.jpg' (45 KB)
Preview of image 'blok.jpg'
Date: 18 Apr 2004 08:03:34
Message: <40826e96@news.povray.org>
very cool!, but you turned of the reflection of the ground plane didn't you?
How long did it take to parse/render?
Greetings,
JWV
news:40826d9b@news.povray.org...
> Hash: SHA1
> Jerome
> =RbfS
Date: 18 Apr 2004 14:25:14
Message: <4082c80a@news.povray.org>
Hash: SHA1
	Parse time: 19s
	Render time: 3236s (~55mn)
	The computer used is an Athlon XP 2700+ with 2x256M of RAM in dual
channel mode and 1GB of swap running linux mandrake 9.1 (kernel
upgraded to 2.4.22)
		Jerome
iD8DBQFAgsgJqIYJdJhyixIRAk9lAKCdc4d8N+qOB3cs6N53NU788F9R+wCgj5UF
aUQsLh3ytNglrW5WHRnSJ4I=
=HYFZ
Date: 19 Apr 2004 13:40:39
Message: <40840f17@news.povray.org>
Hash: SHA1
	Higher resolution version (1152x864) is at
http://jeberger.free.fr/tmp/blok.jpg
	Render time was 28min????
		Jerome
iD8DBQFAhA8WqIYJdJhyixIRAsXTAJ4gPp4sfmldBsVfT9yNCHoltcN/4ACghnUw
2J7t3HdTml6eCMC+ZQ8QewU=
=CZQf
Date: 19 Apr 2004 15:26:43
Message: <opr6pxmsrnzjc5hb@news.povray.org>
> apears
> to be quite a lot.
There are ways to overcome such limitations and render fractals with
greater recursion depth. The most effective (in my experience) is to
generate a mesh (either externally or in POV-SDL) of the fractal at a
convenient depth, and then use that mesh as the low level building block
in the bigger fractal. The reduction in memory usage can be quite
dramatic. The important thing is to keep the total number of objects
within reasonable bounds. 48^4 cubes is a little much for POV-Ray to
handle; 48^2 or 48^3 mesh instances might work better. Unfortunately,
POV-Ray doesn't handle huge meshes very well, but you might be able to
reach level 5 (or more) that way.
FE
Date: 20 Apr 2004 16:00:28
Message: <opr6rtu8fxzjc5hb@news.povray.org>
On Mon, 19 Apr 2004 21:26:42 +0200, Fredrik Eriksson <noo### [at] nowherecom>
Just to show that it's possible:
http://hem.bredband.net/b230591/povray/cubefractal5_2048.jpg (828 kB)
http://hem.bredband.net/b230591/povray/cubefractal6_4096.jpg (2.69 MB)
FE
Date: 20 Apr 2004 16:51:06
Message: <40858d3a@news.povray.org>
Is that POV or Pixie?
Date: 20 Apr 2004 21:29:38
Message: <4085ce82@news.povray.org>
> wrote:
<snip />
God bless recursion, every one in a one in a one in a one...
Respectfully,
Dan P
http://<broken link>
Date: 21 Apr 2004 13:27:40
Message: <4086af0c@news.povray.org>
Hash: SHA1
	Both my renders were done with pixie...
		Jerome
iD8DBQFAhq8LqIYJdJhyixIRAu45AJkBdMlHf7cKISheH638sPvcC/YlFACfTuy4
C/a1/nogEGaY59x2PcCDOlI=
=ZdrS
Date: 22 Dec 2004 15:20:00
Message: <web.41c9d6789e31cbafdcad99600@news.povray.org>
Sorry to be coming late to this, but I'm willing to try it...I have a G5
with 4 gig of RAM and would be interested to see how it goes.
Zesty
> Greetings JWV
> > Hello,
> my
> > Greetings,
> > JWV
