An old 'Rochelle' lathe. Probably from the late 50's, early 60's. I
built this yesterday, and don't really like the steel texture. I'm
using:
texture{Silver_Metal scale 0
normal{bumps .1 scale 0.00000001}
finish{reflection .13 ambient .12}}
How can I improve this and make it dirty-looking?
TIA
~Steve~
Download 'lathe3.jpg' (76 KB)
Preview of image 'lathe3.jpg'
Hey Steve, it looks pretty good!
I see a few signs indicating it wasn't built with CSG. Might want to
make those hex nuts a little less 'telling' by removing the smoothing.
It's a matter of taste, though.
> using:
My first thought is to use some sort of proximity pattern to distribute
the metal's reflection unevenly. All proximity patterns are costly in
terms of time needed to render them though.
Next idea would be to use a turbulent bumps pattern to make some parts
less reflective. Combine that with a slope pattern to add a little dust.
Together, they should make that metal look quite old, possible a little
abused.
> TIA
> ~Steve~
TIA? Thanks in advance?
-Samuel Benge
"Samuel Benge" <stb### [at] hotmail com> wrote in message
news:407### [at] hotmail com...
I
Thanks Sam! It's just a guess that it's from the late 50's/early
60's, but I would say close to that. I have the real thing in my
workshop, and would be happy to post the image if you/anyone would
like. :)
smoothing.
Yes, it was built entirely using Wings, which I'm getting more used
to... I'll re-work the nuts and try your suggestion, thanks.
> > using:
distribute
in
parts
dust.
little
> abused.
Could you post some small code to illustrate this? I would then
have a clear idea of what to do.
> > TIA
> > ~Steve~
Yes Sam, thank you. :)
~Steve~
> -Samuel Benge
> I built this yesterday, and don't really like the steel texture. I'm
> using:
Oooo... too much ambient. :-S I thought it looked (who did they say in
The Matrix?) "a little weird".
As for looking more dirty... I can only suggest adding pigment texturing
to try to make it look like it has concentrations of dust, etc. in the
hard-to-clean resesses. (Probably a nightmare to texture!) And make it
less reflective, turn down the specular hilight, etc. Sorry - not much
help I know!
Certainly an interesting model though!
Thanks.
Andrew @ home.
"Andrew C on Mozilla" <voi### [at] dev null> wrote in message
news:407997be@news.povray.org...
I'm
> > using:
in
lol! Yeah, I can understand that, but too much ambient? Usually, I
try to keep it down, but this time, I raised it thinking it might show
a truer/better image - I guess it didn't work though...
I also tried a Rad scene (my first Rad scene), with this, but it
looked worse than it does now. Any ideas on what settings I should use
for a model like this? Would Radiosity be beneficial for this type of
model?
texturing
the
it
much
> help I know!
No, your suggestions are helpful indeed! It's always worth trying
another Povers' ideas... :)
Thanks, a little sweat 'was' also generated for this model, I can
assure you... ;)
~Steve~
> Thanks.
> Andrew @ home.
>>in The Matrix?) "a little weird".
> model?
*checks original post* Hmm... radiosity probably won't do much to this.
The main things radiosity does is make shaddows blurry (so do area
lights - but faster) and, depending on the scene, lighten up otherwise
dark corners (allowing you to reduce the ambient level but still be able
to see). You scene doesn't really have many "corners" to lighten up.
Oh, and if you have brightly coloured objects near white surfaces, you
get colour bleed - but your scene doesn't have anything like that anyway.
>>texturing to try to make it look like it has concentrations of dust,
>>etc. in the hard-to-clean resesses. (Probably a nightmare to texture!)
>>And make it less reflective, turn down the specular hilight, etc.
>>Sorry - not much help I know!
Well - unless said suggestions are stark raving mad! (It seems to happen
from time to time...)
> assure you... ;)
I'll bet...
Andrew @ home.
> using:
Cool! Just needs another light or two to brighten it up. RL rarely has
just one light :-)
Respectfully,
Dan P
http://<broken link>
> using:
Reflective objects need an environment to reflect, whereas your lathe
and the tiles it's sitting on appear to be floating in empty space. You
might consider putting everything in a shop environment, or even an
empty room (although the reflections from an empty room will be really
bland.. still better than nothing though).
Using low-quality radiosity will then give the room a more realistic
appearance, which will improve the reflections, as well as brightening
up the inky black shadows on your lathe (eliminating any need for
ambient finishes.. remove 'em!), and shouldn't make render times
unacceptably long.
If for some reason you can't or won't do this, at least scatter around a
couple more point lights.
I'm sure I could say more about the textures themselves, but I would
prefer not to judge them in their present lighting environment.
Oh yeah, and don't scale anything by 0. That's just dumb. I'm actually
surprised POV-Ray let you get away with it.
-Xplo
>> using:
<snip:criticism />
POV-Ray will default to 1 when it finds a 0. For example, if you choose
to "scale 2*y", it will warn you about it and say it is using 1 instead.
Surely you didn't mean to offend here so, just to make it clear, anybody
who can make such a magnificent model is anything but dumb.
Respectfully,
Dan P
"Dan P" <dan### [at] yahoo com> wrote in message news:4079f372@news.povray.org...
Just to be clear here -
'scale 2*y' is equivalent to saying 'scale <0,2,0>' which POV-Ray will not accept
and will internally change it to 'scale <1,2,1>'.
You cannot scale by zero.
Yep; what I said.
Respectfully,
Dan P
news:407a0c18$1@news.povray.org...
> Yep; what I said.
You said less. I said more. So there!
>>Yep; what I said.
Ooooh, you cheeky monkey :-)
Respectfully,
Dan P
Which is the same thing you'd get by having no scale at all.
Hence, it's redundant, meaningless, useless, and misleading all at the
same time. Sounds dumb to me. *shrug*
-Xplo
>>> actually surprised POV-Ray let you get away with it.
>> choose to "scale 2*y", it will warn you about it and say it is using 1
>> instead.
I have to disagree; some may consider scale 2*y is more readable in the
code than scale <1, 2, 1>. Actually, I think POV-Ray shouldn't even warn
about it.
Respectfully,
Dan P
> about it.
At risk of starting to sound seriously pedantic...
It didn't SAY 2*y, did it? No, it said 0.
Go on, tell me what "scale 0" is good for. ;p
-Xplo
"Xplo Eristotle" <xpl### [at] infomagic net> wrote in message
news:407a5321@news.povray.org...
Heh, I know it shouldn't be there - it's the default that comes
with PoseRay which is 1, but I changed it to zero for some reason,
can't think of what reason though... ;)
~Steve~
> -Xplo
Is this an old argument?
One time I had tried to do a scale by 0 to 'flatten' something. Can't
remember what I was doing at the time though or what I did instead (probably
.0000001 or something)
== John ==
<snip />
I can't imagine a person typing that for any reason -- I didn't realize
/that/ was the code :-) Well, a person might type that to try an make
something infinitely small, but of course, that is not possible in POV-Ray.
Respectfully,
Dan P
