POV-Ray : Newsgroups : povray.binaries.images : The same attractor by Manuel Kasten Server Time
30 Nov 2026 03:09:57 EST (-0500)
  The same attractor by Manuel Kasten (Message 1 to 18 of 18)
Subject: The same attractor by Manuel Kasten
Date: 16 Mar 2004 01:54:56
Message: <4056a4c0@news.povray.org>
I didn't use POV, I made a program in Matlab and exported the resulting
matrix to a 48-bit PNG. I had to do extensive image processing to stretch
the contrast and luminosity of the image and some minor cosmetic
adjustments.
I also had the idea of adding different values for the colors of the pixels.
Basically, the colors are related to the change in position. The bigger the
change, the more intensity is put into the pixel.
I used 10 million point. If I have time, probably I'll do a 100 million
points.
The image was generated in 3 minutes and less than 200 Mb of RAM.
I hope you like it.
Fernando
Download 'attcolor3.jpg' (167 KB)
Preview of image 'attcolor3.jpg'
Subject: Re: The same attractor by Manuel Kasten
Date: 16 Mar 2004 08:24:33
Message: <40570011$1@news.povray.org>
> I hope you like it.
I do!
can you explain further, how you colored it? How bright is a
pixel and what color does it have depending on what values?
Thanks,
    Manuel
Subject: Another one :)
Date: 16 Mar 2004 09:47:44
Message: <40571390@news.povray.org>
100 million points :)
and a different color scheme. I must go to class now, but I'll post my
coloring scheme soon.
Fernando
Download 'att1e8_2.JPG' (196 KB)
Preview of image 'att1e8_2.JPG'
Subject: Re: Another one :)
Date: 16 Mar 2004 11:52:37
Message: <405730d5$1@news.povray.org>
Great! I love those colors! (And I got a new wallpaper, too :)
Florian
Date: 16 Mar 2004 13:27:16
Message: <40574704$1@news.povray.org>
Could it be possible to zoom-in a little, so we don't see it is
contained in a sphere.  And would it be possible to have it rendred in
at least 1280x1024?  I'd love to have it as my desktop image!
Nice work!
BTW, it reminds me of a screen-saver in linux that animated such kind of
thing... it was called 'strange' I've included a screenshot.
Simon
Download 'strange.gif' (5 KB)
Preview of image 'strange.gif'
Date: 16 Mar 2004 14:08:30
Message: <405750ae$1@news.povray.org>
Here's the Matlab code based on your POV code.
I changed a few of the variable names, but it should be understandable.
Here's the basis for the coloring:
Red = change in x coord
Green = change in y coord
Blue = magnitude of the curvature (estimated)
I hope I made myself clear.
Fernando
"Manuel Kasten" <kas### [at] gmxde> escribió en el mensaje
news:40570011$1@news.povray.org...
> > I hope you like it.
> I do!
> Thanks,
>     Manuel
Download 'att.m.txt' (1 KB)
Date: 16 Mar 2004 14:09:42
Message: <405750f6@news.povray.org>
"Xilo Musimene" <xil### [at] cainternet> escribió en el mensaje
news:40574704$1@news.povray.org...
> Nice work!
Thanks! Yes, I remember that screensaver in linux. There's another one,
called 'flow'. I love that one.
Here's the URL where you can find the wallpaper version of the image
http://www.deviantart.com/view/5883845/
Fernando
Date: 16 Mar 2004 14:18:22
Message: <405752fe$1@news.povray.org>
Is it possible to get the Java-Source of your programm? I would like to
play around with it.
Matthias Weißer
mat### [at] matweide
http://www.matwei.de
Date: 16 Mar 2004 14:20:14
Message: <4057536e$1@news.povray.org>
Not Java, but Matlab :)
Anyway, the syntax is very similar I think.
If you have any question, let me know.
Fernando
"Matthias Weißer" <mat### [at] matweide> escribió en el mensaje
news:405752fe$1@news.povray.org...
> Matthias Weißer
Date: 16 Mar 2004 15:03:00
Message: <40575d74@news.povray.org>
flow is also very nice, but my prefered one is IFS...  and I hope I'll
get to remake it with OpenGL one day!
Thanks a lot!
   Simon
Date: 16 Mar 2004 15:25:16
Message: <405762ac$1@news.povray.org>
The java code is mine. It is without coloring and can be found at
http://madonion.homeip.net/attractors/
Manuel
Date: 16 Mar 2004 18:50:41
Message: <405792d1$1@news.povray.org>
"Fernando G. del Cueto" <fcu### [at] yahoocom> wrote in message
news:4056a4c0@news.povray.org...
> adjustments.
pixels.
the
> points.
> I hope you like it.
Very mathemagical.
- Respectfully,
Dan
http://<broken link>
Date: 18 Mar 2004 01:19:35
Message: <40593f77$1@news.povray.org>
I've set it as my work wallpaper and it's fabulous!  On some computer I
can't have a better resolution than 1024x768 and the image is still
centered and I can't see the 'strange' circle, which I like very much
and on some other computer I get a 1280x1024 perfect bg image which is
different and also very nice!
I was wondering...  the 'strange' screensaver used to animate the
attractors you have been rendering... could you animate it also?
Simon
Date: 18 Mar 2004 01:46:17
Message: <405945b9$1@news.povray.org>
news:40593f77$1@news.povray.org...
Thanks :) I'm glad you liked it.
Actually I'm working on some kind of animation right now... I'll leave it
overnight working... tomorrow I'll check what was the result :)
Fernando
Date: 18 Mar 2004 07:51:17
Message: <40599b45@news.povray.org>
> I hope you like it.
I really do. Is there some website where attractors are described in
detail? I've seen many differents by now (the Lorenz one being the first
:), but I've never found a source which could explain me the theory
behind it :(
Florian
Date: 18 Mar 2004 11:14:36
Message: <4059caec$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:40599b45@news.povray.org...
> > I hope you like it.
first
> behind it :(
> Florian
This can help visualise a 2-D arrangement (OK - so it is part of a
spherical surface).
As a boy, one distraction was to hang a bar magnet vertical on a 0.5
or 1 metre string about 5 cms above the floor/table. 1 or more bar
magnets (or steel bolts) were then placed on the floor/table near this
pendulum which was then set swinging.
A variation was to use a glass table as base, a small torch taped to
the cord and place a camera (long exposure) below the magnets.
Alf
Date: 18 Mar 2004 12:17:35
Message: <4059d9af@news.povray.org>
> behind it :(
Tor Olaf Kristensen posted the following:
//Just in case anyone is interested in a free online versions of a book
//about "Strange Attractors":
//http://sprott.physics.wisc.edu/sa.htm
//"Strange Attractors: Creating Patterns in Chaos (ISBN 1-55851-298-5)"
//by Julien C. Sprott
I downloaded the pdf version and read it partially. It describes the concepts
behind these attractors very clearly. Note that the attractor Fernando posted
uses different equations:
x2 = sin(a*y1) - cos(b*x1)
y2 = sin(c*x1) - cos(d*y1)
Manuel
Date: 18 Mar 2004 13:05:00
Message: <4059e4cc$1@news.povray.org>
Excellent job!  Looking forward to see the results! =)
Simon
