I haven't POVed for about 8 months and just picked it up again. Close to a
year ago I posted an earlier version of this image. I did more work on it
and then left it alone for several months. The cheese got me frustrated
because I couldn't come up with something that looked satisfactory to me.
Also the picture is far to 'sterile' looking, but I'm not sure how to make
things look dirty or worn. For example I'd like to have some cheese
residue on the knife, but haven't a clue how to accomplish that. I'd
appreciate any suggestions. Thanks.
Download 'wine10.jpg' (167 KB)
Preview of image 'wine10.jpg'
"Sun Tzu" <sun### [at] nospamhotmail com> wrote in message
news:40414e0f@news.povray.org...
a
Hello General Tzu! :-)
This image rocks. I found it easiest to make things look dirty (for example,
the label on the bottle) by averaging in a "wrinkles" pigment at a low
weight. Also, if you change the lighting -- perhaps even add some
atmospheric media -- it will look less sterile too. The trick is, just about
everything is sterile looking when clean, it is the /environment/ that
affects how real things look.
Oh, and the cheeze would be a great candidate for subsurface scattering too.
Lots of interior and media statements make things look really cool :-)
On the whole that looks very realistic, the wine glass looks excellent, but the
cheese looks way to "hard". Like Daniel said it, should have sub-surface
scattering to really look like cheese.
I'd also suggest adding a few errors, the tiles in the background shouldn't be
perfectly aligned, and I think the gaps between them should be smaller, so they
nearly touch. Also the chopping board doesn't look right, I think it needs some
work on the wood texture (compare it to photos of real chopping boards), and
also it should have a few scratches on the top (these can just be faked with a
normal map and texture).
To get some cheese on the knife I would just modify the texture, so it has
streaks up it that are less shiny and cheese coloured. Perhaps support this with
a few small crumbs of cheese resting on the blade and on the surface next to it
(as if they fell off the knife when it was put down).
Tek
www.evilsuperbrain.com
Thanks for the suggestions. I'm not that experienced with POV though so I'm
not sure exactly how to implement your ideas. The materials always seem to
be one of my biggest problems. I obviously need some tutoring in making
good materials. How would I "average in a wrinkles pigment" on the label.
It is just an image texture:
texture
uv_mapping pigment
image_map
gif "eldwine9.gif"
interpolate 2
scale <-0.18,0.35,0.2>
rotate <0.0, -47.0, 0.0>
translate <0.0,80.0, 0.0>
finish
ambient 0.0
diffuse 0.9
specular 0.2
roughness 0.2
Even more mysterious to me is the "subsurface scattering" that both you and
Tek suggest. Here is the outside surface of the cheese, the 'sliced'
surfaces and bubbles are the same but without the normal. How would I put
in subsurface scattering?
color cheese_color
finish{
ambient 0.2
diffuse 0.7
specular 0.15
roughness 0.1
normal{
agate 0.01
scale <10,10,10>
Thanks.
"Dan P" <dan### [at] yahoo com> wrote in message
news:40415ad8$1@news.povray.org...
to
> a
it
me.
make
example,
about
too.
Thank you for the suggestions. Adding in some errors in the tiles is a good
idea. I'll try and add a random error to the loop that places the tiles.
I'm not happy with the wood texture on the cutting board either, as I noted
in my reply to Daniel above, my material skills are rather weak. I believe
that wood is just one of the standard textures from one of the standard inc
files that I tried to modify, but with little success. I suspect I really
don't understand how the 'colormap' statement and multi layer materials
work. Here's the material. I'd appreciate any specific ideas you might
have for improving it.
material {
texture // txt_75_1
pigment
wood
color_map
[ 0.0 rgbft <0.6, 0.35, 0.2, 0.0, 0.0> ]
[ 0.1 rgbft <0.6, 0.35, 0.2, 0.0, 0.0> ]
[ 0.9 rgbft <0.9, 0.65, 0.3, 0.0, 0.0> ]
[ 1.0 rgbft <0.6, 0.35, 0.2, 0.0, 0.0> ]
turbulence 0.05
octaves 4
ramp_wave
scale <0.15, 0.15, 1.0>
rotate -90.0 * z
finish
ambient 0.2
diffuse 0.5
phong 0.4
phong_size 16.0
specular 0.1
roughness 0.002
reflection {0.02 fresnel on}
interior{
ior 1.5
texture // txt_76_1
pigment
bozo
color_map
[ 0.0 rgbft <0.9, 0.65, 0.3, 0.0, 0.0> ]
[ 0.1 rgbft <0.9, 0.65, 0.3, 0.3, 0.0> ]
[ 1.0 rgbft <1.0, 1.0, 1.0, 1.0, 0.0> ]
scale <0.01, 0.01, 100000.0>
rotate -90.0 * z
finish
ambient 0.2
diffuse 0.5
phong 0.4
phong_size 16.0
specular 0.1
roughness 0.002
interior{
ior 1.5
rotate <0,90,90>
scale <5,5,5>
Thanks.
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:40416642$1@news.povray.org...
but the
shouldn't be
they
some
and
with a
this with
to it
> Tek
to a
it
me.
make
news:40418355@news.povray.org...
I'm
to
Averaging pigments together is a very powerful too. To average pigments
together, use a "pigment_map" and a map type of "average". The following
code creates a plasma effect by averaging three pigments together. Note that
the "weight" of pigment for each is "1". Because there are three averaged
together, in order to get a value of "1.0" for full color, I have to use "3"
for the color value (3 times the amount of 1):
plane
z, 1
pigment
average
pigment_map
[ 1 wrinkles
color_map
[0 rgb <0, 0, 0> ]
[1 rgb <3, 0, 0> ]
[ 1 wrinkles
color_map
[0 rgb <0, 0, 0> ]
[1 rgb <0, 3, 0> ]
translate 0.5
[ 1 wrinkles
color_map
[0 rgb <0, 0, 0> ]
[1 rgb <0, 0, 3> ]
translate -0.5
finish { ambient 1 }
and
I'd like to know too -- I haven't advanced to the point of being able to do
that. Tek knows more about that stuff than I. There is this really great
animation out there that shows subsurface scattering -- it was this marble
pyramid people were talking about a while back that was really something.
The code to that pyramid would really advance our understanding. Christopher
Huff is also amazingly knowledgeable about densities and the like.
news:40418673$1@news.povray.org...
WARNING - this is an incredibly long reply! But it sounded like you wanted some
tips on texturing so I've done my best:
Okay, well one thing stands out to me straight away: that's a very complicated
material, which is rather strange since we both agree it doesn't look so good.
My advice would always be keep the material very simple until you have nearly
the effect you like.
So, following that I'd suggest this much simpler version might be a good
starting point:
wood
ramp_wave
color_map
[0 rgb <0.6, 0.35, 0.2> ]
[1 rgb <0.9, 0.65, 0.3> ]
turbulence 0.05
finish {
diffuse .7
ambient .3
rotate <30,30,0>
scale 0.75
Now, from this we can start looking at some more complex effects, firstly we can
change the colour map so it returns smoothly to it's starting point:
color_map {
[ 0.0 rgb <0.6, 0.35, 0.2> ]
[ 0.8 rgb <0.9, 0.65, 0.3> ]
[ 1.0 rgb <0.6, 0.35, 0.2> ]
Note that the colour at 1 is now the same as the colour at 0. This will remove
the hard transition that occured before.
Now, before we add anything else I think we should decide whether the colours
look right. Personally I think they look far too dark for a chopping board, so
I'd try something a bit lighter and yellower:
[ 0.0 rgb <0.9, 0.68, 0.4> ]
[ 0.8 rgb <1, 0.8, 0.5> ]
[ 1.0 rgb <0.9, 0.68, 0.4> ]
That's still not perfect so I recommend you spend a bit longer at this stage
until you get some colours you like.
Now, let's alter the pattern of the stripes. That 0.8 value in the colour map
can be changed to alter the way that the colours vary across the surface, also
the ramp_wave can be changed for one of pov's other types to create different
effects. Here's one example that I like but there's many other possibilities:
wood
poly_wave 2
color_map
[ 0 rgb <0.9, 0.68, 0.4> ]
[ .05 rgb <1, 0.8, 0.5> ]
[ 1 rgb <0.9, 0.68, 0.4> ]
turbulence 0.05
Now, lets look at the finish. The wood you had originally had a lot of
reflection and phong highlights, this suggests a varnished wood, but of course
chopping boards aren't varnished. So let's instead try to get a smooth but not
polished sheen to it. No reflections, since chopping boards aren't really
reflective, a soft and subtle highlight, and we'll tweak the brightness of the
material.
finish {
diffuse .5
ambient .3
brilliance 1.8
specular .2 roughness .5 metallic 1
There's 2 important things to notice here: the brilliance value alters the way
that the diffuse lighting looks, larger values give a more gradual falloff. And
the metallic specular highlight with a high roughness value behaves sort of like
a half-specular/half-diffuse light. It's a trick I used to create metallic
paint, but in this situation it's trying to fake the sheen that unvarnished wood
has.
Now, there's one final thing I'd like to do to this material, it's looking a bit
flat so let's give it a normal map:
normal {
wood
poly_wave 2
turbulence 0.05
normal_map
[ 0 granite .05 scale .4 ]
[ .05 radial .01 rotate x*90 sine_wave frequency 200 ]
[ 1 granite .05 scale .4 ]
What I've done here is use the exact same basic pattern as the pigment, but
instead of blending 2 different colours I'm blending 2 normal patterns. There's
a radial one rotated to give perpendicular stripes across the rings in the wood,
and a granite texture to add noise to the darker patches of wood.
Finally, we can tidy this up so that we don't have to have 2 copies of this
pattern, like so:
pigment_pattern {
//first let's take care of the wood pattern.
wood
poly_wave 2
color_map
[ 0 rgb 0 ]
[ .05 rgb 1 ]
[ 1 rgb 0 ]
turbulence 0.05
//we have now defined a pattern so that
//anything we map to 0 appears on the "dark" rings
//and anything we map to zero appears on the light rings
texture_map {
[0
//pattern for dark rings, a dark colour and noisy normal
pigment { rgb <0.9, 0.68, 0.4> }
finish {
diffuse .6
ambient .3
brilliance 1.8
specular .1 roughness .5 metallic .5
normal { granite .05 scale .4 }
[1
//pattern for light rings, a lighter colour and striped normal
pigment { rgb <1, 0.8, 0.5> }
finish {
diffuse .6
ambient .3
brilliance 1.8
normal { radial .01 rotate x*90 sine_wave frequency 200 }
rotate <30,30,0>
scale .75
scale .3
This technique isn't entirely necessary, but I find using pigment_patterns like
this can make it much easier to build complex textures.
I hope all of this helps!
Tek
> rotate <30,30,0>
> scale .75
> scale .3
whoops, ignore that last scale .3, that's just something I was using for my test
you don't need it.
Tek
news:4041b15a$1@news.povray.org...
some
> starting point:
> texture {
> pigment {
> wood
> ramp_wave
> color_map
> turbulence 0.05
> finish {
> diffuse .7
> ambient .3
> rotate <30,30,0>
> scale 0.75
can
> color_map {
> pigment {
> wood
> poly_wave 2
> color_map
> turbulence 0.05
> material.
> finish {
> diffuse .5
> ambient .3
> brilliance 1.8
And
like
wood
> has.
bit
> normal {
> wood
> poly_wave 2
> turbulence 0.05
> normal_map
There's
wood,
> pattern, like so:
> texture {
> pigment_pattern {
> wood
> poly_wave 2
> color_map
> [ 0 rgb 0 ]
> [ .05 rgb 1 ]
> [ 1 rgb 0 ]
> turbulence 0.05
> texture_map {
> [0
> finish {
> diffuse .6
> ambient .3
> brilliance 1.8
> [1
> finish {
> diffuse .6
> ambient .3
> brilliance 1.8
> rotate <30,30,0>
> scale .75
> scale .3
like
> Tek
Thank you! I'll try and play around with the texture as you've shown.
Now if you can explain the 'sub surface scattering' that you referred to for
the cheese texture, I'll be set to try again.
news:4041b1ad@news.povray.org...
> > rotate <30,30,0>
> > scale .75
> > scale .3
my test
> you don't need it.
> Tek
wanted
> some
complicated
good.
nearly
> > starting point:
> > texture {
> > pigment {
> > wood
> > ramp_wave
> > color_map
> > turbulence 0.05
> > finish {
> > diffuse .7
> > ambient .3
> > rotate <30,30,0>
> > scale 0.75
firstly we
> can
> > color_map {
remove
colours
board, so
stage
colour map
surface, also
different
possibilities:
> > pigment {
> > wood
> > poly_wave 2
> > color_map
> > turbulence 0.05
course
but not
really
of the
> > material.
> > finish {
> > diffuse .5
> > ambient .3
> > brilliance 1.8
the way
falloff.
> And
of
> like
metallic
unvarnished
> wood
> > has.
looking a
> bit
> > normal {
> > wood
> > poly_wave 2
> > turbulence 0.05
> > normal_map
but
> There's
the
> wood,
this
> > pattern, like so:
> > texture {
> > pigment_pattern {
> > wood
> > poly_wave 2
> > color_map
> > [ 0 rgb 0 ]
> > [ .05 rgb 1 ]
> > [ 1 rgb 0 ]
> > turbulence 0.05
> > texture_map {
> > [0
> > finish {
> > diffuse .6
> > ambient .3
> > brilliance 1.8
> > [1
> > finish {
> > diffuse .6
> > ambient .3
> > brilliance 1.8
> > rotate <30,30,0>
> > scale .75
> > scale .3
pigment_patterns
> like
> > Tek
Thank you! Between you and Tek, I'll have enough things to figure out, to
keep me busy for awhile. If only I didn't have to work and could play at
this stuff all the time. Of course then I couldn't afford a computer,
hehe.
news:40418bde@news.povray.org...
> I'm
seem
> to
label.
that
"3"
> plane
> z, 1
> pigment
> average
> pigment_map
> [ 1 wrinkles
> color_map
> [0 rgb <0, 0, 0> ]
> [1 rgb <3, 0, 0> ]
> [ 1 wrinkles
> color_map
> [0 rgb <0, 0, 0> ]
> [1 rgb <0, 3, 0> ]
> translate 0.5
> [ 1 wrinkles
> color_map
> [0 rgb <0, 0, 0> ]
> [1 rgb <0, 0, 3> ]
> translate -0.5
> and
put
do
Christopher
news:404294a2@news.povray.org...
> hehe.
Bah, the secret of happiness is getting the stuff first and THEN giving the
world the finger. Worked for me :-)
news:40429382@news.povray.org...
Well, basically, to get sub surface scattering in POV you need a transparent
object filled with media. Media's explained in the povray docs, so I'll avoid
repeating what's said there.
Basically the idea is to take a scattering media that's so dense it almost looks
solid, but not quite, this simulates solids with translucency. Note that pov's
transparent pigments don't simulate real things, as they only affect the surface
of an object whereas media is a volumetric effect.
Anyway, that's enough theory. Here's a render of a material that I think looks
kinda like cheese. I sampled the cheese colour from a photo of cheese I found
using google! The photo's here if you're curious:
http://www.allposters.com/IMAGES/NIM/KE051.jpg Tip: if you want to sample
colours from photos use photos with bright white lighting, so you get the truest
possible colour.
The material I've used has got a couple of errors in it, but hopefully it will
give you a starting point. Here's the source:
object {
Cheese
hollow on
no_reflection
material {
pigment { rgbt 1 } /*no surface pigment, since real cheese does not have a
pigment (if you slice it thin enough you can see straight through it!)*/
finish {
//make it shiny.
reflection { 0, 1 fresnel } conserve_energy
specular 1 roughness .01
diffuse 0 ambient 0
interior {
ior 1.1 /*does anyone know the refractive index of cheese? :)*/
media {
scattering {
1, rgb <252,194,74>/255 //cheesy!
extinction 0 /*if we have extinction it will colour the media in a strange
way*/
absorption 1 /*use this instead of extinction*/
density {
rgb 40 /*modify this according to the scale of your scene, I've tuned this
so a 1 unit cube looks like a fairly large block of cheese.*/
Tek
Download 'cheese.jpg' (39 KB)
Preview of image 'cheese.jpg'
news:40429e34$1@news.povray.org...
> > hehe.
Or find a job where someone pays you to spend all day making pretty pictures on
the computer! Well I've sorta managed that but unfortunately I don't get to use
povray...
Tek
news:4042b043$1@news.povray.org...
out, to
play at
computer,
> > > hehe.
the
pictures on
to use
> povray...
When I get on jobs, I get paid (little) to make those pictures and write the
application and manage the application. Living in Wisconsin is awful for
being a competent computer scientist. However, it is an opportunity to see
the worst in human beings and study it, so there's always that silver
lining. That's why I'm gonna become a prof' -- people behave according to
needs and if I can help the future kids be competent they won't need to hurt
others to get ahead because they won't /need/ to. If this generation is
hopeless, then let's help the next generation so that they don't have to go
through what we did. It's time a lot of people lose the whole "I won't be
here I don't care I'm just gonna get mine and screw you" attitude and,
instead, respect and plan for the future with every action they do.
news:40414e0f@news.povray.org:
> again. Close to a year ago I posted an earlier version of
> this image. I did more work on it and then left it alone
> for several months. The cheese got me frustrated because I
> me. Also the picture is far to 'sterile' looking, but I'm
> not sure how to make things look dirty or worn. For
> example I'd like to have some cheese residue on the knife,
> but haven't a clue how to accomplish that. I'd appreciate
Very nice!
Have a look here for the latest in swiss army knifes
http://tinyurl.com/33bmv
Marc Champagne
marcch.AT.videoSPAMNOTtron.DOT.ca.invalid
Montreal, Canada
