POV-Ray : Newsgroups : povray.binaries.images : Color Cube Server Time
20 Oct 2026 20:11:43 EDT (-0400)
  Color Cube (Message 1 to 20 of 20)
Subject: Color Cube
Date: 12 Feb 2004 03:23:34
Message: <402b3806@news.povray.org>
A quick sketch of an idea I had. If I end up developing it I hope to
replace the ugly checkered floor with something else (either texture or
objects placed on it) that can illustrate the slightly reflective
texture of the cubes. I'll need to replace the mirror with something
more...natural, or else just add a second cube to the image.
Download 'color-cube.jpg' (115 KB)
Preview of image 'color-cube.jpg'
Subject: Re: Color Cube
Date: 12 Feb 2004 10:28:20
Message: <402b9b94@news.povray.org>
Nice.  I really like this.  It makes me think of Alain's marble bowling
animations.  Do you think you could animate this and have the individual
cubes slide apart and fall to the floor and bounce around a little bit like
dice till they came to a stop?  Since these aren't spheres that might be
harder to do... then again maybe not.  Personally I think I'd leave the
mirror.  The animation would make it clear that we were looking at one cube
and a mirror and not two cubes.  The mirror could also serve as a wall the
cubes could bounce into.  As is it took me a little while to figure out what
the black line running across the top of the scene was.   Maybe it would
look better with a frame around the mirror.  Still very nice.  I like the
subject.
Carl
Date: 12 Feb 2004 11:51:35
Message: <402baf17$1@news.povray.org>
Could you post the "finish" you used on the cubes.  I love that look!
"Edward Coffey" <eco### [at] swiftdslcomau> wrote in message
news:402b3806@news.povray.org...
Date: 12 Feb 2004 12:43:34
Message: <402bbb46$1@news.povray.org>
Should be pretty easy using Christoph Hormann's SimPOV or MegaPOV 1.0
which has the SimPOV-patch included.
SimPOV Homepage:
http://www-public.tu-bs.de:8080/~y0013390/simpov/index.html
MegaPOV Homepage:
http://megapov.inetart.net/
HTH,
Florian
Date: 12 Feb 2004 14:44:46
Message: <402bd7ae$1@news.povray.org>
Looks cool! That one cube on the corner seems black and out of place -- was
that intentional?
Date: 12 Feb 2004 15:22:34
Message: <402be08a@news.povray.org>
>> like
I'll have to have a look at that. My computer might as well be rendering
an animation at the moment, there's something wrong with the graphics
adaptor which makes it crash randomly when used in anything other than
text-mode :?(
Date: 12 Feb 2004 15:33:48
Message: <402be32c@news.povray.org>
Sure, the texture is just a simple solid pigment and the following
finish settings:
specular 1
roughness 0.03
reflection 0.1
It's really very simple - I think it's partly the radiosity (especially
in the image reflected in the mirror) and partly the scale and position
of the checker pattern (I tweaked it specifically to show off the
"reflection 0.1" aspect of the finish) that make this finish look okay.
I should probably give it angle dependant reflection one day.
Date: 12 Feb 2004 15:50:07
Message: <402be6ff@news.povray.org>
> that intentional?
I'd like it to fit in more, but it definitely is supposed to be black.
The cube represents a simplified RGB colorspace, each axis of the cube
represents one of the three primary colors - Red, Green and Blue. The
cube at the top is obviously color <0,0,0>, the one at the bottom is
<1,1,1>, the other 6 corner cubes are <1,0,0>, <1,1,0>, <0,1,0>,
<0,1,1>, <0,0,1> and <1,0,1>. I built it to be configurable, so you can
just plug in the number of cubes you want along each edge. Here's one
rendered with 8x8x8 cubes (well, superellipsoids actually, which makes
it hard to know exactly where in the y axis to place the object to get
it to stand on its end - I rendered this one with the same translation
as the 3x3x3 version so the white superellipsoid sticks through the floor):
Download 'color-cube8.jpg' (33 KB)
Preview of image 'color-cube8.jpg'
Date: 12 Feb 2004 16:47:12
Message: <402bf460@news.povray.org>
> floor):
The function/macro "trace" could be useful for that.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 12 Feb 2004 17:11:29
Message: <402bfa11@news.povray.org>
news:402be6ff@news.povray.org...
was
> > that intentional?
floor):
Ah, got it! This picture just makes me want to grab it and start spinning
parts of it :-)
Great concept!!! If you render the cubes so that you can see all sides, you
could make money off a poster for artists. I can totally see this on a
designer's wall!!!!!
Date: 13 Feb 2004 13:56:11
Message: <402d1dcb@news.povray.org>
You may want to use the macro Round_Box_Union() (Or Round_Box_Merge)
from shapes.inc. It'll look (almost) the same, and you'll always know
exactly how large the shape is.
HTH,
Florian
Date: 13 Feb 2004 14:27:45
Message: <402d2531$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:402d1dcb@news.povray.org...
floor):
In your case, you'll want to use Round_Box_Union. The difference between
Union and Merge is:
Union: Will group the objects together but each object will still retain its
surface.
Merge: Will "melt" the objects together and remove surfaces.
Think of "union" as a grouping tool and "merging" as a melting tool. If all
of your objects are opaque, as they are in your case, you can use "union"
because you won't see the surfaces of the cylinder, spheres, and boxes that
make up the cube. However, if your cube was made of glass, you would see the
cylinder, spheres, and boxes that make up the cube unless you chose to melt
them together using "merge".
Note that, as you probably guessed, merge takes longer to render because of
the extra work it has to do. So, use union whenever you can get away with
it.
Date: 16 Feb 2004 01:29:36
Message: <40306350@news.povray.org>
I had an attempt at making an RGB colour cube out of cubes, too. This
one is 64*64*64 boxes. I would have tried it larger, except I ran out of
memory.
Rohan _e_ii
Download 'boxtest2.png' (34 KB)
Preview of image 'boxtest2.png'
Date: 16 Feb 2004 10:18:52
Message: <opr3gx5zmv0x9foi@news.povray.org>
> memory.
Have you thought of removing the cubes inside your colorcube, since the
only visible small cubes are the outermost. For the whole cube 64*64*64 =
262.144 small cubes, but with the outer shell only 6*63*63 = 23.814, and
you perhaps won't ran out of memory (unless you already have done this).
light_source{20*y,1}#macro _(M,X,Y,P)#macro L(N,D)#if(N)#declare
P=P+D;box{-
0.5,0.5translate z*mod(9*P.gray,4)pigment{rgb P}rotate 45*x+clock*y
translate
P}L(N-1,D)#end#end#if(M)L(mod(M,8)<mod(X,3)mod(Y,3)1>-1)_(div(M,8)div(X,3)div
(Y,3)P)#end#end _(2301603551,12850,60365,20*z-5*x)plane{y,-9pigment{rgb 1}}
Date: 16 Feb 2004 18:48:55
Message: <403156e7$1@news.povray.org>
The best would be a mesh, I guess. I did
a very similar thing for LiveGraphics3D demo
on color spaces
(see http://www.iro.umontreal.ca/~pigeon/colorspaces/colorspaces.html )
The meshes are mathematica meshes (which can be converted
to pov rather easily)
Best,
    S.
Steven Pigeon, Ph. D.
pig### [at] iroumontrealca
"Rohan" <rox### [at] yahoocom> wrote in message
news:40306350@news.povray.org...
> memory.
> Rohan _e_ii
Subject: Re: Color Cube - colorcube.jpg (1/1)
Date: 16 Feb 2004 21:06:04
Message: <cjameshuff-FDD00D.21063616022004@news.povray.org>
In article <40306350@news.povray.org>, Rohan <rox### [at] yahoocom>
> memory.
Given that you can only see 3 sides, you could remove the vast majority
of the boxes. Or you could do it with one box and an average pigment:
box {0.001, 0.999
        pigment {average
            pigment_map {
                [1 gradient x color_map {[0 rgb 0][1 blue 1]}]
                [1 gradient y color_map {[0 rgb 0][1 green 1]}]
                [1 gradient -z color_map {[0 rgb 0][1 red 1]}]
        finish {diffuse 0 ambient 1}
    translate -0.5 scale 2
Peak memory used:           266864 bytes
http://tag.povray.org/
Download 'colorcube.jpg' (14 KB)
Preview of image 'colorcube.jpg'
Date: 22 Feb 2004 07:16:19
Message: <40389E23.9541CF3D@gmx.de>
High!
> memory.
Back in 2000 when I (after strictly avoiding dealing with pure POV for years,
instead relying on those klickibunti toys like Moray...) first experimented
with
#while loops, I also rendered an RGB cube... only 11 x 11 x 11 boxes, but
I think it has potential... such as making them semi-transparent, connecting
them with glass tubes - and finally rendering an animated flight through these
cubes and tubes!
See you in Khyberspace!
Yadgar
Download 'rgb.jpg' (82 KB)
Preview of image 'rgb.jpg'
Date: 22 Feb 2004 19:06:58
Message: <40394422@news.povray.org>
> cubes and tubes!
> Yadgar
i was somehow inspired by this ideo, so i made a rgb-cube with 11*11*11
boxes as well, but with transparency and connecting tubes :) the code
will soon be available in p.t.s-f (scalable rgb-cube with transparency)
it includes some splines for an animation, but they are not that good
and far from complete
bye,
	Marc
and god said: let there be a light_source { location SUN look_at EARTH,
rgb SUNLIGHT }
Download 'rgb_cube.jpg' (59 KB)
Preview of image 'rgb_cube.jpg'
Date: 22 Feb 2004 19:10:52
Message: <4039450c$1@news.povray.org>
"Marc Roth" <mar### [at] rothconsultcom> wrote in message
news:40394422@news.povray.org...
connecting
these
Wow, that really turned out cool!!!!!
Date: 22 Feb 2004 19:15:46
Message: <40394632$1@news.povray.org>
> connecting
> these
thx, took about 20min to render with AA0.3 but no radiosity... the only
problem is the max_trace_level which has to be really high to give it a
realistic look... i think for this render it was at 220. i set it to
20*dim where dim is the number of cubes per side to get through all the
layers...
bye
	Marc
rgb SUNLIGHT }
