POV-Ray : Newsgroups : povray.binaries.images : Water on Mars (78kb) Server Time
20 Oct 2026 21:03:30 EDT (-0400)
  Water on Mars (78kb) (Message 1 to 17 of 17)
Subject: Water on Mars (78kb)
Date: 31 Jan 2004 18:38:41
Message: <401c3c53@news.povray.org>
I'm currently experimenting a little to put some water on
Mars. I'm not sure if it looks realistic, so ideas are welcome.
The water has an interior with exponential fading.
The (nearly) same image without water can be found at
http://www.cip.physik.uni-muenchen.de/~wwieser/render/img/mars/index.html#3craters
Rendering time for 1200x600 +A0.2 was 330 minutes on AthlonXP 1.4GHz.
Memory consumption was 50Mb.
Wolfgang
Download '3craters-ese-2-1200b.jpg' (77 KB)
Preview of image '3craters-ese-2-1200b.jpg'
Subject: Re: Water on Mars (78kb)
Date: 1 Feb 2004 00:44:57
Message: <401c9259$1@news.povray.org>
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:401c3c53@news.povray.org...
I like. I'll get my swimsuit.
Looks pretty good, as is, actually. Something which could help it would be
flows from higher to lower elevations, but probably very difficult to do, if
not impossible. And would be a good idea to try and limit parts from getting
water too.
Of course, one thing a planet with water needs is plantlife in at least some
parts. Granted, there could still be somewhat lifeless regions caused by
salty bodies of water and such, but not always (well, lots of unknowns). So
maybe you could add a slope pigment to get regions looking like a kind of
foliage is covering parts of the ground or along the embankments.
BTW, I didn't get back to one of your previous messages where you told of
using a custom-made convertor of the MOLA img files. So thanks for telling
about that. I was still looking all over for more info about the resolutions
of the elevation data and I didn't get anywhere with that so I gave up
trying.
Any chance you'll be making your conversion tool available? If so I, for
one, have my hand out to await it. I'll try not to be pushy though.  ;-)
Date: 1 Feb 2004 04:35:26
Message: <401cc85e$1@news.povray.org>
Cooool!
Now I understand where is gone all the warter of Mars: with all these holes
it couldn't stay at the surface;-)
Marc
"Wolfgang Wieser" <wwi### [at] gmxde> a écrit dans le message de news:
Date: 1 Feb 2004 04:41:39
Message: <401cc9d3$1@news.povray.org>
"Hughes, B." <omn### [at] charternet> a écrit dans le message de news:
401c9259$1@news.povray.org...
some
So
 I wasn't born yet but it seems that, on earth, it took very long time to
life to conqueer emerged lands after it appeared in oceans.
It should have no chance to do so in the time liquid water was at the
surface of mars.
Marc
Date: 1 Feb 2004 05:50:37
Message: <401cd9fc@news.povray.org>
> if not impossible.
Yes... actually, the water level is not at the same height all over
the image but real flow from higher to lower would require a somewhat
different approach than I am doing right now.
> getting water too.
In the right back, correct. I did not notice that before the final
render. And a 5 hour render is not repeated quickly...
> some parts. Granted, there could still be somewhat lifeless regions caused
> by salty bodies of water and such, but not always (well, lots of
> unknowns). So maybe you could add a slope pigment to get regions looking
> like a kind of foliage is covering parts of the ground or along the
> embankments.
Allright, there is no limit on the amount of time one could spend
on making Mars look like a planet with plenty of life.
But for now, I just wanted to get some realistically-looking water.
> resolutions of the elevation data and I didn't get anywhere with that so I
> gave up trying.
You will need libz, libpng, libbz2 (on any recent linux distro),
hlib (on my homepage) and Qt-3.x (only free for linux).
Then, I could send you hlib-compression-addon, QTXlib and my conversion
utility. Compile all that using gcc-3.x on a linux box and there you go.
(The conversion utility has graphical output. When editing the source,
you may come along without Qt and QTXlib.)
In case anybody (possibly you) is interested in that I may make it
available on my home page in a week or so (there is an exam this
week...).
Wolfgang
Date: 1 Feb 2004 06:07:53
Message: <401cde09$1@news.povray.org>
news:401cd9fc@news.povray.org...
> week...).
I'm interrested :-)
Thank you.
ZeSly
http://perso.wanadoo.fr/zesly/
Date: 1 Feb 2004 17:10:10
Message: <401d7942$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:401cc9d3$1@news.povray.org...
> surface of mars.
Always debateable but, yes, I think you have a good point there. I used the
word plantlife in a very broad sense, including things like algae and even
protist slimey stuff someplace. :-)
This brings up something about the coloration of the water used here in
Wolfgang's rendering. My first thought was of water-borne life because of
the greenish tinge. A large manmade lake nearby here has a sometimes vivid
green coloring in certain places, brownish in others, yet overall tends to
be green hues. I don't know of any water having green colorations without
plantlife within it so its natural to think of it as life-bearing.
That might be something to change then to reflect a more sterile water on an
early Mars.
Bob H.
Date: 1 Feb 2004 17:11:51
Message: <401d79a7$1@news.povray.org>
Ahhh, linux.... something I'm not running on my computers here. Guess I'll
pass then, thanks anyhow for the offer!
Bob H.
http://www.3digitaleyes.com
> week...).
Date: 1 Feb 2004 18:07:04
Message: <401d8698@news.povray.org>
Copper and iron salts can be green too
(<http://www.wqa.org/sitelogic.cfm?ID=346>).
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 1 Feb 2004 18:12:12
Message: <401d87cc$1@news.povray.org>
Oh in water, life should be easier to born than on land ( less cosmic rays,
more even temperature, no need of  rain, no gravity to overcome, ect...) ,
so life could exist in seas hundreds millions years before on dry land.
Marc
401d7942$1@news.povray.org...
> > surface of mars.
the
an
> early Mars.
> Bob H.
Date: 2 Feb 2004 03:33:47
Message: <401e0b6b$1@news.povray.org>
"Jellby" <jel### [at] M-yahoocom> wrote in message
news:401d8698@news.povray.org...
Glad you showed that. I wasn't considering inorganic colorations.
I also think of the bacteria at Yellowstone National Park, in the hotsprings
there. Colorful stuff and not "plantlife" either. I keep using that word too
generally and used it again to mean any kind of microorganism.
Here's an article concerning Jupiter's moon Europa, about possibility of
bacteria and the colors on it's surface:
http://nai.arc.nasa.gov/news_stories/news_detail.cfm?ID=53
Bob H.
Date: 2 Feb 2004 14:30:30
Message: <401ea555@news.povray.org>
[following the nice discussion about signs of life...]
Actually, the coloring of the water was the major problem.
I'm not sure if an ocean on Mars would be so blue; at least
there is no blue sky which could be reflected.
And then I had to make it much darker than I thought because
if I leave the water more transparent it no longer looks like
liquid water at all but like dark dry sediments. Or maybe, this
perception varies quite a lot between different people.
And yes, I decided to make the water (absorption) a bit greenish
because it turned out that I liked it...
But now, I will be telling people it's some anorganic salts ;)
(Thanks Jellby)
BTW, there is now an updated version on my homepage. I removed
some spurious water in the background by re-adjusting the level.
Especially have a look at the crater right back!
http://www.cip.physik.uni-muenchen.de/~wwieser/render/img/mars/3craters-ese-2-1200.jpg
Wolfgang
Date: 2 Feb 2004 21:32:50
Message: <401f0852$1@news.povray.org>
Looks better.
There are some peculiar squiggles running from lower right toward the
middle, and comparing this new render to the other I see it was also visible
there. Just much clearer to see now. Perhaps a isosurface with too low a
max_gradient?
Bob H.
news:401ea555@news.povray.org...
---snip---
Date: 4 Feb 2004 02:24:54
Message: <40209EC9.C6D32AB0@gmx.de>
High!
I don't think so... as long Mars was able to maintain liquid water on its surface, the
atmosphere must have been much denser
then today, and so the sky also was coloured up to the zenith, unlike nowadays. And
even
today sometimes, depending on
weather and dust saturation of the air, the reddish/yellowish horizon seam turns
bluish -
so also the early Martian oceans
would probably have been deep blue like Earth's oceans as seen from orbit
Did you use 8 or 16bit resolution for the heightfield? I assume that you used
Christoph's
IC_HF_Sphere function to wrap it
around the sphere... perhaps in the future, we might be able to reduce rendering time
by
just rendering those portions (tiles)
of the heightfield which would be actually visible in the image; currently, I try to
modify IC_HF_Sphere to render only
sections of a spherical heightfield...
See you in Khyberspace - http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Home-made electronic music: http://home.arcor.de/yadgar/music/
Yadgar ((:->
Now playing: Upstairs in my House (Men at Work)
Pashto 2.0, a protocol language for the Advanced Fractal Geometric Heightfield and
Navigation Implementation-Sensitive
Texture Analysis Network
Date: 6 Feb 2004 16:18:25
Message: <402404a1@news.povray.org>
16 bit. But no height field.
Wolfgang
Date: 6 Feb 2004 16:28:45
Message: <4024070c@news.povray.org>
> visible there. Just much clearer to see now. Perhaps a isosurface with too
> low a max_gradient?
I see what you mean.
There are more spots of this sort.
They are not related to the water surface because they are also
visible on the rendering without water.
I'm not sure what it is but I doubt it is due to max_gradient (which
was set too high and hence the reason for the render to take soo long).
I'll see if changing accuracy/gradient will help.
OTOH, it does not really hurt, IMO.
Wolfgang
Date: 8 Feb 2004 15:13:59
Message: <40269907.4B07D28D@gmx.de>
High!
So it must be a mesh - how long did it take to parse?
See you in Khyberspace!
Yadgar
Now playing: Fashion Fever (Level 42)
