The snowman is reused from an old image:
http://www.tu-bs.de/~y0013390/pov/pict/snowman.jpg
The sky is made with the skylight macro from Jaime's lightsys:
http://www.ignorancia.org/t_lightsys.php
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Download 'snowman2.jpg' (71 KB)
Preview of image 'snowman2.jpg'
Christoph:
Nice. This might be the best of your many landscapes so far.
Aaron
Yeah, those mountains really look very good. Do we get the source as a Christmas
present ;)
Ryan
"Aaron Gillies" <bee### [at] snicker org> wrote in message
news:3fe5bd0c$1@news.povray.org...
> Christoph:
> Aaron
Nice.
I just found and downloaded the new version of lightsys. Any idea why it
doesn't work with MegaPOV1.0 ? It works with POV3.5 !
Yesterday I played with the skylight macro (apparently an older version from
this news archieve) but I ran into many problems with light intensity. The
sky around the sun couldn't get bright enough to give correct reflections.
Has this issue been addressed?
Hugo
Very nice image, Christoph. Excellent for a quick christmas card,
indeed. No snow around here to check realism, sorry... :)
To be honest, this version of skylight.inc is the work of Philippe
Debar, adapted by Ive to work with Lightsys: I even don't remember if I
myself done any little teaking...
I don't know if the results are very accurate, but it gives slighty
nicer results than the original version.
Jaime
How? ...what's the error? I can't figure why it will not work (I
don't have MegaPOV right now to test).
Hmmm... I think the answer is no, but try yourself, please.
Jaime
Subject: Re: Merry Christmas - Lightsys error message
Date: 22 Dec 2003 16:31:46
Message: <3fe762c2@news.povray.org>
> (I don't have MegaPOV right now to test).
Glad to see you stopped by! The updated lightsys is great! The bug is a bit
difficult for me to track down. The error message prevents all your demos /
templates / tests to parse. I have 4 versions of POV-Ray installed. They all
claim to be based on the POV3.5 source, but your macros only work in 2
versions:
Official POV3.5 = works.
Unofficial MLpov 0.81 = works.
Unofficial POVman 1.0 = breaks.
Unofficial MegaPOV1.0 = breaks.
Here's an example of the error message:
File: demo_cyndi_cubes.pov Line: 38
#declare LC1 = EmissiveSpectrum(ES_Osram_CoolFluor_36w) <----ERROR
Parse Error: Expected '( or [', ) found instead
Returned from renderer with error status
When I add () it complains that no value was found in between the
parantheses. When I write (1) it breaks the macros. Maybe it has something
to do with splines, since "ES_Osram_CoolFluor_36w" refer to a spline...(?)
Best regards,
Hugo
On Mon, 22 Dec 2003 22:32:19 +0100, "Hugo Asm" <hua### [at] post3 tele dk> wrote:
Yes, there is known problem of spline being parameter. It is fixed for next
release, meantime try to add spline{} around ES_Osram_CoolFluor_36w. It should
help. Sorry for inconvenience.
ABX
Thanks.
The snow is indeed the weak point - i played with the idea of a
subsurface scattering version but this scene is not fast enough and the
geometry is not that good to show the scattering anyway.
The problem i have with the skylight macro is that it does not offer
much control over the colors. I used a different light color for the
sky than for the light source to have more freedom in that part.
Another thing is of course that the use of a mesh for the sky is
certainly not the best solution - although it is of course the only
viable one with standard POV. A feature to have image_maps based on an
internal array (or an ascii hdr file format) would be useful for this.
> present ;)
The mountains are actually quite simple, the structure is made with a
f_ridged_mf() function and the coloring with a slope pattern. I posted
examples for this in the past:
Subject: Re: iso - ridged mf question
Date: Mon, 12 Mar 2001 19:20:26 +0100
Newsgroups: povray.unofficial.patches
news://news.povray.org/3AAD136A.E955EBF@gmx.de
http://news.povray.org/3AAD136A.E955EBF@gmx.de
Subject: Re: Isosurface troble
Date: Mon, 05 Aug 2002 22:58:41 +0200
Newsgroups: povray.general
news://news.povray.org/3D4EE701.AF500714@gmx.de
http://news.povray.org/3D4EE701.AF500714@gmx.de
Subject: Re: hf and slope
Date: Wed, 21 Mar 2001 17:08:21 +0100
Newsgroups: povray.advanced-users
news://news.povray.org/3AB8D1F5.7D4595C7@gmx.de
http://news.povray.org/3AB8D1F5.7D4595C7@gmx.de
Well, SSS will have made it a christmas card for next year... :)
By "not much control" you mean really "no control at all", isn't? I
think this is a "feature", the main feature for a sky model, IMHO: I
don't have to think on the colors. Of course, you can always ignore
SunColor and use whatever you want for a concrete artistic effect. I
tried for example using a blackbody between 2000 and 6500 K, depending
on the altitude, and it also works nicely.
Yes, the mesh is a bit slow to generate when you need great detail on
the sky, to avoid seing the triangles. I hope Phillipe will have the
time this year to add the save/load feature for the mesh.
Regards..
Jaime
You have quite a bit of control over the sky appearance with the
Current_Turbidity and Intensity_Mult parameters. But still it is
somewhat limited - there is no difference made between dust turbidity
and fog turbidity for example. I agree that it's a nice thing to have a
light setup you can use without thinking and that works reasonably well
then but for a scene that needs a lot of work otherwise you usually want
to have more control on the sky as well.
