POV-Ray : Newsgroups : povray.binaries.images : Mosaic Server Time
5 Aug 2026 08:41:36 EDT (-0400)
  Mosaic (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Mosaic
Date: 16 Dec 2003 11:34:47
Message: <3fdf3427@news.povray.org>
Fantastic. Cheers!
Subject: Re: Mosaic
Date: 16 Dec 2003 19:19:53
Message: <3fdfa129$1@news.povray.org>
I'm not sure that the code would be very valuable.
This is essentially a grid of randomly-sized superellipsoid tiles.
The placement of the tiles is offset by the corresponding positions
on two splines aligned along the X and Y axes.
The pigment for the tiles is specified by sampling a bitmap
using the eval_pigment function.
Aaron
Subject: Re: Mosaic
Date: 16 Dec 2003 19:37:56
Message: <3fdfa564$1@news.povray.org>
"Aaron Gillies" <bee### [at] snickerorg> wrote in message
news:3fdfa129$1@news.povray.org...
Sometimes I think you overestimate our abilities, and perhaps underestimate
your own.
This rocks! (by the way)
Jeremy
Subject: Re: Mosaic
Date: 16 Dec 2003 19:45:26
Message: <3fdfa726$1@news.povray.org>
Source posted in p.b.s-f.
Not sure if it is really all that helpful, but maybe someone will
find some value in it.  It's a bit of a mess, looking back at it
after a couple of days.
Aaron
Subject: Re: Mosaic
Date: 17 Dec 2003 13:30:02
Message: <web.3fe0a0416b903b863e7f78a60@news.povray.org>
Thanks for posting the source; I'm enjoying looking at the effect with
different images.
Subject: Re: Mosaic
Date: 17 Dec 2003 13:40:33
Message: <3fe0a321$1@news.povray.org>
Thanks!  I'm also hesitant to post some of my messy stuff.  I always start
out with good source, but in the end, only I can understand it.  :-/  Even
so, sometimes it's nice just to figure out how one certain effect is
achieved.
Thanks again.  For relative newbies like me, p.b.s-f is a treasure.  :-)
Jeremy
news:3fdfa726$1@news.povray.org...
> Aaron
Subject: Re: Mosaic
Date: 17 Dec 2003 22:12:55
Message: <3fe11b37$1@news.povray.org>
I'm enjoying it.  Thanks!
What resolution is the jpg you use?  Mine seems to wrap strangely.
> Aaron
Subject: Re: Mosaic
Date: 17 Dec 2003 23:48:22
Message: <3fe13196$1@news.povray.org>
Thanks, guys ...
The original source image was some multiple of 100 pixels wide by 70 high.
I think I multiplied by two for some reason in the source (probably to bring
the bird head into view).
You should use the actual dimensions of your source image as follows:
#local I =
    image_map {
      jpeg "mozaik.jpg"
    translate <0, -.5, 0>
    scale <Width, Height, 1>
where Width is the width and Height is the height, etc.
Aaron
Post some of your own images that you used my script on?  I'm sort
of curious.
Subject: Re: Mosaic
Date: 18 Dec 2003 02:50:01
Message: <web.3fe15b496b903b865bbd07b60@news.povray.org>
I had to use translate <-0.5, -0.5, 0> to center my images.
>of curious.
I'd like to see some as well. I'll post one, but my access
to a news server is on another computer so it will be later.
Subject: Re: Mosaic
Date: 18 Dec 2003 03:59:41
Message: <3fe16c7d$1@news.povray.org>
Yep.  <-.5, -.5, 0> completely centers the image.
The bird in my mosaic was not in the center of the source image, so
I adjusted it a bit.
Aaron
"Renderdog" <slo### [at] hiwaaynet> wrote in message
news:web.3fe15b496b903b865bbd07b60@news.povray.org...
> >of curious.
