My latest rendering...
I don't know why, but this image took 30 hours to render??
30 hours on a AMD 2100+ XP...but radiosity settings need to be tweaked
probably.
Download 'Ball-of-rings.jpg' (214 KB)
Preview of image 'Ball-of-rings.jpg'
Pyr### [at] shaw ca news:3fc875ac@news.povray.org
This is probably problem with bounding boxes, I quess that vista buffer
and/or BB don't work very vell with differences (I quess You used
differences of cones to create rings?)
Probably if You used mesh, or divide each ring into small sectors (each
having own BB) that might help... BUT it's only imho.
Ah, your probably right!
The rings are made by the difference of 2 spheres and 2 cones (then union
two torus), so the bb must be of the sphere right now...no wonder!
Thanks, I'll try to see if that helps.
> I quess that vista buffer and/or BB don't work very vell
> with differences (I quess You used differences of cones to
> create rings?)
Apropos bounding boxes, does any of you have an idea why my recent rendering
with a few hundred thousand blob components (maybe 300.000) has now taken 70
hours to render in 800x600 and STILL need a few days?? I am completely
stunned! I've split the blob into a grid of 8*8 blocks so that not all
300.000 components needs to be considered for every pixel... But... It's
still so slow?
Maybe I should mention that I'm using focal_blur with 40 samples (not a lot,
but enough) and I'm using pre-calculated radiosity settings.
Hugo
> still so slow?
Splitting the blob components into several objects will usually not
speed up the render but slow it down. If all components would have to
be considered for every pixel you probably would not even have finished
the first line yet.
Then i would not complain.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Thanks,
The blobs are meant to simulate snow. They are traced randomly to cover an
object. I thought that maybe automatic bounding wasn't very efficient when
so many blob components have random positions. This is only speculation -
but I thought, splitting them into a grid of 8*8 sections that does not
overlap each other, could help to eleminate tests for blobs that are far
away. Even if this doesn't speed up rendering, would it slow things down?
Hugo
hua### [at] post3 tele dk news:3fca23f7@news.povray.org
Hmm this is quite long,
1) hierarchy is ofcourse *on* as default ?
2) bouning boxes do work? maybe set bounding_threshold to 1 to enforce
using them
Btw, I do have few ideas about speeding up renderings of most POV
objects... I hope I'll have time to implement them and they will prove
usefull :)
One of simplest of thoes ideas - triangulize Your object (trace lots of
points, then connect them into smooth mesh). It would be nice if POV could
a) done this automaticly
b) ...with calculating normals
c) ...with handling non-continous objects (with holes in them, or with
totaly not-connected to each other parts)
I've checked: yes.
> bounding_threshold to 1 to enforce using them
I needed the docs to explain this keyword but yes, my scene contains 87
frame-level objects so bounding_threshold is on. There are no particular
.ini settings used and also, the sturmian rootsolver is not used.
You have good ideas.
Hugo
"Rafal 'Raf256' Maj" <spa### [at] raf256 com> wrote in message
news:Xns### [at] 204 213 191 226...
of
| could
It would be pretty useless. It is better for you as a user to build
meshing macros based on your specific need than to use a generalized
algorithm. The only situations where a generalized algorithm produces
anything at all reasonable are situations where Pov-Ray primitives,
heightfields, and isosurfaces perform well already.
You or I could write a meshing algorithm specifically for snow, but I
can guarantee that some generalized algorithm like marching cubes would
produce so many triangles that no one would have the RAM to render the
scene.
-Shay
Would probably be a good idea ... maybe even an isosurface would be quicker.
My rendering is *still* running and it's been another 2 days since my last
post. I can see that it's still going to take many hours to complete!
Although I think my image looks nice, it's not worth burning off *that* many
cpu-cycles.
I think, there are some plugins in some commercial modellers that can add
snow or dirt to a mesh.. If anyone knows more about this, I would be
interested since I couldn't find enough information on google.
Hugo
"Hugo Asm" <hua### [at] post3 tele dk> wrote in message
news:3fcbb4b6$1@news.povray.org...
I really don't have the time, but I am tempted to give it a shot. Out of
curiosity, what algorithm did you use to determine the location and size
of your snow blobs? I've never seen snow.
On the original topic of this thread. That is a quite nice ball of
rings, but it would have been pretty simple and faster rendering as a
mesh also.
-Shay
You've never seen snow? I probably shouldn't take this literally.
Well, I used Gilles Tran's "makesnow.inc" at first, then modified it to
speed up parsing but the idea is still a very simple approximation:
I declare a direction vector that simulates wind and gravity, such as
<-1, -1, 0> which would tend to cover the top and right side of an object
(assuming y is height). The size of each particle is random but has a
minimum & maximum limit. I use the "trace" feature to shoot rays at an
object, which in my case is an imported mesh2... Gilles' macro can be found
here: http://www.oyonale.com/ressources/downloads/makesnow.inc
I know you're skilled when it comes to handling triangles - so good luck -
the project is interesting - but feel free to stop when you want to.
Best wishes,
Hugo
PS: we should probably continue the thread somewhere else.
Saw the first snow for the year this morning. They were filming
something or other on the corner and had snowmaking equipment out to put
snow in the scene.
hua### [at] post3 tele dk news:3fcbb4b6$1@news.povray.org
> quicker.
No, mesh is quicker. I.e. inside my wax figures are over 200.000 particles.
news:3fcbc6d3$1@news.povray.org...
| this literally.
I meant it literally. It has snowed a handful of times here, but it
melts as soon as it touches the ground.
I put something together last night. I guess it looked like a blob mesh
would on a little isosurface mauntain range I made. That is, it looked
like white, puffy grass. The parse was about half an hour, but the
render time is measured in minutes, not days. I took a look at Gilles
website and saw that he had noticed the same problem, that the algorithm
only produces good results in small patches on tree limbs and such. I
built the mesh so that it can be further refined (within the limits of
fp precision) so the with enough memory, an acceptable snow might be
made on a jagged enough mountain. I would guess that mountains don't get
snow-covered in one pass anyway, so it might be that this algorithm
would never produce realistic results on a large object.
I set followups to p.gen if you have any further comment.
-Shay
