Just a little WIP
Digital camera's batteries and little "buttons" (?!) batteries... More
styles to come.
Rendered used : mlPOV 0.83. HDRI + Bokeh_pigment (for the deppth of field).
Comments and suggestions welcomes.
Download 'wip3.jpg' (100 KB)
Preview of image 'wip3.jpg'
"_Light_Beam_" <s.f### [at] tiscali fr> wrote in message
news:3fb56374@news.povray.org...
> Just a little WIP
> styles to come.
field).
> Thanks :-)
Very nice!
Maybe throw in a couple quarters with the coin cells?
They make me think of money. :(
Can you post source?
Good job for the textures, reflections of the hdr map look really nice !
I don't see depth of field , may be increase a little the effect ? Also the
shadows on the plane are too dark, what about a small amount of a fill light
on the left ?
M
Cool stuff. The small batteries look a bit like coins, I think we would
better see the carves from an higher view. The black part between the
two faces seems too thin too (but maybe it's like this on the real
batteries).
JC
_Light_Beam_ wrote:
> Just a little WIP
> styles to come.
> Thanks :-)
_Light_Beam_ wrote:
> Just a little WIP
> styles to come.
> Thanks :-)
I don't see the depth of field. *shrug*
Reflection looks nice, but the shadows don't seem to match the
environment. It looks like you oughta have at least two lights..
alternately, you could try using radiosity with the HDRI data (if mlPOV
supports that.. I've never played with it).
-Xplo
I think you need to add more detail to the batteries, such as the seam on
the battery label
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
I'll probably post source when it will be finished...
Thank you Mr Mael ! ça n'aurait pas été possible sans ton fameux patch ;-)
the
light
> on the left ?
The Dof is really "thin" I'll surely increase it...
And I'll also put à little shadowless light on that corner... its an idea...
(to removes thse too-dark shadows)
I'll change...
I notice...
mlPOV is the ONLY version of pov (known be myself.. huh) that's can makes
HDRI... Try it and you will see this i a great patched version...
Thank you for these comments and suggestions... so I need to improve the
scene... (9V batteries... etter lightning... Better DoF...)
Last I heard there was no Mac port. *shrug*
-Xplo
Can you post a link to mlPOV? Haven't seen that before.
Douglas C. Eichenberg
dou### [at] nls net
http://www.getinfo.net/douge
> -Xplo
Ask Mael for sources... and re-compile !! No ? ;-)
> dou### [at] nls net
Ikusé !!!!
http://pov.monde.free.fr/mael/mlpov083.html
On Sat, 15 Nov 2003 18:33:07 +0100, "_Light_Beam_" <s.f### [at] tiscali fr> wrote:
IIRC MLPOV is the ONLY released version that's can _USE_ HDRI.
Next MegaPOV is the one POV which will allow to _MAKE_ HDRI (when it's
released).
ABX
Yes, mlpov only read hdr format (with a not very complete reader by the
way..)
> released).
Do you realize that it's kind of frustrating for users to read those lastest
months posts about "future pov 3.5.1 will fix this", "next megapov 1.1 will
offer that" :(
Sure it's nice to know that things are done but at the same time, if you
can't try them .. :)
M
> > released).
> offer that" :(
Sorry, I was trying to be informative rather than bragging.
Sadly, it is kind of frustrating to answer this way for me, too :-(
I really wish we could release binaries, but we can't without sources. But we
can't release sources because they are in sync with 3.5.1 development because
at initial stage official POV was supposed to be available earlier. The bright
side is that there shouldn't be long delay between 3.5.1 and MegaPOV 1.1.
And... there is already tested solution for frustration for braves :-)
I released 'user_defined camera' patch to two persons. They asked for
simplified diffs because they really needed them for important tasks.
ABX
On Sat, 15 Nov 2003 00:21:09 +0100, "_Light_Beam_"
Great picture!
Perhaps the shadows would become a bit more realistic if you could
enlarge the dimensions of the area_light (or isn't it rendered with
arealight?)...
The bottom of the lying battery seems to have another texture than the
coin cells, it looks more than aluminium or does this come from
missing reflected objects?
Erhard Ducke
