Yet another MayaFur test. I have the initial placement macro working (it
aligns properly to the surface normal vector now), and the incloination is
working. An inclination of 0 means each hair is fully erect (perpendicular
to the surface), and an inclination of 1 means each hair is tangent to the
surface. The attachment was just one of the tests that looked kinda cool...
looks sort of like a shag carpet bunny.
Douglas C. Eichenberg
dou### [at] nls net
http://www.getinfo.net/douge
Download 'shagbunny.jpg' (75 KB)
Preview of image 'shagbunny.jpg'
Worms. Maggots. Ewwwwwwwwww.
Tim Cook
Version: 3.12
> (perpendicular to the surface), and an inclination of 1 means each hair is
> tangent to the
> cool... looks sort of like a shag carpet bunny.
nice effect. Is the bunny CSG?
aaa := ira
Having just watched "Princess Mononoke" for the first time, it reminds me of
the boar.
It's a demon bunny! Just add red eyes... ;-)
Jeremy
"Tim Cook" <z99### [at] bellsouth net> wrote in message
news:3f261813$1@news.povray.org...
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
"Doug Eichenberg" <dou### [at] nls net> wrote in
news:3f25ecd0@news.povray.org:
Cool!
give it another colour and some tomato sauce. Then it will look really tasty
Nice Pic BTW.
Robert
"Doug Eichenberg" <dou### [at] nls net> schrieb im Newsbeitrag
news:3f25ecd0@news.povray.org...
(perpendicular
cool...
> dou### [at] nls net
Perhaps I'm crazy but the word "maya" gives me the creeps. A neutral name
wouldn't sound as if POV needs help by importing features from competitive
software. Ok, I AM a bit crazy, but so what...
It looks nice, really. :o)
Regards
Hugo
Hadn't thought about that. Technically they aren't really competitive
packages... one is free, and the other is about 5 grand. The fur output
from maya is really slick though, to be honest... so I modelled my code
after it. It uses the same variables, so essentially you can take the Maya
variables and plug them right in.
dou### [at] nls net
The rabbit is a triangle mesh I converted from a 3ds file. The fur
placement routine requires a PCM file, made with Warps mesh compressor. It
then parses through the PCM file and places the fur on a per triangle basis.
dou### [at] nls net
>dou### [at] nls net
Wow! That is some very nice fur. Have you played around with some form of
mapping for where fur should go on the critter yet? I spent a couple of
minutes the other day making a proof of concept for the eval_pigment
method. I could post my code if you want but its kinda messy. Plus from
what I have read it would be faster to do with functions if you are so
inclined.
By the way nice model, dust bunny... dusting bunny?
I figured most people will be using it on meshes, so I wrote a placement
routine with that in mind... basically an add-on macro to Chris Colefaxes
PCM macros. I think for other uses I will leave it to the user. The per
triangle method I came up with seems to give the best coverage. I tried a
random bounding box approach, and there were just too many patchy areas.
dou### [at] nls net
Yes where to take samples from was my main problem aswell, too many samples
and the parse gets slow, too few... Also figuring out how to hit every
nook and
cranny was a problem with using trace() as things could be shadowed from my
rays. Still for baldness and such... maybe do per-vertex hairiness?
oh-well I guess I will have to wait until you release it to what it can do!
> It then parses through the PCM file and places the fur on a per triangle
> basis.
Would you mind to send it to me? I would like to test it with my fur.
Thanks in advance.
aaa := ira
"Doug Eichenberg" <dou### [at] nls net> wrote in message
Rugs bunny! I love it.
Alf
Sure, send me an e-mail, it might be too big to post here.
dou### [at] nls net
