POV-Ray : Newsgroups : povray.binaries.images : HELP!!!! Server Time
30 Nov 2026 06:34:22 EST (-0500)
  HELP!!!! (Message 1 to 19 of 19)
Subject: HELP!!!!
Date: 28 Jun 2003 19:35:39
Message: <3efe264b$1@news.povray.org>
I killed povray!!!
Can someone help me render a scene,
I am working on this abstract thing and i am trying to render it but its
taking forever.
Will someone with a fast processor or way of rendering help me...
Or maybe some help taking time off rendering...
I like the scene as is so anything that is not destructive to the way it
looks or renders would be great.
I would love it so much if it could be 1024-768 aa 0.3
Thanks Tonnes!!!!
Source
#declare Radiosity=on
global_settings {
   assumed_gamma 1.0
   //max_trace_level 25
   #if (Radiosity)
     radiosity {
       pretrace_start 0.08           // start pretrace at this size
       pretrace_end   0.04           // end pretrace at this size
       count 35                      // higher -> higher quality
(1..1600) [35]
       nearest_count 5               // higher -> higher quality (1..10) [5]
       error_bound 1.8               // higher -> smoother, less
accurate [1.8]
       recursion_limit 3             // how much interreflections are
calculated (1..5+) [3]
       low_error_factor .5           // reduce error_bound during last
pretrace step
       gray_threshold 0.0            // increase for weakening colors
(0..1) [0]
       minimum_reuse 0.015           // reuse of old radiosity samples
[0.015]
       brightness 1                  // brightness of radiosity effects
(0..1) [1]
       adc_bailout 0.01/2
       //normal on                   // take surface normals into
account [off]
       //media on                    // take media into account [off]
       //save_file "file_name"       // save radiosity data
       //load_file "file_name"       // load saved radiosity data
       //always_sample off           // turn sampling in final trace off
[on]
       //max_sample 1.0              // maximum brightness of samples
//-------------- Includes
#include "textures.inc"
#include "metals.inc"
//----------------------------      Variables for size and seed
    #declare R = seed(12);
    #declare num_spheres = 40;
    #declare area=10;
    #declare min_size = .15;
    #declare max_size = .35;
#declare thing = sphere_sweep {
    //linear_spline | b_spline | cubic_spline
    cubic_spline
    num_spheres,
    #declare i = 0;
    #declare start_pos = <rand(R)*area-(area/2), rand(R)*area-(area/2),
rand(R)*area-(area/2)>;
    start_pos, rand(R)*(max_size - min_size)+min_size,
    #while (i<num_spheres - 2)
       #declare s_size = rand(R)*(max_size - min_size)+min_size;
rand(R)*area-(area/2)>, s_size,
       #declare i = i + 1;
    //no_shadow
object {thing  texture {T_Chrome_2E }}
/*light_source {
   0*x
   color rgb <1,1,1>
   translate <0, 10, -10>
light_source {
   0*x                 // light's position (translated below)
   color rgb 1.0       // light's color
   area_light
   <8, 0, 0> <0, 0, 8> // lights spread out across this distance (x * z)
   4, 4                // total number of lights in grid (4x*4z = 16 lights)
   adaptive 4          // 0,1,2,3...
   jitter              // adds random softening of light
   circular            // make the shape of the light circular
   orient              // orient light
   translate <40, 80, -40>   // <x y z> position of light
     location  <0,1.5,-8.5>
    look_at <0, 0, 0>
//--------------------------------------------        Extra Scene objects
sky_sphere {  pigment {   White} }
//    gradient y
//    color_map {
//      [0.0 rgb <0.6,0.7,1.0>]
//      [0.7 rgb <0.0,0.1,0.8>]
plane {
   y, -1.5
   pigment { color rgb <0.7,0.5,0.5> }
    plane {
   y, -3.5
//pigment{White}
     pigment { rgb <1,1,1 > }
     finish {
         ambient 0
         diffuse 0
         reflection .3
         brilliance 0
         specular 1
         roughness 1
#declare thin = union {
torus {
   0.8,
   0.2
scale y*1
torus {
   0.8,
   0.2
scale z*2
rotate x*90
   #declare thig2 = union {
object{thin scale 1 texture {T_Chrome_2D}//no_shadow
rotate z*0}
object{thin scale 1.2 texture {T_Chrome_2E}//no_shadow
rotate z*45}
object{thin scale 1.4 texture {T_Chrome_3A}//no_shadow
rotate z*90}
object{thin scale 1.6 texture {T_Chrome_4B}//no_shadow
rotate z*135}
object{thin scale 1.8 texture {T_Chrome_4C}// no_shadow
rotate z*180}
object{thin scale 2 texture {T_Chrome_2A}//no_shadow
rotate z*225}
object{thin scale 2.2 texture {T_Chrome_2B}//no_shadow
rotate z*270}
object{thin scale 2.4 texture {T_Chrome_2C}//no_shadow
rotate z*315}
object {thig2  }
  //sphere { <0, -2.5, 5>, 1 pigment {Red}}
Subject: Re: HELP!!!!
Date: 28 Jun 2003 19:36:14
Message: <3efe266e@news.povray.org>
Also my image that i'm posting is the source, ty
Flaming Monarch wrote:
> I killed povray!!!
> taking forever.
> Thanks Tonnes!!!!
> Source
> global_settings {
>   assumed_gamma 1.0
>   #if (Radiosity)
>     radiosity {
> (1..1600) [35]
>       error_bound 1.8               // higher -> smoother, less accurate
> [1.8]
> pretrace step
> (0..1) [0]
> [0.015]
> (0..1) [1]
>       adc_bailout 0.01/2
>       //normal on                   // take surface normals into account
> [off]
> [on]
>   #end
>    #declare area=10;
>    cubic_spline
>    num_spheres,
>    #declare i = 0;
>       #declare i = i + 1;
>    #end
>    //no_shadow
> /*light_source {
>   0*x
>   color rgb <1,1,1>
> light_source {
>   area_light
> camera {
>    look_at <0, 0, 0>
> //    gradient y
> //    color_map {
> plane {
>   y, -1.5
>    plane {
>   y, -3.5
> //pigment{White}
>     texture {
>     finish {
>         ambient 0
>         diffuse 0
>         reflection .3
>         brilliance 0
>         specular 1
>         roughness 1
> torus {
>   0.8,
>   0.2
> scale y*1
> torus {
>   0.8,
>   0.2
> scale z*2
> rotate x*90
> rotate z*0}
> rotate z*45}
> rotate z*90}
> rotate z*135}
> rotate z*180}
> rotate z*225}
> rotate z*270}
> rotate z*315}
> object {thig2  }
Date: 28 Jun 2003 21:20:01
Message: <web.3efe3be43a03cfbfb78e044d0@news.povray.org>
>I killed povray!!!
I don't want to sound rude, but this isn't the group you are looking for.
For newbie questions, please use povray.newusers. If you want to post a
scene, please use povray.binaries.scene-files or povray.text.scene-files.
Please read the FAQ, too.
Anyway, the "problems" with your scene:
-"Complex" objects
-Lots of reflective surfaces
-Radiosity
-Area lights
Any of these makes a scene render slow. If you combine two of these, your
render will be somewhere between very slow and extremely slow. If you
combine more than two, you are probably hopeless.
(This might be a case of RTFM as well, I'm pretty sure that the docs have
some info on how these functions affect render time.)
Gergely
Date: 29 Jun 2003 04:06:20
Message: <Xns93A96864C38D5torolavkhotmailcom@204.213.191.226>
Flaming Monarch <fla### [at] gatescom> wrote in
news:3efe264b$1@news.povray.org:
> I killed povray!!!
> its taking forever.
> it looks or renders would be great.
I let my PC render your image during the night. It is finished now.
(4 hours @ 2 GHz Athlon)
How do you me to send it to you ?
E.g.:
.jpg -> By email
.jpg -> Posted to povray.binaries.images
.png or .bmp -> Uploaded temporarily to my home page server
Tor Olav
Date: 29 Jun 2003 07:17:23
Message: <3efecac3$1@news.povray.org>
Thanks dude, Email me at
Fla### [at] fentraxcom
>>I killed povray!!!
>>its taking forever.
> E.g.:
> .jpg -> By email
> Tor Olav
Subject: Re: HELP!!!! - 1 attachment
Date: 29 Jun 2003 08:18:11
Message: <Xns93A953BF25C10badhabit07hotmaildot@204.213.191.226>
Just for curiosity, I rendered it last night @ 1280X1024. I thought that
others might want to see it too. So here's the details followed by the
image...
I rendered it on a P4 2.7GH[512K Cache 533MHZ] @ 1024MB RDRAM
Statistics for test3.pov, Resolution 1280 x 1024
Pixels:         1312689   Samples:         3065041   Smpls/Pxl: 2.33
Rays:          12091612   Saved:             29036   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Plane                         59562867         5475468      9.19
Sphere Sweep                 129703511        50443719     38.89
Torus                         44692530        16088791     36.00
Torus Bound                   44692530        18582480     41.58
Bounding Box                 525172097       179772564     34.23
Vista Buffer                  38184506        30319591     79.40
Roots tested:           4817612387   eliminated:             7407854
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:        142451087   Succeeded:             47275155
Reflected Rays:            8855638
Radiosity samples calculated:       5305 (0.08 percent)
Radiosity samples reused:        6822597
Smallest Alloc:                 25 bytes   Largest:            25644
Peak memory used:          1068595 bytes
Time For Trace:    5 hours 55 minutes   7.0 seconds (21307 seconds)
    Total Time:    5 hours 55 minutes   7.0 seconds (21307 seconds)
CPU time used: kernel 0.78 seconds, user 21301.53 seconds, total 21302.31
seconds
Render averaged 61.53 PPS over 1310720 pixels
This file was encoded with the new yEnc encoding scheme, designed to save
bandwidth by dramatically reducing the 30%+ overhead incurred by UU and Base64.
For more info, see http://www.yenc.org/
Download '=ybegin line=128 size=101656 name=test3.jpg.dat' (103 KB)
Date: 29 Jun 2003 08:26:12
Message: <Xns93A9551BF548Bbadhabit07hotmaildot@204.213.191.226>
Martin Belair <bad### [at] hotmailDOTcom> wrote in
> save bandwidth by dramatically reducing the 30%+ overhead incurred by
> UU and Base64. For more info, see http://www.yenc.org/
Oh yes.... The attachement is yEnc encoded. If you can't decode it, and have
enough request, I can re-send it the old fashion way....
Ciao!
Mart
Date: 29 Jun 2003 08:27:12
Message: <3efedb20@news.povray.org>
Cool, Ty for the help, but I dont think that the image attached very
well. its all weird like when u open an image in notepad.
> image...
> seconds
))=J*:tpsp*++**+*+**)(*zp“–J¡œ“žž˜J¡“ž’Jm™—šŸz“R|SJWJz’™ž™Ž¢Jm™œš™œ‹ž“™˜JR’žžšdYY¡¡¡Xš’™ž™Ž¢X™—S)*®*:56864:878<;:=}BRDB@
@B[MOGRd]gfc]bajr†xjnoabz—{‰Œ‘’‘hw›£šŽ¢†‘+;<<B?BYDDYlbl)ê*;2=n*/*-+;*,;+-
;+)î*°*+*-++++**********+,-=n/01:*+=n*=n-//2+--=n+,1+*,-;=n<K[k{‹/=}L\›l«»ËÛ>M]|ëûŒ?}œN^m¬¼Ì0O_½nÜ~­ì+++***************+;+++
**************+;)*6-+*,;-;*i*'++++++++++++++1>öÑýô'qÙ><8²\¾ÀcÜ7—1ÊüFú=J–GkjJ;o/Bœâݱ=nDJJÓÕQÑó/v‹¬q€ÊË´jf\Ç`=nJÇÑ€ß=Mв-=}ˆ
¢=IŸÊåP¸yUëkž<ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª¬46[yó±¡a¢qç/‹’ŽV—”ŸkQï]Cê”?pœu‡«ÈÒdM™±71H”T¶þÁ¥±ÌÒôq¼:¦ä9~Aí¶Ûå÷×ÊõAR·Êþ¸
> ÒM8ìúst´=nÊJJJJJJJñ;2¿É`k®˜h™êÔR=J sZëk6Ì€‚úFº›
ÆnÞtÔcÌÁe’#º„òžGYÓË8-öWoZýĹÃÞ_ÔBÌ–)*¢J¸ýNŠó?ͱã1øò=MÃí=J­;dã
J=MóWP!k«Éãî[ñû1ØFb²òJ_òÌ7ëà†x‘XdÊæü0Zجºšn¹Qœ1þÊ?=}qo>äÜ­¿ø8qg§=I"/~‹²_5ü8ø)*Ì6P‚‹’þ0«ñ$z¤bŠÚ_ðòk1™¥{ˆà*
Þp³$(ôÍv^JÀx%Ú1þ'~{Jöµ9äAÊTܴ͋¾=n=n=n=n=n:ª¬z::::l,2*•ÓkŽ>¼`òØ@:šZÙ·ï6÷e¯{ø‚FæxÍýÄ4‘žŽEà¡Y~G;xfXûÿÒ/0Ûôò“ÜiåJ–ª
Þ;ÒÌÖ’·oÞÊì†U‡Ê”­°†=}ÂuÍNG0Wïù°Ÿe¬9m9›ukñSk2LëÚ¬z::::::::o8D¤J¬åʰòñD8Aó/ºk…€jÞ7‡úJǺ:t,,,,,,,,,,,,,6ѹ沴7qÔ8rö:u&k0ÂC
> fX²ÇƒáÌ8Î>»Îª#ÅÒkâcÊ®@k0"˜­aMq@Å=J²Ò–Þ”y²2Ïøb[=I:ªšn
ÒTj)*e•(wÏz;a¢š`:r]Ú•ÀkùŒ¬¨üû"·9{$Ò׃MHWØ=nžkŽ=n=n=n=n=n=n:¬z::::
::::::::::::::::~­Á@õ>mÇÊlE7,6­à“0!¾T´ãÊ®D]åkæd*~?†n›½ê/{ôLZ3NféäÊ»ëÊaª@¤=nH¨‘y³á‡-‘ÿ1ͯ’6÷…Ìä::::::::::ŒŒ)*þ˜¿ç
> §zŽñ‘Dp®„4¬N8˜ñl:Ÿv„"rÌ9JÝMkÐÒþE=IžGB]ù‹ ‡{|MÖuF«³`†+=@¿n
Ó)*Íš$J#ñ+˜fØú‡c2ú¬­º,7„FôâJÁ:‡±ŠdcÐÞ­ÝÝ‘Ú=@çìêR`¿'äI51
îÊðE¥ÿ¼jI=I´9’4>>€=}åV8a‡zš\€â^¼”³À=@ÔB=@À²ÇˆjhÎÊýSA;=IkÿBÓ7´P'fæ¨4pöL‹H˜ÄX´´êðnW8?Ì2Í'ÿ~
í?Ä!=nC«!Œæ€=J¨ ­Ï+++
> ++=nJJ¾=n=n=n:«’LúW=n+¨²V¬z:|qß¶OðªÊ¶=Jó"
¦f'tÒ˹„§`mîÿ1^ÚbI2Wšó,Vj½Ñ>=J­{]ÙA·ñ|­ú¸j„FýŠÒ×0Ìz7GF:PC¼4JJ›gÂ…Õ:‹0\¦Eè
> õ¢ÞÊ
šââÛvàG¢á²kúªªªªªªª¬3Ê­Á;Z’ÕþÔ°?Àu"–Y¼8ÍÜ´ðprÛâþJ¬kVW¢h’^j2Z‰C%=@z&÷þJÿ¼_mç:„ëkR2222222222K1@OÇñ¿)*~:7®CÁB–Ì™þJk
> =n‚=nÊÐŒó’#‡áÔ7::]®ˆLžQ=J¬=n·º:ö?{‹K0Æ^&ëo†@äêJk}:
†qukÅŸ<*X×3@Òõè¥^¥uy<w¬²ÿÜ=}£±ÊÎ?LAEœeÉÁ¬¼aóO¸y¬Å‹-ÂþRÕ\pf¢†45Ê
JJJJJJJJJJJJJJJJJJJJJJJJJË=IžF¶%øú›=Jûr`1¡¥ú=@›a<ÔQ8]½­jŠ$ÒÕ‚¦Î·°Ò[ðs¾[­|†^?=}5ª•e–gòb›¢ÌE€mÉØ%=nAë­»øç‡Pº¤+Ö*RÕJJJJJJJ
JJJ·ú›wC¯ö=n¸-'è2VìC`2Úl2•œhÖM³?FýìN;È]2[Y@7­Ñ*ýfMo?‰¢hRcÐÝPÅA¨ÔÌçÙÐF“Ë¡­ä§R/êZà(:en@$­Øaˆ€å€«€­’»øòp¥~­ú’7¬
> ÄU¬3
ˆKà_Öî­{†b-Œ•9ÞpÆÿqf6<vú1¯ÑiÍ=J¬›ÀŽ7‡&:žlú‘d;º€Í³jÝ:=@ǸkúÌܱƒNÊ¡?E{ƒt·ñÌ55“„^äg,7º::::l,3jjjk22K=nA*jN,
Fú*é
> n@kR2SMíDs^0ξF—1@MñÞ"„§ÍöÔ¸Ï?¾÷•ÒdÜy{'TͰ ÂÉcÄxì&RZ¼ÏŠcŸ=JcÊÞ\CÅá(z’ñe2
<¸=M¼9pC…MÚeÌ֎ó"ÄÚˆéä­„×´0$Jï=JÍîÚ-â>H5
®âfpÙ“"Ôgö0câà{ükâÊjjjjjk|=J:V÷˜?{òðå=}WÉRÊ‚ú=@ª>~Êðt6š8ØYô–¥úŸÊ»Ü4ߢú¬¬Ù«¸
‹—¡`Äk-犪 /ÂIX±¼7::::::::::kRZîãǁ=I
²ú×úœÚºu‡â=næ‚kØ4y3³ñ€­Ó=nrWk;bãÞxD:­n?`´8añŽ*È”ÌRµô9§'zoô78eŠ&zƒâã…‹h²aTa“žoo•–¥¢:z}â’&\ƒú–¬¯¼^CäÞò­Z_?ýô©{
> ͆kÖ“kX7›/Íö¨MUê%ÓYÍßk‹]Å"¶MÒþR×D
æ…rK=nʾ=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nC¢­¹2–÷O#³Í­‘D³ñÌÒß­Sü­‚1Ì6˜Ö^Ü(‘ã
> ôTú´Ç
?Fb½µ•jä2`º;±•_Ðàù|­óîÈ{M¢´þ—Ü9}=nìC=}xށÒÊJJJJJJJJJJJÕN‹•àRbx’ÏW›iÙ¬5CãTµz¼\7E?ä2Ž;ŒL1X77J=@feL“7åÌÅå[-’cªXîp
> àÒùßœp`þ¾q±ià"=IþÊóŽÈ`­AEd–¬÷A‡t8Ñ,ò+de}àäü8²p}50ÎNœk0‹qô=I=}ç:
y·ñ¨d›{‡Ñjz£Â6Ê吕ÌÒ=nöÛ½õy©IÇÊëña“ª˜­hÒeJ“•s_î¬ÖI¬
x%¦º–ÌÜ켝-€4ÒÿôþCóÒ•y<;„9e§©o0®«ãÎ;Çé¦z]á9´2ƒù¬n;Â=n@jjjjk2K1hY@öe•öÚ'ú‘¬¯›îvs»íj§º­ß=nÊJÕÆD­ÄpFmª¡­Ò&ôÍŠRzúRÔ<5ªÌ8–
–M±Ü`()*ž?21˜Â„YxQ¬4Zªö޲1ö18Ë1NÛf,…(zZ"Äc‰Ñmë0êe8=MV€„¡Œ8ŽööJl4Aå1ØØí½‘Ìäë•Fü2e:¬˜ákï¢k²®çÍðq~H=n|hCm“÷T¹ÎëŒÅ
> ´®b’48¾=n;ž¬¹Ã¶b9|­Q’Ü­´†=IΊ]&´Òm6¼ÿ<Eïñœ­ü´Pîê=@´+o’ª­c0²b̍±#,i~GO1µ@gÖ
Ä  ?qÍ8JdÓ÷š=MraŽ·¢ÛÑlÌÏ÷•á*ÊÊ·öexq~@9_“H
> Äʺ Ř’Vªªªªª¬:{7/ø^*Üzœî6üC‡ñôc=n=}´µOrûÐøkj–J÷îð ò
:¤Vš¥-Ä–;‹=nÊ͹9,ëûþ­n<­½C3k˜±•k²KÆ‚ò4jùU¦ú=I&—*vì“÷še’P½v÷g9¬n
> Î:=M‡yÔVŽ•
QÒR_NIZÏ?ʝN=n;¦ë2TŠ?v›-À=M=J¬ÃII,q"—'ºeðâMÀ®¥¿oaò)*›kZ˜}é]zD7B$=J45¡0È5dÇèTUzkD><ªªªªªªªªªªªªªªªªªªª­1
F·»ñÒì6â‰}t7O&Dqÿ~u¾vM™škr뙏^›ó’×Lü`ÌfÖm³4þ¢Õ¬"=M@j•æ§“ò—2fG»¶åNÇ£:¥â€¼`“TUã++++++++++++0q\¯’b›­GÊà
> œ{¿{Ψ3w–)*Ô´k¾ä1H²c=Jͳݵ~› îÁM…Û6'©®q½b*pU›’[LÅ¡
­L:—-5Š-¸ÒdÑ“aj€²a–œé>—ß·*;kdhÖ¸æœÅ¡p®Gâpª’k›Ý”UÛkô]ŽËŸÓ$T¸âÂM¯×
_kíCæžîGª”9j4·þbz4Tã™Ym$Tµ½lþ€‚†ïÏøåN¿{‘ä=I½‡Øúz³Š&ʾ;]Øt:€þ|úW0ÛÜ&xªkÓNÄ-o{J”ÌØªªª¬::œŒŒUޤò©$Êë¶¡üE’f§Ì­þ,ºt,2N+1eÆóm
‹ä5d=nChjj’=}ÚF?:=@zY÷ÃøǬM¸q3v®£Déx-ŽCF~¼µ]ª–ÿü7ºß÷uæe$2YMsV¥·ÁÆãU¥­½=}0s²,òÓF:ˆcG:“Näa–‡47*‡ì^h®GûtƒŒ²d:­¾ã'Ç
> JL=I¯£)*=Jz¤V¥ŽŠw¬ÌÐÓ1÷ ÎGðg꣈]*ÒñÝÛøíŒòQuÂk™ñ‹E!ªÁ–0Ïkμ°][úŸkw·¼q}†m
ß{öƒM=IOîÇ•t!Êhù»A}oþ¾GúŠM¹|]eÃoŸ°ª^zƒ++/IÜ8Aµ
²)*¼8¬òhšÓ¶³1êÔ´_±ìrš=@âÊí=M~å—škm]ˆ0ÞÌÌß•íäHo=nʶÌ´+N‡,wJºkkR222JÊïå]Å2=MÕç:—5R=nDãË÷WLëkÚ°âÚbb-j¸RX‹=n=Jò5àdá
kªo¬9>?¸œG±¾kÌ2šöü2åkùEB¼mÅò¾A•‘å¬6yÔc†d®Ci89Fi&z‘_ÑëUÄÒ/â°ÇÅJ#ÊËÁSÑÛ÷Ÿ$¬eˆ€ÔXH-ç:”pÈ[oo‚äSob-:qï¹Nš8þJ¶üp¦j
ÿ9=n±p*U·ÊÈíò%F¸Ò]ó¿¾ð£Ý™¬ÒÀõM©V¿#wI¬7CeHœeÇ4´üút,,,,,,,,,,,,,,,,8–u)*ÏM=M)*¾>²€CÄ›ÞA§’f†?p}Æâsð¬Ž+ÇÆëÑÁk¢Yã—rfÑ
m(o=nGœj¦WQ=Mmk­„ŒË“=nEçä„9‘9)*›†-1Ìå::::::::::::::ŒËö53fj=M&Êða¡·pŠ^M²ÔVüuuŸöºŸ[ë÷=nE/oc?Ñ<­VZár"/{
ÎÁ´½·—(zšŒ
> owÀæÌèr[LëËÿ/Tô8Â9
‡Ù²4kÿ°™£EÄ=Jâ‚($I¼9mݏ¥ðuÕÄ’ˆÄ|=nybÆv¼±ï1Ôû¿Êœ>̱Œ­øí¬&m=IK”ÍÚ#yÌ´Šå?]â‘tÍè…:ªaTTD…‡•ÔP}{f“
{ƒŠw„=MðôÒõ4Vüò™ShInDíÄqœÊ­aFübj{nDñG"ÇáNA»ÅQ¬ÒÞxY’›?¥=nD¯?R22K+1HU?À=M®"Éô­¯×=nƾ˜©[~¤b¦vƒ„=ISÜ­Ï=nʬ’„8¡æòÖd7õÌ5^0´
EJôƒs¡žôöoÔ´ðì=Jj»ÕãG:n2Â=MÑ+úJ뷞‚S¡w×H†,8–`>@d£xØÝm¼8¶6—¿ÙÀE¸…2_¸¢Û‚%á……‘=@º‰=}*îö=J^¢DHIt8|8H6×X°­ž11‹†_X®£JââÇ
ïÛ=nG¶P¶àâ}Äzœ_ù­†uÚùdIô­ý•­ªJ¬aûo‹µ¯Ü*=ME‰„”W1;í‹–KØF+K~œð³9ô*“ú=nDy[Çëürúù·`z“FXÆ´>Pàk±´Å†dÒØºú`2O++++/IÜ8C©LkN
> EÞA¤J­Sú’çp1eî]b3+´x1ÉÔcëæ-ì€ÃåÊ
FǍcšžK=nq]ͨÀýðá"Jš揼ã¼^#škópl=JuªÊúbGá´Ü2jkR22Tzší!½hwëd¤JŠÊ­VŽÐ6NÜaöEÑÙ=nIi­
> ïÛ½`,sYŸ-òÔg Å4T¼^Äšþ>Gâ£nû1–
M»kÌ2¥*q–zuGÃákŽBöü`zŸ˜±û0ʬ+EJ¾=n:jL²1ÿ/6Ve4RTŒšDbH¸2[¨G°Ýo?ïÉÜ6¶8I¯X42P’ù³°ã·zu¶Ä0
·Q©êÔµ!^VŸûo6úæ­MuGù#2^+š'z6ËÄr\$kŒðe„Í÷/G=}Ô·fœškÈÛcçGÒ"Òúv…‹-ÂþR_•í¯¬2¬zt,,,,,,,,,,,,,8vŠõ°¨å»27?>ˆ²Pw4ÍfÝ
> ŠÎüáI^Dt3ìZHJ‰ëoJ&@%ÿqÀ˜h)*ö':PÐõ?×"”9ª/
ÆWè=n­ýí´î✊'~„,,,,,,,,,,,,,,8Vvo¸øíjÅéô©ï/†]~×=ncäbTµ=Jü4×¹ZÌÐØæ0ÒM2\ë†s?
HF[‡Fé1^ã†qAš«0Ù—­¨`åg¨òcΚXŸ´ŸÊåi8Zl‚Ÿ»¸`9><#[OèLBOc‚Ýk¯E]Œ0Å8Ãk&†—¹o?³ïçø-j43ìZßfVÿ8Ô͡ċTUÉ/@r!A?{æî
*ÒÖʝ޵]xÃâÔµw‹)*³{†=I$¦–’܆Ó~ˆP¡د/ÚΡO&óR\Ö1Ä5°Ò×CGÒù;¶¸Pº=I=}"=npBz&uÝsÓ›þü9s­¹7¬´ä,2jjkñ´î¼vzǧÑ8H²c\ß¶NÄ’?Fqc~
> 0í¼5¡¬ßÒØÖVüÞ4Pã>H­O8F¹N>¼úžEÊ^0´,¬6‘Â=I¡:OÔLRÒz`båJþ„8{‰O?ò¨ý³
·èQ¸j–?pÂñ¼ðïmej8+/›<¡JqEkú’­’mšD§å[=@ºx9€sµ’eôc847Š
•ÇZ›Ž~8i>í´I•oE­ù?G;žoÜ»¾G’[ô^¯±ó(:‚=}±½eyÉZ­ÛöŽúÀâ…GÌ㹨@©Üö¦Q$JW1hQ7FÿÂ:pî˜?F9ñ=I°jq~pú
¥Bk»ùKÊkþ*š7ŠÐ{
…«l¬3jjjk2Me˜×/†$Jò<=J¶=}¤?<¥ðÑT3?×cøTUï±B¶¼¶÷fG×Ô¸_šs)*$–©2X‰=nõUv\ɯ0}=JÁîûU1Þfë1>¡·
šb¥k,F~»d³›81Õ8Pc5žË
Ê–Ê`ó÷ä´ÿØ8@7ʾ=n:ª­F}‹¢ÿ9¨²[í`Ä,8ëÜ9eàÐó°ôbÇŸk=MKÍ­!¸O»,žQ%ÿ1ÜBÇ€†0®ÈO/á2SE(ù`
¸ÿ1ʬl4b²=IÅ ±Ì7:k+ê­Ûk¾QK[HD·¢J++
+++/†ðéö+km7£Fq÷0™®½=M¶eÒúÊíã—"H„£bJ§lòNžþJ`’8\=I=n•Ƈ=}ïÈp´Òá§]2“,j£´#ÒÓ–ºäù´AŸú¨ò`÷Uoú¢=Jƒ&ÊÚ¥‡Ë=I¼2[`±S:Œw(¨E><N
’£èo~’„w‡HqŸ?¥kRK++=nÊ®<ªªªª¬:‹²¹æ‹•³7åÚ¬\º=@²+ë{…9¥*=Jn‘¶—ê‹?Ǧ™žE9³ÃwÀ´JJo£_=nEi~Hn֞É=JÂkÐZŽ¿®I–!(òN¹)*?²ú&ek‹)*G
)*:Ìäú:::l4ÃDb=IÌ4Cã=n?]b2Mç¡^8#ú‚v¢ü53±:¬ìpÈRV¬zk+ê¬VGì8v°CœÅô¦ç¤JÕ„ƒ²—I3è´ËSb³{}M®bq7Ü\çÍí±ïe‡Ø€,§:œv3—½Û0Øï=}ñÓkËOÅ
Êïû¶ù¡82gxñ¾k°øvN±ži~>/ÝŒG´7õ=}fÊJ=@7„†”™nDRÌ8R-9¤•Ø´³¾"•³^><_ªãðª2c6ئœt†rÍmª!Ô³ê‚í{=J­–?ÆU"’ÌÓ¯ÙÝñ÷Ö-%??nj׳$)*t7j¿á¯
> /MI
=InD°úÜ9Ê2S²¼Ëc„‡¦,9Jfãùc³ý™ºkŠ[ì+úå}­Óot2jk2bB¬®ÝÇ%JìÄð+{®ØøŸú7¬6ªYpz—FL
ÎG{ÜÒ*­¡,E¿°Æ¡RVð°`¬6¼¯aÐ±?{B¢„ðdæ#²
> ûkÕø€×h²Ø††ðRòÇyxtÍFVn,ñ£Éyº',3W÷²YŸÆ¬ßñ=JhÒ]íÚ÷h=@âœ(k³OÂ
ÄQºzˆ¤CBû­©o‚)*ýÆ£k=Jk5оçgú`o˜£/{ÿ²‹•fMXàEÚGS1f¢
> ³Cjä’g@cُü:…7K°ˆq£t7¢¨(T
ÕyÊà4^hM!¶úož’oJ˶%XÎ;=}`­j-o=n<ª¬:W=nADäÙ~?ªPm—,2òˆJ{=n²¯³Ÿ—’YjJÓ¿ª=@™¬0‘:5jHÒh¤vU=M
> ›7Ú©Uâ(ÍJu8Àíò­ÓÂ샼 1¸éËkû=}=I@Dv÷I$˜Jãî‹Ñ
ƒ‚ŒÁ–Jø¦K7áZt8˜13´rø’‡Æ¦úžånsÓ=M÷1–¢ª=MŠd­Ôc=J_Ýáço”2Ml¬zl8¦Ž™¦—7@-Ö$JjR
> =nG2fhºCEÊe½Ÿ$T[Œ¼a@=}º’Fs(™Ê
QCŒ*ûM…ï0Vi82O8“2^ëtrZåöä®Gr=n1^Þz|QG¡Ã森DÊηdcÍî:ux­÷/º:::::::mÄFSê;ÿ0;åF„¨K0|lyÄZ
×08íßî¨æÇë/¨(Kn¼cGq¬húüXp:`à?o‚E£Ë­ó±kÑ[7üp`{ö’€Û=MŠ›Öðaœ¨É_0q_à0›úÊóâöVÑMBy>­m8‹Ë8F-ßk|B¢$Gqï{›Z?Éw”!I?0«êÊÅk|
·ô2
> o’3kG²ûé^>OQ«ý~DN€áö|*8&ø#JFìÓ=Mþ?P‹#GýŽ;
¬ýy·êÿ{-A5±Äç~FýŒ…E—¡Ý$Ô³–×¥Ä"ø±ö:—V£éRX-ukD⏮·0ÊJ=I»Ù¥Ý¼Mî¢=nCð!r%òFsç
> Þ2gAŠöÞæý«0°=@:|v>陸
W,¸äÌà«Ø˜Mî2/1„,2N+ŽÊ÷ü(‰´6Æ¡RU’Lú:l+^­CP7åkpôNFsR`·Àй„k=}œ·$Êü#®=n?¼`ôì—køF_½öë¡ùÔ65Àÿ~}ގõ
®Íäô9g×ÒÆÎiÚkëgÀ´ä=J­£j–c2‚jì[ðõ«WD|5gÀÅþ‰ìº|@èpàZ‡º…‰^GfÞá6ñ=}Â5_í$:Ÿßã„1JÌÖ¬:žG¢š|;éÿ~‡îä¤=JûRSU=n<¦M›÷1U=@x=M
C„Sðß(kÿ°Ü7”ô3ñ<>®5^,Tâ—ZêE“d”²¥%öj©é~GÂ×Zî8dJÂÂ¥Ú2=J­c‘ò&¶=núáDÞFí:"Kd´¤Êà-4]3H™·JDRRÓk22K1>Ãs¸Mv
Æb$Jø®—ÊÔZ¿)*/?²G
äX’aŸÎGv¸°ò`’7ú£¸':…j:‹fÞ*Fž??¬<‡f”oIJüã*ÌÛ¥«áG°=MÙ*ÔbwQPÖ^&†­Š‡Iµuf•žCö=n––J"ÇÕš(©ŽG:°ë3¥±²U¬"{¿ÜŒÎçpÈ´Tû¸$…
ͧºœ Ʊ
> ;J¬]Íy²·y?n{¸ÅEXxä²ù=}Âñy¨Cþ)*Ï1E¯=I<=IÄ7ÚœÀåKdGº ãç=MT9L­Õ3Y§@’
­SóìŒ0KÍ”kò{‡ê±*=Jždʾ=n:«’Kð¯Á|*dÄ“k=ncꔄd˜¬q
> «w˜Þ,4!· —«,”ª˜ä2¶ø›kŠú`*J¾B󱕫*4Ÿ2bÑë´Ìg-¸È­°vUÍ^b%8'?pjÂOØF8²a=}Ü{¼
=I5ë/±©°kQ£B=Jx=IÜ3%~}ºœ!œ­’UV›ôTpýéZ2[V8
J=I7µðFÙEIû1Ž¢Ì÷s=M™1•Q•°Î/?Ì3kCo=I>:!0[øe+1«„ŒHþ=@¹¼Í˜õ=@QGÆ,çº*ß1˜VœÑnDŒL+«÷D´/0w`:‘JFN‘ÃÐì8Ζ۱ጬSMsÑaöäÊå†F
úï/º0s90ɼ7:::::::::::?ö•ñ²,­]3Hq;ú:Œ"o¬"(J¨:i€º»kµÅfqq_Ñ(RmGŒ¢ò1ÀË~u+@VþyÜ4=nâ±:…´«ÙIÂ=n;FyÌ0O÷iâÊ=I7¸ñC¥ÓÚÏ›D¦
k
„÷êJ7TTêeÞ^JÈ&øO=n°^šk^c=n=n5ÎCä€/Êë"Á‡_ÎÈw~‚yKeÛÊ™¤ÊúvàáJ¬ÓCËúÙ¼´í;®•íˆmŒÔcèóQ¡Â0«òÇ46nY¯'E—ÝŠšReåy=}…0®#³
znÜï
®¶ìüuÔ™%Ô´«iïÂ1<Id'ÿqzGíÄ=@^{f"ʹGØ|*؍~GVǹÌÞ=nGºt2Ÿ=@¬ô8¡â=I´/3k2222Kÿ?ù¼8ŠôŸ±æ«çäú6¯ñV—XºžëA
í¿èMé>E2­á0"¼z†\Â\{kzI
> ¡lâÊÿá„´kJ2\î¼BTá­µ46®­ÛiO{ïý1t‚7042Z»î‹ëdAe,8C8×ËÏÊù—þš1v6ó5yAƒhÉk­—ø
˜*krO•-&åanGbpãCÏ`ÑÊk=@̲2^꽝-݇Ã~–ìœÁGÙ!¬
‚SèäÅkù5P¨ÚÎ@큤rJ¡â–åJìƒ5Œ*3­6EuÛnÇ’'iéNH¯Ãx×Kʦz‰Ž€f\A=}îzFón£ê3‘;,j0„­=@¯«·úo?Ô2jk=nü8SϞ[ð“Æ†b)*2T”`ú{ùM”­
Zü=M˜"R^-ªkû6’a^ú*@-¼ÒÝ…¾”§t´Î¹ýyšk¾{¡Ø9šJ^º+H´ÍÓ×ç0«o|ƒ6<9îÊ=MïuÍŒ¸µófÿoͷ׊òyPERKÎ_Ø\¼ƒ@ßêÈ-Ù­fexLM°±|£JþÞ›,dИ§iéÔ8
> ¶uêÒÅl¯û{€èõ®ÒÁ?«ÿ16wdbÅ›@ÿÑ#?{ÅÛ<Á¡¢p¬û
ãRP€är%ü5ˆ…»ÿ1;šø˜ýxn4,j=@Ä_ñ«k=@²žxef{zž‘Zöpñq=nGð̝y¿o› ŽØÉ®Á÷IÁû1ÊwGº
> pæwJªŸûÎRP³=Mˆ²N4«—’=J,43m³6ݬ3â”m§:\_êCÕ³kŠU—º:t,,,2J;n‚k¶Â
ãÎ4ÍǺ›ù­?n¥ÇáâÊ=JÁ2„“á¦D=Mq¢Ô¶ÅN»i…ögï/Œî4¢7©Z:õ8ñe¢•Ü7L
> î•Ñæ>@¦zxpÃF£JÏw/CÅöJ=@Cˆ/î8V­é7¸“Ð9ReƒJ¢ýŸ?ž,V{k
±Ã¯=I£ˆ}Ûüº}+±¨HLüüFFVI~Eu=Mîp˜kjL¸òb‘ '`RJ:|Ce³’(Eøç48=n>QäºI‹
R_kÞcÎ>;EÞôžžRXªªªªªªªªªªªª¬¸³¹`pæì6=}°ª±8xkùPHa’Àž=J­¼ˆødÀ&„¬ºï¶YôDN™a–?qž¢2­­õf•ç91‚™aúRÕ*0ë=nÊJJ®:w=nB;^±j-¤¿{ÆËKÙ7J
–0ñ%÷0z³OÔ‹HÆiéköej¢Þ­z=@«j/?Ú£ªÌcJÙ£Pè4×ïc®@ÿêc®5þä8Cµš›+«ñ„Õ"T´‹Û¹ÈC¾b2úÊÀëXPlÕFb=nGûîòñ®•÷/õk>jhÔUa‹
H{q‹+NßîH
äÊÝCUUÑ^@<;Ë=IÒÎA–«ÔTî,Rµk½ýR[uw;rK+=nA|6ˆ؍ÑÌ4Zd‘–mbŸk-EŠ^‡›ÎG*¿Ñkä5=@ƺ:t,2kõµ½Oµι~>±Â—¥ÿq±bN›am‰~=}´Ðà`‰¿À­2‚
> ‰U¢°Ô7õöM—¢ÊÆ0</Š*Iç?õWæ™o;,fý°,*
é~HÎwôî?þ=n=n;°¢9º¨œ„ÔdÎW1S_Œº?`õ„=J†bˆòM9EÅÍ÷±^¥×0B|vÊùM~GøšCC§í)*Rb1e°kD9Ô7Ú¢B
> =nÇ¡’em•Ÿ>
·Rb[¼Ew-ÉiœÒý1±;Ú˜sþÈ’ep«o::k^­¸ƒvV‹%èN¥‰ì2›;`°cÈ'£¼ÒÊ“dåŸ/º“E¢¾GWCj_
E¸ÔÍz*{ƒäl„rE—ÿ0[ð†¥èa¤ž?G·—/*ÌÓVÞ
ŠN›K1eÆMËMx>?qfVž¸Y©±Z½ƒ&Êüö¹\>M/0]<œìKÑ|§Ì­ÎÚ‹ë×=M鈲dJЬFÊ!™©JÌÜìáç¾ôw¸DTUµ¥‰JXÜð<-©[z›ögðJ;ã~ó]VmGŽD‡‰êJŽ<äJUïò´
ÛÔ8‹:ð„d±’z’rW`/®Cdõ“äª*Jͬs‹ÑaW(˜’eŒ‹¸PÛî<dRÕ’–°•n<+¨2O=nc÷’á:gz}çÝv“¡‡¬/t]­qP¬nwDº†£â5ª¬z::::::::k@R­SZšJ?œd®F}^Ì
F-à!>FyìÀD*)*ïI›Ô]CÅ—=n“úÊÍ=MޱåÂky>nCÄ¢®Eï²NzcĬ'œºF¸ks„»·ie©~Aµ?NhÃéÂJÚ=@çä»k=@,VRÕ„+*­Ã¡6uNDÞJksBN—Iœ8iUµ£Dk
> <ZcÎ>D=JX0QÉ=} :žÊ:FüýÛkr³@ñŝ
fì7zRôn­›â:’2š=n–zt,,,,,,,,,,,,,2d·z»ã°j¤ûû/·øÏ=nÊJ¾=n=n=n=nCv¦N¥ºŒOžç®Dšà$Ô´ö3ºZeî†q+êJ
> -D*>ÌÖ¬:t4âü4ˆqEI]©?{¶úAçù69=n“q~HˆLAî±`¹ßë1Ë®ð1q¿=@†dJ=}ð™„Ø^¬ë
ø1´Üª¬z21›’RŒ-€Äÿ/s¦÷ÛöT´!”íä–z‡Ü\{‰O?Æ»þ–­AFåÊïÊs^
­R„‘½e±®£q=nGÌZ_âk{Jº°m‹Íll8âDkÌ,,,,86zù´™Tk®}†ú¢‰?q:@2U­É@uÛX-„ʬLK»=I^G§ÅGòÇÝ,Ufm&CÇåÖÌcÊ7+üâ‡DŠz™®“Ÿâ«f£Ê,¬´¾=n=n
Cïvî_Ê›#Ô³Ä|&{ôú=JëÑ}'Þ;±ÃÝßêªF*Ù¬9€ª›MªÏ?q‰•¥+ÿÙ1{þÔ¸sN}o‰é)*2M9°ÊFE©Rdê+ot6[=}`[n=@´Í¹9;čMÊüéy1Ì//?RO=n=}løòb»Á@áré
(1bnEÊ¥ófókzaï=nʺ_kåp€W‹$Ô·¬ø&~€œòkÖáê*Òø`CÆs›óîµC䤧{GЦ,´Î0Z·„U}ðúŽØ/ø*+êT¸lxL¤Ûщf,7†ìˆK˜Jò¨«,£\Þ@â:/]‡ù^?íq¾32
NˆÇzŸphûh§=M‹ýÕº‘´¾õ]Œ‹ýœqYÌäŽWí³QW7ñ/1À#rWMøBmû~æ<6:›â§:u=}E~8Ê·žk°ïZæ,%›šMýÎBï-ɲ¿Ë®Ýcс5­à6?9èW¡ã1uK´e=MAç¯?Ð…
> =M‡,3Î:ßÈ‘*¬Ìl=MÕÃ>ª‚!=}™Ëê^|-ŒwÝöz‡=nÊJJJJJJJJJJJJJJ¬V{k¶Â
âzÔ&Ñz­¸–Oo¸+=Iͺ›è1^Ì ¸HÆÿp~Ÿ7a÷Økm=}¢4fàk7ö`áWñã0»ø'æí»
> kË«¼,Œ |¡F:ã¸³ígð=n–zžm¹¦=n`z•«EJÊïqU+8ށjšT3jjk°Li—æak²`:‘J†H÷FþGÛr9˜ñ¬T
8™Ãä®@­FhFºt6¥áh–¤kÔ,,,,,,,,,,,,2X-´4¡
¼3kR2ArTŽŠ:zM&ôÌhýI^C'èE-ïÙ"ÊÝî‹0x¬hýÞ…TnA»¬rí¯‡’­Å4$‘ç÷Ñè²eþ{+=n‡J¼ŠDˆy®–£¿{[ææ6Ðóÿ¹kû/­I;ààñ@¬´Õδ¾ª®{2bÐëñCPc-
> F8yÄM\[;"ÉHŠgÐ>; Ì9³îž¥™­
ŒÞýS)*µz˜€ÄÁaÕÅ©nE\‘Deúû"JâÂ¥v§{9•àšh<­Sš¿ÞoJ¦œìžÑ`}ÔÒ–Ù’“wGú||ýC¥fmœcLâЋÃŒ
ßÕ{G7¥L‹
,õ±Ýïo{Ìs÷ó—:ŸðDð°á¬7mº†dúƒ++=nbúO1-Æ6Ø_à²bÛ9õ/{ÆQ·›P$=nFNÈ=M«:ª’ÜsÊ:¥97ìŠm˜³úÈÒÙTä‘’37D=npžÞ½é¿Ì"ÊÚû°^ay*Íï0Rªª­S
> ˆCã?C=JÕ;²?Ê—%)*à:‘9­ßɁ»ÜRgVo£
…¹Â+þ,²Ì®¼‰J=@8ra{n>ÀpïC¥¸ªT¹ZÃ[}@3Íö^„9t`2D¬T,+J,sÊ:›çî䯲±)*Ž=}M5jHÚ~œòcñÙ>:/–
> ÊJJ2Ö‘eˆÇ?qmCÁîa_?ÀLšðé+”ÍRMž
†wG÷?G:¡_å+Ê4UatÏ#·7ª²“]bbECÒ“ë{vvïø–[½Å•$¼¬‚E±­æ-k"Šzrp¨S_›e°Êê+]I5/*2=J­¦#ÆK²”¦ÎšFt8
ÓÈXF[áá7þ?šZÀ­MágzœŒ,“5عôi[?F˜±´Ø“ž’&Ë1x7«×V–ŽE‡>A©sfõ%à7ã)*2d'ɱ«Ê_ãÆbåŸ?ÿ†0«=nú¬F
álŸï/âµ•§û-MÇ£˜²OÛßå*9^@kR222
2222222222222222Jªo;‹0<Äj,iUº›ù®ç5–=nû!>F¹³êÿA,Sí%û~/˜âG2k8ÌEs)*KË(zr·=MñE­ñ`(òXó듖̬4å7ŠÂwÞñJGY0<bEVO1¨Aߣ‘“ã·º¤
ÛøóEÃØ/æo”43j$J»°aÇ–Gºp/L½Å&a™úkª¬®!™÷娱Ä7z|p1Ú¸f:M£š’Ë2Xªªªªªªªªªª­]UuõBkš=IÌ3-³þkŽ=nCè
auܲï"ÁE,±L­3LȍY-~m¥[øQ
ç£8Þ<øô·äâ=Iç^’øù·ÞnŠžçz‹Vp]©‘¢*ú:PLÏ%À0½ØÏ/·žðQ…L×1†BòÈù_‰8o=n[çJIöU¨re>{+0\dôûãköŒ½=}RN0î=IXÄ$Ô¸=M–—дÿoH
Ú”“1>C‰z
> ÚbÂT·‹°|í=Ie¨+=ne3?»ëѸĦ:&f¸ÛNv¼"J½05·1^·*
ÊÊ¥O“éô¡//¶¾zYä=J’dKñûÌF1}[»ò*Ä¢¢ï¦ú˜Yôrc¬7-’¬F Ç8ÈÔTÃ5™PÍ»k}xûÑU±
/{½6šN}âÌ8ÑêaÙ¬´ë¦¥ûFêkz˜…Ñl¬½•Û­€r9>D±Jß+J5P¬8K¶–ðv±ká~BA@Z9’Ç?q0Tlj’3!=n@“ó5ä*‡kìwn„kpeS­qv#2•Pââ½rW=}‰¨AFѸò^±
> [@1°[ÏJ²~Œ!dÉ~?Ý//v×=J–ÿ~?ü=@=J¹„2]
L·,ýRcyY’›=n•ÊÔÞD=JPŽw»ê£²’x)*J¬egø˜X|†…ÅÈк¥×Òð‡ÄËÿ>´0Ûº›{EL²2f&~=MÜ+Âb}o˜?qp@+
=nŸå¸º–ÌÏ*â_νj˜zœcøîå²²š¬»Â¢%±_q:¥Æv¼£ÇíºnrJÒÌ,71ÆùûáˆÒdw^<z‹^s×ê?pW³"±¼5™ˆ‘%ó1„DD^RÔyOFÍkò˜?q-ÆV1ê^XE¤=nDB¢Ù
ªH-¼6=J²"åf±kÏ3ˆ¨·—*ûêJô‘A¼ë€y´ãk–Ë·XQìû˜ý|©žG‚P¡šCÊ!5F,´ùñ²îí¹?GBᎱå“ÌYºÌæ=@‹È‹wg`Ûã?G¨ø6¥Ï¿Î
ÄšG;‡×…’43Î,
> =JaJJС;“
²/¯‘IkÌ5_·˜ê8¤JÄkR222222222222222222222222Jªn,:‹XCÙE,cIúÊÅ4™Œ=Mq¦¢Ê2N;Ÿü²!T¶:pšj%xß³¹a#«o0ä»È1‘™;e?MŸF
> q=n;PC¼a{ÆššJ™Z™âÆu¤¨ògVQ•[0}kñUˆ+“0{„,¬Hê
ûköÆíökÅFk¦NÑȦwÈ‹1|+*´e>?¶ÀÈñ{Û:’­S0m9'ÿîJúE*¸RO++++++++/H]´8M‡ëk,
øj5±hTµ[ëëEü¬GJDa|­Q1â…È+ÔKÚ±+Šå:”òõo*=@¸«oxmïÊÆ­ÅèRT"­êCÇËÞ@Ñ·Æ9ÒjöqÃè¬IF`Æ+k÷
Jû¿Øc”ç?q]ø®—=@àû€­v^gëÑì…ÕménGšžÌ´
Ü4æÇDaiJ­0áçcjÒ°ñŸ?GD^œ4U3,\Db?Ba6&k9¾ãןK1•MŽŒÄú:ƒol-°²Z[ãJéxD–ÔS²«¸1e16ìú›Æ=nN¢†sE“rcÉ«¥k[ýÕ­Ã÷»­î9[éç=n`¡ñ¥Åõ‡:Ÿo|Þ
~¿J’dMB_›¶Èì8Àr*àû™`G:“—¨ä4Ò{}=}&‹Ø»2d„–J¼+=n;ŠÊ=Jîδ=I+N¨|­Èf}¸¹*$Ekâ3ú}äGz’ñ▝¦´7ƒRgS19’Œ¶·[Úý¢¾F¢dK-jžT̓I¾AšD=nF·
> 1æNµ
­kÕâõßInFÐ]VY+ÐÅgzF˜»·@y=nD¡<pWcÙ€»ÚkÝù¡@œ˜qûòJæ7:êúâkæœ3YS=@®JÛÛ•$ÊÕÆ5p‘“ä2,町‚p$LÄùÄ6Û{Þls¡´Þ2[’•Ж[áïQI
©>H¸H@8ú¿—ºœaxm­þ•U}ÓÌØªª­ÁCbuk²'?ošº@­N­ð¢IŽœkü̲8šuÆ’7ô8|‡³Ÿºn‹ùÓkÍÑ?HžÏýs‘;=}笪5†“ꬴM”7вô–ûã~
’ðJÿ’ÿ1N
=næª-¼ÒØHax—Ä`FäÊðRz=MtUcI€7:ž7?qF¹]bù™H«0FU]D-ªF:œÎB±µN'úi|­£S:ÛêÞI;&øk<ôB=@
$`ÝöÊjì=@¡¾IÔ7JªyJ=Iä¶(˜kØT|ð+
> =@à=MùÌßíÝNŠ^•¼7=n
ùÿ#Jâ*J¬áöjRUA£E§x«=nª›I%žkW…žT!kRO+++++++++++++++++++++++++++++/†úx@­È–R¢_—ê¹l­°†U«c¦?š'ÿq[ýmF
> ž0P5cÌ
}¬Ø¿viÂ’z„C„mõ´8°õ>œâkùhA…MS=J§z€cëâ,rE¸o1Õ¯‚KÜ¢s=Më1̬VE4T=@46=I2`…Ë­¼’üFfXD¬­Ô3nÛ±–
M»kÌ2¥7^šþ><ñ—¢
> ¸rO0—%Ñ
‡ÒkÔ,,,,,,,4Ç”¸²2=nªV­´sK·W*0ÑÔÒ`bàëо€×…툏kŽ=n=n=n=n=n=n:„40ÍÒ#Êð˜ú‹“1Â~š•R<lr7`RµQ
­Œ _ä8R΁UÇN¼F!½Ø‡
> s(;Gg&‹ÌÞE•Ì6GN½¼ص¸­#kÖb
qשRa{n:ª¬3û1a©E0åz”~œòüƒQZ¬Û!×»ä±`5¡É‘¿ÅXM꣸2Ufx±8üCÃñX˜Æúœ0¡kËб°³kµؐ=J;öJöÞ‰±kñ~0h‚
> †u†o1l­ËÂ2\6Ñ]2d‹îA"Âp°ïJ­Fô%ù3EÒØ=@gÙ’F2fl-Ôº£âÒÌösŠÝé7?q=nÖ6
ªü´Þ}iZŠOìû1†ÜºO1=n®òúžHŒbÔ·-Å-3=nûú*¬G!Ü߬ê“n:0pÁˆä¼c
k‘Þª/95qÿ/%^8ñÃÌ­ÓÛÜeòðà#=nBP•C¾ÄE½$JÅ;eˆ-ª:ŸèPå{Íâ;ë=nðókMU…÷ï/%Æçî0Ó/î—˜÷2ÕR2c¥j=}±=n7+þ?;öYïÃ¥Üu…mºe¨gJ–W^_›OñÃTU
> ~=n=n>¿·å*kõ=n‡%+ʦJ'?q|´ÓšGz]Èk0=nh¡ï[Ñp(Ò_ÅEVʼqsQ!o{¢DVÊιöz‹o“-GK0~
FÛá„ËÜ9e?¸Ó5BuÎdz”¬â‚G^ÑcX=@óû1ÍŒ[ð0™LŠ
> C†ˆÅ’ØQåeÆ-·¥™Ij²@Þaè¢7¶£D:äÝâIíÙMÑ*­Ì|>9¢9Mzí>ƒ8¾fpàýþÊÍEAr%?êšFºž@ò ‚Б
éUzŸp\Þ\`ýq=}%RÓ–w1{‘Ô5úD¬Ø¿×@+›è2TsKJ"1K
ä1š-ëûõßR_Ê::t,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,8–˜»ßílF_k­Ë=}aîVD>F¼H=I=}fmÂ=I=JÔcóÛy@­SZðŸ­1‘•æj=I^Eë´¥oD£Jû'«WË÷¸inFض
ށ†¹=nE‹›¼ê¦X_ïæ:¥B˜û´Š-¸qŸ1šœ´cË²k÷h3ÚAZ#ªkü7¬z{1‘Jä2¥mo=npoeöakž=n=n=n=n=n?›ç,,2­o¾C…Ï``F?p·³«ëÿ˜,×o~H°ÜÉSkÜ,,2j
jjjjjk8’J¬^e¸’T_àf‚e‰­Q‹"öë˜îT¸wNœ»Ê«ç˜­m²•Ǽ*ˆÊk¾ö^r…º5ÐÄÎAŽ6•+6‹çVHR;4d<
§z–H=JXóGbÊâ¾ÇTòJᤷ¹œ39•ÅÃØ=n2Ô÷f·hQ
> “Ñ=npVìÜG…ÓÔÜ­¶]!ÿ0¶Cˆ6¸’E­½ÞH›Ö’
ê51Ô7—aAgùö2Õé¼8pÜs*ücÏF¬NÈ‚ê–÷!ÞÊùh7yW´4@f4—âM~Do®¦·çÇkJÒ•=@¢ˆa—R^B¶ê³D…׸2d
ÚüæpL§<_F48ÉFÄvü9,`R[Á>™Wʺ=@óE–“‰/?WL“ô:yKXÐùºÔMä+ªI50Øf$J÷¶bÃåñ4·Ñìi~Eò…=}íí:¬¹Ì=MŒ×ê9nDºX}ËL·¦:œiÃö¼bEJ¨e8=@‚º
> =}ê=nH… P¥JûRe¹XΕÜ7”Tò22MZ¬5êk[ýåMjõ=}êT¹m56zpC:ú¦þ€22JÄkô=J›YW
DŸ£T¸·*Ï?qÄDk*¬^T¯ROø6—Ç:›uS»)*?nÛª5RUNÁÊk¼´Þ–žØô°
¼ÍÏØ7¢³×Ð+Ón›=M›nóïø>U¬6â\F‚G=Mdãí­áæ•1›°Öíöú©R700ýkYQ³=Mÿ0Oø»Ž˜‘ò¢ž2LRn¹7Ô·Æc9=nŒÐ¦à2Tø=@`Fú˜‚SÍìfJ—ÂRSErçãÈ=MÑ
> ¬xGøŸsŠþ-Ó›rdL¬Ä-B*=I]ßQ­ËÛ0
‘|ÌÖ_åÄ:}e8˜'ºr¶ÇŽc¹XI=nAôT°­¼**–*kR222222222222222222222222222222222222[ïa`G'/&_k¶1j­Êð
> µL¹[ä83=M· ›»ì&‹1N“Lc±³éÃË~‹$DRZž^—/Nö’ƒè*fÞÆÀ¬‡B»ðá=J¬Àù: elrªA—
kk·¸ˆcy‡ºŸ-”SlÞj/=n­`H'#©ŽDÊ÷*!ÀkEúJårkE><ªª
ª¬3ï=n+k*º/¾C^CG‘ŽE**ÊS+0˜—¬3Çg:„\=JúNMaxRXª¬::::::::?÷8>z~Ml]á˜Òc;Ý;xòú¦fyo{í=}«ºÁÚ±-åwJ“óP¨ñ—I1o\…_F„{~òkÊ–œe®p\t"ðŒ
^K=n§Óã+“9Aƒ•‰0x£ººìƒØª(²U°·#ˆ†V­û’þô@R-êJÂ!_=Jp7¦:Žöj¼…£Ñc×ÜbÊÁc×O÷Oïс‰¯éô6ÃH£Ç^Å7jéR­ÁB=J8zœ½ŽÈR`Ž÷ó–,_™@)*2RÆ
Þ`ÞÈ/1f¶[eV×1wFþ@V¼Jü8o©¨²a±@ó*Ž÷!¾D!W`ÅrR¦QUæfq!´=nœ28}"Ž)*kÿÍÅØÊÊð†ZQ]™üú•¯û¸˜ŒfpòU³Â[®=IʬÚaU6¼˜ŸNÊ͵Ϩ“0€9Rk]„9ï1
> NË?´7Ú³*’
{A÷=n䑪b<Tªçzœô=MSÖ±a7S/ƒ­ÃøHG3ÿ1Í8?Û¸æt7ê+o³ïÝ8ꇎǪ?Fɘîu"{߭ź•Fø—³PIóÍkk‹eƦ6N$ª¬D!ƒY7õðøÉ^2µÐ›ýVj%hÌ9
> }6-Äo0ÞG±­Í7Ø£Cm¸­Ì´+=nJìqÁó]©’4µ¼òþ°ÞJïýÁFÛýk
Çñû;q‹DœgfókrͦBºúd\dü7%=@JÇßdJārH?+òŸ•ÕÇ„LGZ¡¾4<ÌÏ·\iMxß¡ó~žÁ`a`
2¯ÈN(z›=MQ¢½NJ”SÍÊRW°í@=}‘^ØD½ë0ا+=n@Bfù-©n@eÉå®-Q=}„]#k­=M–²½(±%ä5Üa0ÜZôdÀáÁ}ÿ-;Q:´Z†•kÕ´7šEusPq”!9Êk:Y÷[Ê^•EÓ+1jø×G
æŸ_$R×EE…ÚÃ«^,C=MMt”/g%ÆÍº=I¬…E„–7£kŽ<ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª¬F]^¸‹18FºR^ReƒÜ86WùIÂIÑþH‘yM†"jf
-$?q¦
> ’э‡"˜šç`{†¼íVh ™ZÔ\ô93Þ>™ËEˆZcÌ Ê­kJº}¯¨Ò]¦Æwk’7¬­ûì
«Š*ÇcGº¤šÃO5ôy-ñû0!¥ÒÏûþ“÷+9—Iz£J°bâ”R·45Êõ‚)*1¦´7z::l/J–W0
GúJú*/=n<ª¬:{·FžE®@•­¯ÞkR2222222Jºak¶½ª8y;F,ÒÊÅMª£•sþ®>¼–[£šö?¢kk1:Gì­Ï<{€]©+íž@—_#Â5g0)*^=}²¥-„þ=Mñ¼ÍăIV˜;ý‰Û'2¹
L€õ>Üc¸Oöd=II1¨=}:›{7M%>GwírOžÁlÞé’ʼ#6¦IÛaÜ9]<ð±µ£X`t4Úî=@¹@Œa™n<øzDDD=IRE9^?9X›øñªd9¬2žƒ¯âÅåþÊ­®èMþÄkiŽ¦{CÂJðSW–·
> •=Jz”ꂜ7ÆWÀ
­JðŒsõvºšk€õPH†Ù™²’–ÊŽ¾¥jÞ;NoÊÀ"Ãõ²k½Ož0á¹&J´Š9^3ˆð—*eÈ’bÏ9ÈjkͳkÞ‹øh:ˆqDú¨²<rú¦yYš
ƒí­3DŽúŠ_i>A:^8MÃjµ
8SFDiîÊÙ¨’C‚ûrKüß­ªoŽ›wÙ8ßçL]]sM¦M=@ß$Jö‡M¶¼7£åy¼52Ú¨™"µÙ£kKÛXJ–wʶü_È@ߪ›œ6ÅC›9¥õ¯W1Ó¯6¥“ä8Q2eŒ²*^a…û1t´¾;’[ÀŒ9
ë=M
> ež¬5Å5œª‰KE/{ôo^ßVXHõx«0¼=Mž
û=@ì5‹z"·N„4[C0€ƒ›þÈrcد7óÿ=n´2ҝ×0˜ˆ¦w0º{ÖWš5Ǥ0Ç“;Eî„íh‘›j;ÂmsÊŸßÊï÷•Nù=}2æøQŽ<7Ûö
µ÷ÝÉ%JÕD7Ó=MlꞬ؟-61R™Ç=M±y~Dpðï2X“70­¢=IˆÒ_Ñp†ˆ^*‡©2M7°Î]2\GD=@k1…›—+Þ£¿?
Û»5Ê9<zx–[èÜ1¡Â"ó¡w¬5ª*ʬz:::::::::::
::::::::::::::::::::::::::::::::š«½;M©ô(dʶ­6‚ÔŸ“€yË)*ô9,0!‡ÎþÄ?HÓcîƒç©©ÿoŸpëNŠ·V‡GºœŒegØ`ùå©òÊ»Ülœöý‰Â–ÔTp‹ŒÆcJðrmkVNHr\]
> f^Þû2Tý¤JÚ_éï0ûŒH÷aF¸ògFi’@w¹ôyúÊ‹îqa¾ýéS0ÀpÿÌʼj»×J·ñ^D,2=n–zFúº RSE¸Ö
ÒkÌ,2,6£QMb€™¨ë0ÛÚ[Ëày\¢ÊÜ,,,2K0™ s5ÆM-{†z“ë+
> ++=nJ¬Þ…²HÏ=n\€iòFð=I>?¦ËØô_TÌËÙ£á6Íÿ0'ö€úD`jµ9ëùDå„kҫͬ´á
1=n6«-T8vžŠÛ°³OêzeÒæ½ëwäéã1É8FŒ!Úº5½#©žG=J=MŠ;_㌐ß#´3É<ñ
HÞ„ý_GzœQòWôa6E%)*ŽH8ºââ{þ²[¼r=IO-wë0öˏîz­’=I;š•Fêp!Ì7ð:f…Ý:¤¹ûo”ZÛßänü¤¾<Mš)*ü©õ"kƒÌ\nä`¸Jz¢ëžãå+~r¨vƒWçŽJ@­
àr¶±Wþ×Ê=J¶ãٝˆ8›åxðºŸßª,x’ùó/¶tÅi~FW¥O@õÌþG–šï«¾-„f:”EDu¸î-k0£Ç²CuÓŏŒ7C3?¾09uR^–^sLù]ä52MD»’Vˆ=@5ÚgžkùPV­ïk¦üFßÁ
Êkˆ=M™¡ñ~4¬]é¢kú*¬Mì=@ð0ÀŸK0xWQdlc­cN’Ø—¿ÒR›xÌL’¶k7/A¼š@­ØRF=M“FR§dJÚÛŽŠØ„9û1DB9]ÓTRD=I[+=n=nƒdJô†u„õ‘²»ÏJ<cØ
l
IUù³äT·E7^!®*¡§t5àbq¯×Šè+0~š=M„8lV›ÎFøÃEMæÊ¬*=IÄ4±cYJ”¬p²ËT2k|?Díj\<:“>·¼‰=}•‡2()*ŸkûM+ÅOÊ:›ý³Hõpçi¼ªG‹=}Ó­cO,¶
> *¢Èb¤ŸkØ=}8r=n´’h0·'§z—î¼z-ò*¨Òa“
Þ™‰±/?™8H\É’¬ë©»ãqa9û/­/þkŽ<ªªªªªªªªªªªªªªªªªªªªªªªªªªªªª¬::t,,,,,,,,,,,,,8vrõ²•éZ
> $JL¬[W÷@å‡I¨ÉÔ9Çï'c¹ääé}'TÍý¶¸FY%kÿ¬a-d‚"’Ìä²=n{0\jFT­«=Jz£ý
§bÂx}ïÏ~›æc±V×ô£Êô‚mHŽFØ‹•Ô²RJb·ú‚b%º‚b´ÿ0öÇí¹Ì9l8ýžÁ𦩾H
®œñe—¸8Øp²{€ö¤i€(˜ˆÒa=n;Ž?»¯þ#ÅÜ3­2kQ¼3ksˆM¶â…8’S±Ä숗îkÜ,,,,,4⇒S;€âôèï=nèp]ø
áþÌÛbâ'º)*îJÙ¥²©¼PáÕ·ÊÈ¡#Jœ˜²N‹L™³
êæ¸¤ÊåÃÄßW-ª~uMVÞ*£Ò[bÜ[gõ…·üҐ–0æ×­¾|/¸‹/u+ÝÜ6‰µ¯Íø9Ë?BHû·ðÂüy‡:€VmÛB°Þápâ;%Ó!J:ûUÆFrªIÊÝ*mÐZ–cJî=MV}ˆMpÏ1ÇPc»
8‹e©1+îòXdʪºúW=nkÕŒ;ÇßRT¡ÓÛï0›¨OG[=I¦’ʽe=JÿüäãA„4áGUÉ{rE×1sbóŒWW•m¯<r>­¿çÁ´÷Âh@ÈÙkVã/
àF7JŒÚ‹›+öD“1Xb»eŽ“
> Ì=J32`¯íå/í좞k Ákh} =@¬®b’Ü44=JW9VŸ,•ŽG18F=J†uÕÄ7­*'º…jÌܼ
Ú¢·H†?qcȃ‡!–Ë#´5q¯&|æ=J,75L²…¹Ï¬çdmG8ok³ù=@Áž=J¬F"—ú
ý¼ÒÁ?˜j’i¾Bõ]Ȧp±Y&Jîét,ú—=}3cÇ2ešâ“O§•ß9yK¸`ÜáûÌßÎGv•Œ’›=Iªkƒd±eå窩2\íäx‚õ=}’^ÈbGMý‡¡kñ=}ǵÁ]k6˜Áòœ2dH
êúÍö*JÒí
> uY´£réÆ:‡âðÀ¼jMÜ4gõ8:•žH†*óK»
7kÿÄúwÒÏÊÓQªÜÔcG]Ͼ`WŸËÔ8nÝU†r*ÁJû"£]à‚‡µt7gÚeæ“ÔþÊ·Øî6ï«»š”5æã>*¼fîškèI=nM’¦î^7jå"
> kûÇùê’ Æ^H´UpÛÛ"ñekq1ò&û¢câz”£²Grk
Þ^*^+=nÊJJJJJJJJJJJJJJJJJJJJJJJJJJJJ®=n=n=n=n<ªªªªªªªªªªªªª­ÉB=I-‡#t=no0ø@ì0Ì9Ç
€=}xE­Ïi/{®ºdbòÞ·â‰*zŸ‹7¡·>”3k_Ø„6Pí±´Wö=IÄ9h–3“X²%´Ò=MÀUàòüinFÜîƒÓÿæúŽ„pÍz¬o¾@ͅʺ:•F؍­Âýö>H¸Iß+K⫉:¤;æ8¯êÞÈ1m
%Rذæeÿ/†5ˆFV­ËIÔ2ÂXØz~ò!dÍ—ªXój;bþœkÜ3jjjk2\¨TPDù‘½Ÿk»îô'M²+÷ñk}6Ü9æ¾ÿ^?Aµ5:çmÆ8Ïo˜M•
2Vªž2R?á=JzjŸ$jRcœIàDÊu¡?Dæ¡»º
pÍš­Á;edEAÐæ:¡ÆçakúfnB‚©á¬¼‹M«ÍæšY&×k‚=MPÅ÷1†›²7@È7EÈÒO]8]sÁ`ëÍ%kŒ%r漆28-!ks³À…ÕkpíMâ|52R¢¹×>@ê`ûÃ=nÁæúšŸÈ
> Ò]X·,2Jã=JúšI=nAíï´Ç=IŸ§wú2g–YŒð*½<!iËd¦:¤Víp=@0ï:-Òý=J­ˆÅìðþÌڝH3øðº–T·’
{‹o‡ÛÞ4=J­µE¦?4[æ–·h4¹`–5÷—ªü]az²Ö×9쬘ê
/=n9’“€Þ­Ó¶•**LÏø7@zŠ&jÜE˜e*þp£[]”r£›2_<`ªrá›O/=IV›“Œ#7þ€uÍpp¬C=}-³hQ›TÌÝŒ³åµF,8ƒ[ød^|­»ÁÅN¼¬‹ƪð:cü8åR9ñº-ó,pmEå
> âD‡ˆ‘˜­r=J_Œ!–Ekñ-ZúýàÙC';póÇ4GÄ;<†=MÕkAðæqúšk‚Ê’=n⑟õ­“H
,s•„bUöÄ™ßv+›«„n™EÇEmj|¦KØ=J«EuΚ˜Îñðº‡ö[Úæ*ñ8*7›\²ËY
N4~H_ÆnëWé5©\7­”PäßRV¾~ʘž~œŒÐÐÀ\²eåÌL@0†¯àx­–cZ˜ÛWeœ´÷¼°’Mß•ç{=}Mî×õC•Çâ=n¬E5«Á!—×¢D':ƒØ¹9{ëGâÎAŽOñ^]éReLáUýªz
=n`‘™kŠS=nÊJJJJJJJJJJJJJJJJJJJJJJJJJJJJ®=n=n=n=n=n=n<ªªªªªªªªªªªªª¬¼áfx™Z­Ä1‚2dÜ9MߌàåÏ$•&¹¬Í8÷¾6c=n+fIŸ(ò¸"3˜Oê0é??„
> :t,,4c«9Z­È’…ˆJUÉNF|бÚr?H¦"qñ˜7ÙÌ8|_J´R,ì2̇ ¬™~@8­’‘¼1·îH†ú¤Z
¾œzÆ¡™gå©2eðJÜe›•ô=J¦ôUPhæH]⼞4Í¡^ÜLçí³ôj'>€‚†mѼµpÆ¢ÿ
> ~ RÌ,4èpðùš’­ÇìK‹i,6%ӏi¤qKÊkæ¢
áŠ:–B,3Î?ŸÞ<+^3Ø’VüFúpï=nÊJÍ•Fú=Mƒ·9~?»±ö2k7š™cJÍ!ÖœÒô‘ái:Ôúʶ;S\ý­qµÂk¯¢/û+ÍŸ“
>>€¢Ö’ÜW‡ßkôò†ÄuN?qo_ÊÁ?¹¢Iä8V’[ÎàI?GzšõGÇðçžkÁŸEwãêÈ’Qe§º:?dÕQîÊùæ¼æLÕÏJÍQE"ÊØ
½×$/-ß&l9mÝåW"ÉFÎàhm¡J!=Míï:•‚ëm€Þ–dÊ
Ö=@–ÒÕÊÍÎ’EÊʞ¹PÂ*zpsŸ¨„T0H¼^Ï0¶»Ü`zm²ú´kŒï«ï×Ë?ÐôÍù³Ö´‘â92ËÑ^Ds³á²AȲ,3Oa]Óé¿Òa¸Po>¬NûÄPò˜ÌÜXÀj–!–éï=nÜ`]?p
œ=M¶À‘œ2bðòj°¸²\Žœô¦7Q¯Ê¹*yÆÉjW1uZöŠÛ:QÅ´7—•b™û/Ëíó²›ò!`i÷áë0»íEr•LDÉ[`r2eÚß·•Ô²?Ùy&:nמø•q³­zcȏ/æù˜øš
Õk;„q;AÈ·c$ÌX
à`-¼´۝s³¢f{ä˜ÔTŽ•3«ÖÛå…Š¹Ä3ÿÞâ5*â=@À©Þ­Ñ2'³þ¬jfúvP6D=@Î8fú£}óPXšëÃì-…Rgp‹…±í<’èÕýÊkö썤„4A_åº;ƒ³®¼@ZµEnQ¾o3×ÕˆÒcZÖ˜L
šˆ*áˆògXø•ºhí‚9¯Ñm†'g‘têfê$??­Íà*ö×Lá~ƒ¬bï´›˜d*¬Êè§·]µ­’Í•/Z\¡TT#zr>^kRK=nÊJJJJJJJJJJJJJJJJJJJJJJJJJJJ®=n=n=n=n=nCè’=Mò
> ûú¾BåGIÚéúÿ1„,,,,,,,,,,,,,,8J\v
dJ‹Ú­ÁލùBÊ3d¨ÉÔ9Mݲ˜SÅK´Ò­¹¥=}AË!¹o¡ÝŽAjjjjkµHï8Æ:ŠûÑ4Q«e(bgÉFèjB¿(´ÍôÄQê1ç0¤â
jڞeJ¸G:‚=}’X_JJ%i6!ÛæDfú¤×’’úRÖÛXýRCâû0bbJ’^4ÍÛo?–—ö!*c¾F¹ïèmzáR&ø'º?ºAe]óã¾G6¶82`7Î<¬z:l6ê–xXXÊ=MÛú”ª­Å?ˆ<§Ç
¬ƒ¥&eˆ
> ¡×§z?ñ䨘1lÔ0›•7+ã×ú›“¾pûx“ú᧺eë5øG8±îd6Ħ›»ú;ó1nbšëÂy>=}`Lb„=JüF
QÁÓ':£ýö=Mº°Ñiœ6—¶H2êÙ“úŒ#ÃåȆ¤–­f p€eº‡çÅ£F1
> 7:‚m]¸»âÉn<š|O¢‹0»
‘¢uƒ;›=J¬éñXê77jšÞE‹6¿#ô™*¢¾HW+«¬·7rû0×’@¡QœÌκ/Ǻ††’”dJÚ˜g:‚4jjk½=J1€¢†¬„üEQâk‘*=J„ŸÞH€M=nCP
œ2“=J9?{7•‚SÊ+û?<tò&ñˆ*˜ÊîÏ)*"–ä2˜p“EH¦?p=}Œ‚ùeåí#pë1VâãN=M¿æ¬4o±À{‹Þ=Iöž2eLìëBöGúJ‹›*\[j’¬CÉqz­k±W•µ*¬×ª;Ž¢žÐÇ]©2dFö×
8c߁ÊFúj²ã¸Ö›­ŒÂï’)*ÌÖðâàªòžD_Ë̪Î:#-p1N®u£„ù§åû~„=}2%à,2=J=J©~;E\Î`’ª­Ä|úñ”fo0=}Fkÿ=M
·G¢¾FÂÃHk³ÎÁf£)*(q­Ù+®˜G÷A
> ÇùX´U–{Ö]ò­õðôKw=@¿ßÔ¶Í8¾¡;õ¬4âq55‚m…
=MîÊîøN5õòÊüIæ0@:5Òdâkm¯îqP{3õð‡:Ÿí±•†V•„a±­Î»E¦pód4{~µø“˜âp`!Ô·!"RÓkR222222222
22222222222222222222K+++0yîìù^·0úŒ©=M¥'ž2Tïs•‚gVÊÙ½O£¤JûÂPa¬7Å-…ë0ò22222222222222c›-V÷¡>­‚¸²M<ì"†ú­ÈDU¸­¿Ô¹sñ=J
> /߯›=M%ÒÙl\7;Û2_jjjjjk8’šÑ*l6I3-ëF³­3LŽÖV¥8n”:£bÈø¦€"8(ˆTÍ´ÙlRÊ{k0úŸ
¦8É<=@¸D¼­Âððê=@´*RÕJ=M¶ÂÁb#kýú©io{Ð?Î^ât2É@øp6#
9??öB‰È}Â':ž\Z:”=@Êú4kR2222Jªo>?·Àâ”`:‡1Hcêpü¿qh=}<KO¸`FWÍÇ’­ÏžÖãj’å*':€vj­8üRAƒ=IŠ­ô¼qämMm°äæ·´6ÐÂèuµßk¬¨†üâGj*>6p]cʘ!-
> ™¹>F\D3NbJ
Lqč•ÿ*kMæ|éRt*%e8àû1x?ûó³\0ßðÖ>H¶âr=MpýÝÐÉì4Ä·"£jÕŸ=}öktâ7sDRÙi46œìú"ŸÔY·CÛ—–˜Kî*eœkÚ¬aeOI*Ëo/Ͷoa®
> Ò­Ëo‘Oéì45ßË̬5JJJJJÕÄF2d$Ê÷Ï÷c3JšRWM=n¶W
ñ­óîܐv™®¨˜”ÍPîCŽ6øtUS•/A1;ê’²Å>!‹×=J,2±5^ü1 òg2ec×Ì…Çu⥺ 6XŠ-÷«ë?ÕJ¢R^
7-Š:mÆBüD+0œF×9¢áIN§¤Ô·ÚÀ^óSG†¬…õÆfqk…¸k=n+ŠÛä¸QÉ­lDfqaU=J­o?Å=JtҝubÞ-âeÊâÄP¢„qï,lü"Æ8·ºpçÿÇd=nHv˜
YC!­¤Êït=J
AF%‚d^œGt5=JŒ’9£*cÌ­©XÒeÿ«o‘¶)*àœ9UFøá°ýo{ÆÝ²„=I™¤8ˆù*ºDõËÿ1^¸cÒ“Ø«1Ý¢ql=n¼áO–81Øb”Pào‚â[àQ•T2S#ÇÕ=JÔ_7×¢ÒÕJJJJJJJ
JJJJJJJJJJJJJJJJJJJJJJ®=n,’ƒ^­Aː,£a~CeDyl=MÿJÓ¨Twµ‚d9-¹½HžO0¶ëÛæ,7Å=}q=n@7-¬3kR2222222222222222[îàQµwÊÖo0FïJ#ü¶Û•
=nùŸ{ÿ°š¦v›Ý–MwŸIü­é2Š^"RØÞ=n=n=n=n=n=n=n>¼PòSía2c³÷þ¶÷Hú=I­¹;­µ;Ž'Ý9ÿ~£Â¶Nâ=M—á­°òZÎIk"˜4NMïPè«o¤R]Ã'x¡KÌ6‹“ŽQZÝj¤)
*—~<²Âø†ŸäUbË7ERdDþD0Êâ>¬z::::::k2KØ8—µ’f}µêŠøÝ¦×~eb_¬=J’0ý…ýÉÿ1pWïü\`z›b3Ž~mjÝý%Ùï1Î•M0q0úz¢"Å`T=nFŒkCBffÅÜ6
> 5¨”ä-†å=n>¡žë›¥ã]™´4'ÓìpBd5i>Cdl˜XQØÒÌ­ÐaÀÀçå¬2?ImMPf5H‹{†Â°~\]fI
=It?HàC'Da—4U÷Å^|c×=nÆþû'!Ô·åÑ[Ûæbd|&ÃFúŸ_$­?Åy0·Fr
Aï?Œ’<ÊÖJ/Œ­n=n=n=n=n=n=n>»«JÊΘX•Â=M™ùÔ6›ÛÃJöûŽ™o1ùy³›=M¾œ4ÍBÁ<ÛÞ»#¸ògfY\džÑeä­çÛßÍjÌÙrO+/‰MƒèѪE¿{|¥Ð!Ý£ÕìørW±ªò((„ö
F
º˜!3/aŠz{»Ab˜*­Î^7¾{î^ƒ^:œèx»Ä™A¨ôÍAr}E"—^=MùÌ5pû[hT™:9éžAÁ9;¶ýD2AŠ”­a—·ÏÊ«ã×1ÉBü…l2é2ý¬5ðëªí0,=nü5éRkû›^ñº3ä0äJ3ÕP
ääè’`®"jÌÕ¶&8À:£ýf+ÇñW—¦?qfB‘Œ=IÂ"2QFeñ0G°ÄýÒ8áó0ÂFEŒKöŠÀu&q71Ê'z¤^KCvÜ=}Ê'ºs<óÕ¸€({ãkÞ{°’i­Þ/?Ž=n=n=n=n=n=n=n=n=n=n=n=n=n
=n=n=n=n=n=n=n=n=n=n=n=n=n=n:r’ÜjFô6‰µ¯ä‘ö£a~CF"šÉDkA´½¡°92-1¸ù#EkÕZÖ™*­{Eq=n@ÊbJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n
=n:jJ­Ûkó?ÞÀÇëÎGw`:£GÙ:96ì)*é?qYõ{çáÕ2š-$ÌgvSõN»È0'¢¨´UßÐ:ƒ++++++++1PP\—Q„e>BØCðÿF¿Ø¯ÊÉ=}iŽqÚ*•jE7>~ÊñEŽ›(¡ª§a
nŽóˆªUMpþÔ`¾ƒ˜Å/?W”7D:†J¾=n=n=n=n=n=n=n=nFâÑäa]PhKö›Rb¾wZ¬=}Ãî¶îTµo=}šbñAeeDžFèR×QÃÚîˆ$øÓ;µˆVOżmÒ­øï=M‰Và¡E+ë1Uµ=IŽgê
J÷ùŠ>f‘=Ji¾>¦¹§1ekÚ=J­f÷hRM]y‰œ0‹ò&:]‰Ü§a²­!!â@µ`í„JØV¢^P¶©[)*ª­ÝÜÏ9ë,y¾ÅQÌâOîà†n½€­ìëîÔ·ÃF޼ãNH¶–F§>zÁ_ä5J&zŒµ¸vßÛ
#Ô¸»Ê+oƒ++++++=nJ÷(¦êE™wì2>…JÛˆŠ•«I#k=M8õ¶ˆ#3La{F—·ËÖ**ÌØ¬z:€sƒ=}gê=nFyð聎íÞÉ?G›îZÛ³Oce8ÒL`CÇø“Ê"–ç0Ãö6’L[ìákúð´òUœ1
òJþ*//?ƒN––X£*8O1SÛ˜8¼Ew߯$¿{vnãÆŠ°9=}±=n?­7—CžË„–­£‹––BSê·q>@Ü‚·{ˆ‰’÷cÖMÃÍë;÷®’—Îü&­¼6åoü±°â»é^H=@;ÐF1´ë*¼ÊÑ‘fé4‡¡Â%
ôÍ€çÛðˆr+ÔU¸–mÑÃíÚ0ß&Ô¶¶lmnýCç:™Â@?}0í³j·Á~öÇEí=I÷1¥Š£=@ð˜¦1j¬ì`ïá³³=JÌÖú–µ³?D«kot,,,,,,,,,,,,,,,,,,,,,,,,2Äû˜J8ŽÊëò…ÝÝH
w@¬±?Mé8I¥´4=@Ty^ÃqP´kM=n3á¼=M÷ðú–eEêJú[ͬ3Î<ªªªªªªªªªªªªªªªªªªªªªªªªªª­À{¼¥=J’`¶­ÅßMXªb˜7¥´993Q›¶ÔÕü±‰~¤â¶mFwWéÊ"ÒØ
H2Xª
ªªªªªªª¬28=n;ŠÊ=MVǺÅ1Œ¢Ê=@2ê›§•~­Ë+1ɲÁæî¬íŒ`Ä~ˆ<E˜šÕkå¯åÌÖ,5ª¬z::::::::kJ5P¬9QA²ž-5ÕXøÿ~‰=n믶èk!¸D^Ǻusºi:yšÐ2b¾c÷£æ
¶>ëîkù²¿ü¼2Nb*­ù¦×—°FñÂ0yÃdǰªšk‰;Ló"ü2õêÿʺ?¤žj,#»øúp€Az\,^™÷0ڶ΁ÿ1Ûþ¹¸&ìì8jâ9D¡Hä§z£ùMšíÞ{£þkÐBÂÈ=JëpÒ›ØÒ_¬
a:
EQ°J™{ä9¹–·8­«>?‰ÍëËk¸VHcäb:k?E[Â?‚ä{2O++=nGÞk=núGžkR2SP·Üo¤J=MÝ@Käâ,T³D$¯{X†â6áROoxªƒk÷Xi7@°zyPÔbÐÅ=nlô1Ehý¹À«X
×ù*­=Ií=MëkÆ:Œü\ud0(²X=JsóŽ5Y8ÈÒeL³Ö+Ö—*Tñ8²`*+jz{?¼kEsN¦zŒöø<uÚÞ'?nô•78QkÆz,7+Ë0°j2¸;˜çyJÌ×c=n0¨—:œ=M[,`=n‘
·I|Ô
> fpÀuM­³[ÞßH2gfVCÛCD#my7VJK
Å…~3ÎHÐ[ù‘t™„_TU8õ…5þÔ¸“ŽYgõ3=I")*RVuж+Î@°cIo÷ú{7=J9]%J¸,1Õ¹>G¢ܵÊ9x4U‘b[®kªOøö
Ò·745JJJJJJJJJJJJJJJJJJJJJJÕÆ=@5ªFókµÛºájuù"µkm´»=I±?Ÿ›k†âÃfü@¸w>¬…­“`›wÊÚ[æ,7-*=J¬zt,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,6›WâíâÞÊ
> ²´5õBÀQZ%lº¦ðWϽ^èé=I?{`}PGÜq€2
æ©äLçR7:žT7z:::::::::|‚î¶ôžf9L«=}u*ï/ºœ‘W,PDáf¬8–emÄd;?Eâ°°·¡E¥úž\µÆpîkÊ4Tò222222222f
ûî0BøåDkÀ@JSÿÊ~ˆ›vöx±¤¾F¼ôˆü8ím…I1>Àܼ×:šsUN½jrSlA¬ëЯÊ0GVÊÚŠ@«¾?€²*+ÚÎ<ÌËzÌdÚÜÂиyôŸkt‚X›ô…õw¾¶Og¤A¤ªÔWKîò‚
­×­Õ9¶ª•°¤Ñ©zz™6¸¶âq¢«pRg<(*Uq¬´Öþ3ç0àd”¬ûEþ­j¬zt,2k¾xȎHkͤR^¥ð›Ê¬ÜéNìÙ‹¬¸9­*+;áÌ8¦u=n£’<qHi?{¶¼¼27*9:`­ø
> î
õóW««ÍÅßRf#Û}x¨qeÑ9¬6³fºžŠ¼ŒÎ7ä™=}rhÅ9±±+±éR-|zŒ#=n<œD^Ä-Ók€-cõE·–‡áâœ2eʳ֒6—^4/o–¬Ï
r˜Ðºq Y]ßeÊðsµqŠ-n=@ÔÌ´šý¼´³NXgˆ˜
QÁ¬÷6«ßî&skõPJ[ØÃø=n71?{=MŒQ¦ü:‡¡Â¹æ¬8Øø•Gb>SÄ9É­ú·ÎþI:ú/?gÏäðÇpœ?qq—æá,ò±Ã“­³¯öìÜ\˜
F$$J⢰]fÄkû®ë󲨣R+ýk&ʍ³«ãû
> Í¡R^]:”Ä`{…Jìq¬$=J`k¢Ä•[Êÿ++++++++++++++++++/†
Ú…ÆDdÄkµÛº¹SYi:zÏ¡î1>?õ²½÷S-½žkWëàȏ0÷«×=J:’B1=n=}rO+++++++++++++++++++
> +++++++++++++++=nb1^­Ûkõ;Õ1š’ʓڭí¦hè°ñé‰×Ô´
ŽïöWe—$(g†[%ÊWc~zþJ¾=n=n=n=n=n=n=n=n;ín<­S:–c¾H¦—ˆ'†sk¢*6£4Ì‘—øëì°é>
> G÷D¿?Ž<ªªªªªªªª­ÉE²B¢sHÍz¢8¾½Ž'?q
G¼§eÜ«2SfØ›W=nØ+1òÆpå¹nFžb¼sfô36kŠ*=nÒÌ2Û÷{C±^mZ«ÃæúrD˜Ñºo–HKîX!´z„†^º¡lkƒ"œ?
> G}Œ5=J¸[ê6Íkk¨ùìÃ9š-k ÍíZÇýq³$+òJ‰»ËÑpª/k=@óDN9;òa=nzgl8"[‡v‹÷–߁
48¦Ün†Bú¡˜1†‚¸FïãÔ«ÎEq¶«%éStUËØ8@2MÂkƒN6ÕÜsÊ*å
kJbÅP±TkïPQ=}6UfLò£Fã/{Ü@*u„0ëkô&k½ažüRD_~vÖ–¼pìò]E%û|öpË×Üc€=Iô­Aóò„xègôÒ=M¨Ëꢓú7g:¢"Ы³¥„ü_JÕ‹N"·žkÿ°ì±çו˜
z§@=}
6öV€¦ÿÓÎBx!ŒFu¸‚ÃØå©QÌ4ní_്þ$Ê‹³ÖŠ7>>€Å=n>Ü)*YÁÉ^=}wŠ=IÐåÊðs5²D­¤/{J`J@=MÝ~~c¥ö›Ç§Ñœ:”ð`Bú7ô8“Ncå÷#žFtÒýÆê‚XLÒ“rM3=}†
É}Ù>CmU˘Oöûïÿ¡Ú#ké‘e¤±`(R^‹-á‰Kú_ÏîÈ2W´îq²L‘^!—ûªÆ(ò[†YM˜‡:ŸŠšX½UÏd-¤šk!—V6’Ð8-o=nz£òBaØR×z€‹MÊk®vX
Îúkü¬z:::::::::
:::::?ø•/ãëÍÓkµÛºáŒˆ©î„6øT¨FjŸ›':kB³fü:90ªM˜Óz˜DbJâŠ2Wk=nÊJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJ¾È"bJÿ¯1Y”p‰±ö0$©¨ÒffU
¶‚¼1â¦ìÒ!ZÉËâ‚{‡¶dJÜ,4sM“âJ͇Uï6™‡t50½Ë¥×/òÛËMû/“=J’2PòáªF9G£><ª­ùïs=IŒ\9V©\¬÷—=n6b0`úÙCN~„œD
G™"RdÍÿá÷o‡+++++++/†Þƒ
K0q:Rº^AŽÊ‚±HHd9o{ÿ±íq-=ný0ÊHO/Pîse¯“¥a¹10\¦éŸ?å¼8Jú:tSÜ4;:‡ÿ/5zp‘Hk*¾<òMí‚üGªk¥JA­³=JYJ'þÕ>;jÛp=@8«0ªJñÀ÷
> EX´´8@_ürñÃï~§=n£Z⊞*4’i=I¤9A?]лüHd*¬ºj§½¿·ñŠ­Ô’M
FÆfÏ#¡=n{Gzœll=J=M¢ÔâJ…M•ˆýâÿ0Û¼q€2km:f>~2\Å‹WfëÎAãâi[˜­Zßo‘¿È
> ‚ÝzÔ8_nšÈÙö<YjpÒd—=}Z»EÆ©$¹£0·c‡hœYpàùÑn<Ü2ÉNÛºûÓ
³!Jø†uO¢¸c5oúU¬C@“]ßÎ_+²Å¤d’U­ðñbì&þxŽCêô+×&Ê›kbfUš»!½b‘M|¬Q
¾õ¥Üp`F†­b=Mž-jëÚIÌ9pR4Jž{P¬4À—ó=nhjðÇo®F°‘ùR:µF‡ë~—íÚ•Ã^1~>Š¥mwå©>}BDú­É:%A–‹+HrfæˆVa]ßN*=M'$Ô¹^bÃ-Ɲf®G{b
> b˜ýÑëo›Ú,öw˜H^!¿{ÿªÐÜl
/Î)*{†ýÀy¶»êåQáÌÒdõާzû¶F,8Ö@?üòIJh²g€¢-RpaM³kÍ,`4Q>?Âúð°®@kùUµÏ*š=Mÿ0ö’ml5JJJJJJJJJJJJ¬mo¼*zŒ†W
¹"µk»ïòí´äâ(²U¢³füFÄS+âzwä£Çz–DbJúp,50ª¬zt,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,6Û7â˜ý’UCû0Ø’¥5xî|9Àïð[J·5y?qÕ®¢ž–M
> ¡g«{ˆ½8Ò^kº=@¼
2[·Ðseñ­Ðë1l2k*"ÕÏÊÜ,2J;nJªR¼­fvçöXšGE­°0zkü0¯0‚¡ªðàà¡ÔWµÛUF_ʞ"Ê®bÈdÒ×::::::l6‘î\PÇŸks¹,hd’¬ÂÈ$íq=M£
> =}ó~žš;‚v®d|c­3ަDÿÍ—a(:œÐ:áå“áÇùNH¤R¬Ïò´ÁJË¡WzRÇúwJJ5¯½AXp4F†
2g&`<FF¨<]››D¿?¢¸Š‰#¹ó0«1VÝäB=J^ûÍÎ'1~Fâ¼Í–v>aT͘ô­æ»üâ’
> =Ik¦¨RèvÊúG•nF6“ÄtQwsQª­Ëê•^
éU=}öœˆå«E‚k††IG=J1S^Gè²^ìxò˜ÆV€ÒeîåhQ,+Í„Êÿ¸•øªV’~€ËÒVD¬Ø³ãØæquÕ~XDP¥Â8‡u²)*ênŠ=M°i±M
> µ¹0-Ùë/Ä&zÍOàWãdçò^V•wK
3Kñ[_kÆšæÆ±‚ʉnGŠ¡‹ÎÈJ’­s‚B‚Ù/?=M<e[CҐØI?qx<2×]r5Ư”t7›<*=JoA%[¸HÒ:ê&måóož(k\ZêR7/RÍÈ+×s
,-ki÷k¾"°ðü+ÿ1U-XçF³eT¸ÜíohTUB#súG5äœ4Í×¶6’•o*ÌÜîô‚ú=@#Êÿ1Á¸îà;ZÆæy!Ôf=Jr¥ñ¬j´Jƾõ7šØTUÕ4s¨™kjkñã¸^dÇ”ÍØB–EŸ`
Øg>?N·Ì†»ªDû?ï~Ÿ'=M`?ÐzbŸk–{ß°ðéh²dp€Üð>0`×ñö{kDG¢JÎvWN½Ô7z::::::::l6É´¯Åò3zŒ•¹“/5\GˆDc^J6h™OñÓÞDà0¸2^;¸rXB¬ê
JJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n:­Äi5µy-rdDžk
I¢†0¸A~‘Ü"ÅØ°ïI²'
{HþcÒ×°Ë*j,¬3jkÆÑR9&ѬO+=nJ¹[L[(ÒXëÌ7júÊ=M¶ý²«i,Ôd[-ªèRY«½fJ:k´z::::?ø7@t8FˆgÛ´‹!Ê=}è†ù›ôä~Zv¥ÓöŠ\fý1z¥b¦]Z{
> Ø‘’‡ðûFæmmu+Q‰C™=}òJ=M»í53Qø¬9_øY›·¼¬3ÎCÁ"JÓQ¸&ºjž<ªr2T†¬ö/Ëá^Im«Š­4=@ª+
ÎÒׂPÃk§D’*­·e?—²Àíï%AžG:†0Û¾*•j"JŽ£¼l£¿{a
> (Å0ï‘Lý´9`ò=I¯Ê·=MóÊ›ÿñiéÌ+•åæøûæ/Êô«ÿ1n=}‹ª*Síkñ=}¶|-£’؉:
÷+º8¥×èóʤÇ:Ÿ‹O•Ëòúk™+Ù­ßÄám”TëªYÿ0ªJ¼?ŽJöl=@1¡¡Èââ
> Êûã²cª1ËÞC`j
=nIo{<eå“¥oÈL?Å[6¼a9MðÎH²¸Ï?ª=}nm˜j;ÏÔ´hlñý*¼œRå+0â†;÷È|†×òe&[áª4UMUÎ_:›T^•mVÇ#z››Ê*EÒi_{Æb‘÷!½"aÄ8%–
{—¿Ê–Ìã„ñ=IÃ$p`4Íß×7*+ko?0zñjcÊâÀ%ôšYQ¨«~£V°s¹©Jg=I5­§>~g÷•“î*žjí@ÞûhóÜ­BZÃÆIï=@^þ$T·Û=}²»K´
zJ·×>'„V½ökû¯–³W¼Ž“=I
> w1ÊM78‡Ï^âÿ˜­Î}ÓŒÞ{€k=n°¬s*8’\KÃØ1ê0ÈÒ_,¬3jjjjjkƽqIÇ=JžkµÛö`c'
2\]Ià€8¬ô4!X½F¤¾D`0¸2^;«ë/í:†_=n°ÊÄkR222222222222222222
22222222222JºaR\¨L`DåQªkÜ,,,,,,,,,,,,,,,,,8£ðƒD1l­p>FÓ9£¯XE݉œ918œv‡=}Ûf!IiÔÒ!Ü3M“05{‡€ªs×:]*V¾<¬zk@RÊ֎ôwÀ«SLQ@rf½¸ÁW®
†=J+?HÞ¹;ðÇÄWo£Ú¬ˆ–Ê’kÊ2fÐTàþµ-É(?qsãZJ?;ËÞ>!»wgz¤TRªª¬¼r†,9ECPmÀX’[˜;,q<wkj–[”§Ø«1ß6[Lý¤Ìû1P\¡_Ö&mÏ(zÔbÍ7AK
> i
÷Ù³­ùîv¾å±*­Ljk»››'zp7#Ê*ªyWz|«¿=n¬åå`/¸rgÒeq8zC‰ó=Iä´ÿ°_¯çËÌÕÙ­Æhv£áZ&Eïòdª7*+j’,6[¹õ@{åÞ!T¸fc™Œ9@5à­á=}OÞædÝ£–
> ­À0…¶Î¢pêf:Ÿm;¿=@„7ÈÏ/=na~Ìâ‹“Xô÷qI~¡ëJ·÷V/ê˜R"±>H
_ؐO÷•†ò’šdJ몌µ[ö’þ“êJ2ÆmæŠ5ú1zRgR·áös0ØÓo”,5®<ªª­Cxq,˜Æ•úÊø|úü
> ‡ÜÒêpýBÆ3*b„7šâ¸"@sD$¯?xü’D•ôtÌ"†UM’ekÞýñ=n
=Mm±?06¸†}Ýõ–¹­U‰¤ÍÎãºÝª-ª{†=}‡]ÜoŽ4Í‚Z··ÎÑõ2dó6‹XL°ÎÒÖDŒ‡Ã$qêTdj7>^48
¦xWÚ´Dåºk÷N=I‘³ütçM‹Ø{õÿ~¢±øvððýï1¢šÅ2•tF¢RØ=}]…ÝíÇòJùMȝf­¦VG=MÝæý¡Gz‰?³Â-U¿®qh?¯ç¨ª~žøq!Š"„`Ft9mÝ=Jš’ŸpòeÆðåö],ÌÍ]
> ‹=nâÿk+f"…¿æô2Â@ÜEd42U­97OÆþoÊjjk=nªVÄ2Z¨\@’GƘÒ[
\q¨FŠŸ›ÞCÈ$‰f¸Ømn<öeq=nE`JbJâŒ50ÊÚ”50ÊÄjkR2222222222222222222222222222Jº
a^­QŒ8ô¥ã^„2÷eù¯Ë­ÅájB¦=I´!h"–:’òI¿Ê¤Jä,,,,,,,,,,,,,,,,,4t»ñ›­RÇŠ>E:HìýÛ>z¦àTak²M“ÕI=Io{
~ËWD¥j8éô­ýo:ŒîðuªÚ¢„Òe8‚¯
> “E5ÛzˆS†S¼¶Ø=J¢c?Ü6œæe«úÊâJ¼VD1Æšª
¾˜Mju¬ÒÞI{àKåøè­$>€{`¬8°®D^J[ÍXQ˨TÍxàq`×Ü5W=n‹êNþ;ÞHÅwµ{€jk=núܭꖍϽã¶úq?{Ð93
ŠA9o?ŒBœ`RÅ™iN@í°¶ßäâ#ÉîÊí;bÊ…)*áyÄÒ=J¢X¡¡‘eNšIãk÷¹¾*Kª™rbx²ÖÆøÙ´LÏ,3D7ºa+-}Ü52
“kÊí¼jªk©Ýzúr±wMH­¢Z“-ÎÊðFz¤j**,ª{
|­÷ïsvjdajÔZŠ\x1+Ófª1€OïüŽEi‰­‹CøH‡g&t86¶^–>ÅµÂãD­Õ-­Ãœ’íìßœÒC-BìñËkí{´S…Øq{i÷Jí,ðõ—§ý7«­û*`½¥}£/1u
o’:‡+++/ˆú
ºl8‚š•ï«ï~ŒD5Æù3PëE¤>?¾b¿­V¶J=I<i‘ç煍ËkpÕ9E…˜›’DkÖBŒƒø“a-­{„ùb³ç~H¥®âñ"¦Êx¬¿q–šñ±Z¢àèO?Õx€§8OkÂ0¡&KÚ­ŒmqJ­÷ð
ºH2
> ¦xd-ë~|0²+îŒGÃô9ÿ1=niAS
«ª(rSVI5ªWÔJ4kŐ=nJáÌ6¯°÷:—®ìÁ”Fͧ:žŒQ–vÊ\ÞšÌæÓÏ›¨4ÍûêۋDz¾ýÇÍEò›kØA6#Nrd¾H)*°`’R+ëofÎ<ž
> fú=n—÷ª‡ù¼5ÊÃÊ‚˜¾ÒŠÊ>1cÖ@*c¼­1=MŒ˜·áÉ2Z
T£fÊZ¦t6öxº¸¹|­pì1=nD°=nA7kŠþ@7kJJßJJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n
=n=n=n=n=n=n=n=n?Äû˜šHÒ]b°Éí•É)*:¬iN&Û¹³jB=}œcùgt7„=@Ú}j-Ì3X2Tˆ,6Rkä,,,,,,,,,,,,,,,,,,8Œ\td®EÚ­ñòf—º7FR$ÊõÚÎ8ÆÞ#ªi=I_{
RË1`G#O[ãÄõŸ"Ô¸Õ{zßKíž0obHO+$ÄÌ£J´xƒEKIÂH´ÍÎ{Ñ’w’l´X[‘½/Jÿ«0×2^2båx\„¸4Í0-^+ÿÚ`0'$Jëlk•Èø-¼7%ó5R=}ƒÄcʹ9’šÒÕJ
> åCn‚ëÊ:¢"‚×'=Mø‘G?qÛ®X»êÚ’af>˜·ä=I³kõ´ÆZç0Ñ
?H–¼*#/Ÿ2UÂë5º¹ak<†se¾Cr=MÚkÇ82O×Ýw=n¾Ea7Mâ0$Êÿâkf%º’f—¨Ò^7-Š´zÊJJ
> Jí4´#ÅkÜ6ѾqCM÷„JrLaä&ÍÔ7“¹6*ûÄ’kû*dŒ
ûèæú¡=J6¨XDž44›,`À­ÔUX÷íCÎÎDšk·0þ¬÷‹ Ñõó/[¹°V]®Ê@â?k=M=J¸†r˜Þo5?H®=M8Eßê¹Ì­ÓÄ
¶o’:‡++++1hP\ƒÂDM…kñFùY•y(ÊÚ™´ÒÂí[µˆYÔ5‹¾w3Â/?˜ø³·íà^jeúD“kØMBòkEå¯{¶¢£[8ùcÐ’­ÎÀjú0ÆDëñ!ouD™e&ãLRY<=Mѹ(=IìUsŽLâ
+ky³Å>†ú=Jð-|?lbÃ=nƒ¦Í¨ŽkŒÛ†x“GlæÊ–cJÀƒÚúšû=ne=}C>†ü­XaD=@øòdK¹æ§ƒËÓÿ0tL¹ïˆ;ÊéÄ´ŽÃòrÜ?q˜A2Ž¿Ëðµ·•ä9oÏ²’bH*Jú\CHp
ŒV=I5kþ•ύ„–=}Ùë?Óh`«~@k8K×N/Êí…Óù,ØçŸ'¿oOîvÀðm„8ŽÒÖåÌ™››—0ײ82XB¬ÒVD¬ëÒN=n@+=nü,3jjjjjjjjjjjjjjjjjjjjjjjjjjjkqòð9E­§t
> 6(üGÎv$ÿ=n;Á:)*]Bû/۶EšYf—0̪ËjJ¬=J:?ü+ï/eìUsj
a¬ì0%nã/=@Þ}jH²Vªªªªªªªªªªªªªªªªªª­Fmž9Hô3¶ÊùÞK¹—”0Š­%h{¯0ã^­žd
T¹¨V†\ѽÞ{…JŠÜ2aÅg?q‡ÒÓ/=nÉ=}rfz{¹Kðæ9Z­f}Wç=MjOåFzp<y$œ=M™O{ó7âÁG–ÒØÐ®DÞJâkÈTZ"rf:œŠs<»º^^¢²EÔ¸ÆjÐ,ûp!2[cˆGÅR=I²kö¥
s›²º31x8s‰UµÎöá’ÙeDe“ʽò˜~GbXö£+"­À'ªŸkªD¶C„cJñ;Z³¿ˆMÚ?H[ºõ²6é8«I=Iøˆ¦×#¾FÂóöÜ?rcæxûªâk†wâ«kÝZá›ÂkÊ*4*+ûot/ÊÅk@
¬5¬Ò˾ˆ/¥¡#®@^k6×;Þ;ëo•Å`¶J¾FÂíoÛ­ŸÓ?>¼Y6Zåvñ]&Êëùb¶‡Þ:0·-¼9o»§=ML=nº)*~G¼fqCdœ4Uõ·¸ðÕ|úŸkoB·Ë×ÔÍpacÝÚ{{µïq®®çúkïV
> ÂuϾ¢pí¼Ò=}½Hì3ÌŸ$JøQ]ÂÏ?ÐBMËK1mzƒ++++0D¯«Ñ>H¦êé0yáCé¡
¿oZÝ1‡·uÓó/XŽ×šúÅ“!kÆ<õhR%ñ7_­Õ9­*±ó¢d‰=nGy¥˜$'z-‚¥•cúž
> :oCóöu„8æÕ¼´Þ½_­Už$|9[Ñ
j‡JQ°Á'ÔX„bµ°#Æ`™kÿ1·¹ñdýž¦×纚㺓=nJ¶øH«n97û0Û]SÜpŒ^:“=Ii5‹¸þ­S5Î/îÁ=}çÊ=@0Ü`ùÄ8&ESÑd
> *\^O1n[Á@Þ‚ûÇî&ºŸÜ*=@ÃF8Ñ]™ldJ‹†¥I±ª¤4iÔ8ýMM“¦Ø7Oos¸Qrƒ)*ã=IÜ6¨ q,!¼x¿ë~
Þ«CW*“„k²Œ´â”50ʺ:‚=n@+=nª¬“+=nÊJJJJJJJJJJJJJJJJJ
JJJJJJJJJ͸[=M¢HÏ0‰“Y&BÆ(Ñj¬eænÈ£m1P9ÿ/¯³Äö£å~D2Jæ=nCÃoúþ2I¢ÅmÃRQäQökîð%`£Çz‡++++++++++++++++++++++=n:F2e>F¼ü„¡0ºž7l9Â
> bhùµŸ7-Ýaû~¡n=@óBMzl´ÿ°‚é7éUß2W=}ë¦çab9 ¿q†xöëç·_{Þ<7½õû+±Z*’·kzmGÂ:
Lº‹b–B“B÷]IÓn:Ê;…ÞJþJâkN,2e>Bn\Aa²eʺf>kú=JÔ`/o‘
> PHCr\nñ;î®<‚ÿ¨M+»q?ÀÞ^ÈfzsaúJι•B†w,ôÒ[<d£†™W·1J­Æ¢Š¦ªÆùý˜26©Ÿ±V™Å™¤8
êûÕæo0¾0ëol,,2jÞ;šÿ~{0ãkµµÇèòU¿,ßkû=n›òTžR^áê&Ù
ZÇ47ëJ^­RëÅ<s@0ÑÔ2ïõvYçrôiž>ê]P£x«­yˆ2gvE\qÂ~XhŒ!0aÏJb°:•î©àÒÌr’ÊþÀïC›^=@µRh‰G³¨i?mõž*Ôg@Zk2˜1`P"Ƙó=J­=@¶kE??B`
> ø÷RG,ÍÛÔ5JJJJJÕǯæì9e>¥ØåìFWI_{ìha˜Ê’”­ÔŒN¯ÿ
T'“0ÂðÀ÷Œø‹ÙÒ/1•Em¡G¬U]ÀYæ§Á–i®p„òG¾§d8Ò[ïðÀqít=J­6`H–ur2A‘„kÿU=MíÛûð
Ê9潺´›b­´š¦[]±^pg÷=n!vÔ×cLÇå=n®o=n˜@]„6ÈЗ–Ê󛩲n=}ÉWßÑj¬Ùį7¤¾Hò¶Ý+®°ò\Fø(%ú¤‚
ÃF=@I’N“Ê0çÍR·ª7!IÌ6Z¹Ê޽ýn>–o
ñ]³›~€÷¸º†:ñ¸ÈO{ãÖ·,ãÊ0ÒÓÎ<,3+/ªk^¬z::::::::::::::::::::::::::#͹ød›kx'IŸ=}¹’:qŸ^ɳX{ó¬è’WHDR6Aöz•ŠJÍÎ-´2ø£„z\f#²-Ì3;a·É
~A*+j*dJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nBv\òGêz’ì­÷ò]nó°c‡©é^F‡ÁWÚîy³±?qÐ*TUc=M>Iõ©o{’ó¯ÎZ4=@ç~€xžDb
˜ýä7]*jçxë=nâª3ŸzDò]Ÿé;Ž*úb%tÍ6‹CÂë¥Ѻ(~?ÍDJÒX:†JÜ8£øƒ„穨ÒWØ•ü²?+Å|øD:¬EÛ=I/?`=MÚÙ~;?ãܬٻ×Y¼Ò=@Ã2é-YzœZ;®²i˜«0Ãs6
’úa|­Èz>~„2Þ;ÂGßk@=MÝ•þÔ¯bªok•q5g{>akÃi#kD¾;¿,ÞkІü2d®GÛvömeã1µ¬0’׸Ü0Êk’j–e"È­Á<0·Â:
[Ã>_Õæx!)*I~GýçÚí‡Ux4Uµ-;ñ
7:¥·ÊYŠ?A³äe¿1Åâæ¶:ZŸœÍµÝZ$CÆg;G©³KF,8†…í³•Ÿô©žHÈCË‹ÌÖù8ZxI=IÌÍÛÔ5JJJJJJñìíb9ZþJš"Æ·Y¥+ú_²eT·Œ»ÜsR“=nbˆÅ>EŠŽ6¼€+˜
|*Î
> GÄn]d=IUàIÌ6OÌ=I­¤JÛBì)*ã²¥ðò`ë
“§s_«â}%JîxBý>^úû¡Yo¢¢ã=I²gdnýñu?qb°­zs?b8²@•q;¬—êdŸkl–báô¡k«¢ŠKшQ³kµÎQnCÁ<¬q
> øð¨‘*­Û·óN*wM­åÝ–ž®˜’H«oœ
½öºðÁÔY°—‹c¼E°ÒÕ°ÊôzeêU±Ôdm-m’šowRN=n@+=nü,3jjjjjjjjjjjjjjjjjjjjjjjjkŸi]¯¬°ƒI"{IÄ2Gö¹&
swœ²XòŒ¹ôê9hRV†,4Ãq*yÌ2%íê9|¬¥åbÉw:‚[×=n@jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjksEÇ®›=J­bÇ‹/²y-=Meb|9Â/"¦€—µžš?H|1ZdLþ€±—ÖJëªÚäa#
¢Ô²òIO¸™]{„Ý<„nœ­Éj2=M%JõŽA{MŽBŒPCåâü·žh{öÈ+~ŒŒSÿ—>“0DR×Ĭ=n,ô8“—Šd®FVï!âÐ`}­û²œÇ?oN’¢®D‚k/íÄ6Æhí^­ù¿îöŒª^X
> i~H•é[,Pê¡åkýV·–Î8*+$':|ƒ5š©<¨rc…K
èRV†¢,zof-û?c1Gy~nÒÌ2P¬Í\œ¬=MäMGyç=nü2jÎ4jjk=}M*£èAr_›78f/úk¸I8ŽÇØ©ÀÝiû1I›Pq¤ÊõCQ¥R·Ñ
§>Ñ«ªo2_Õ±ó{€mqçkÓK·NÄ*ƒkc›=Iî¨4ÍüJqBz{Ëç³k½¸˜0sf¸æ/Ê-°šû1nÀN³-¯%'~…zƒ+++++=nJÛºäF›ŠH3fj?BІ…³WØ©=nHÀDk>ü’3
> V—¥µºˆs=n‹ù»î=}–§¬81膕­L˜€‰7:¤‚xù¹9oêcí{ûo…?³Õ¸a{ Ç#z¦
aHü=}s;ßã?CáA/€Œgl5¶nXp%kšåô=J§4´@­ë1f¸Q?…á?FùÆæ=@ª7¬6†RU€¬”Þk
{=}¶éRQ­0AuE)*W·dJJЏ@Z4Я?=MrGPP=@ôW~¤7’*€>€ªJÚ2Zî^!¶ajº?q‹ERÏJÄjkR22222222222222K=nÊJJJJJJJ÷ýðýoêÈm|¬ÐsG‡¤›Î8i¥S
M½ž2V=M¹ôú:s»Í´2ö=MÝyç-M¹Ãÿ¬¥àA¬J¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nFCOf¸Ë0÷`:¢ÇÛ*¹>NÙ5ð
èæz‘@­CM안fº¤ÖM}ÑÔ6‘µê8››ÿÊÔZIJƒ‹÷Jiѭ̃KZ½‹=@iàÌÛ]t*–¯ûñ¤r=J]+$¤Ô³8/ã*W—Ç¡¹é%k]÷ÒØÀR^2X:››k·ÎHnÜ䁃RLQ!œ[=MJÊ
1‰®©žG=n-ÙH”ÌS=IÂIz«¾GóM¼6[½!{ªö=MmÌ9QA´W“¬a…Æ—üGúx<[>p}î“úJX\f=I=}Ëkã¶xöÃ=I®J¦\ðœã豬3/Ä¥r1É>E11`ðÒLì´Åk2T=M¿p|ÅJœk~7ú
t5\aæýD†¤=nEa-e°×-þʽ7ªh¯0\‹Ð¹öì1{Ì8¦WP±±™~?§ãö¶ˆÑ}reŒ‹/i¡¶Íý%k¾x;†ÝGg:+3Ȧñ¹hrgð¹LÙ:å¡g¾F'ÕYŸ¬ŸDXÊehF¶\å¡”Ôa@#s=J:„
BxPŠf7d‰<­–¥Zø¸b™|­ÉÜI3FkkZâ‡ö•ÿožáz:‡++++++1ŹºúOáxË…%Tfêìö‚NI›nžè€ñ²÷ñPÈà«F\=MŽá™Ñ=nHæ:à@}pæt´ñ?³õ›ðhýéT9ÇFŸÝå´
> Ôf¼w
¬YÔ3ܫŭp÷M¦Ùš!ʱrä–k|zj2V/Êÿ·7@t8ôэ=Mç+ÛRh°½8jÚ‡×ÿ1·^»êRÙU>ã¸âÔÍÕ9¯±ÊkÚ4TŸ
qç=nxC¾1=}Œ4Қ̲O+++++++++++++
++++++++=n=}lô6‰µ¯ÐÄë’UÉ;Q¼[B=MÔ3%c¡ôJÿ׎ì*kG#kh²HašÎ+HèQ<¬Ê–*kR22222222222222222h©'¡;ìRè©ä3)*‡î©ßI÷-'¡;(þ©^9o(>Ÿj
> )*ˆÉ'Â(’Iâ¸[qj)*ˆÉ'Â(’Iý)*ÝI÷-'¡;©¯G¥úi›?"{=Iç-' ©
#Ê©Øi¹«(å²)*iÄ1$M'Â(’IÝ)*ÝI÷-'¡;(þ©^9q%{¦úi›Iñj)*‡î©ßI÷-'¡;(ö
> ©^9q%{&úv§ÛNüÛ¼ððÞÇïÊ Ÿ®B ¾G(;ÿ‘²JL
sÄj=Iê©yû~¤{æ[­U]7VÊ,´0bcR,êÍáÑ!û1fÍS‚f9·ÕÓ?;>¶õ*àÜâ’ýúJàJ›•Ö?·yUý'O[Að7:
=MjfèR¸ñ·Ï?üÿ/ì4ŒOÌO1µP¦nηº‰ŽZ½’c†\¼9=nHöVLPÞú-Ô_¸†È3788TU¥û0}Œ²”—*?H–ÙH#ÉÊ™~H–w]s¤÷-òJÃ=Mã_=nú1ºkñÁUÕ­ã
DýªÕR
> UÀ‚÷b1\è2T-­˜ZFýåGÜ6F‹çjðV
ñû/—Ù@:{÷زL0é:¬-ßþJÍ·âÊØN,r*ƒf,9m9ª*1wÓ&Ë1•„DSÊ+òRÓjk°[#‹õ#´Òh0ßåÇ')*"Êà,h!>žç”#Jc\ÚpׯJÈ
ør…ê|´edX9ÅŒ0Å84ÍÚ´{ñn€÷>ú>H‰”È%;F*7¿{ƒ8€’!JqCÅE¡çz¡Œ;¬-¸ØMª{ˆ8eC=I=@É=nx-?{¾­q­üÌ„j´{í(5d4kÜ,,,,,,8ñ[&uŽÚ
> ­ôÇßeª^„w¤Ô`°;³ïZ;j_îÉ¢kqE˜€44UÅAµ6/¶Ÿb£Ç#z¦
aGǤaþÔ¸<:z´FñTjòñ—ÑÌ4@cÍ«klq>:8ä=n<457¢Êâ’ý³k‹wÿ=nˆ‘•kýªÅP`Q=@æ¦:§À‚w’ˆ
oo˜v›­µKî1çïæU¬ÒF]Œ*,iòÒת-ЬH„ú†=Mk1X]æ[AµŠ@*—~žêNW¢Wo’ªªªªªªªªªªªªªªªªªª­S‘´;œr=@$¾F¼
Þ7û·ùÏJÂðw•‰òëÃò_÷´½pÛÛaŷɬ
1D‘»Ènú"=nDAm-§°9¬8ƒå…7H«ïñ&l8C¥—'j8˜RRe”‹)*ÍCÞ@)*‡É'Â(’1á›FLµ«(å²é빫(å²)*iÄ1$M'Â(’Iâ¹
#Ê©Øù(ö©^9q%[&úi›Iñj)*‡
î©ßI÷-'¡;(ö©^9q%[&úi‘)*iÄ1$Lé4iÄ1$M'Ò(’IÝ)*ÝI÷-'¡;(ö©^9o¨>©i-'¡;(ö©^9)*¹«(çi%[&úiÑ)*iÄ9eT0~6ÒCz\ʏjô«¿-T0~6ÒCz\Ê
> jô«¿-T0~6ÒCz\ʏkGÉi¥-shKËk_2h™G±›\n+ô…$¨ôµj
`I’%%ÌdÅ]i2XÚ_8ôTï»Ø³=J[­„D¥¹Ôc=n¸a°—z^ñ½w™Ñù~>´©1›EF#y+ã'º¤BˆùZ½Vècøé
=InA±‡~mz†J=J35Î;µkØA2R‚­ÛaK*ško1£¹ÌfWIœÒÝ!–ø„’çîŸ%û0i˜ŠÃR/íµz‘P\@Þÿ`#(òc¥]î7G¡!Jàgìb…5xѤk[qâ8V’™æ©çz@/Àaj=@t6
> R‘äQ}ŽJ´¡^}¸šbz™E›äñJzs*‹‡kk^”ÞM»2cìp„59wl8‘Ü‚æìùžC½Ì*ŒúŒ8Þ¬
JZâ{FƒÙ2škÒ/±ö•Òkša#JÚššÚ~~Ê=MïFýª¦Ö@yO{ösÌFº¤§Ç9žö
ƒ•”$Êðfi>q0JØ<]^À¡›"=nHþ—,äJâCÏ-ºß?Û^VÊ‘ÃñEŽQ}ÏT·Â5Ď¥œ1žG‚n;!¼9?¦,´=M†s±8æ¼–?qǧÉNØ8Ü*hQk¬+â³…?=Mš$©RgPäÔþ€Ûÿ:/*z’ª
> ªªªªª­b¯dxØk
°‚QYV1æ—-)*4ÌÇÂ=J›·*·B”8ö˜Vn5B=J9Þõ&ÒÙÄ6©Ü÷ãHgtÒíÅ[d¾G;éZkŒ;~¡®ˆîL\¦Ï7,4°k—:qÌ3Í€a27§I@Ë/=MdJ¬u³ô^kÐF½
‡ák:Œî¢Ýˆf‰û1ÒR´Ü´Õfv0=MrSVìf™HÅÊgÒñiV–ú/‹ïCQW¼jUz•yo{àc½ó*;€ÄÇ~}=n&®ð¢c©—~
RÓk2O=n„3jjjjk2222O+0|L®†¼_èÏ1ɳòÛ=}5ù]
> Êk쉓x‚ĸÈ;%¿pâ¨ðÇñhL‡£œz¤:
ž:9Cø‘nD!¦eœ]RDÄŠ'º‹Q’:8€¦t9`˜üîrweR­»¥÷çïÏ/\ʏjô«¿-T0~6ÒCz\ʏjô«¿-T0~6ÒCz\ʏjô«¿-T0~6ÒCz\Êý
T0~6ÒCz\ʏjô«¿-T0~6ÒQT0~6ÒCz\ʏjô«¿-T0~6Òd%`ˆ–®Ô9Ÿ°ì9iàÊù5˜^•¼9T1°ww¢ä¢)*¤T¸#Âv1:ë™DhâŸ4U½]„5ƒÏ“Ÿ¤Ÿi=Iû~rí÷µL`+¾”+Í!kàDX
=J<ê¨þíÑó1‰¶œªpªÈ-Â$ÒÓ®’:ž_/¬9_­è<xë1Ø=@°´2Nzš``ðó¡G?qÇhX=IVª’Lâ»em¤ˆ¸‰î¾ÄkŠŒ;Úôªû0Vg(a]¹¯ÈLzžnuÈ7Þ§$':‡MãÅ
éç/=JÀPAàÅJdÇŸ2[ÄJf›bâœÊøCœ+WAë1›–šHdgzsï[àvªÉÔ7ÃUHWØ1û/¸4^kkõ²íñ˘Ä­0™R?ë=nu¯¦Z@bº¬ú‡N0‰ª­á5ZW6e·:žÒÔ@-ÒúÊË/Ød·¿@
> •CÞRbÏ¢šeù± »:=@1òðGØô9ƒÉŸ*a(¤J÷èt&ï1
CãƒÄ[ôýú©¨rgpˆzx/Ëÿø¡\ÌÍBFD“ñj­öÖ¸=n¼ÔeìÛ¼X×’g>?º”sиRfñøˆ%–Júf‡û~¤cÃ
=}\Ú0ßͰë1Á°š%†¯ä,É…/1ʏVg~uwâ¸^­n=n=n=n=n=n=nCñÍÎ)*Á­ÅÞ…›1¨|i™ÿ;mKíô7̦Øà~£"¡*Ÿ=Ji|­ôµ³NRK=n¬pòWÇ=IÂ&zkNzr?Ókd¾=}rN
> aË2^Š0ú{ku׺“=}°„­Ú^…¹²­Üac¶•ŒÔ#>Iw±ÉbŠQöAö˜Ìâ[ÃÂÁ*!ŽL?Cn…VX¬
ÿ=}ä8“ª=n@’8ßó0ŠûNÒØ(ù¼¤__8+ë?GÏÝçËDHý‹öa¨Ê=@avB6Ê`ã
> ¾€¬G-º‚ÄkR2DJ‡ÊJJJJJJÖ¼Ü[™¢’zŠ›)*«=}Èi[úJ¼súr©¶L±)*M$Jò
~½E¿ì`È7þ&t8Âåi3°A¾‚DF†V?B÷)*;Ì6É´¿z=@9³kµ«¡Çø¡Ó??d44UÅ:“Fúœj
ô«¿-T0~6ÒCz\ʏjô«¿-T0~6ÒMT0~6ÒCz\ʏjô«¿-T0~6ÒCz\ÊçJ|/J|/J|/J|/J|0~4jÎ4k^«r>«r>«r>«¿*…rMš­ìôN·Ø­Ìp3ŒGݯ>I[V˜°qZ¹>˜Ûì#Ô¹uÝÐ/ëä~
> ¬)*¯?=} ŸyJn=M‘w™¼8àߢæc„ûà°
#Êïe88²½·›F³ÔcºCú1_Êý§grà{…®@h}­øëΟ›k^3eJe€˜4B8Øi/{æ‚0­~<TJÙ=n=}°¹æ¢×´9
> y>>L`zÅÁ3Mø°lDg)*ü¬‡P‚Ž¢ñR2S¾\dE»‘%'1>Âq3F"I¿Àã=n﹦1PKçl8µ°
áFižBu3²¶ÞGë/Í¿ÛÅV8Gz˜vYM]-2(­ÍZú­Ãѹ­c+Ëëîµ0œ*jPé
~E\pú^šÿ1~yÃÖÒcѮ܆ûæ“1GÃà¬ôT:Z;ðš×¿q*cÚ¦J’:Ÿ=J§=M!ä’()*¡kûµ½N9’Õ*^JSä£Ç2g6]FPŠå}¨+1Î̝›­ù~F'ÍK’-ÍŠ?FÂ`“2“ü
> ­ü»(ò=I³4UÇ÷<õº#DWÔ·ÙíwÐÚ›{ˆ \]6JÇ ?C2¶bÑ_A^Z½ù‰1ˆVªe½¬´íæÃ5r
kß{üÌÏ+++++0{(NéIn>ðahDkû1ö ®Ï»’ éo{=MbÁb¼–¾:ªª¬zrkK/ís=I
nA>ëÔ2÷ŧº”ü-±]ó/ܱý¬8‘ZÎA•m0äJÆíZf:¤Â\G5Íf`kг6·Ê¶ês";ké’5¶f–žèq±Ìæ^¬SÒ¹5°|ÔY³µî†31ÉK¥‰Ñ=nECµDÑ´Šïgâš*ÚÊ=Jî=IMõb
¤’ÒòŒ‰?È1´8öQ’c=JA’c=}ä­ü°€ºWì$JEÔÿ=nʵj!JÅk1›’T#¶…Dd¾BF˜‚¢ÉS~hROÛÏ=@ƒEE©Ua"ÊåZÛZõ˜&øþÊÃ6wAUïœQy¬8£et@“BXúJòÐÁz=Jð)*¸Ï/
\`›ŸkŽ<¬Ï/Fzœu¡Ì4jô«¿-T0~6ÒCz\ʏjô«¿-T0~6ÒCz\ʏjô«¿-T0~6ÒCz\ʏjô«¿=nü/J|/J|/J|/J|/J|3Î4jÎ4jÎ4jÎ4jÎ4jÎ4k£‹:¤ö`:¢'ß9¡][
J‚hA¤)*1P?aÀ¬+1]§?HÀMGIš-fyš)*ÊސY?ZÉÃ×üÞû~¡šÙ…ÂÞ+ìêIND÷­;ãÝðpø-¸´7Í?ÚkXeû1ñ_Møå­ü¸w,5çb>H9’éhNûÚgÍù»áKQ”û0gÝr
g¶=nKÍa*:²©¢å±&J=@ŠM´BàW˜Ù=}Ñkø¦™³Å^…ƤJù<hAÅMc"=nF×Ä’±·ÏíÃ0#î^­x1šl8¡‹‡;ù°½W•À)*Þ¬ƒµ‰¼›¿ñwp¯0õw@´1»Þ<3²«M-㥺”=@º
ƒV›¸éô6PÁeß‹•"®GB–^¼ñ¡Šʽr_8š¡¡M“÷=Jh¯0ËÇOÀb‡§z’쎓ŽÊ-¤”¬»½>¾×¹ˆÒd¾{1A’òƒB’=MÔÒ‹Kä”
kñÀRÌ“çrÔ(ÎBHxˆèYó0;i'„hÒg771
> |ûé|­?B!wkñN¢¸à`F?F"l„µ’‘‡ú
÷Pp…•[üô4ŠŽÀñäÈ3ÚnÊñCµ]eãª7<:ž‹š=M6øÍ[DFº›³BHgÚ9ç0"š˜Ø‹o™±è®·\ª?qŒ´¾=n=n=n=n=n>’C=I
> …Ò<5—J#Xþ?°)*h´Íô;Áàñ^?5uw;o:jkK/ªkÍ…„ÇúwGzo¬
RN“Ðá¬=J´ä"Jûä=n:ðýû/N“=n':‘o1˜;×0Ê|92%’=n 9~HÆ|`¢>¿Ž}±hËo£‚ÒG>εö©cÔ·‚
> ¥òµ™—oÊïÚ±Iu2bë›cã–­×½0,Ÿkû¬®ò
ÑÒkØTU˜z£¯?»Y¦2>`ÔgFVö¸Ýi[>Ó8JⓃzŸ±‚çº``­aùEVç­IßÃfb¢Æ(å=n;ÏôMFÄV&z“H40Fø˜¡£ÞDè’ÌH
Q0®FñHéN6Y¡êJÆÂ³©<zëó­k΢’‚öö=M{vp8S–=@”­·“‹þ6íÅ©Ž0rF­n=n?R[»þ:Œ‚pÒLºS,ºS,ºS,ºS,ºS,ºS,ºS,º\ʏjô«¿-T/J|/J|/J|/J|/J|/J|/J
|/J|/J|/J|/J|/J|3Î4jÎ4jÎ4kVO¸8E¬­¬j,bÊàX+²íhhN’£>IeEˆå•Å‹~‡oV^­ûëùÉ–Ë;ó1~ø›í⫆U­P–­ÊiÇ­ô¸ëN»¡ÏÊ޾cJÿÜ¢ŽŸú-Ÿq³[/ð¯5²
›á>D8×aRgcr±6EöJ¯Ïnûãc´3ñbÆ~¸1ìý¾•õnCA}ާ”•zh¸’^Dëkø!$9õû/Dü‡Åô1>D1gªAÞÿ=J­‘0õC8+=M¸Ä&:‘EI8Úbgƍ
é=nG»tóÄ„õ9=ME)*ä$ÒÔ
å8]‘¸ð‡ðô̽CG=}«CòE=@×(:mˆ+ùcjûͬ41c÷8XX-ŠxòeÐvúñĨêÈR`*ð¦qx2^7zMPÜÇñû/þ»\CPW1ìýtÌšÈQ]ϼ­úÇã=I=}ƒËP¹kßÊïÎ¥â–ièAìð¨ý=}
•±êÉ1ã~ªÌÝÑî„÷dúJñ<øLurJT¸–U®­ã;¶ê"Ü8¬eÇ;û«Ìì6íäÆ=@Àº¦†1Ô7Š«ºâdâAêj½<ˆs“K၀s1XOسö•ÅÁ]sË¡RdPŠ3)*:~€
€ìx°êG?q
> Œ´JJJJJJ÷É·JkY1ô
á'ݤâ¨ÔÍõ¹`}é/?¡šÌüqÌ6‰=}ÄV-ˆ´´*²â>¬=J=Iž=}nd=nA7Fº…Y^:jÊ:o¶þ_Ø2Xf…–ckÍ*äh:$=Mä4}³J“­‚s³ÞHÂJ_Ù‹ú­
Ò;J‹˜®”475®×ô–G2J¼AñÕ^çñ-=J­3Ž•Ë6¢Kf£¤ÊùF؝…—R^³±ªq÷1Ó°ï@a€É¬´Ã[<æ}LdO1[ë8Ѻ=@4Íà8÷–jAòû~…NíêV¢ùj¬=I”Ã$qGŸRNk²ÁNJ
> œDJÿÂbÅÓC¹\­qs>Wb^J½ÞÅ£‹ÈzŽ[|#ÆMFÅä6¶M|–ȏ0Y®­Ãà2®G:
­Ãvî,qIÔ9pcEMmÂ=JÈK/ºl6¬c_Ÿak³íhiK9™Q˜¬GCײf´Òìm¾¢Þ{†ïÉÂ%±O{Šz5
£RÒÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4k>«r>«r>«r>«r>«r>¬“,ºS,ºS,ºS,ºS,ºS,ºS14tIz¬›â&Êï3‘eÁÌ9[++=nÛ·ë÷Q§j­ü<3‹OÏxå5ݎE_
,yì¡Ì9eW]‡z~<ú_Þ=}UÝÈyà¼ÒIj<7Êê5RgFFƒÆ3=M'$JàW'ªÄ2Y=IóUඈçiË13£ÝŽJÝÕe10µ't81óüså:„b†$NEd«$ʹ8=@û¡²·ã=nD=@¾Ìܞ7DÚ
íó~¿ÙÜ_Mµ¡H:mªö”p·²J±>S¸£è0¯?‘ÜïdÙ«ç9'kì],-´ÒBF+,³=@"J©‘Þƒ“WkÅf7ô$ž¦!kû®îßÞ½úÈRdˆþI:=nr=MÌ94ƒd½ñ­Ù-/îž­Ý
2euÎé5BrõzºÇ¶=JÞG‡É™ñ_øÕ=InHÛI~{jkÈJ°ð†x­±_{í;jŽ•†=}Ù}’d±““ššN©žC,"Ûtô™Ô3ïöðÚ-ØU}Ñ­Ð2m”q{§z×Äc=nFçÏŒ¢žå=n¦ì2™µÝé
>  R×›„‹ÄÝFT¸âH‰:¯=}
c”ÌÞjjjjjk½iD‡£JÞÈ|­¥„èò÷_÷‰?{jê=J~?¶ÖdÝÿ0|sÅì*+{j²ú`¸å':rËï/];Ùã0þ1=n;†xSMÒª:~6å?:†¢o–¬Þ€$J=@­Ò«Ì
+Ëó*5kÞœcÌßõž­ÌCÜ’y®&º¤[r/:9!ž=}XBtù-òf_k÷FÚš8äʰ[®WÌŸd¬‰¬Ž®ûF¾€MEVx6Bœ·3Ï{j›9ªä’%º£¢è²Ö®ÑŒ
=JD•²ÉÞŠã»ýn<ü«±í°ýÕ
> ºmå}Î[[é^CåAµº¢š)*¸Én>C­Ý ‹ÒN¬]î¼¢ÈRej¡˜Øž­Ê¯?|þCãÀ­Aî9=nC_Üj&bÞ'z
kJý›7ô©Z1•†ÞcØ81²RVª¬k×8òUPHS…x’ÎF] “Dîc?qM¼M=M“
2ªRV̾«r>«r>«r>«r>«r>«r>«r>«r>«r>«r>«r>«r>¬Þ«r>«r>«r>«r>«r>«r>¬“,ºS,ºS,ºS,ºS,ºS/GK“ÐDfúŽªª¬::ˆS‡=}¸z2
)*ä9{²_”=né®zœãé ýû1^ªª kÈ
> W#š
ÝÂÔ¹hm{r=M=I=}×|ÒZ=Må³ø&×$)*l8j—ùº$=nGÂpG#é=}%|9gê­DÇl6ϨrΚ`y±%kÈE9¢Ç=I{ãkD*ÊÌÏ/NÃÛ·xÒbÎLJ‚”7šÚCN+à*ʽ63X
> ¶Ÿ?¸T͸¦ZN31 8H}%JöCÚ …È]âk°ÀAps’_þJÝGž’g¦eìýðÒÊÝF2J{HTU¯b‚=nîx͵?q–y•\ä
­F•ðç5'éç:¢ðò>aRg7L¬°Ê%ùÊ ŽóÎh­ú©N
Ê¬FÜÈ-RRd¥hjóë£E«¨Òg±´Ÿol¬F=JûŽÔ¸V}öÐbĦ­«•ÈÀ,™}ž­f_܃KæÊ=}~z”˜LZ!^=}êÙ~?±0ò9XY©\­â’So£'Ôf¢¡•͸Ô˯A®ô¤¹Ä´=I<üZÜ+çT·=J
&2é2ÿo’ªªªªª­P©u:vèm­¥‚)*üáÍÕÔf«ã{qDkzÔ^Š¬Aín1€r_ŠËÒ̬ìó†úmÉв]’X››e–¬]ƒýï/úŸ›ÞAÚ`ÊhÒK¹üãJú7—0úl––=Mã:¡õ6¡Z¢…ã&
Ê¾d1šý«­þílñ‹É|0å=}ó0·¾ÛïØC‡Œ­ˆØ—b4$Ê÷î/àUçíwJ=M%5†j1L3kq=JE5!ô\ˆÞ_kµðÜ2eÒ„sMqœû1¾M›@D“=n!wH‘^JÞ›[ÂüúJJ·è\1"á|¬Ã
> ô-1öÊÀ—ý¬+’eÊ'Kš=JF´Ï=n|4ÀÊÓ”4@„62f:CNX÷=}õyxRdLAás=MÛ#Å%J°¢ÐI
yXR_Î<ü¬òT_ÆW1N@G„Uû~›s=}Ìdb>:7ÒÕ|/J|/J|/J´jÎ4jÎ4jÎ
4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ?Î4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4k^«r>«r>­cIÁkä6:t,2jjjH‹Ôg’·ÛÑÂo˜ÿ/‘&Lªƒ›aû18R‹RcÛé²X·ô_ÔbF]:þEîü«ö&ºŸI½2Uly
­¿íV‹æ"Êœëêùö%"-‰j­ôïaVÑ”kpìJ/ÍZA%k÷MΓÆæUw:ßøö…‘Ì7mj±;kq¼ŸP'{„Æ=@·†žn¥:îÍ7™æ{„JÕà²å=J­Âì‚ýº‘iÌÍ;=}5F£‡Ëçën
> œñ—Â)*~H¸,wu9Gz Òҝm¯>H£Q-Xîð4Ì›Ø÷°P!þ¤–­ù³ã’é21Ž
„ô@ˆj#J![{²¥Oûáj=@ª­ô5šÛðj8ž®ÊÕ\Ax•wZ­=@­@UM³»Í-{:–/ý–=In:Køh=J3
kñßâáa*c=nHÕˆà~=nê]AÃä¢VÔ¸²ƒ¼@áºkÍ/Å{këÞbÌWØ/~/Ö˜™#ºÌäÐa±©ÊI_{¦CæNq&l´+++++0VÙÞu:„§L¡ËkØi{=M„Tå¾nª­€aÈë/Ö„šÎ
> 0ûú¦£JúºûrR3N”¬ùD0ÊÕØ­j^¬‚kÐ$˜¬’=n0ª3k ¬r*<xêJ ‚
˝¸ØLó{ƒßߎ–Rd‡®®‹È&{*HŽF¢£¥àýVÜ'{!‚Ð+ÄãbRcO°’‰ÀóçÕ´Ò볋›•³ÛëÒdÚ÷îŒß
=@JJÆnG£½Ç¢„­->6à£ÄkIŽÃñïUDd>Dñ«³Þ‡œHä=nEú•5‚-jF0«1E8#ãÊË=JcÊâ22dÚ9,qZ%lì8>Î4k>¬5z~ß/u:{ú­ë0Xíl¬öh¦=M½ßkûA“]“‚Hz
> ­ÜcÁž//út6‘²g±k¦ãÊΑ
$ë~‡ÎbŸEÒÓÎ4jÎ4jÎ4jÎ;r>«r>«r>«r>«r>«r>«r>«r>¬¾«r>«r>«r>«r>«rPºS,ºS,ºS,ºS,ºS,ºS/Ž¢™¹=nFî¼–¬:::::::¤Â
> ›_~ž_o;"ˆD»!mˆ2f&ˆëæúšïç)*L?qe¢¾Eqï9¤5x£Í‘’O/ž\`ïµé¡ º¤Âùä–7e_°'ë1„†
1µQ{Ô8ÀðêJ¶¸þ4k÷³íàyE0¸©¢ÊP¶ïOÇãÊÀrKì7ô9/°
> LCæ•ýÌUÏjP¯¾>›Ðœ6‘¨‚5ß0Þ?>¶+«*;Ò=IÔ8cð׿è¯/=M£­z¤ºôƒÂ™îœ{„JÂFv×-¡çôÒÐdö\
uj(%úšë7XLúÞHÈ;Ç`;ÁìêY$J [3üpw—‰N±²»ü
> dKBXdäÕÃn}@AÀGy=nHÐA9š±\Þç(ReK®[ÍZ/•?Øòb‚ ÿßÌ¿qEPžQqº•¸ø(z °à{Ž’•l­”ö’R×/*¬¸
Þ_?FÀ^Z±å]²dš+0GÀwb;ˆUM­Ñ=}ìv£{$Já‘ÅëáËM
Ìäº:::::ŒìhýQÍ©~=}³&3iz¦ñ•¨=nMÓTÍð¢ÿ=n*¬˜r`,&MŠª-mû=n^°‡úq³øèRXð@˜$ʇÅk*kJËÌ7*Î=}Šl2é:#Ê¥`6ø\»à·'þÑ[Òí0/ÄMìðOű¾›O1
>> J!±0ïÝBbÔ·Šíè–Ø¿çMòøO0¢¶^sZ!¶
Í«2VóÀfØ-mõz´æGÈó÷Â;Gf‹=J7¶+ôã{†‡’ÝÒ?oío3װѪ?>Ä€ì£þûï1=n±öŸ^mŽ*«®AkR*ÀâcвþJ
> à¢R×Ó=n|/J|2Î;r>¬5z?û6Ç2f:Œ&bªNîo¿ÿò­€
¶ð¤’¬=Mßqß5±ËÞB÷U/÷“*+?BßîE2a“ödÒÓÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4kÇJJJ|/J
ÄjÎ=n=n4jjjÎ4jÎ4jjjÎ=n=n,j=nǬ8qæçk~=n=n=n=n=n=n:­ûëdqLÔeDÌÕ²&Y¤7H”9œ9T¡­M1<=J­É<WÃãâ%?FÏ=nG¢
þM×ÉŸJ÷±]ÉQ]Ì7š÷³ŠI=}Ô8=@^
+ç\c15g¶¢JHXiº¡¬0»›â-ÑÜzœömSP¶˜þ;ùÔ8–¨Bt=J‚RfÌñn$Pð=@­åÝ=@¥!·æÍkRÌ4cëøL&MœÒ¼–
ÄfÍÉ~pbñ¢Ã:ÝÐÒO¹16BxîJò:s1ò)*2­`…† ®
Jíôø‹×’qZ­Ü£ñ›Ã°’:?·;À8^™~Cc=J‹ˆ!•ÆÄ2b=JI¢ê9>Hѐe`^È@h¯1×´¿¶«=Jâ,qíÔ9`CÚÞb+ÏÈi=nEè–•˜±=J,7îq=}ƒÄò1j¤´àŠ­cÎ’›eJİWÄ4e¯
÷¼p/àÊŠôQ|ÌÔs›Ðʵ̃?A%x­f†ƒš¸6Q`!îÊõ,öÂ{î¡MŸ{Ð^€0¤&ÔS˜÷¯)*ÿ1Œ,,,,,6ƒ)*YÍ©~6‰'æÉRh•ßi0G¢ÉÊ?Heñ³*a­šö×ýžD_¾ÒT™Š:~Z
„$Júa±JÖÆ×/•~:=M~,2’§:’úã@¬uÕl¬®<÷d–:§8>2=J¶0½w1o?ÝÈöc\ò]çÛÆyNC²Ĉ\r¦×H€$ÔdLë2¹§c<õͤ*²o[[CÚþ=IeŸG¤J¬qîðH_å¥ÿq–B
Ž>ìDx¾žkùC®w¥3>¢Jìn­M&=I~G›ÆäIœ´ç~Ãâ;t͵H`ŠÎFÏޝa:’,:u¯¸ÒOØ=J¡kž=n+Ь3=n›2dðãät]8‹1†qQ¿=JÌÞjÎ4k>«rPºoJÕĬ¯Ò]:ú
¬6ÞET´¬­peSÞE´Lì´ÄjÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4jÎ4k¼3jjÎ=n=n=n=n=n=n=n=n4jjjjjjkR2cÛ<ƒòb˜­>=n=n=n=n=n:ªª­Ù=n½YZÔgPÒÔŒ©5«´›˜BH²f
> €ifá4k“é=n©öÔ¶•¨²aÄxJ0Î9¤2·¾=@]­ÍÝÅ@÷æ:
ÍÄñð6÷šrï?íèJ„—£‡©Y¼MÖÚÛßà˜'ºmöŠc¸1å ħ§l6Â5p3Fq;êÊððCköâ–)*2d̝‰B
V=@¾€²Kô^@t8ƒ‡å™ÀÉo{öŽ9ïpøpó†:‘²ŸöŽ0úJ¬=JK•…ãÌ2³°z5Çm±Ô3¾Iaà÷':‡¹ÌH¸^<ÃO®**•ßkÿ[¤Z¾HÈœÝ­˜ºv^Š=}re˝ÚאmÄl™nHÈE9V
> ®ó³ÿñzù1‘›HvϬã|­9ÜdUZ⻈qG9ÒÝ6ajV’q:«¿¤ÌÇÉ©~xpÚ=}ãz£ùYî±
V^ÿ=Ih2¸ÆU+£¨¯ÍìýùÃkÖ°ëÐ{{ÜWDa©­€[Ö˜€´2Lz52Lì6mÄ5„
R^=@ôÌÂý)*ȯoÑ(ÇÊ)*¨2g>=n=n=n=n=nBñ)*XæE$ʶ‹Ö]':¦=I“Žm%Ú?H…±·=nÛà™¬7™Ž<Ÿ^:ƒÛA{R^;ú¬«Þ3fzŽÙ:z€´*’Gzt+š2\Xö=J¬kJ½ì1þ
> Šz[ΕjRÒì‹ÝŒH‡™¥žøíÊ­Õ;eš"¡À:†^*9•¿JÞ¼…î†mm´*2XFEãÕköÛׯÄörš“?{¶„–5ÿ0ö
XŸ¤ÒØA‹H3òþÔ^¹<&=}7cz qZ–F÷R^cŽ‹“CÄ¢Gú›ó¯¦{
F÷îJJ¬’{43•xRYËj/÷)*J¬ëêÊßÊJJÿ³ƒÝùËÿ0ñb£9ËÎDáE;™ÒkÕ‘¯r=I£Ï?šk­¬l,2RTl2K0\sE¡šQºkõNï=@0«~Œt*RV47¨ãso—t/J|/J|/J|/J|/
> J|/J|/J|/J|/J|/J|6ú:::::::::::::::::t,6©
ì¢:›J¾=n=n:ªªªª¬¼rBcÈ+{à@ln=Mè”R¹ÔTâ¹ì!ÊØ](üñNHNIµCiÂJ=@¥…öbÒÍE!Šç:vñhK¶=Jz’üm
> šk鎬›VQœü=MRÕ =M‚=Mp=IæÉL^¬,]ua˜ÈékÒš¿Î‡+Û'ú|’6×ÌœæE=nDÞF¯ù–ªsÍö:’
Ü’ã­ÒRc†l¥W"$Ê·»«÷`4U3sX^Q˜²¸SÑ떐ٹ<­2sŸÏ˜
¬ÙÖk6f^I&J)*яa¡’YÁ(zj¿ü<?<-¤ÊöePû×ïkÐGNŠ(‹Ùç1ʇĜêD¬­¼Bí‡SN}+ØÒ:‹ˆô@%û͞H
1*Jc=Ix½É0$J*7¾~¼*Ü’J[ÍÓ¹8k=J™tÍH÷¸“Nù
Ê’#­ÿL¾~Jåq;JW´KƒØôÒý5A›®ê^­Ñ6êí8ö,Êç÷^þ¦yio?Ýj’*4+=nÊì£mu‚_XRN7—0‚Û§ÉW›IÔ8ˆîh1¸­z¤Ò22222Zµ†n?ñDìéû1ø
ÁÄZ©WÔ¹^µœ7„ì/
> €²XV­’=Jz•À°­Ž:kµ¯“íªklcÊË:??f7bÌR—ìúTÔ"J7A§²Ž?¡¤J$rÇHzh+íÄ´=Mñ
ÿ­8>Žíû~•­ŠbrFuæx=I”1¬Sèûµîu×<Uý¬9kÔTyÃ䘩nCu¯‹ív
*C·åÑ_{lR;kØìþ{­u¬½=@tJE:›âŽ_ï²d‹¼pF­’Ô·ÃX‹ŠJÁàc¦=nd>F=JsJð'q1Jëö¼My“Gz-º…mä3*·¹ï=n±;âkš=J
RPúW++=nJÚ»=M‘â¥ú…éÁ'ñ¦z
hûa%¸kq‘×N¡ï=n3¹=}³f–3O/sk2NJÚRV48âÇáñ´´Ü,,,,,,,,,,,,,,,,,,,6ºt,,,,,,,,,,,,,,,,,,8fmóm­^=n=n:ªªªª¬¼rBR”=Më{µ„sösn–8«ç—1ß
=nÃ=M·ì´ý;ÖO0‚á¹Ü+û1¶÷P¹ÀŠ­“Ão„¸ÔËBâÍt6„†2kßþ<iÌ8÷C›[9)*®¨ÔUf¢žçÎêåй¯Ô¹ˆRÅ>W¶”*=IÄ´È6Ê+ê©ô4“FjE,Þçÿpœpó‚-Ò(­Äz"w
?,¡Þ*ü<’=Iİ'zœôG¯£_·NBs[+=@–GskÉ"¶øåe=nC_þý팪=JC;ÛLú{×ÒÆJ“'"¦zukV•˜øêJ¸@în…‚íRZînp”ÕD;$ÊÕœ¬ì`X'zžô†!Ž’ÿð÷J=I9-Îó>v
> ·#z¥bf=}J‘aG¡iì8ß>N+Žúk¹ºŽ¬­gÑÔ²­-Z‚+­³=Iì9pb=}œÚ*>1#{‚rF’±zçÕŸ{ò³ÛðÄ\¹
)*^E÷J7V*;R_¸ar0=J±ßÌä*Ëk=nÊø“nwèf,6=M²\u
> o¦:wúÞ?Ç͘™j:š EækJJJJJJìIðÅÿ/en=@;'•­¥uƒÙõ‰_{îE!°
kÒáz-û0ï†_kþ=@z«¿0y*‡®BâGô6Ÿk½²2[¥—ãÊÊFt57úyEe7z =JC[ýsË¢úžk†ˆXqß
þr+0v®`KPŒ†¢¤Ê»ý‹ÎËKVšÔå-y1Ï(s^e­ÿ”´Û]jœ9W=J1zÔR'j™_?š:öhã’­ÈmŽ*­Ú'þJ9ަtÒý7:´:8%¾CôñA,*®=}°Y¼JúÛêJåÏ6û€0Wbs&Ïã²
wI¬-Ú±¢häJóût÷§ÊÒœ3Ú¡kdRC²¨²+=Mýÿ/ØúW+=n®<¬2kÅÂ429W^ãÊä,R²ºz‚>Ej&ÙØ1n|ªªªªªªªªªªªªªªªªªªª­N=n=n=n<ªªªªªªªªªªªªªª¬½iNnJ=J
kR22K+++0œòBR”=Më~Ž=@¼–t7jÎz”{H°8„¹KeE2eÏcÊœ´=Jðõ{0k^„¢¬7ÛxL|d•?A²=@FHLú2âò>=}NÊl
›O1×­—e9Q`|´ßâóQ^–4ÐÔ·kß=nôTÞ-o{ë
> ³–ÂÆz±b{ž­s-öˆøfúu®œëÀõÄ
Ø2cGQžuO^pø¬ÇZáÈßó16·’¢“=@eå­ûC6O×S1½enœÀ»ŠGäJøl†Q|p,5^±ZµÊwÈ«0ÂpAx7:DW1v8%n±Šj"JŽî3dß=I
=n:"FPô+šd´k‹šP+Ê×5áØ­Ãkk±Ž67ŠÊ:–ÌÜÅ:òq²¸÷E¾q6Ù½:y£ÊI$Š'©qpI0D*ǺŸÒÌ6H²\¥=I"µ?FÛFà§Ýw1°æzN£‚+#jF™2gZR|´¾>¼kE5Çë0Z
> ÞâÃÏü 1ª~|¦y0µFãÊúřش5wÎ_Ÿë1½Î3ò(&º¥²2222L ­Fb%ó·C
Ã)*ÏhÒf8ü1è—IÔÒ7á„8ÂÌËÿ1}BEr^Ø’R­1Ÿ"Êï0Y¡Wt8‘Çè²C™—±>=}kÌ"ÊÙ=nA´Q
wU’Q³ÙÌ7ÛveÜXùInFŸîl8ì=I-ƒSo‘²›Y•sä?H¹ã£ýJDÌÙ€ql¬H­ôº"ïœ~z5£fÞzƒôì¢Ê&pºxGÐsÄw¢oÉ?{Ác-¯kÎÄZ&tUøÂÈ=@?AG§iénq¥jd/
?õU‡^™6bz?E‹ÚÛÃw@Xz[yWôð›>?=M‹Jƒdœ^Òæ×…¥m¹{ÔLɍ¯µ™ç0˜ëf£riNCä3ƒå9å~C’zpkíyn9:=IÔ3<«=nJÚ¢fzxŽ5k|=J:Ž%£ËÑ~D=n~ÒO+{вÚR
> eŒ
¢ë=MÛ{jjjjjjjjjjjjjjjjjjk¼,,,,,,,3jjjjjjjjjjkñµ§òB`˜(ÒZkR2K+++0œôCÊÿôÍ@Þ½‘|z”,´ÛúT²‹@£¾Ep¹/1ÐHv8{ˆˆ_Z:œáögzžŒfê{ç+?Dðýtú
_@:ŒŽWçákÆ®!X_Ô9•݆#7WÊ…ÊTT½Sô™w2e®D@_ñ×·?6®^¶ÝLc½00vø^WÞEåNû-åxÒf#½0&û<…ã1²k™äðÞ縔8}=nÖCÅÓ˜Ò[À[^§=J=ne¹­ffø¯øåVcŸ
k\Zu³«ü¬8£Ü!ø•ŸEJÁ66DÇ'dÊ`cGÌâöÐfEÂ_–?D=JN5Õežk‹ZNª^^XÙºkïEŠ•p­Ž@­o½koœi>#G¼*RGˆ
?>¸L7µ¥²›iÚkÿ>7Î,¡z”´JÕ÷=n>kïXK
> ˸LóÒ8d©^ÔS-†D’r_ú©kký±C`
’é©Ñï?ÊÕÆDVÄ2cj<æõKà9R×ÿp¢Æm²Ë+1CºÁ¢F3=n,£k^bò+-RþH”Tå­qÂâk=JªµÞHRæËßqÞÊJJJJîõó*é]
> -6sžݾC
ÐâŠcâJen­³Ï{†eoÕajJ·Ð#Ê^’Kî9~CâØÒcLÕ¬8“ŽÎFãt3ò0Ñ=Jª+dɬ4fÕ¼2òRh­ÜZÖ°6CF¦oo™B`=MZ°­ðÖ¡L­ÜãÜ¡y>=JJ?G
> Nf€oœò˜|Ôh±Û±'e·›k_o‰”4óÛk=MŒµx&?nîk¶:—o‹´ÁﺥúÄÌ
k°CM=nµXTÍØí…Â_R[ÃîÚ+ËdȲ\íïÃ'!¤J7Eåo?¢»ç¢ÊÛJ5e=nF»†ÜÃ9Gç: Zzk¢
7E/{â>>~Êø‘޳ø:£r2O/ˆWÔ¶¯³5xî‚n’3×ú‘MÎ×Gr;rIÍÞškÚ4Tzt,3kTÌl8¶Ulý/?=@ªªªªªªªªªªªªªªªªªª­N=n=n=n=n=n=n=n=n=n=n=n=n<ªªªª«ÚÜ­öµ
> †¡Pú:l,,,,6ÏÅY¯äåÔ\•ŸÝÓkÊ2ժʱ–ÔSŸ]EÐÅÊ2d†Ñ¬U±@—k¾ŒŠ:—e”‚Ù²?Gš4È
/1H^0å„Fº7x(ᑜ_ý´9ˆQeÝrWPvEâ‹{‡ýnO´µÕlgÊ­»¼Fؼ
ÔdEJPÆR&´´ñC±–»ãê}ã¯{ñ®ïd`Àäö—ekvxSývü8€^&Ê¿'î÷ÀTH²eJîá:V4šJuG=@‡Vkèa\uš,"k}ÄAI9±¤­Ç×Nã0ÖCIy>8ñ¼´•6'jËé~F¢fEd·÷Ôh±/
¶½íŒ£Ê„-„*ú/?¶Âàß#B5=Iò/{ö&üe8¡Þgt7Bñt…ëÍy!8RdEƒž*çþ?º::ŽwÅk¾ž›c÷@HÔÍøÃÌ2͐–îx$É&J¼à\—@píÉ­á09
ˆ…oð{„õU‹‹¥÷8Gt8
> QòcÏŸ\ FyJÔLssçR8+1^ª½¡ÙD=J­¯ž]_ö^3Ì49ϵîðeÅk{‚=MGx­Õ)*l­»íå@f7F/$­‰lÔg?>jjjk
Ýõ°%ký­Dø™£†­Xý&bña®Ii1(ÔÖG,Ò2=Iå1Ä8»mÿ/«f
> :~úA
­1éÃ1N܉ç0=nJ€{‘ž;Ój›Ë’\I\­Í5H‘¡®¢…'þãùà@H0ì8þHy“ŠÄ›M:H-Å«kòs=M†zŒy?Iq)*
å›kßo…”4÷"˜Rf8üåŠ?F»t"÷Þ%ãÊӝµõ¸àŸ{„
\È=JúÊí½^#Å’ËÔ`¿#–*™³)*Ü6ƻ꽨É=IÔ8²ÅwÜ_RÓ6ãÈ,ªz‡0BÑ‚;7éÌ7K€®;¶Érfaÿ~q‘ó=IëôsÍÿ1Œ´JñhÍ7zšÊJJJðjjÛÅ?@˜(ÒO÷ß?µ
=M=@ð¯{Î|c‡ÍèÒ·~~ÊJJ¿n®o17ëÞHºÌV–̲22222222222222222\jjjjjjjjjjjjjjjjjkÀWš"Ê=Jjjjjjƒk®½‰°i´ÒÍ„­j>?ªkЬ¸þ_{pÐQÔ8»ØË*tŒ
¢hóúÊù=}Ó=n–ÌÓ0Ý_0"Üf1«”ÌcsïýášÎ?;Œ°ÐúpDXh:Hb®HÆ=}1ÛE=n§©Ò{{-ëxû;ZÜGV#zž=MZì!»€‹å¢bœRfëNÚ5@"ٍíÌÒÍQIº‹F˸š¦9þR[È
> Ý<ü=Jñ•Ž™ó0޳Žô„3ˆzŽ
†j¥3Ì­û=nº±Þk[ؘqZ­®â¬Œ»ßôúëÀj¤¬›CsŠ~€í½•1|bT¹‘-¯7û6¢ÊÅ?F€ú—íjûÔ8wV%qPk
ðj6H+ë¶)*£ÊfZ*
1Þ0¹‹å¥ù>r>ʾ:ª¬¹^gz|J¥µìkC—9ª?FýB«–¹*ÛѨ¤4kB€¡A›úžkã÷·Àž’{ˆnãÆ/€­ªIã?10Þ×#¤Jù}ñn?šûošx¥T¹´ÿqû‹wŒi=J>a’hÉ*N“k†k
7îp2Ü’¹¿'?qÊÌÏ+=nJ¾Hi˜I沜=nÊÄcG¡™O/eu¢q#J#£1:rlÒ쬋™8Òdj*J<­CI=@ºœò¢6’ˆà¬Fm§z€³þª­AÆø:uBŽ¢Šü!f¬9k·7’-ŠÌäÚ¸õT9{Ø8’K1Q’
D²¸k=Jx÷÷~ƒ¶ö/€òh­ÜªB‹ö“¨­û”´Ûá—´4ù"yRf8ühP$¨ͯ=n®*Ê=@j­ú«=M5¬F_×1\¬Âšçññ[Ý­‚ÊAÕ²_ý¬8Ôûo*j›7“›5RcË0qÃF_iNG—>­ô
mPMAF6•Ü­„<?qÙ6w°PðÄS?Ÿ=nJ›\¡¼Äd7,6º::t64Ì»½ºˆ0þÌÔl6‰GÔ³¸Œ=I5(Ra‚{|ª¬zr~rn¡‡Å8Ħ>€ò22222222222222222[jjjjjjkR2222222222b
> %k]Å×1\,,,4h€Ý‘º~ãºÊ;<=@Êú/?Ьl3kw?pš†zžázª
“2]J@72]ò†’„5ßÎÃDŸ+ÒTÀt¸=nIœ8æ’%ê¢>2±©MBf×þ¾pJ!™–¶üká~GB£A^¢yÇÆä¯1u
Ix8Ú„p]»ÊÁs:¥–&òc‘곍=}‹fqµtҎϹW¿ãIìú’ó5Žô*ì_12cFo#Í`ñ¥µz€¢„‚“ð&P!kø6⡏J¸±´9la³àĝ£Êñ=}C¦‡…ØIÔ8p¸÷8ŸƒÕºžï±Xkô0¿á
Ô9y8Š•ÉM°Å5þÊi=}fU0p–*Êæ¢†ÈSr’e›O1v›cíìø矛'»…qE—Z¤â~AÔkRK+=nJî#Ä)*ôžk¡ï~œ!ãÉK˘ÐÞ¤Jïô6Ço«Ëè1¼9q0k¯c+F{qg"­˜CD`™Y
> ˆÒ[¦¶2˜ánqeˆÂð=MŒÖ»ÐæäÊúŒNF߆´4ó¿è­žCÀP,yKë1Û« –Fq&~0Xx<8Ö
Ç`(zž…—³=J—ÌÒERÑ=n<ªª­ïé%²ñ">Gç¿)*dÅkɓɿ®ŸT¹ÇðÅîe¤Ü²í
-g:’†­Qò­1<2]§—îÊ÷ø×bÊו‘ž=n>»l6x¬ÞÜ­Ì@À’¦îTUÛØ*•Ô7šðkN7®BQ<,+1Â"mÆ+DÊÝC¿”Ó1çê6bÔ?G{|©;è±k†qeû1ù=Mò]+ý?F¯Í¨2JŸ
0Â’åóªe=n@îô›]ÜBŠ^ižG««0®“†±!kÞj¼ˆpÑ­o>k°KLHØkÞvô,7F=JðA>BŠƒ!˜£=I]áTÍ×o:‹µÁä®Ã/{/>jkR2TÌÍP!9¤M#lSt2K0y¸ÿoDîžþœkå
O•0¹L´äª¬zr?G§È<]»é¼´jjjjjjjjjjjkR22222[jjjjjjjjjjjjjjkR22fèþ›=}Üç»’\–ÖšÚ=Jd?nÃBaš"ÊÍÛ6E…»CdƒI(MÌ4°Jâ”5ªÌÎJÜ3j=J­\^›ÔS±0µã¾G
;ÅÛ…Jä6=I›åZ@ýâkŒDE0âZF=M¦‚¬û‹®@g®®D°\’Å=}÷gÈG¢ü8²Ë–6ô=I£oŒN%ük¹&ÌfP["£ªAjÊ!Kî_8ýc¤RÒu[vž¸+¸0²?G1f|!Û8Ù—öRÕZú8
> úÈ1¼9H–`U2œÀAð`çqâÔ¸¡‡ABϲ$‚k|#-u5²EûkE²·»Ä\-îʶv<ŠÐ8‹âȞk¢ÎD:Xøë/pG¶º—ELák
ßñ{w×3ú™@F<5·^Å2e¯í€aS!µ›Ìà–v¶Õ› ¸Ï/eÊ
¾=n:ª¬3ˏ0€ûβ"Ȩ²\î937++Â0ØšúT¹\ƒöŽñ8=MjpíÄ6„DW´Ÿ¡ˆ²`™¥V·ÉA=J·­êø†ÞkÑ¢#m—»šfúœŒ›~(DLñÉÌ-¥j»¿C«ü¬8°=MD=J/¢¹Wl3–·Y*¬8ú
> ž8´U¨ù¾8ø9Qp=Iÿ16*ôsh‘Á,§Ÿ'z
êP*ˆè5"T¸=@Å’g>~·ºt,,91á=I½:ñœ’é´9yÝ©D­F£)*Õ®žTÍê’¢kÿ=}Ô0928©=nC½ÐÐú{øk³ŸÇ:j>ªz~¾B=}‘[!JüBÆ=M
ÈçWoŸ\=}Ó̤ʘGïàw’¬õ*beÜ4Æxd›K1eÆyÔ2¬€ïZ›Arduhû³÷Bâ,yNHà7ßILwü8=@J¼hH¯/[I¬Ic1(Ê?B7l+-WœkÎqäìèwµæWkB@"ö¿ŸÊ'z¤W/×îyj
­ŠR|´¾?»¶Xf:-3Oe|­ÓË0|¼#Dëá?{úð°`ª{|ªz£‚Ã¥ó1ì,ÒÌ´J¾=n=n,V:ÒîJfïL_‘>~Ò>¬2kq\ÿpx·+ÜrùGz’¦êß/î¶eb¦zuύoH«0'À§%lþÐªªªª
ªªªªªªªªªªªªª­>=n=n=n<ªªªªªªªªªªªªª­óG›xFªkð„ÔC:‚_=n°ÌÖ,¬jkRO=nʾ-ÜÍ]Ý';;1®A·=I£‡_kä2dz‘ܺ•¯ý<©¨Ë0Ög=@Z•ñ÷/›Šñ]Ž™=}¨¬Œˆ
> =@áU™ZÚ£J¾@ê§½§—1>Ä8¡ÞDëeÌÂ0=}
­ée›ZFÎ-£ÕÔ5›³Ë½=}—µkýåè®±n†,´•ÅMWÎ@¾Bu¬¬j–cé›IN:øùíÜf«àa/ûkmÚ<H=@Àf¨>FýáM‰>Ê@;Ûi
> _{÷=}…±’hÿÊÿ·¼lnvÍïï1Ž¢=}ˆQ”¡N•kÿFVµô_¡{å*4kR2K+=ncëʼ’=nC°ÃߢÒ"aÉÔ7
2bÛ\°F́:’T¸“Ñ–Z–=MUÅ…?8’c³ìFŸÎGœ`V]DŽCÎ8*Ø’\ŽX
ÇÅëÒR#¥#%°…‚0ÎJ÷"-q‘“ÏÊ΢Vª¼ü9^G;Í‹8õÒk“=Möú…ͰÊÊÐHš%“ûí¬6=M¦·–»%ÒR`ëäîp!›{‡gÀ=J&Nö&¸Ÿk±¨¢DÒÿ0­Š¬z::¦)*)*º5»ð&ÖD¥ú¤'ɉŽ
—4þ'zœ=M·=MÃØö'ÿqù=M‡Ã­hú`*=n,“/5ºš2N42Jʬ­C‡¨:¬ÛÝeï#p­ý³ÛçטÁõ?åË­ì!1ÿ´1~Fy»Àâå¿„7LìwX㜸‘nGvë0ÜÆeÍoJÍÚ|gðªŠt1$£H‘^8
> ’`í¶Xö±žFz¤‚Ó2d¬§éœ6Pˡ孛Ös”ÍPÇ“/ëkB±¢ƒE
,z¡K6oz,ùÔ8°µ£©>A{|­Äm=Iuº£‚ŸzžÛÞ:ƒî[ξ?«ÄÁÇôÒo:œ=MÐ=Mò9³=IJÔf ´2V̲O+
++0<’…ûôÍ€˜z‡o:oJ|4º¬Ï²R??[J»GJꢛwFë$RÙ?=nÊJJJJJJJJJJJJJJJJï++++++++++++=nÊJJJJ[ä=I$JÏzÏ?^¬“=nü,3kR2O*ÒÐhéÌLÚ#i
JZ»øç
0²d«Û’JÊJ¶[)*ÔèCyÿ1xLhgfízz=}qô5ˆR2N+’Êž­6òìòpÁjJp¥*G¢|7»Þü5¨ÒeËìö=@¡¯‰â™NCC=I¬¿å¸§z…3´À1‚Jz¤¦m†eò_˜¹²>
†HúÅ1Ž@k÷²ï2ë7Ma]Úk=Mù^¼Ç¡#¿{ÿ­ìõJ=n¼=@J¯»92Ä´ãJJ´Q§ãJ¾<ª¬::?6@§íÄ4_¯9º—Ý£J1f"ªê=J^JG¤Êšá¡—ãðͶÇgtÒ
}SŸå¹ÞzMîúÚù›á
> ¼7=M­Yx›þkó·ðbÀ°’ì’È’WÖàdq˜­ão{Ä=J:l,8vv>
[=MD$Ô¶Ž´sÈrš’›þkû7[E}ÕÌÞ‘»µÃªx”'û1Ѭ?°•£<h0=MŽ<¬:t99àƒÇ­#‚=IÔ9}=nU6=I}
> kñ´i(Ê£2ôÒ#󸊇÷òa“+Ê+rJã/7åÊk-¨²V¬46 {ÿ0w“›ØO1}M7ÊOo¤‚FEÂ(
‰2E,¬"³n½*Gw™E0Ÿ¯7ÔAñlt3–Ú]¼ãGº”[{xk9î_öcFHË1b»ï †94­ú‹“*Þz
kæPÈ1^G–kh=Iã0‚éêhÍ­[Þ›Yi?{­s²kÒdJà<h!:3•k#j­jRRÓkÆ¡–ýöž2L2ޝkú,6áæZ–8ÔÍšRz{|¬Ùšu¸êƒk=M÷SÀ–ø
¸«~>{=nÊJ¾=n<­3ÞH{ͦ
òX̲2>«rLºoJ|2Ï{à9v~¨)*Ì´º:::::::::::::::::Œªª¬z::::::::::::::£bû‚á%è²ZÎ=n<ª¬z::t,3jeJÊþ;”ÌKaGÜ¬ÄÈ©ºký5Ýpg:‡=n–¬Â)*}û1¢TTÐ`
> Á×?:TÕo1`KÇ7™,'?qI=I³ÄÊ—_äJâR×ö¦y=Míû/=IXŒjá¨ÒÖ‰@
-£ˆbnŒNcÃíð§l7ÄN°€äa…¸Öš)*ô´Z¢àâ<úE#$¹=n[ö›Fß$T¸P³O¢MÉ=}
> Ü9pFE‚k¢Cpç: `ÄAmw~|óz¬jÎ<ªª¬::{õj5›=n0p™e÷åg:’¬Ù
pA*†¢+ï1Iœ‚=ICGDèǤԸc&MJ£XùhI²cONþ;øº¡‹ÚíÚg‰…kó¶ï¼ ÿ!Šº÷/Q³Ýñ
> C¶¬c®˜GÇþW”­D2Së=nÊ®:o®Fü­iÍóG`?BÛ0
G$RÔ=J[=M„Ôh­2=J"u°ø¥¹÷o–퍇ð²V¬:t9MÞEÅÉ™ÿ1ͯ&0%(Òf&{1C²Q‘Ôh¨‹z%ú‰Zô42Ìyë+ð¬*>:
44¼*Ü­=}˜añªkŠåg˜F†~Ë5Z…æ7yI/ÈO¢þz:ŽŠa£3#Ê˪›=nJË­¾CÆeí×ä¥kÓ¯ïãmêÛØ²TJýS£"JüShø¦ï÷Q{…J‹=n1^âk=}ÝZb›2Qg,6‰­2h…A
)*š=Mÿ~Œq;ä3•ãJÚš¡[,¡d¾EÞƒöjkŸ?EJ÷XD_1…oJÁåM3k‚EЍä͏=nJ=J3!wd7†ÔbÅ÷/¾~ʾ=n<ª¬zZÚ?okŸ?R222K++=nJ0i$Jº::::::::::::
:::::Œªªªªªªªªªªªª¬z::::£‚‚Íþ=nF2O+++=nÊJJ¾82R0Ï~„KˆH¾­;‰£)*K$J=@1¢§:˜¬Ù^ü¬ÂšEO­Üþ~k¾ÙÊt8œ‚¦j*/ˆèÔ·šÏ=J±t˜ê›h1nù%æñú80—
> ‹ô=@››ötÒú”g%¬¸Žš’D·´4-ºc¼^Ÿ- È‹/Ä—O¼a’^E;Oô5ºžoº:o°¦: _¯7‡ù~A¶:3
!ïo’¬z::l,6=IK滪‰ñºkpC‘¡Gókž=n:r*½ÚkŒ‘›Âcjÿ
ñÉJÔf#‘c«™³ñ™=npñp=}Ù=}$Jö†û¦àk󶮺HûÒi>C‹µƒ²c3WeÞk7·RÖѝ­p}×ʲÐ9crô†ú”ª¬:fH=J)*Ãéš?Fcò¶ñ{vg!ÈGêÚÒ$F;i‹d<–ÿk掐gz’ª¬
> z£½6øð$*­á5)*—IÌ9`!âžÙÔÒ*!…–z?­ì9Dkž>æøkž?O0y
û1ÑÄ!ÞwM”’Ko¤2gáã'YnA;ßÌÄ*F¬5|/J¬j«­A÷2­W0\fð™ÿ1KX÷=Mç#­jjÿ=I=nA
¢ßFð²Y-úpÐ&QÌ94\ìEõnAI´k$ÊùA"m(rh:˜û~zJ=I/1¥²)*@z¤ØÑFªRX^4Tz‹eµ²³æŸ¡Ì7ÍŠ’+0ÊJ÷Nª7âT`*+kkR[îöK²å³ú¤Ô¹Gî罤£ÊÚ{n@jkRO
> +=nÊð‰o{
#º’̲222222JÊ,Y>d,z¤²22222222222222222[jjjjkR222222222222f(ü—rñ?'"Ê=MjjkR2222O++/1Ã~„d1­T-æ-§úJ¬³d®G6
¾z€—õž2^H
RdmÖ,̯òc¿·š9äMŠW{¢B¶Jd›Rd²]„AçÊô%mç»Í~E+¾çí}~ûó~~¢…n¶ødü7mÅ5-Æo¾C½;Kò2™gº…UŒü`´µký>pq¡;ì¯JÞâœý–‰gÅ=@ú…6„f>s’dDrQxe+
o“ç><ª¬::ŽˆŽOÛï&ç:’ð_·Ð¹/º::œôeàÇ&ñºky³žÃÄûƒ·T¶BOè”=I¼4ö…m£=nDŠþ-‰¦¯Ê¤>€,`p!bŒ×;æ<¡»^åI~1µTUQð9Ô-PVõá'ú™âÚª­1º
†ûö榬Òó%ú‰9QŸ]I€+ÿo¥òhðñ«Ž¤„7aÙï02O1È*›ð=I!nG¢›‚’ñ"¹Ì9WîfŒß*c§W~£Ýn"‰=MH(/0X™:¬¸dJ°kNÊ÷=J:¤g»钚Ȑ'ý¦Ê%q
{ˆ²-¯Jópú–
> ¹œ8¡=M„70=IæJëÆ“»«¬îò
¬Žº=}ëË/E®¿#Æ­€=Jíw¬ûÞ@%RMïM¹Ð²]Å4=Möüs1…k¶™òeJDÊlï¸oÒgr¦Ñÿ/±ÂÊñA"—kݨU¿o:¤"b¶B¥Mð•kæ—JƒÌØ
Êι;Úå¨mÄ4jíÕÇÕ¸Ï1ul=n¸ô÷aT®WËÅÄ­n:w5eJ[ÃÏýô^4Í+Ì3/oƒ=n®<¬zt,3k¶¾wH”ÌJûo::t,,2jk/1à¥ã4(&:¤R22222222222222222[jjjjjjjjjjjj
jjkR22ceoÁ*¡Rfþ=n<ªªªªª¬z::{bHÔÌp°(rT=Je9öþ;38“*|5·´4âgù̓£Ê–¬Ÿ…8=M™n{¨Š=@´X¾Eñ-pΐf%J^8Ïk¸O!{ak[áR^`DTµ,2Ú–8R[YÎC
Ÿ:žo®¦¹[1U¡Ø’e‚ô˜x«=IÄ-š·÷‘W´=J¬MX—úfpë1‚>ûoœyC·#°îÔ`•ØeøiJÌÞ•ß7Ô_ë/º:3*ƒ^,6æ}–uïò_*^*/*¬z::ŒÛL@eXØ,':¢|NJÞº†'s'?oL
νNˆ¦¬8áŠö—9²"é??ë´¹êˆë!˜úá»Ô^ªp„Fú?;î>E[ì:ñ¼"‡¡NGjàpJ®?1äʼnU!z’¡{{rT,­[È=}ÿæl7Í»Ü`§q:­=}‡¤©i?HžìÏM¯ÒÒôm-ãÊ!OâÚ{Z
> ¶Jìdø±žG’2O1=nŒ=MðHŽ':ŸÚ°jü
7kªž˜Nˆ‘E#T´ŒKºf±±NHÄ‚œ¾CtìÑæJØë/ˆ-žGB6=nÂѐô¥àǨ´UZŒ\°€Þz*¬ÖìèwŽ›Ëë=n'³ß툤ÊÀBûxakҍ„
R=n=}Ì,,2ž·˜Aó0|ò‰E­‚j×ô8<øä¾G—ÿ·¡ã0úZ¡Ãã=nGúªM>¬íöBf×Gz¦Þ)*¶)*?{ýªí¡¹HfWd81Í©"¹Ä7>~Jê§áa˜çzŸ^|5·,6©@ˆ^Ôd*ËtR­µÞ[+×ÄŸe
(ôÍ÷NûJƒkÂ§ÌØ4¬êÊÚkЬz:t3kµß¥™ÿ~’øRÕÒO++++++/t8(÷—l¨‘Jjjjjjjjjjjjjjjjjjk´,,,,,,3jjjjjjjjjjkÆJ¥£·:¢ë=nÊJJJJ¾=n=n=n=n?¢ûz´LÙû
> ö¡„j¹WÛû/ø°Ô3k­aw>Aí±è€"¸ñÌ9z[Í‹{€kƒŽ;Úâ%±\­ÈP½˜
Îz˜û=n$Ô6³ý:ð¢‚aœMèFU*_Þ0t´­0¬ô-²5Çí¼4°ã8§Þ¯Ê¬Ù’@d—ë=nìúB”â”­
Þc®b’­¿×N×ö'ÿ{âNámý—ô¬PòN“êJcë·Üžk•Î`'Eëéä7zt,,6[b°êì¡¡+÷1¯³îãªX`yˆ¨Æ¿qeBIm±Hrgvi5-‚¦sÒ×ë1ŽF¢Òªö¯gÍ­ª­±Àæ÷¡¾¹’T¸
ˆ]ä¨ÖMu{~Ѝ<¦®"Gç¹ÔeˆðòìýÛoF¹¸k>äñÄMÊ{@`{tk|k½=M]wb›2R9´U=Iæ¡ÔbI=nRÙuÝÍ;¯·W1“º=@»óÒGÈ&êGz¤R2O16Dqáû1pOZ¼ÈvinH
Erª!&ùÔ_=IŸ?õ³íÛáû~š²†x€#ñÜ¢$J¾;¨=}¦º“"AOd»B`¨«?ÛÛÛp=MC„ûj//ŽÚ–škŠ*l,2gz}e©ZhÄʶÝF§þ¬Tmëͬ¥Áeö¨rVDûÊ2L¯ñÏJ=JWÿ1r
C’ÎG;Z°5Ê’Ъ¬0Ø¡Ô6[¥Ýú(²f›¬‹ÇibT¸¼-…¿æz‡Ì¬´¾Bör³åÇùJ­‚D*2_+/Ÿ6Ê?@³Þ~DJñ;Z°Lf1?{=MçX›þ¾2òK+ß=M‡9_?­­ÌhWq_{
äþ€ªÊ
ÚkRO=nÊG´ÍZ–Ì^Šûoƒ=nÊJJJJJ¬¬Øk‹êðÇêÿ0²222222O++++++++++0R222222222222222222f¦v§=@K
:ª¬z:l3jjjjjeJÊþ:Ô8CÄl4¼+“=JŸkÓÿ=n=n: ±
> à´8¸ù´ÄŽh«1Œ´¾F™©©W¹M
ÿ0ßÊ>ŸÒµ0Ž*óŠœ{Gûðï^LÖt6d5£¥¤ÊÀq„æŸQ¬5ÊÕ¯Þ´H’S»ä݁÷/Ì£šô¦íÄ=nÛ³……;Ûköñ€<kE7ß?Däßª·xëæt5pñeñYÅ
ºÔUŽ=n=n=nCyUŒ‹Në1¯¶ï‘›h{óFœvDdȲg2L6¹W•¤{VFºäF^kcˆ`¥çúù2ò„wZÇ9iÜ8j‰CWšþ˜ÔeŒ¥›[BÎ=I«{?¬qkQ›Sþ£yZÔd¶rõE·l0Hxަ횭„{t
k=nJ¼­ÌÙ!9Ò=JÅvyâ§>H=IŒ)*^ŸRSPŸô­Höº!—¿1ÞýŠJ=n-Ûkó®=nÎ×óRQÞ‡½-Q„I^Hnâ¸Ö×ò#™$Ô·ÌïÜkó0=J±7R¬Ìã›:³å·¹O{øFH»Ê»âfz¤bsƒE=n
—’-¯“{‡¨h7"¾:=J*Y¬»-o®ºkÕkÓ®Ç=MÎ8ÁŸ‘Ô50+ÚkczS=nü2k÷¶¨öHÏ1M1£O•m|­×¶ø=J–:™;8›J‡:ž7º0ÿ1X]øùl­¹³hz’Ý·z‡o€q°`ùÊFú€BøØ
Ød
¾G*J¼mo¾Bðeñ~žÒÒN+‘Š­òïù=It•ô^4Í¿ðâJü[v2VÌʪo;‹1eÄŒ¡"Ç¿p·`ÌÞ2V:t3k9~z‡”­€´*LÖÊJJJ¾:ª¬45‹=M›6™5Ü­jjjjjjjjjjjjjjjjjjk´,,,,,,
,,,,3jjjjjjjkí{……RËkꪬz:::::t,,4GFÔ=nœks/Úž`¬ŸÚ<¬rÍ’E·a1ÍE=n›ßͪ{k°Tt’·åå©n6foî_Í?qÓ0?Ûª‡ÕÕ?1l2›e7ú}[›ôëàk
ZZ“é<¬òK+/u„k
8,ãJëöó…0ë2`¸kM-à=JqL­É@ê!§!ßê?CìaN1ez™²kþBX«Pï«Ü´ú:ŸèÅÊÅkRSN··ãÆz¢¢&ƒ»î-û~œm5§ÿ8Q¼9pBÄðýoRÖ<äA6×=nG$JÊï½ÞxšÔ7E´¶Ä§ÚR_8‹
> AÂ{jž‹J8fvPaª™&GùÑÔÒ/bgÅJ
v˜Hñ_op9@™äÁö`&Ô·Ð0S=nö²küñ1ÚcÐë{}r=nJ=M¾ôi$Ñ?F‚·Qè­ÌçÈñ&0¥úq|V:
(è¾Ò!Ì`ëÊä2 ·h²Zê
> ´í¸ÎÊñß‚€áf=nH…žü:R-mñk%T¸‘‹=I=}µªrk¢Yµ©3ݺ íµŽÊ1¢†¢>Cš(z>Ç¿î·
f:¤fz¢6£Št´`ºcϸ疚FzˆSÄo‡«kÜ/J|,2k¾ü²Ã‘¨+1Â!äƒ
2D½ãk6K¶Aj›­Fx_Þƒ;-«Rde^~xþÉA?q¤¬Eñÿ1XYƒ„c91OƒD$ÔµÒË^VÊïÊ÷PH~GW2X,6ÏŸÆæ,Í‚¿ç¢ÒV­­Þ[?!whÔÍöâ=n=}ÀÄ/™ä7p«o::mHìýï0;¼7GìÒR
Õ®<:t4æ?:/º:”ÌÏ++=nÊJ®=n?Reå`Y5Ïfž2eº::::::::::::::::::Œªªª¬z::::::::::::::€p3M8î|9?÷V›•á0´,,,,,,3jjjk54Ê7®Cßã3lzCX™èú‡Øöd®
DÃÄ‹ò”­çon¹;Úã=nBšŽX×øØe/{k±Ž7еf†¡TUŽ?N•Ø­ž?õÆ€ËѬ=J**E=n<ª¬::2Û‰nCã¬ïqnF®ÑâD–r2¸Â­m0mŠ‘œ´ïðeç¸d®?¬{P°Ä'ßfzž#^Ì’”
> sk ½Ï¦¬=n¹––X›Ê:¢¢&Î­
F¿qÄêAÇy=nGâ6}’po8†´´œýu:M†ìNQZDb=n?ŠÅ€"‡÷к]ª’Mcb„6…²¸Ífž"–­€ŒTçÙG¦X'ºˆsÌÄ]F÷W1Œg
­ù§íK
> ·7ÆcÔ´_ùírFý¢>@Ç÷¾!ÖúF¾=}>O™¡YÅ&Ô·JQ9Y
M¹®Re>~ü9d?DŒh´Í½<¨"$|U!–46%Š'#G:› ›LdÕ@?qû‹÷î9o?Ì4ò”a¤Jõ=nU6þFÇÜê’sk­B
> 3£1^£TµbcJÿʽ6=Jsü㪭CK0‹~£”:–óª+Jù;ÊsEP™£C1k‚ϝ7eü#ÊâÚ„D?ü
1µ1-ÒÈa{F:ž‹öS€1t2k=nªVÇ:œu¸wq=Mf"JL–uÙêJÚ¦Bpǝå
Ì9e?¸Àˆ—îš2]÷Â௔Ôg÷ØîEJ{zhÒc[‰¹)*Þ¨Ô¸šSkR[º!¹ðíö©nEÛÞ:’,2¥­E¦z|@Ö?EÒZïøJ¸ëC¸ôÍð¥³aîÊÕEÃêJâÑh#Jä´¾=n=nFø?cÔÒÔT/ºX¯
> Ô]×–ÌXëÓR^{n=n<ªª¬:kk+Ï7˜úkpëF—
’Î@kR22222222222222222[jjjjjjjjjjjjjjjjkR22fû°ÆP’úF’22222O+++=nJËä"T³fú{÷Këí„#ʰ`Å:­é0^
›!JN+‘?¢Ú‘<=J#WÛ·j&{H½BDûjšoƒ/†žû=n0Ý2Xªªªª¬:Fj@’+÷0Q^Œ=@9›œ3žŠ@°"p­žCqXqXOÑ´8Ì-«“@49h¢‡FE=n„4·LÇØ—zNDÝÚz–ÒÝâà$JÛ"
> r+ÊdÔGÇøï;VàLçió1‘’ ž™µêR7^=JÌæ3¦<{9ÄÒë
ªW6¾b{ˆ­O´…7¥‡üú›š°\‰;^§¾FƒTµÇt4JGÕV˜I¬«ÜLý(YÞFBÁ°…2¸Fºn\±aå£ýf¿o²V›1x
ÒO¿È³Ønšo¤;éçGöÄr1®nžY0aÉE¨’d>ÃÅïÙ%?F¹ðœ9}Ü9½¼´ùß·¹ã1P6û¢tÍÚðká>>Æþ9g:5)*–ùnH‘–èÛ{`
‹i?nêÛ^œ2µb•Â7lTkÞ:„2þJ½5îp
> c¢>qKŽÛsϱœfzn¸ô„rû¸Ò_¬”a íñ¼8úçä=IÒTTûþеQ…ÿ=nêœb ²døLPàõï=nFÜ
¸ãŒ‹›žkö(}¢³jFÙkG&6ü`C95/î¢æ?gc?Jjö0ß%®H§~ýuk=@û"¨Ô
> Íef¢G×Ìåz?̱æÊ=Mï¨[!9¼Í?0œæªD=I]àÿ/̶[ÊJ=nAk­³»=J9œÍ Þ_Ê/=nr
Û¯ø^,9A?²\òˆ=Mmª?F‡#ê,±EkþBU¬ê’´Üªªª­Ç$ø§?p÷4T=nʱÄû~z—ä7„S
> Ë?+=nÊJJ®=n?Ree`Fø]b’^”9o+++++++++++++++++++0R222222222O+++++++++/ŽŽ·ö
î|9@pdSFñ˜42kR22222222Jµ2T9/zúJªŸa ­é4TJ*Nâ,9q9­ÌI`Øa
ª{‡’2J=ngút,,2kRK=ngŠá>C°C2žÅˆ·'ú’kJª“=n@±¢wÊž™øsú7ÞD”¬£²%á¹@ØK0ðÍVšú&º£™,Zwê†k?F‚¶}È9µx_$JýÝÚ–ÈjŠÿ×­=I***>0êRË@RÊ
å}Ýåòpfwý¼ÍHFñ˜=Mš²ÿ¼­ÏÂã\Á™Q”ÌÔ#nÄÀ5z‡#¨ÒTŽò]<ú:Š&}òJbª­7øä/{ÍEj’­¢I{æû
‡$JÁ1^ý¯>G;tBM¾Mò(rØÒȎ^’ŒƒÒ)*Z²°kU]79:
> ¢LæÚŒ5ŸËXé>pb¹ð¡Ô9uÜsB8´TçÌ™>=M=@Þkï;WîòdÜÒ$FUØ[o?þ:´_±©Ì5jT08²f¦š<
ÓI»Ì(4͐#~~Ê׏ŸTµR2K÷9˜*ÿ{óhB1¢ø†lMºÞñÀ…÷0ûŒ6žF¦f
dJ£›+÷§a¹o?¹¢2ÿ¡ÊkC±0=})*QJAâ–¹"ÊÓ*+޼¤Êª*–€Þ­ýd^Ȳf<žd˜z›b§küû!»¬¤Ô¹¥Ýé7Òe¾?ƒ2bÛ0¢qû{­Bi8”4îìs¥æï1j2V,6§*ûã?@¯¾V%»
„?1¹‚=J‡»è{õ¹?{ãïðô6&ܬc8«W/ì·?Jûot3k22Z™´qeÔÒ/?ЬzŽŸTÌ÷@DÒÌ,3jjk2JÊ[¸Àpð­·¬bð/JÜ,,,,,,,,,,,,,,,,,3jk¬,,3jjjjjjjjjjjj
> jjjjjkñB¨h­ðëÒ:£ÊªF9Ô5JJJJJJJJJÕ±;äÊ_2·âc[Xд’
´97¯¹6ôгTUž:¬_›>žkRO+++++/IJ“ô0‘Gªk6‹÷ÇH²^k2F¢¬ØCÃHÒb³ËêäðlrôbJf}
eáÚ…èÅÊ%mB›9Nz·äúT¸¦UÍ×Hì9ˆ’®ö<êzÌ×­ñ±eäÅì÷1¤+*´eJ#Èë6XLhwqx´ÍôšWŸ7b®A–ðßDÊ§ËækH>bÅû­z?øX`skÃaÜ5Û®:“0Þ´¬VL`¸xË
¹7¹^0ÆØþ‚47ÆHðàpE’”´Z«Yµ“`M©TͼQ1Œ‡m)*­fjÓÇ­éÜwv=Io?BìxJÈ=nÄkê!ðÞ7²*Ô¹©=nôÌåì6›É
kΤp=InH[=M™œÔ·Ån’—ot,4¹3õí¬Ì2
> jk®"›JN’ÔÒõ»ï½41j£Jå†rA–¬¼¼Fu óo€ø‡ŸeÊÀ5
ò^½š:žïàþl9pÀ39"¾H7‚0)*à­¾5½þÊL7Dœ?H;g~”4áô:£b¡Ü½Ú¨(=JÒëÊô&‹48°®A++î_ξB
> pýN®Ç¿qxôU÷v¡ž6[Å£HtÍð¡µ}×ÊÍwFÑ­pa^ökÊ{|¬z::|‹f
4´n2·ª{€kÈ4ÌÒ^ŠË¬ôR¬z::l,4¼­üê‹%â%ñ¹Eèk1„,3jjjjjjjjjjjjjjjjjjk´,,,,,,,
,,,,,,,,3jjjjjk=MšîÃhñ=Jz›ò2C¬2¸ŠžeÔ`z:::::::ak¬íK<w—™XO~¥6‚ú=@ª*=J>?º?ø7@=Mk,µ·ÇãJ¾<ªªªªª­af½ÀdQ³=J:uM61³e½ï/ú::o•
¬0Í„N
Jì–nŠ}ßý­íq­ìû¤Í®Œ]gØhz^-¬8¬ûJøùa:gÎE=JÛ¸®s™:Ìå[Zá?BÄ7HcJÆ1’ÀÈ;Ñ5RgŠk@7®FçѱB¶=}€"Ä­—Þ?B»Ð™´6Ž
Àçzƒ¶kÏ*Vʰڽ©ú­jS+
o?o5ßÎEß'«f–y>Dë]Ì£“DG2R×Ç?§HòKk†EÝŒ7šd$Ô³î´ÇöÊÝ‚«Ü´ŒŸÈ¹~F|á(Û¯/{=JTðæ>Ì7¾B=M9+öÊè{­îí¢ÃU)*f¸TÌ,=I=}Fmâ{kWDºf
">DJ±6ì¿0<påÌVÌË+/O³ÜàÆg4Òš[eå¾…¢H²MR—@¦º‘Vå–p¾~€ºµCºF—dËgl8æ=n!+1²8·d“0{5ºkû;æ‚Q«?H‘‰ž™Ä´P¯Ê7¬9Xp¦Ê·eí$TµßÞ>?êkŠ:
‹UÝåRä4Í’»ßñ´´ñðDY8ÜeôcŸkOâÅNTÌEÒka²0âœ5íãJ’X§Ç°ò_{n=n=nBeNÿp÷>>@2NÄ@Òò¡nƒÌ­?>kR222K=n<­Í-±]sb§yîÊz::::::::::::
> :::::::::Œªªªªªªªªª¬z:::::::::::?–¶V¢à»nJ›:d35GÒ yZ­´€Ÿ¯{’ž
òذæb’~@jkR2K/=M³æ_·XQ¼Ò§Èò“}Î#/?¬zV÷¸°e^›k6¶ã=Iª=J:–ª
ªªªª¬`kÇä‡B“Ƈî$Jå„DúDRJÜ2jjjN*skñ²ï+ÅSС­ôÀˆ%‰ŠÄ•kÿï~¢üù=IæÞ´-jcJó¸[åS?6ðQ17qD';GžQ%ò•æÕMJ7³G–7~vqµ¹è±öf÷kb6¥=J¡¡_À
> ­•Ä
±^¬49¾ðïŒÏ¸Þ8J¤T¸1—×þ¾>–‹Í—z‡*5`z…>~~âÉYï=n—zujåkŒVJå†N>=MyEH’aíöi½°?–=}ݍroÛ‰!9)*»kÑè_̴ê%kkóµõ5±hK~¤ÇȞ0þ
Òíö?=nBw_LJra£ó=}·ÿ^¾HxGãšûáÈéÔÒÏ?qpFR®BBÉAÅI¾ÊÀtF’"‡òÊÁ-˜Ìê¬^{|¬::‘^w¿Ãx&9O{ê5Ê£
kÊ7Jß쨇z‘˜«‰Õ‡©i??Wÿ=Mÿ1…©tkØ[)*(È
Þ:£;rfw„Êm•¢>D‹„‰So~¥'É"QÿoŸG´*JL_Ƹ$Ô·j{€+/Pºp÷x̺Z#Æ™¼5ŒQŽ;CHžE8’ÙÈÈ‘ùS»}n¬×ûþ¬þ­vefŽÊ,¾~ÊJJøq;™Â&¿nðöËo’,3kqdùo
> {E=nD[ÞdÌÖʾ=n=n=n:¬3k¢K
L†Íkî2g°[ÛÚ[̪kŽ=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nBÊJJJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nC
> J˜LLñ’¡=nšRfVnx³ެ²#k¯€%TQUÃ»Dqb ±lÌàkR2dZâc[XäôøXT¹”6f¢
Šft­~=nFù9=}#·¬5ë9¡˜›X£ï0ò22222T!ß·áDkvÐ}™ûæE%Êû=nÊJJJμ`PÁ
> fª,9Y=}¸\’ê­¸l#RÀ¼a6þԷ̵Q³ñ]ø4Uó¦S¸yÞZ¢ˆ¦‡48Eø_TµoP}q™Ì7UÊ ½¾Å_2e×âÀ³Mš=}9
™=nﲦ™ùI¯=MöíÛ{‡™•[{ÃË>“ÆäJÆH[€ub¸rce?
> ½CN¶`ü+#/{DÜ=Mãk|^¬„Yˆ2VrEÒÔAÈ-Ô>x$ÊÄko7£k Þ7jkš:Œì;Ü8ªnª€¼7¹^E
§§ÓæJübœ8Æ[7À³Ko” -´MšUžFÇÓ‹»ÈnT¸5ò1ûo¥;ÅÍ÷1`b'7
kØcš}IK1=n@rêDi?{ü̾¬2k¾ºß²k³<o(—¡j–¬õ°­Œ9/{Ü´J®=nBK<ÜàšÔ¸6ù³ïΗâk݆Fì5[¬­Lý-­ßžaé@$ÒØú=J$W`2ý­HúÂ]2=@›ö’Jš(Œ8‡Êûø
7µ§†—0Wfˆ´ÍZi®??üSjJÑ^JN&ôÒ+o37“O1]sÄmË?G8‹Qp¯?=J=MÛq=}XÄ[å/{öÌË~k>—/ðÒdÊ—qÔUo++/ˆÍÃ=J??7
0ÊRO=nbt¶ðäÌXë#Jûo
t,,,2k=nÊÂ=Mžü0ZƒiNHî:`2íEfô7:::::::t,,,,,,,,,,,,,,,6z:::::::::::::::::t,,,,,8¦ˆ?â¡NH>ÛäS5N=n;ë*…d®1î/Úû?Càî¢ýÄUÔQ3r6þÈ
+kea‘ù‘­ý*^*/+ë=nÊÕ=@^ãð¬8†Œ÷]ë9<¡œÒ°@lÖ>ÌÞjjjjjkqòD’6øe*¬CC÷Ç]âœH²^jjjjkù´ïñ°‹Yd2ffpT†uÝhíb/nÛß¢8šÆ1ÔM˷ˎeÈ”TS^w
ÄQp—šÎI_fXíö=Iåx&ÿoY´7§4h‰Ì7B5¯£¢‰^G=Já@+=n`‹Û­bÑÀC+=Mö`8o¤Nñ²¹é±©“Ïk=MŒÐ÷K6ûàÔcóç÷ʪ–ánAö=Mà²J_/ªk^¬“?|W=M¼Mj:tURÃĝò<²
> ÿG¢^kÌ­¨øš%uc½%ÊÞðÛ?÷ï1€I†…„`M¬´ëðd#Ê›ÕpÅ?o˜G=J„RÙ A…kA‡zŒßñjc>D
ÀâaacÍ:œ’î-£³`Ôd>{=nJ|4»’]žl˜­V¬5âÔµÜpéô™Ì´Ü2j
kù³ªt™Æ¦ÿq*›·=IÌ8²=nG²e¬¬Ï¹í½NhRâݼ83žÁex*œ4SCôŸJרäÔ¹q4üBübÄi=nH*;;1Ä´¡¿,m{â/1ŬIöhé|Ôd*{†âÃ5Ú$$T·ÌŠ·­°²fÈüð!ØÍh+é
> ~F22ÌLGÜ5ð]::
«l¬´JJ±b^•kpÞ½Ã'?DªÊ¾,mlÍL–Gû</Ä2_,¯RÓkR22K*¾:ð䁰Z…´9‰5±˜HdDâ#¹^EÊJJJJJJJJJJJJJJJJJJJJJJJï+++++++++++=nÊJJJJJJ
> JJJJJJð‹C´¸¸¹HJFñmK´{o/r[ÅEJ퉷>=@“ïñŠ­ë
¦B`"E˜=Mä8Þ=nCóUD£JëÚä¡Å€·ÄÔdª*z>>~ÊJJJJJóùXOÛÛ¡*¬öŠŠxkž=n=n=n=nFBûF@]ï
QJ­í¼ƒPÁ]øQpüÒ»äZ‰ŠäèH´Túêw”Gk=nÊJå„F9-z=I´9P¿jDg:–*RíÛkɤúDHÒgBöŽw9Ÿt`¡ˆÒ[ž‹ÉM7ß>•´8|1J¬a^:†=n=}ÊDÊÓºšj•óMŽD5=MÔ3
P¬4îafú”¬{~íIèš’·­jÌÙªIwØ1!?=}³ý:izŸ‹x˜ü,à4UÐW›¹þ˜­Éß–ôc,¬â}=M’ü¬9Êí=IœÊÁï{¸rWP%°¼(+1h;ß5qU$Ô¸¯>jjjÎ:l6ϏµD¤T¶eàó(Y1
¬0“6ïo‡¼[(}ÙXRVª­Á?±ø5f†q_{êü‚žkýFÁÕ¡E®Cù±–±^j‰­®N`U¬5îùýœžkð·+ÍŠ­ê(=}ç~màkvkÖf±&t8F:)*Ï‘ÌÒÆv@H’\ìn–ô)*]ßk÷¢×[
> p¤b(²f»¥Çô3jjkRaíq¾f
kä´JÕǾQŠÒ°Ú½ÃÊú/=nÊǬ6ÆTÌTº”ðúÝäTô3jjjk=nÊ[¹¿»µ›k‹Ú÷íÝw†¡œ7ú::::::::::::::::::::::::Œªªªªªª¬z:::::::
> :::::::::::‹µío³´Îú·ÇîJë
}¸â±6ÍŠbÊððêð^_Íj,5J®Cäu1PÎJ\[‹ñö­~=n=n=n=n=n:r*¼’=nCÏø¦y­pÞ^*ûjJ¾=n=n=n:r,óÊ­ôñ
»a@I¨X­òÆ#\à
ÒÝò«Î^±rq³=IÊn™FöÀA*\â7„¢RÓ­rÅ)*NGrO+1Pcä^%º¢²ÜeZH=}k¬ÒW1¼4^ƒÊ­€¶åGz+"ÊÉÔ5+k=nc^k+أᖭkEq=n?»ÃoÞ¤®<ñ¬1^@x}‰=nAŠÊ¬˜»~žªL
> U±¡=I<­ØGm¬´È÷)*ä!Ô³î)*9#J=IÝò¡”r©ð¾~P±~;Mwkñ­J󆯭š=IªþFö ÉÊkGÎÄD
„§,2«ãBûò*­~=n=n=n=n:¬S0<Zð÷4ÌÈ{ƒs-‡íˆ’]ãÍ)*[ž
@–dbf´7:›Œ$CBi?qBÛÒ^¢>EqR½ì6­¬ÝqÂ}¯È¦zŽòöxøG­àA±âz*´ý¼9-"˜{‡8­V“ÖN±Ì8RÈLìZ=@Îz-³?FÞPþ„Ÿfô5›lP![II=}ó1¹RXL«J›kÄ3jk
> R`¸<Ÿ ­¼8¯>k|'“Ìùû~Bôþ£Ò×*kR2]¥ÙúT´k
`÷Ǻ”̲222J¾=}>yÇ#MHѪkíÝUŸQ¡kÔ,,,,,,,,,,,,,,,,,,3jjjjjjk¬3jjjjk22O=n’«‹,ì3Þ;‹,ñ^52@
:]J2C¬0Š«ÂJ2Cì0šª8w@z–òªÌQ­n<¬F=Jû0˜öjÔ=J¬÷Š˜ßÔ5ÊJJJJJÕB_0/-FGQ7Åó0²O+++/N»ÛÞã*:¢"ænà\ƒAAkACG‹4Ít–wòí)*Q›iì
> 4ºGä´óû»Ò?Dí²[*^â- a{‡»‹½õJèql­Ž=nBÅšåÐÒfãGHËø>z <'‹¢šd¶ì¿qhM9VJ¡¶L
f44Þ}zsk-š¬úmǐ¬-jDÇt5¡Ç:e²Qç=n{2R/åìz”bäèRV†B:ŽÁ>;
> ¾Êo"²e‹hQRÕ
˜â»'=JÔQBU?)*ã?¨õI¾GÂw›f1/=n=M¯õ†úš‹9¶¸`“{â—Z8‚w=MÈ=J¬âÅFE)*ê"å"kÝbÊÜ3jjk222TjL´62žœ™ÌÒq54TÏÒ\¦k®BB†ùí›™x2M
> èÃȐßíвcO*èìú¡4ÍQ]Zú`R^µ;©¡`=M‘Jü=JŽMl,5¡/¸8¶µk Ý[
RÌäÇâkùPÚ™rf»Ãõ:*Ø+~•fí32¸iîMÿ1ÅÓN½ÿøfz…`ÈG1^?[±”*JÇt3Cÿ*‹öÊå
2ÕÒ=nªVÊѳ%’hÔµßË̪zƒ=nÊJÍê–ÔS€Ÿk¶ðº”/4{|ª¬::k^­–`?"Áˆ×¹µéŽHÖ{\@0Zzkž=n=n=n=n=n<ªªªªªªªªªªªªªªªªªªªª­5k/êJA|2ø¬]Ê­JkG2^Þ:
Ž@ª=@úeúzèFúy¤Už;kG!~=}=I¦:jÁ§ze`¬eÒG!~-_§:q¦2Ú«=I’¬e+1vZètXàáØ1•B=@4’Î@jk|’”zz,c¸•ÕK0ª*¬z:::::#7ŠöºjŽ£x‘Fùe¼­n=n=n
=n=nB›[ÃÈ+1»^ÜŒ‡yµ­t8CNbÑ@n¥â…£~ÍW[‹¿Ê¢ã/n¹“Ñ{$ÊڝÙ~A–·¡><‚46É?YÙ>B»É®=MÛ2V¦X«zNG=JCÖÈ’Z[º’”­Í/`q!™ü
ÞA‡šû·
ÓJ–k2Vûãk,òʬꀲ_’>¬NÊþC_ã¹Jª=J+ú3–˜¡k÷0ÄZzkÃOï0·”5€Ç:8¯ñÌ8ÂI¡Ì´=IÜî„Òà]v?)*»k˜øiyf,8è÷Ÿ–TT"û¢¬”úšŠÙæ×ßT¹Íµvd­Å3xïf
> ÎCø
ÆÆÅÁ&ʹ—ÿÊû=nÊJJJJ®=n?¥-Årcí¶|}àQŸ{讂{?K/uz,­Qn9=nF½l‚–£?qf·ößk:øæQ€Re=JÃÎ,3h—k=I°½äºIŽÌç-2cez=@Aÿë1ÆNB’ÝĞØ¸tÍ
> ¯ïù››cÆŸNÊ{QÃ#=n@•_áEë/þ{=nÊJÓ
Þû’+À—¿pªRO+=nÊÍêT¶«én@-ªkÝp{tTz:l,2Xk¯êA:#ï87'ú¤j0ªD*-Š:t,,,,,,,,,,,,,,,,,,,,,,,,,,,8ML4dtkˆ
ˆTªúÊÙ§îÊÑ©ÐJ÷ò4!'žj=n¡êskg«íÌ2«×˜#JÈÜ0Šoˆ²Q[ú€,/"®:Fxå®:‡¦3jäe%ú-²F§òCÖµÎ5¬ûqNØ+·Q­þí=JÃ@ÙeÔ8Î<¬8²T€ÎªYÄ*—
o*žkŽ<ªªªª¬`@z†žßæ‡ùû/ðÚ}l5JJJJJ=MðÃ±Z‘ºú­øšÊ›Báƒea¼8Qò&‹X›[ëÙˆ«~sVn‹ÞëÝ—1e–
Ö›“zŒ²”]a¬Ìjž¬k“Ü^g:ƒÜg¸û=@aÎE`œ§Çh
’Qf™d¤Ê±q—þ1¹>C¡Ž£F§GÌ2N´8?^kPÎ>9hrSµÁ`GÛæ#®FÆ::†’î@“*>:xÒVH,6uô52ù=}r^•‚bƒ´ÝÇÏL[¤2ŠÍä5­ìúuÆ-9Ì4kÓROØWdRÙmÜæñ—?mD™=}
> Ä3!¹a'ށ™•V°çÏ0â»!¸Rf&GÃ*×z§6‰
ÒZë9ç›ØRcëæ~Ùf†ªý~ù³V¿¸EIk±î³0Ï1rRO+=nÊ®=n=n:­cÌ<`Õ?p;fð(úÌd>~:¬ÎJÓ2]-«=n‚kë^Paže?{ö
›k;‹X=n®Gâ–‚öD$Ñ›’göUõ+`…{†'Ö”@8Òfl=MMó›NTÌmq>@{|ªª¬5ªýòJá^c=nA7*’¬“=nʾ=n?¥ÕkäÒígä«Þ@’×,7ÄÍÔTô2jk@¬ûñNõE–f,9y5¬ŽHM½
íÓ+++++++++++++++++++++++++++++1¸Ÿ0xÒ]žzޝ$Êöù†z~÷èà¬eRMè=@(2G<¬¥ýß&:=nЫrVrØIä5³ž&:‚f½Ì5àmà/í³Ëj^@?kŠ`k–Á×|1
>  se•Ì3:캞kªømÇÍz¤[îòÅw*Jä,2Q¼4¼•–ñw,37þ½ÙÙ=n@jjjjjkgÖ@=M&ÊÐqr˜wEëéä7:t,,,2P¯¾H
YÞ5ÈŠì¶ù+1Eö‚@CP £Çí´8\ÆPîđܸ©ìÒí;V÷º<ûº
’D0¾¬»¼4>9R^=n·az‚b=}ò{z=M˜ŠQÄÒÕé¯I´6¯hõ«kÅÍ¿èókˆ=M#kV¾^µCynD1‘˜Ìñd2OÞo_úÊ­E8è|:ŒŒŸPë­Ç-œ,5åôl4¼¬:t3“Î<†—=n±œk•ÎCâ
4×,3ö¬ØŸÊ8^©Ì3˜­úëÍã{$>;µ=@—£Êà=n<GÞRØðHA<aQo0"Êf‘ºk=Jw†Yqû^=@:z«ËÂÉ|­¬‘Ž«Øe!£èPÿpY‹ÁM1%
´<é8$=@»HÈABª3{‡×š òVª¬z:
> l,2k¸L: ¼a?p¢£ßhJ­Ê¯?|:~®?K/N¶gÏØDTf#[æÞ%´MTÎ?+k
f1GjÙ??¨¡»ç49UŽ=n<ª¬5ª_ãª-Çè­Ì5_«Íj¬þ¬zt,,4ãÊ{ö pîÌXð0ÓR`œ¡k
>>k@¬3k±!óĆy­ü¸`nÖ’’¬ò2222222222222222222222O+++++++1øç&ßk­›~­Qb~C¼sÿ=nJJJ{ª:V®=}’WŇªkŠ–:†dÕ¬÷¡-mÿ/=IŽD[=M—ñ:
­pæ‰~D`tüú—8“^•Ÿk=I8B`µÒ¾Eʾ:¬Xñn;ñyW£ºu„DRJÜ,,,,,6OFÖCÇõ¼-MÍÃ]ãkÌ,,,,4ç·Ïø^,9P–~â!!¢œ…AA7ô8£z=JDŒíª#â)*¹ÔÒŽXXÛqf±zü¨éÜ
7Fu·½o~ªo;‹1V‰”hF?p–ÇöôV:ž_ë=J²¦ú‚‰-§4´ÆkRO=n@ߐ­~ŽšÇ«™Ën}Þs•=J¬6|+(å&z&
†go®CÁÁáSaó1[>t247žRR¡k22WŠ=n?åj÷…JA
¬Î¼«rV0Ç:?0"›Õº+ô£>HÁ‘41ú'46›‰³ï/ñV<*pÄ>G´D%–Ì䛈s9nH€,¸RúT¹Ë£ÖRÙ¤´ðeBsu¡W_rfû¢ö
·°€%¬Ò͎·&E—h€âÂÍÄ\=J_­°Ç+à{G"†ŠäQ
Ìç@æerY¦út,3k2TDí^¬k8@2K1PTEK÷^™lÔW°Åbô'F:˜l´Ó2J®?K0}nNG"?qÈÀ¼4K;ÉnGgÆ(EIQDkøã½lUùz:p•„37Q2V=@«Úk”kRO+*ºa^­aŒL˜4´
¡¼í¢È’¶ºò=I²k¢ŒóÐRdDèÔTòLúkR`­7XJ"p€(Ü9u9­´7jö)*özžJJJJJJJJJJJJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nI^pÅÊ÷꺗/5•ËklD
§:pˆ2*Djôq5kcdü*‘(z-9I&ʎþŸk/Ç7„+‹!Ê´RLòRNr=J¬ìŒ¬¿š•kN*kŠ%hq*kˈz­þŽ—·Þú*kž=n:w¤ÊÕ²?¦2C€—±=nAjjjjjk=nªV:†^·/ðÚ}l5
JJJJJí=}´¹6öüIœ9W!’efñ媕nÿ¸Òc›b%I‘ê4EA«Ó?CBGª«ÝgÛGÅ&ÊÝMõS9eRXQÀi‹0Öîp(^£??Ô4s=}NHKÙ_qM=J¼=}ñ;<óï«Jô£®G+=@ûÛ:x{åwH
²Ïâ˜YûkKê$jjjk*€ô²D]k!Lcì_÷âïeÁ=nH¥«0²Ì¬÷džkN|4º¬Þ¬`jjÎ=n<Dyn@+×þ­ÔV=nðNVV²ak9¶oE=MM¨fkk¾HAEk_œ{f’¾Hà3ã¦eúÙ¼8†ÜÄ-8œa
> Óäk
ZHÞÌäÛª¡Yfz£gÅ)*žyÿ~¥"Åjþ?‹™'_7_1=Jkk=Jyi£N휇áo{¶@åUæÑw§É0ûŒ¶y[èòEJ¨ƒ*M??­E4·ÚÁ*R=@Ògr‘øSëkân*—=nÊJ=MñÚè]…ÊÌïu-
> æYh¯~¤[îÝåÅê=Mñ¬´ð‘³XñðáFÿq¦=}3Í1´72{zl4º¬2k
¯Ûöš=MŠÔ¸ŒŸ=n”47Z=MXXLib$ÊaO%‰Y1Bö¢Ô´Ú‘g§z†=n=}rPºt+J5O0Yïnøc¹o{ö&•ù¾0®B
dqæz•F^]sáNDAÁFÖAû0»opù<­Ê*ûÌ´„2ÞA´CQ_EsFy*­û­Ý͏d}ÇâJÔjjjkR222222222222222222222222222222h£öD7çz?÷JÍÂs`:zÜàk|í…=I^*Fg437
PáG:xtDzxk‘n<C„·¤ÊÈØ!¬\8M~:ƒöJB£JÓµªe¬°Mé8rdšçÁXP·Ž‘<z¥Âv=nb€"E˜=Mä8Î<¬:o½àòTGÃÙ\¬÷’D£ÊÜ,,,,,4gŠÝé*aRTB7óÊ=J=I0²O+++=n
> –­¹C¹–-MfœGªkê‚/[ü¤a
kë`T˜û©2V´’=MÔgV8+ƒi³ký^wÈQp—šÏ?‚Æeýäaš4ÌÖÄp––œRVŽ·(¢”3•µi4‰›kÍ›x™];…\¢=IÝÒdJ³J•ðÄ>q]ͼ-—Q
RYHOår\È’d-«@2MÌ´Ä/=nMŒ¬W훨²C±dkR22cÛb‹Y³ÄiÔfüñ:=Jk:‚GdJ“„>,kC9n6¯-JÞ=}w˜V=@hyMwkÎ6x‘”¤Rh¹/¸KÇøLÝ€±Ä´=M–+¯¸¿ÄÜß­ï
> ¹ølÒÁ-=I7ßRg¦SÑ=}
kïµ&…Jlœ=I¦z¤gºfDª“oŸ=M)*Éþ­óé@O?{ŒvŠo~»H/ùúŽ=n«k«±ãi[%?@ò‰BNƒFp\¢X—HE>AívbÞþGë¿åo?ñbžy8“?
> Gb†‚ðçgrÑÚVìþjþk•*‡Ê=n>ÃãÅrf††cI–Ô-4—ïéNBän=JósËÐ|bJíåä6¥7àÒÊ=J
¬4´¼¬ÒJÊ=JiN¨Ï~š^"rfJêþÂÒ•µk¦u®½çíIÔ6ê{}rO+/I^›¹
=}±ÌÍÇ"ñerÃR¶öõÕ×/x@j`kÀqõ„Ê`\]Žã¸29ºÇbJÝHjú=nD6mªÒQ1®~e:6I>qïŒÆó„2•+4U*^*ú*F,3jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
jkéœ6#ʬúŸû=n@7‡Án6­Rk}G–gz=n¡ØN]œo(ÒQåºy¡zrŠÊqÔ3óâ2CV|0m„9œ3Ž8»„]Ÿk%_¶Ñux¡NGê*R42O+=n„4¼DWðºog‰5£›RX*,ªÎ<ªªªªª­as˜õ
> BöQªjŽ‹Ñ[cÆ¢¾DJJJJJ±:û‘ŽHUÞGMöb—‡Û¡NFٞb0º!Ýå±­¬ñôN^ûî=Io{
¡Ÿx;akGô8?RcÛpôž¢å¼ÍO·ò>;?Þ@/®”S/®j#‰jZrgÅk7¦»
> †dJÿâñ– ±=n1¡<œHn’¬×K÷dD®E\Œjög0ך
î>@úÒÒWkCc“¬SíÔ/ÈK-Z¬¼ìóq²•ö˜Ò½1M7Ýî;B:ĝrRJdºx‹÷=n¬‡Ê8Q¼3[ôg¬gò+Þ—÷Qÿ1~=}ªj¿Ê‚n­f
¤b˜:F¯Ø*´M¬9ˆ6ŠÉ5PH˜WJ=}ño?ö_{šýðy<:¤ºƒÌ`ö™­µ=}ÖäJøQH¨—S1Ýe+jRظû_°L·JeJ†øM¥?HèZ"¯•{‚
¾ç+÷äOÊT¹TkÁ1=} Û©=I¬3í#>?‘Šú«
Ó¿qUmwª”ø¯0ûãöš“çþ€½,¥µ~_ÐaAÒn¤bƒÞ0ëÌçBÏõn–¢J­¯´kž?¨òf&…V„6ZøWšû1žâ’››þ·Ýê4¸`ɯg&{GÇõÿ;àHˆ'ý¹Ëkâß?/=n>H™”eîð=nÔ¸+í¬
> 9qÛ֍x¶˜ŽC·jfrÿ=nÒÒX•¡^­1DVÔ¶¶½tž®@¹5×å~uM•p«k§º‹PK×ûäɼÍÇøY›ánl4åž<ºƒ+>n¡
XÇËÑ@:´$/+++++++++++++++++++++++++++++++++=n
> ÊJJÆú|ÜÇùÔ4»…ËkF¡"J€Ægò=nDjç£Jº0¿Ô2*{+/êAÿ/ïz?Ì37C¹MkgÄDʵ=n‡ÕFº
Ü`ðSÊ=nAjk=n«ä0]/¶M¹*¬ö”=M˜e¾Ajjjjjk8š’ÜjGz™Á•h‘
kÍ„DS̬5JJJJJøƒƒ=}uÈ=J,9XƒÑðâ°š·ó:œ÷¶µ4íHDÙŒ)*1hA3PW#N]ÃÔd»àPðð¢…ò¥ºÜÇزgo>jk÷·ëq¶¸Ç¢âš?Ig²¬v^ÃO—H1«kÄ*N›k͐¢ÊþŒ]£ªK=n
Xʤ’¬6[IUòkI‘¢`ñ¹›Î:…eŸVèÍ"j*hPÀ¾E[#Ž•äG47„¥wM´ä«rLºk”2òb“¬Rk=n<RÞ:¬Ðbøa)*´Ì=nš·œZ¥º’*ER22?’D±172?>À;]^šI=nFë³ÙÞF
f$JÀ¶ÇØÓ1ѱ&`Q{RbP&|­Pâá6mqGS1áQð͏?ᔓ°ýŒ­±Û«YQ­ýî=I¢_ü°òbe˜lƒ>£ÞdüÒïz6™’IÔTŠÒU³cXtͰ@·îRdœÀýHF2kN@˜s’´â·Ù—¹¬¬û
> ÚÞ¬ak5ùç1GÊP×0î’¨R9d>F·l8Tͧz¤B¡’_kü’¸²c›Bj
­?1-ÏÔ`²b`Æ;z~ÊÝ3›8š``H´ÍMØÆkÌeT£‡ÍΓ"–>Á=I`PPò?Ce:!DŠ{?;óKáD?Eq±-„o˜=@
*ʾ>¼€ñã¼ÍÀsÇQkòLRª¬z?':uzƒ++1™)*%­§9û1úÒÌ,,,,,,,,,,,,,,,,,,3jjjjjjjjjjjjjjjjk:¬¯ä=I÷0ç`¬Îž!ÊzLì4^jÔn*xÆ•Ž*•¸X9~@“pù4k
8@sR»¾Re«»0æô7z::oÊÕÆCÕ¸%8’T-Î@•©Y>D**Ê:t,,,,2kqòD’6øf,2–Žå^°ù+êJû=nÊJJJJðìÝ}™e^˜­÷¥ÇY=I»æD­½?·\aM+b^˜zx5*Žš¼¥Ø7?HÝj’*
> 4+o›
°·‹=J4ÍÉÝøƒÃK;RÓjjkÆñ²¶Ü€¬h´¹=}A¹¬õ¦¦ð=Mÿ;í½½±ç*Þ¸//kkŠk•èRPëï/®^¸K0·ï¸™ï=n«%ßé=nE[=J*+?ÌÞö9>6ë-Z«Ä/J|2Î4kCzpk
ó-XåÉ´2ô™ž4¡n9?k=nâ:„7·²?<²“=n¢=@éŽH•Ä…UÄ¡*'z‡ª“E­&ÊJ—_ä’*)*%z£±§k°Í9­¹6l¾?%†®=nB
bËÒk´Í³Ô=MrfK"Vz*¹ÄÒîÅ»í
> »ÙªÎ~î=JBÊíH$ˆO~-“·=J­Þ`ß>*ÈŠf?nŽÍ–Éô
R^ì-z¡{…Ûÿ†:žqX¾žkâàÒR@\Ç1=nBò=M­<_å>­Ì,­ßÑn=n=n:­½I²‹W1ð1o{‡Ô8Æ@GÆu„
1®”=Mû1ãîqø•p®ª1ù{ˆ*±]³fxô·Å247*+=n¼*Ü’JïÒ’FñÌÒó"Áå”’k¸ô,3jkRTúEä5ÊJJ¹)*š‘Ë$Lè¯jjjjjjjjkR222222222222222222222222222f_
û/5¢ÊÍʼn"kש/5r=n;Ù=n?Œãʘ¡^ª/kÿ84srN1³kí¯¸DJƒz–¬z:k^¬_Ì6%ìnl)*ò¬÷¶1›ö0²22222JÄ@
kÀ¡sΤa¨òXð_­w"½ãkž=n=n=n=n:r
,ô9iCC¨+Ãu2fñçÚéæÂ!ÝÉUpÞÒÅ:#NïQ+ëÒ¸@=n]P@Ò/1ÊÌÏ1a’5í$I~šê=J[J)*~Hòo::::kRfèúìÛî笲DüÒ%M÷Žš`Vˆ´UQoJ`ôÌÐ\0×M%ÿ;}CÔ2
> K÷çúeì0Ë=n“×2k/÷D¼:]Ù<*îcæ¢ÊûÂô0ǹ@z‰ì
TTÑa,¬6¼á´4'Ðk¬Ò»¶îo°W±š~?ðPM|Ìì‚øø45…xîJ|/J|2WäJºÒM¬ÒC¸bÁ*5Åí—ºmw§z¤ø/·yò=nH
> pM9Ëkq=I ¤¾H¹åD{}P*gzeCä-|­Œ™>¤<­õîâódG_{¶X ™ös#ÌÖý¿ÀÊîif—ÜÒíáîëz
|´|2’\rB=@=I]ó~P¯´¥Þ–p0c˜ÖLp¸¥ÌÐf•‡ÏfâRdó
> o20ŠŸI^Câþ'zuXÕ_4¸Â­ªç§Wkÿ=}Õl¨R_åjkÀL
kCùÊÔfsžÜAéí¼2°A÷J/½énIs¬ëÝ3*ŠÿøhM÷o ýÚ]ÅÙ%käp]ö¹|Òë"ÅáLZ `qê1÷/f™=@q=}
üú‚*0²O++=nÊJ¾?œ-wü5̲¬8ðA¹™p¾Il̲22222222222222222222222222222222222b•¬ÎJÓE¬¸—ÈRR´=J­\c’¬ãx—X$J±-N°™]ä8"š»oÚÝöÊ=nÊJµkE
µDJÕ•^eªEÊÒ·ü5Â4=Jú­z*>`kR2222K/‰Mƒjx꘬¬ar˜wâ^–­‡ºt,,,,4sMŒ“÷=nHxUF‘ÛCùÄ8Qy€ž&ùRc„I]ì3Nû£ÔgfP4fb=nµ¡ˆ2dþ~ʾB‡°¢F×{a
lýý©nqß=}Ýp4T22K/†’J•ßøMö–¤J=MõÁ]iSÛ­QEPú“FïÄ?®>¾oPãRÊòî8î¹Ä*íÁÄà=I‡h’\Á2;Èa5ß4Í=}:ä8-Ëû=nBb<g—/rAÒ"Ê´-ЬwGS=n±b–=nA–
> Fkk›³_x//åñ~6ÖšÚ~?v¦´4Àº_+-íî|Ìpˆ©_0ªœ¥±ç/ªº—Kkab
«kg=M­t8“=M²³ù—ˆÉ=I´ÒÂïöB•}‰^HÖΐº›#Ê*t(²TôŸDü9¡Ü²•3d4ÌÝ¡~ª™Ð`=I
6Kò+ˆ(Kέõ·î=M5øá¦_'?pž>~öº’’Ç?qE/é~G@àuQÿLäe=@Ì6•8ôëwz¡ñEJ¸°y^~°Á1O0]ŠD)*>ŽÛ&ìÒ[‚‘[ÿ^ž¢gÒcÂJ`ýÃæº
mf7D=@ú ¡xÊo;
> †_{’+û0ÞAÞ@“ô]bªÏ0=}
¶›´¹ðÅT¹XƒÎÈvøOøfcJ5¬¦þúk=JÚ{ÂR¢ãÒØ¼W÷k=J©#FßU„7}qöÔ¹6_økÍ‹FŸkª3Î@kR22O+=nÒÌÒÕáj™=nA{onLgHí—=M†£
Z'lU=Iz::::::::::::::::::::::::::::::::::::œ»Ì4º¬ÏÒR…Ô4°AG+h²`¹=n‡ЮG{‹=M²¢…Ù\­~=n=n:ª™‹Ì4ãö³à!*:‘ÄsæÈ0e¾DqED˜¡Qœ¬22222K0pqs
Î…¨Œ^!JåM6¡Gó/ú:::::›{sL#J[‚vŽ^+1f¹Ð¿Cê›RS><*CKF,Òš"¢ôë£Êot3kRKl9AW…rÄ'?qÓ«¨’’aožÒ2K+0b¬¥Ü0j¬*Ê*Jï]Sø0
=IZÒšE·¾:/¾@Çê„4ºpº:”óµp6÷zž+>÷dâ>Cå--à““ýr[©‘ÄuÑQ5kø&=nÍ)*wØ)*³ÎBh,ù]N™Òû~}J=Jû=n¡™o/†ñÞ£¨+=n<k×zZ0¸Þ¬1qIn<O
‡ñç
/åÄRMbfúeë¥Ê»[ç2"Êûâ¬:‡â¸žÌÓ´ºhZ¢Þ¬Ô_ía`d,bâIÿo¡ô“Ü©ñTÍï›æk)*´4ó‘~H!“;ÿo‘hJž­Ù4\á×:{ðÚ¼§­k틼f¦ž'?n7´´ì¡ÁÀ¸tÌJ—æ¦
> zž=nÝ­Í7±¦ä7¶˜©ŽH½mŒ’E{€•3`t7jkŠ:uÂáUªJRb[G½Eëžxò£G¿qÃ`+›¬qMÔ6Ä‹
/1†‡ÐlzF:Ÿ]I5ð#©nDã씞Œçº_!ÊËëì'‰^¹fkiŽì݁EGs
> 'ú•=nšt¡V“•xß'ÿ1ͱ·×,¬´kA=Mزhà†ñsòdè4Ͷ4jk7út3jjkR2Oo?oGä-žÎAjjk
-˜sò+'¾Þªªªªªªªªªªªªªªªªªªªªªªªªªªªªª¬z::::::™o=nG”
£=n+5`Ê£Êû␬5³O0ו…*JÜ,,2k@rú¦zfÊÁexO0p‘rœê)*MÜ̃*8øÇ&ù/0ò22222K/‰MƒèÎ0RB_½k#q­z*>:t,,,,2P¯¾FBøûŽmU2è’fc‘¼“/…
Ø4´çöªò
> ¼íªn‰9¯
LkVg,9?·•DDú*F,´ä,3kRO+1½²†~·&ìñ!ÔaêhÎW=J©éä9ko::l6O=@8€t5JÕÃå„9[êÛ]k1nDñWJf:¬5L
=M=J¬höý›HÒM“àæ8Òd…£oºyn<ªª
> ­aíE&Þ$®Bå+±¡Ú„¤>Ce1Fx1]õy\­ä6@<ró[ƒ¬‡ÂL©4ç3kq
8?=M¥¤­¼y)*H»àΕ¹MËRbÐv=n¯=MÒC±ó~B#Ǥ®:‚•†Ï=nQ”2WeËk=neÉ(rJÔÍÞ
> HÁ"Ñ´!'4­Ìm›öx¿k{â€K',4iÞŸEJ
åfÈuRÖÈV{·J“Wíá„RZîbÝ+]áQR"º­ø˜Â‘Ȏ^§©o{ƤÅ{†üiæºå°ë~™-SÁî­ûí‹6¾/]ª­â—À[j’4´åB,7*kŠ:‚=n
-jƒk÷fª’7ô9iA³;áMG=MöÔ¶5=nV<óõ2$2[¸AôýK’ަ7§:•@2w]M‹Jâ&:‘³±æqSš“·ú6n°­èòeÜã»=}Q‚¡l­þðBwaÕs$RÙ|;Ì7ºz;ÃËkåæÃùeâ
¼Ô]k—†úrkR22Oo?k+>Þo3ågzu¢„5ÊJJ!e/¿°»)*Ã4UþjjjjjjjjjjjjjjjjkR2222222222222222222f&6÷£óRá“èÒg**>/J¾=n=n=n;ž¬3f:*׆l6¸Jb®‘¡h-
ªKYKýe[&ÍŠ­Š*>/=n<ªªªª¬:3Ë‘ŽCÁãÍIû/ÃBå½ãRXªªªªª¬Ù¥‚›Ê­ð8þA¼]üñ=nH•ƒPLx€£^ÒC-¨48è”{?
Gúo圭’[CxÑ??> ²a=n>@jkRO+1É—ô
> "F7?{­Gòa•kÞ±^;Ü´¾=n:zÇ‘gD¬2cÛš‘Þ”?q2šQU¯IÙÌ®|5ßJº:‡Ü»ä7nê·z‚f-
¬#ëk//u²kG2T‘K/I`›nJ=I1S޾ kƒÑ=n;6þØkþ::‘XDCé@PbM
> ~H QÜŠ@Œ““=JYnH¦âXÙj¢ü66oå0Él¬6˜ô3‹MÀ\¡®ÇE‡oT¸¸ô
¦²?vR×Jf–§;HŽáÇî—Ù>CfƤ­!}¢ÒÔs=Mï‡k=IKGÿ’zš µí¥g×ýñRI*tÒ=MÇïÂ@=@¯ù$9
> 1F™¥`G!œ5ÜK@ክê‹‚šÄt^j•xæ~z“©Åkó0×—Jâ2V,3+*ºûÔ8vpOÖÿøô?H–ÂÃ[<¡¢
½’«N+}Œ¸­²‹'t8Æaæ½³ñE›þZÉÔ´ØTjEa¼5l¯ìi>e&6't9Hƒv¸N
> ÔB€¡ÂâÃ÷ë1 Sêâúÿøþ©§:¥v‘
òÍMôê>žMnDJïs½-f¿n¬inIX¡TÌ:~”—=nʾ=n=n<´LJÄ2[¦®Ç:COGz†GVÿ/Åä5̲²kÁI¡-ãCèdÒØÞ=n=n=n=n=n=n<ªªªªªª
ªªªªªªªªªªªªªªªªªªªªªªª­óž]Cm­jx=M´ÒNڐ>ÿoƒ+=n<,2=nÈDJ0wʱhÞ’ö£=nC‡SãÇј­#kÕ„DSÊ+òJÜ,,,,,2kqòD’…Æ¢=n?;ãdš’0ßrO+++++0b¶
všZÁGz¢BèûÁ=}PrëM—??˜Gº^s´Jâꬸžâñ}j–Àí!n•¯§7yhRd²gÔU÷À]EäJoS‹=InGÚkeÊŽ«ížAkRO+0Bò%eª=IšÔf¸¢Õ²ú(²g66ãô¡2d~{=n>BaÉi~A
jjkñ´ì‘cÃË=Mÿ~œ1beN¬³ïo„Õû/¯>;¿=n‡kcò/=n³ù^E\•+/,¬7>?WF:?ûÊÇo;ä8÷@Ñ~Cw–Ÿ®G‚vj»ãsÿ1|,2š8>­¸’ð|5“=I!kõ9žØÔedºŽ—å&l6ÛK¸¶Ú¼©
> ž8ò®àƒsÕôÒr”AÅÖù2bH—ÙaîÊù)*|$JÚ8àɼ´Â« N¸`­Üm¿Ø^R•rfÃ=I
ÙÜî8ÎçдÌ[»c"†epÄâÊó¶:ÝU¦ï1ˆ5=n#EÆ^E½ï1ÓELQæ²Âóû«Ëûo–D¬=JJǺrŽ1b^
> ”­õð=MõfVJå·?Fz‹ïäõ²­¨Ç ˆø‹ø¸¿1Ñ'ÃH:1éñ[ñ±Ì´¶
N5’e’:£8kCm´6›ÂÁŒÈgÂS¶F,8‘*=@Ò 𡱐^ã1…MÛúq†Ÿ(¬­Ü›nšLðÉtUú¶}zv
> ®0< k
íö§ÉE3bµ!=nH,Ò­ØÉ>4kR22O>n3ÎBr%^­^<­…K­§º‡åÊä,3v¼_­¡:,9؍mB=@a´4Tò222222222222222222222222222222222222Rp¾ª3“G/;Œ’ÿ
>>z,’½‡:7+‘‹÷=n¡ªëÅÙ=n<+J±€æºr>RJ¾=n=n=n=n=n:¬F=Jû˜J=nCEöz‡¶•0­¬22222K1H]FòDjdÊöq’r¡6F?oÇVB0Â7žÆ†
2Ø3Ž¥È†u¸#áz¤b=}Å4g
Rý|ʘË0b²-ð«1ÃM5GrJ<8²aµ<…ä8"›Kê,zž¬2û=nʾ-Òk=Mòø=M@GD{ÖyZø3(é²gZ–„´J¬­+Îø,5ÊJJ|8¦pGÜ`ÕwÿqM˼Juk¼[õš´Õu‰Õ8æ¾5Mž*=J¬ØšÔk
> w
2YÄ·{kL~<Ok‹S«>@·=@2i=nEj&¹Õúʺ3Mkòñda=J­ÿíøOŠ­Ž=n>»ã±~F¼ð^ßííkq«øVIS­«•ŸTÍÕÝF=M=IâŽ-­QâBÄ_ÿ%ÉnFMz•¦ðºk@0g
> V;нíû?ØB=}[Ÿ”_z…Hìæ73«zš=J+½GS Œ²ü5=M3Нª)*¬ÔdeeÝå1ø“ÉÁµº§MCI
Dê-pª84U·û_¼dá«Ê/‡JD=n0RV!°-Ô9YC³»ü°ÚDÒôfMkžÁ*ÌMè¨h‹±
> ®àBpÄÛ'=J­ì‹LìnC:ft´¶ˆTR…¿ü^=}~H@UDO©ª’`ÞF˜Oð–Ê®CvžÏ{ }œ‹£Eý©žG§¼ö"#OPÅE¢O1Ö
ÉÞpxÐþž2]îåêC#·;û1·ˆK»¶&©Ò–Ç಺S+
+++=nÊ–­CI¥Jøºl3E®D唬þ5Ê®G¹9¥¹•²ð5¹´$o+++++++++++++++++++++++++++++++++++++0‹ñRVÿ溇Ø9D¥ì67½ägýå¬6=J¬\Q¶=MÓ~–K˜¯=@÷
ô5ʾ=n=n=n=n=n:ª­]SQV[êJ`Wf¡ˆ2^kR22222Jº/¾H¨YEåMû1Qï¡Ñz­½;·¦Ø:Å¿Ñk„=}%TbÅŒ–Ù,ï´F^n“¶:‡#ªiO?ø%áaÔ-¿1Žxà­tç:›=JÚrk
> »pºl5_“Úz ‹Ãr8kñMŽ—ÞÊä,8Xü±flkå¡?FÖgažéÙ=nGâcÝ]Kškü̯09ü
ÈŠ®AjjjjRTƒpäÍÅ:ðb¢Â„8’n1cØ7¢0'ʬD=n‰[ä´ÍÊzj·ü×-UãJi¿=nŽ
)*>8Ï¥úeÌ¢¾DŽírkŒ–‚k±¾;qä4xöØÚ:n|dQ1a˜Rg‚–Ö=n>DJ®By¿¶Y›*›ÞHv`¡¥„`1ì*?0ŠÌ-p¡!Ä7ÏLbH\°ž*ÊPJoHƒLº›^"I†‡r0Ý^7oLåŽaíüþG
»+¸¬Ä­hü…=}q‰·=nFç²üŠðuãšËiä8N»#„2*”­¦fðŸˆÒeå0fúŠ#ÄßR[\ã0»\ï¾Dg·û1V¼A=}ó0|ôöedÙ­q?qÁhK"±°ªÍв÷/­/1D”TÒ22=núßqe
·äûHÞ*qÄÌsiy1Ï»;­øqˆæl9kì6üÌäz‹Yµ?=}©Xé=I¼9Å3ežÙåCÒ¤7?qd,,,3{on‡L\¥úz,t7„ër]»ÃŸk;µœ7F’¸RXúƒ+1éz¡¢tpÜGg,´ú:::::::::
::::::::::::::::::::::::t,,,8’Ž<ae^Ÿ"Åÿ~”„*šNHŸ?lzžØJEÔkÔ3jkAr2O++=nJÍ7^Wø:MÎ&mm®Dª*ÊRJ¾=n=n=n=n=n=nCèzëÐÒbŽîdÖk÷fúŠ
> Áªkv#ÛQç¾Ææ/§?oÚ‚6¥Púv
éEÇÐíÆ9ï/Ûj~n›ŠI/?–=}躞öf€­–eÞkþ_k9˜º­óï]U–­=n=n=nEk³¦XDkke—­ÙNEJ¬-«1Œ­ñx=}<„™K#¯{ËPC=n·d›'ú
¤[òNŠKo‡0]¹8‹åwÊÚ`V–ªªªªªª­¹?®0¸”…÷~œñZJ`}ÊküÑî=n¶f£JÅ·îgòNîy¿ÌÝV¾DV1úÊ­Šû“H«Š%j¥´2N©âôkL€u=n‚n|ܼ4T‚?z¡,O¬"Êëä¢x
^´qj=Jp×­ý¸pòúkj¥íE˜kí[¦ùܓ͋ó0yž{9E±æÔ¶èûNèFfnöž2Tf_÷Ã#Æž`2bQ`=@÷O1>i®~0¼7G­å9ÔD^ÒØbЪûÿ1Y˜sv‘…kٍÝåÍ”­þ¶~—Q¼4󲎊
1FÂáiŽ?¶c1Ž›*VÊÝ7™NF³RcPïß­V¨Q›f,8Abçïø`y>;rMR~RzoD=JÔH/?srõÒ?CÛãÈ1æÊ£Ú»ñïðª’hÉ5A±¸[Þ’ÌÞ’ã$0Êÿ6‹·*VÊ=J¹:pD–}Þ
|o
ç±òJ#ýäÒL´,,ʬ3Îpy¤4+0Ö”70²K÷8>­Bï=}¥Ê=}˜ØÒ`™><¬úîŽvbúkûðÍ––>=@´4Tò22222222222222222222O++++++++++++++++1¶GP8”Lêý(m!?H¾y•
> O¶¼7ã)*R`•­¯¯?RTx„kRGzW++/ˆ ÜÝG ky溛¨’Xð_¬Ä:‡+++++++0œtEÊ@zœÃMå»#²
…Ô4r‚ùž=I÷€¨tͬ¢íÿZç|Eä0¼­ Üï4ز[Š=MN%v¢û1;ËÁÌ
> 8Ör%ÂòâRÖM
‰NH­ø¢ëj¯þl8dðÒX­ùðñ¤Ê=JÊæžw>Då8rÛéÿ1c=nDeÊæ|äQ“k‹›wÇޞ¡NGRcÛâ¨(W1·ä¯q0C#±ž'ð=IÜ7˺òS;2š=nE{z‹0›’58û/ú:
:::::y®–Ø9‹õJw4Ò\õ±¼Î¹S´8°ŒJÀ­ÞQ¹=nE!VW’QåAŽ•zrj¬6ŠÌ¬P«j+²­57‚/Ží[=Mw4´¨Dp÷þJàCõHRœK0ܸWk6*­zMº‹ÇjEòÊøv©¢·Ø
> ¿ñº??óµÅö:_RYH8PFîAåÅßkúÌã70‚¢‚?H b¾·ÓåÊÚìlTʰf­ó;ëÛýª4UàW*מk
öM-¼Íü¯çù‘nô=J9ëkÆž“Ëê=nFÐBs`t8=@ZZ”_k0mè²Z¼pª†
> ’dÊQðÁ¼ó6îÔ¶m?Škzt,2jjkc~Š!aë0º^ÇßNúk=J=}
ÅBf»+k{Æ÷÷?¤ÒÕðfygžkó=}@ê…¾ã1Q“iã n6¸#9~¢4,,Ì;?Ó0˜ŸÊÒ@z’=@Êú4kR2R=J
+ÞCၒ`D=n,­FSŒÈiïÉÓ{ˆü,,,,,,,,,,3jjjjjjjjjjjjjjjjjjjjjjjjjjjk÷µ«Ýppø=Jz£â†mڼ㼃‹d­íÒ?HÝ5wcÎF­j—oa2[öœB=IàfñNDAJ„-È=@µ
›+/XsfÍM£Çú‡»ß䣾Ajjjjjjjkc×@*Fúœó³¥ï‹Äˆ©_zkp=J½†n䨀ÊÖ·ÈBV=J­cK®å¸íÿ~¢¼=Mx›¬=n÷½äŠ˜ÌªM°ÒY6ÖZšúû1Â'è’dCÚjš#¯?öú
¡ìj`Ú¬D“þ­ØQkú7Êí<“krØkz’9q5RJ-rY²ë³0­÷¼apšÎ:ñc¸8“Ì:¤âfCIÍ(Òe:£&[1é¶©ò9ÔÒøaá;C•æ=M%’^íø©¡K!ÊÚl´ôjk9E·':‡ÎcÊ·´3k222
> 222K–·ô 2bŽìh³µzgÁ˜Ô]–ÝìjFdkÚñ­Ý™­€=MM^8¯/ðLMÝì5¡û( &zkÄi!Ek1;:
ì4eC5§ÎCeÞMÙ5†™—:=n"Ãi8,dån=}ŒŽ&s­1P¬ëlý˜ö(o0’’Ъ1J>~
ÊJJô¤T¹MFYgW10E´Tn†…ñžqž‘m=@¬´­=}¥“Ì8˜û²ó]x$®GâÔ–V˜…$|9gÖNÿ‡Ê°:/¾Gê/›krDY±|­ùÅÞ0Šòp¡ž?F\õNΡG°ò]Î<,552VFz„þ~cêDEÔ¶ö
> Ê­SkqbÇ(2Uãk±’‹ùë¬'g¸ò®ßÜuåÈmkbÊ
*×>?=M>꣭õV¨eߝáË_¨Éô8HÂs·V™ÀK¾T¸=n<ÌÌÿnAJˤ6óÞ<E’X=@Êú=n<ªªÌůomDý‹;R_ì=I´î`P›Fû‰
ƒ>—´Pðëw’Ê>@jkR222222222222222222222222222222222222K1Hi4O‘¢ð¶#Ô¸VHVìE\¹Ü­=@•­ªJÊÚ^>?Hú
û4Í@òp=MJ,žHÒ`/o~ç·»à+›ýÒkÜ3jjjjjjk
> =nªVÄ2bÐ@±!¢
CÎfà2PVN¼bs¶¨ì[Iä8Árðz=Mê=n?Ñhµ³’&ÒR39T~ÄD-x·þ®q½µÜ‡âô•—^kÈHõ¤·£ŸRg6–Žrd¼ùÌ9:Þßé~G»¢\8w1%kò^TUÕ8$Ú¬ø^z™=}
> úŸ[ ¬ŽJá§z£Â°¢³k¬MrŽòRÙpF‚×
k\ä3ÄkÙ~Hžú!–Jò<7­o1Ï­ñ1~DfG÷1¨1õìä1!úš?0ãÂÒ#f•Ñÿ=n§Öª–×Oáâ$Ê´¢—Ûëë=n(;)*-{jjjjjjjjj{
> þœR]¦:òf{ÞÔ¶¸0IŽò=IqJ¹Û8=}f8rMLö§:hêü\ók™ÚmîçØk
Zdng$Êÿוf×7>ÌÏ=nJJ¾:ª¬5±+¨²[Ãî_ïÿÊk=M‡ÎÈÉË?F¢}íÌUÒ˜g~EÛþûÁ…œ8ö[+ÌòÙ~1
> ¸!@ûçGt7[Äèâ?§:€RÞÛkç°·
çô6îñ=}3›Ùÿ1Â[ô–¡äÒZ'¸=@ꄆ‚†aEÒØs%D¢)*8prh/16»ó3ÓB…Òª²ÚjÎ~ü¬¼^»—!Ô¶ß×^M¬4¬:“=}–e=nGœ[»%xc²$
J$†F,6f—1Ÿ?ãþg:[|BÊO蝒z{א-=ny“NRh€qÃHâÆ–Ô´k/òRˆ¬ÎÊ|37kš:†=n=n<ªªª¬:_N*3QŠ:§YŠ¨ó/æ§¡x´Uç++++++++++++++++++++++++++
+++++++++++++0{t„•q7ñNDJeu2sÍE˜,Òõ/µó{ržh|¢HrgpiZÍˬt´ø’%ð=n?{z†žX*;Ϙ¬֗ޝ?ä,,,,,2N+Žúkï³RüiEèk1=nÙčÅAK•¢p(IäÒít0I
8öÇY¬ÂØü;ÚßãiN¤Ó{…ê1f7‡Ó=@!2e:Ž0Ú¼­ùÀšOJ-ÿ~œãîuïӝßXJ°<RólÕ|­Q*u˜þs"J†Ïí²û1p-ïC—2(&zœÒÕðR_ãJÞ™ÿ1m×l-ÛD˜­Äƒ]
>>CJJƒ¬H-]ã¾:ª­Ý3¸ž~óWöîJò“8“kÚx·HR¤T´Ürv*f­°–f…3õöJì
¾¸LcM\=}à‡ú¤WccÀÌÞ=n;Šjjjjjjjjjjjjjjjjjjjk/ê˜zpŒ
> ¦Íz\‰Â50Êñ貊z¢Ý›ò§lÒìDMwú
á§~?™Up!вeœ]{Ü1‘¢¦±Ç*­»=IfÇâJÈ!ºÎCwcžCÆ­2Z<ùY¾¥aÊ~¥Zë@Cä{¡_=ns³?ÐòcÇ]Ȭ÷Š¢ÌVH/0}
f,
> yž»ky6â“vaUèqû{j{=}’Q\2D)*~CB£c*oü'aíÚ,†=J“úfº¤‚Be†˜d²Ê$*RRÕ^…ç:"ù®©
iñÿ11)*ºŒåâE±“ÿ$ÉnIf†ÔJâÊ®4kJJÚ”5*¬jkR222ÌJ¬3o¥
Ç·jîø=I@“ÿkÊJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJÇٍå÷f7qh´·=JÃÝÜð®£ÅókÍÄFR81¹¹ì2ˆˆ1«ôÌ"6‡Àí[9U#ʝbD§/AºD8ŽÌÙ
MYˆFzI´k×°Ÿ?GTTz::?ù•/ãê8Òb0^Hë1>¼÷²CÈ&Öeˆñú˜?oícì=MC©÷ìó'ºˆ“"›uÇí°f‰“uZV¶¡–ã{†2hÀ9ë­)*”8þFýåzb7z£úahH‘š/ŸÙ~}ÜÏÙ
> =n#ÇÅy¡­ü6ž–Có`fmÓ0›^!<Þ·ƒËý¿¾HPSã›<ªbkB1}·ša'"Jø
ÇÌÔ:„ô30º…ck=n¼¬::::r“f:\âšRK++0ÚŒN«=@íÑ: RgvhXc(|¬ÂÖ5P]ëQ[ï~œ¡ª!‚
àº`9k¨ÝKJÞS0Ûm·f:¨’`-‹úÒÕ±‰4kRO++++++++=nJJJJJ¬jʶÚQÿ,Æ¡i=n<B1=n<“Ìó*JðvŽv^=I;­1y²¾ý0j­É<íB+ð¡?HˆV¸7"%új”َGÊ‹aëo
•@Ïæ#ʁþŽßÌ8ø˜ve9=}Ók¶¹ô•…/kÇ„µ=J­ÌR‚íćyJ­‘Œê>ê*E|6I²X=M’R3¡^EñC_ó1†{¸k1upz­ÁC>¢Âvœ5F9;­›zé3`q9¿4ÒöfG´51JÅjÞA´aô'Òa
> e®@àôÖ?ÁphÒgèó>F•î
Fžk¬y*gTÃÚì˜íÙ*¬K’¬9CC·ãñÃ­eq<›¢áõ=Io{öª¬“=nª¬êJÄotLz:;o+zk2¹•Ü%N‘ï`âà]TUjjjjjjjjjjjjjjjjjjjjj
jjjjjjjjjjjjjjjjjjjjk`ú›w=}=M¾÷?,h’dš"°øõDb£Ä¢Jæ»àp@â‚Rff˜:ì(mšq/{ýªñ‚:ø“õ¹­þ“ç`Kot6P¹U3™7oJò³„òÇÕÒ½áåÄÍÖÄ@’¤ÒZÁE6¤ö£=nFü=M
ÏWà«E£ã1X‘öu¯â›¥÷_~#Нc-bâ’g1­k³´`!¸—â·6Ľ=J­¹;¹Äœk¥­£RØ„"ʬ8é~4ý•k:I$‚yP®Gb‘˜¡eïwDÉï1X?ëÂS†_^yû~Ÿ
v‰â˜Sè´UÒµöl6D&¸ž™H
> A–£ÔfV“Ñ_&jÍn®û=J=IÅÔ5oy©ÃÊÒÖ:‚J¾<:†`úp‡t2Lºl,7Íš­Ôf¸=I´7h÷Eñ~CeÝñÜBi/U
@:Šc萺¬: k<qw½ð¦z¡`r[vÕ•«Ï0I‹žXXìó¾G=M ×Ṫ9¤
f›š"¦zÄ=}—Nk°üÞÞ2dB=J–šš{€÷öJÅFút,,,,,2jk/÷Fl2ùò<«˜f*#ʏQ¡><B1=n<’5N=nBéA5V-Â2\bÓÎü`Fô4!8½ƒH‡û0ûêð7*kÒôþH¡’EÁÏT¹MA"X!J
´ú¡`]=@øeÒ׃>«K\@ÞG†“1Û:õAKrböoüAš=J:‡×šD*:\Åþ¾:„¬mYŽEñ<8òÌ­›Êk9Ÿ’­1Åk°U2ö†0a¡849ÃÈ3Zdc/cÔÌ׺·ú”1†z[Ö9Ã#B
-¡Jü“-K¯ÏÖ
0(ÒB–=nùŸ^UkoC7:=@sÍÜxkÖx¥H„=J…‘z_Ùo?{i[-ì=MF„îÊÖ›–Gý–dkáPÊgôÊ:wJÚ2P»}r¬R²¿>jk22WF™Äjò†=MÚ2g(øÀ‹ƒ10)*Rgn=n=n=n=n=n
=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n>¥-¯JÄaoY£?ßíÉ>G‚–m‘™Q¹]z„’ƒ^¸2fV€Gûs¿ì·’£Ô¸ÆA’Àþ
ÇÞ•#¤ÊðOªÛÙ^—òÒ×rÛo1ɳÅýü±ª+{ñXQæaf=I%‚²]楘Rî–&R]Ä–`F'=MÇfÔ(‰ä9e;¸îǾF·FE%(òUB–Px©TTuÆ=MÂÇ£Ê?¾<^F:s™ŸÊ¬
D{Fz¥âÅ=n=I
"¹Êk-Œú£‚#v‹öErT'¶ši§eÍŠ,a½ä'»H€í2/*R/?*zÎFýá]†ûƒÕÄÒ‘/êàÒû0Bœœ{HG§zžñ»íÒ'©??ò¬kkŽ<:‡Ï=n=Iç/t4ÊJ-r`Ž¿ï1vkâÂDk›Y~=}ÃÙ>
=J46É®¬w«“­Èx÷¢&a±ždJ¨H¢·Àb:­’›ñÍ&ØeLñmP¯9QJ>o´K/G6˜ÒZbPàc÷g?p֎×úâfŸ{„=n”R$ÊÓŠE“«¾·³k>özrö0
ªm¹ßrLÇ#´0…a‘¬œ8rQT3Î
>>¦Ûq¢HBiIB_økµÛ½éô-l4@cCH‡k
²Ú/îê’bJ¡$zj]DÕÜ­ax£Êïs—èe,Ôf&ƒ%Üd®C‹=MöF=Mú=nGR¬ŠCÛAëé~Hâü\b|2ò-qdk=n*¬®¬¬-sR`¸^G{ð*Fz”2-Ž
,k»J=n+¤Êâú‰>H—ï>ט§ØÆ´9*,…ij™ZÔgf0<a‹¥Xóµ'R`%NªuÌš&Î=nG'É«¥ƒœ`Ç¥Ç:¤Ûl=@aÃeÒÒ¼@b^:s@…†48–vÎÚ‹ù=MF^Ú­¿üÆF¼*ñ«á?q·^Ø
Ä|!¨rU‡z*k^¬zt´JJJJ„/Ê„9m1B¶odkqö§,9¥5®±2öÛ\¹AGô7ú:::::::::::::::::::::::::::::::::::::::::::::‘M]8æ16úãØ<pœæ›2dšËZô6­›ùû
=n÷îqˆúÊ›:äaºq²’jÔY°ð!w6»Ìrâ-íû1á0Lañøø0ñ´´=J6n‚²ûåúÔ¸¥ì„IjIþÉ¡­¹;<öœÞºÅ)*2b½úIŽRÕ‡4,±n4kMy=nª™yœ3„J¸…Ê€$­êÅì
> +ú§,9lM›Z2c‘ëá>RåS•¸Òc%O·B»¾*-’«ø¯'tÒ3öo>kòFH=IõÕyh´Í÷ññy÷…ÉÙ^Hq
!Þ“îJïà!…¡îRØ=n=nA2O+=n1=n:ªª«’V>E`ˆRXOØÏ=n!®=n@=}n
Da=}­o”¬yYÇ·hCå/°©¾À$>?˜/ű:ÎEZŒ„“a¸¥>E5×oJÄjÎ;r>ª¬^:kpJ­U1Þ­aŒÍ™\­QÄf×é~BéGSûÞgòZ¦Üéö¬¬áa’Ndà2G,-ç«”«RGkˆ
> Ô4d‡ß~Ž#-¯¡ÏLc›*äE—/Ú|´k8c„t8¶E5„ýïÊ™í†:~ã=n;Î@–
kÕMwú–ê1NA€²Jä¬4A8o=n¥÷JÆ÷ŠÜ­c‘–{Ã3=n2h™I´¦Üc·dF$JØ+O9²ýyÃæº¤ŒÃ8
[×,*bÈrg¦^ÖÅK•³*›`­ÚJºW0‚³îWôŽfcJö‘SÀq6!•!¦¿q¿¸ñó´•MNŽ‘K€­¼=noxÆúYÔKÃ?cºW=nz]TLón“>|tÛÛù¡Pµo¤‚˜íîsÖ;8…¿1Ù¯`@µC™HßR
> dú::::::::::::::::::::::::::::::::::::::::::::::::M/AÔ8fpFšþ:­†`Yc;wÍ
1­ºG®‚†=IîF©\95:ìñ‚Hç?oŒ¿Fö^­Ôfx f*ü‡åx(Ë=nBE²ìü
ŒÚ­²Ü±¯oz´e:¤Ê·ïÊ€þakhÀª1,zˆ!#ÊÓ,úmÆW1áÐ)*%q­ûíÉä™u2V÷N¡Ô9]0¥èûº7„;?HÊÔ´Äk½‹’›¾V5k¸]8Hñ**øaë~¦&à5‰„·úž=@¦RFu2!¬­ù{n<ü¬
> 22222222N>@å/ÖÊ€çt2ס`¬kšD>@<âŸkM>ÊdÔ7ðæ9[z–øúQ´Í¢ãæ÷Ï0í:ìaÎ=}=Ip škc
RT‡ÿ/sèRRž?VFúzðc®?[´þÊÓ·æúk•*/Gm¬6óÎ>dklzl,,2O{@
Ê®=n?í¸¾ÔcƒÄLkû÷^~z»Î‡ü-1©R™ÜaRg2oènGeʺ)*ì3•kR_Š=M&Êú?ú,#JÆ=J7ú~fäÒJ±‚þǤÊðvmL?ÏÊ=M½BD“Ë÷/E²Ç˜Jô£Uß–:œ÷-PHKxE;ä8Œó‹¨
›Fqß&ÊŽ=I“W˜”…rgæb¦[=@’„=MÑã1Õ«Às%=@}±>DŒž—+ÈŒ­¿¶*!¼=}ØM?ª½I3ÏžWPê-‡âÊN)*æu©5>ñ©ö;%Ê©Œ
½0¶·(¸'ÿCiÝål]xìb$:¨²¶øE@û˜ì
> v1&t1›³)*&ƒ)*(ƒj[_©É)*¾Ci»=I/?`^‹!Ê}ò«zx¨‹2Xô•Ö¶Ògèùïªú*?ýtkp
kž=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n
> =n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=n=nCtU|ffyNF¶b
æz€Fƒo²PâiÁÔ4Úìpäp?’cÔ¹C„û/7Þ!Jìx¹DÀ:[šZ¸$WBZ1ô~KµØ)*
> N?ó…/uo«ñ´2õ×:p„2öqØÒUú:¥§¿ØFŸ™ú¾H¸B"†cc0±sgl9]4…Y“ä¹½Ÿ{|´Ú2T=J^7áR9˜:žQ˜¯1ù
®£Q ¿¤ù©?{ÀF»:*”ÿZ­·ô!a»Ï?22Vý’Vªªªªªª
ª¬q^@Fº‚:¬ê¦zw7÷„2ó%Ê@Ì4càpÈÒ]_Ô[škÍÌ2ùQ,žkP“D7º§:“>øJ¬x²aJÝ´5¶{´á©Ëki’úÅÿ=n¡ȱž8&Ǟ"ÊÙ¦q:¬e=M=@úzóÙ:¬]»ï/uk|—=nJJÍ7
> ?Cçä$7:mX^EŠŸkš
=@Ðçzw¯>’ž°Ä:ž`6¬ëÝñÔ6Ðí!ÌÍäÊóâss=@ª’dB³«×=Mã­¢…wÿ0!rV3×úƒåúRY×Êàãáýºk”E=@ȲNýŸd818U?¾ÀÞ"¹ó1Ès`—*aud_/
> ‡ZXô`E=n:ª¬28=n;ŠÊÛV¦<¬/Þ£$Ê%Uß²’ޏý«il­=IµFœ=@‰l­C›Úß^×8¤&:
‹ÑíåðP8QØòdn¶eb¦z…Z::2=nJö¬::|ƒƒ6˜¼mw’Üz¦Îü¡ÝsO€¡AÔ4JJJJ6ó
o›k‚C3’­ç++++++++++++++++++++++++++++++++++++++++++++++++++=n;Œ´6µ•ìŸ1Œ­È¢-«û1Jžâ¡4`ûêkvv6»çmmå£?{çãFq5"JpEë2e̾ZÖûél:v»0
»¾G¡ÌÜV>q>Cã߆gzƒ~:zÞ”j2Tp²Tzl9‘Ü7î1mk‹ù·=MúÊÿ=J»Ð1îª%t…Ù=}¦ÿqØ,´Å-´4äìgzw“Mm’fÈ=@´Æ‰ØÙê(É/{ê“Ü7kÕýÂR\ð´îâµÑ{@ÌÚj
j0º‡Î:¬z:g:::::W=nòQaN=}È·I?o­¯RXIkc±ek|p¬ãºS=n7_?Bb¹œ4•ÚkÝ/4Ù¤5|,´JJJ„,,2jjjk/ê›?ChŠV‡$J\b´ArKÄr^2Ž@Äùã?Î{ä‡rW™XOk
û¿×˜ªàâ¸2V•q¦l7Ve”R*+ë/«kÈ’^=n>A@bÊÚó=n=J=J¬#òDG$JÆ!0‚³R”§òfæÁD¬ª+Õè2fö‘”ßžZdòDâ–g:}+Yî2gPÅ2O=nJ¥uFˆF¥7a0‚¦x­[Ñ­
> ý´ø¼’¢H’[Å8·¹=}£ÔUFð—¼b¤?1žgÕR*r!¤®GÖðô
ONžRX˜J—UèR`‘”Œ©@$:­Ôhº“^wš7Jÿ'á°6O×£©Ùÿ1½µð÷µš\:D`’Jjjjjkè@L!­„J$F>n5ÎGÒO++
++++++++++++++++++++++++++++++++++++++++++++++++=nb14R\Mefz‹VjköDŒ›üžMÄÍÅE±?]z%ÔM÷òz•=nÃx£‡Ì8ÂÈM›´…ž™"¸ÍÔ3¥œåU²d‚¡4Ua7°
> ßkÃF`2]š=@/F“0‘Ô2k
eÓæ¡inHÎX%V{InGPwú£ù›GÖúp¸‹Ie?HÅŸ+=@w¯?R2Jâ,–Êð§=Jõ¿ÿqúÊM/¼íðñÔSµ@M¨ä´Ì´jk1ŽFŒÇ±Æ›“J´pôêE//º::
:::::q?k:èÏ=n¡®#†7JÈ÷=@àj9=@¹|«+¤µoŒ#5ÖnŽ3N—­‚Í§ò`ú4,¬´¾=n:ªªª¬::kp¦?oG]Eð':{­ê|6U²/5µâ%ô504熨rWŠ4^1J¬°z/^JÀÁòfMþÌØ
­G˜þÒd„oGºwb95·œÞ;Ç=@–-:j_à±Ì7…M³*•÷0ÒNDRUÉSk©ÞE¬n=Muÿ/®вX[-¤kgÇ/Ä¬Ïã!k°O"¦^ƒš’ÿ1Åf­:Fìr•°®J#Úeƅ¢bß1ž9•ä­·ü7zš
¸câ’õoAkïYº¼†–¸’VûïzžoMžd8’gBåv¡‘ç¶î›k<u°½îöŸ—r\øú”ëkû>œ#מk=}Ds¾2\ïåÙ6ž‰kÀF÷²Ls†uYp1•ƒpóܬ222Xòލ÷Reš'ÅMòX2
g–a‘à[1„DRJÜ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2k!–­gGË=I¼6ޏúŠ„jWdÞ~£"æc·ïíþ:²á&ð'zˆ]Ý埱7º™3<]䧬khó
> 'º{W›•æ??½ãˆ²RreÊóðÅo0ŽÒ2gXó¥AÊ¡­ÿ‹,
™ç”:ŸÊ[cƒ¹·—¤T¹{Ù/ªÌÖ«€ªD0ê=n?¥ḵˆ¤J#æ6‚Úêÿ¸$?n=M‚hörH=IâÌæ+=nGº£¢œa­f`O"
¡Ÿ“Òg¢[{ŒMùEÞäfëkÚJzW+++++=nT2´b,Ÿ=nßÊcñÄ5Gº‡m¨2\Ý^ÊËc´7¶ÿÀ&zsž×_éÊk0ƒ0=J¥ì1¦)*ôþ<Qf„¬¥
=@=I^;=I)*¹÷-èšHyÄ2&ÉN,^ˆwkG
Vâ¹~:õá­\fÌÕ¹>?ÿ,zr¶É[k`ð¤ÊÍÐfS0guÕZé~GzïCþÆñ¼´+=nA²&nªdÊûÙ•¯ÞÊâ7’ʸˆîJüZ0ÌÙÁNAjkÆèЬÁrKØgz†,qND*/ƒj\ßÍÑÔ8C%ƒ·
p:=}
ë1»a[‚¹æOÐå=nG‚N:›a{¦º¢ÇÊ솸kÞyö=@ã1ÝC%àȲ\ñ=M¨ù7]9õÔ93}€ÎRd…ªÇ¶æ¯øf¸ò7&?ųòY
VmÞ[b_0×ëŒF/ldJµÜÛ1qZޞ2dŒë¡P=}³p
> òaLÜd':‹e‘ŠWŽxYf•ŽFÛ
P‘Íš˜Rg‚¥h›Ùžo’1J­›"­Jÿ翲fS0Öƒx1me:˜­Ôhó¯­z­ÓÂrÃÝz”DûÚ2Vªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
ªªªªªªªªªªªªªªª¬¹—û`k‡Hd·ñOpyŒ­3MàMxŸÜÒb¡ì÷k°Î˜®š2a8út=I'ë0ŠîmÄ&—)*¢J§ÞºoG²TUa½¤I¬6Æ–RK+1ÍY7ø3=IÔ9€qšJƒ=nGbÊ∌
+18hLFN=nçÔ¹p<5++o‡=nÊ®:“Fú¢çÌøØšª8ñŒÔZ?X3'º¨I"kGþ~:¬2û1¿¸i¥rcz…4‹…dî¸`EýÔ9u9·–¾G¡ÿ~Ÿ±È
¬ë=M´5,8òOo:::l2Lÿn–Ÿk<<EÊþ
kµ{QRªM÷4Ëï0·ÖFù^A{zªª¬^4¯Ê¬jýj£LM[Núú›O=n:Y|yòJ­M…„·zŽNšËÊ×#ÊʶÑ=J¬“·=I¬GRÔ6NÆ^…Æ*kñXgÍp,å=nFøïr…¸Æ°²Õßëìì­‚¼\S8/
> 1žgÊ8¹ýÿ0ý=MEE“Ìpº£½x‡˜c¹X+,VnÛI5÷œeJLK‰¢ü9Z­ØfžYI²=I£ÎE³Do¬¬±Z¬™Ô2Ê¡ÿ-ìcJ¬
^˜:Ž&ŽV!EkóY”7Ì‹›ž2f#È}˜£M·º„P1IBéÌ9tbíŸ
ÒkÓLZI¥˜­ì–¸ÃøEe{o1X?CF´9†Œ8=ng$»ÊFô9DsI]òx‘JìcÚô7±=}Êû1ý=JÆ*N=nHæZ[=J}E†zŸa1@‡‚W/®{·eà^¬´\R^|3B¢ª4Þ?ž›Zz’X=MÌ6®;âëÔ8Ò
=J·Ê¢…kÐp({k^1*ª¬z:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::‘M‡‹öš¬+9—¯oFï1fºß÷Jü(´Íòîj‰—ÿÏ/Œ¼ÇÊÈ2a¶äc
> 0mÿÑ«­†€CâÂef[o£=nÅÿ/z::
ƒ,½Ú-­¼[ºÙ5kì5kFl6ÛVùEà´Ìš8Q4õj>t,2eJJ›ûºªbiò?FBPú¿±—çz£Ù˜ƒF8=JÒÔj¨JÛ¤gѪ2UE-Ef-õw
> úŽ$›Üxï0ž­ÌF~Û“£±LÔd=MñðbWi:­
wE&Ù“!Êþf¸RVN:xš«Ä÷=n|ónk_J8Ï=n‘—s:0Ú7$ÊdZÓO=nÝŠb¬–º¬8¥úàç:säÖꥺoËO/F
Ýœ¨RUÃÿw{ÿ=nâÄ*
ºgJzN«Ùj«Â%ʬ˜ä4Á0®>ž÷2Z¨W­¡¹œ6I¶™Üüy~FŒO¨øôd=nFØ•óܝI??|2JJºr`47nͲkW§æ”*k¡fåw¬4ÊÝ„skÊ—J»óÌ$ÊÝ…¾Å­kN­‘å¬ì£q(Í(R0£r&&z
~èmæ¸hÎÊË8eºzDí~Ÿk;Mká:­rŠXÕ=n¾G‹ÅÏ·z”s®–“16"ÈG´9E<†m‰Š­RG»…¬übçêÌ7B·á˜¡'ºn€&jÊz§y‘<-l9ÊíåêT$JYØÏ=nX
ĝkŠ3Ù¤2­
…†z‘Äô8²ÃŒøº˜¬z:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::JV¡¢ûFúx¸@7¬­a_1XLF=J´=IÔf³ž<že>A‹9˜l–GäJ
ív„3šû1›÷0§Ï­à¶vDߺhÔUõjjkÄóU£ðz¥ØÿáöJ8˜@ý=J¬ˆV»÷0gÆ”LøW^¨TÍßo::jk°TföÚV­ó«ãš2"T¹iDâÁË`Ìã$J±äÄz£ù¹fí`í©´6›9ùP{ÒD=nB
È_ªªªª¬÷»çíúÊûâÓŽ?oðd‹â“!LØekÕ+Rµ¸ûCH¸jBâðAGÍBEb¥¬5©Òñ†¨2IV(®:¥pJŸ$J©Ôk¥É(O=nHþ­I(RMþ¬xhgÖ«úJÑŒFG2Mû(q¥úqê
> iÄ4Æ¥âphRR›üÇ­qã?qŒÐ¡áˆ«k½Î¥á¥èRR…øÒR@t2W
=J=Iç/¦«j9çU=J¬ž=MÑÔ2V1¬4—=n|*ú¬­š3^:†pjܬ÷Ÿ4k¦áéë/Ó+++=nʺüx«0ÖíÁ?­Ô7=Mí*qmë0íÿ
=}k1n¢šýà¯0Í­c=MX“a¡èÒf–?$çàrkðHKÊv2¢òbîo¯îÇl5êú¦?cŸkƒGÄ–JS:qã1üŒô*Ù¼9paBàRa•õàR`87=n4kƒÎ7˜¿¡ž­6º™±˜Œ­á\31~@222O+
++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++0XGûYKþ¸‡z„­¯­ŠÊøp“1­¬
1½FßÈÞ)*XË~£¸Ë§Gq-'­pæÄ¿È q^GÚvD+þíP)
> *zš
À=nê¥ïî…/?ꪭÝÜßð+÷Φº¥›Fúp£ÞJ7¢A¡ÂÊì¢[Z‚CÙÐÔÍú{|ª¬b¾?»ã=M£´kG[7¡1µ?FgпØ>8òSS¥ºœrž’bΓ÷ÑGz|Ó++++++++,ºS,¹N4
jjLëkøk=@úr˜—´51@´R^0út,,2jjjk2=nJÓ™}k@¢=Iç=nÚK=n@^jò0¥úåJt+AH?Vf_kû/@—ÒúÊå÷4¬B™¼7:::rkŠüw|7Å31~Eñ:eß0´°ñ=@º–ê×kå
*ú=@é>DäILª‚qkõž*Õ­cZ«ð–›2f‘ÞâÄõÿ1ÇQæ<+8Fº&Fœ«ä8ÖIŽ’Ø"9…9¯*2e„-Ut­€ÅN·"ÊÀçúÇ™S0øÈ°Ä½Úk«¾¼s=MîÊ݈21~¢ÂÂú=@­Ì7h=@+
> û®%úyóDa’NŒ#qï/°R—I>@BÅ
¨’V[7e¬¬ìHN¤®A8“®@jjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjk2[&1•"q)*Ù­l:šÇ
¾žšÿØE¬Ôf#LçßU¦ík:þ•áÔ8¶e(XϹ#>GÚr_íwÕ‡O1¿¹ëå5SúQmõÌ´kÿålXàhrgöi'åqWh2^ªþØFïÊÿŽFȈúgjh©¿{·¾{=nʸR2f–¥ãF©M¤H+~
Ř@ã1ÀÌÚîezú§zuÕ’˜zY-n8=JÊ¡9¬6yF1ï/2×ú?=nªt52§¼¬ìA=}Ü5¡8&é'ºyœ©Y)*Ž8)*&J¡QÑ)*Y-äaâ"ÊÈÉ’¦z61ÇÊ­±QwUÔ4ÆO€·!J­¯©mkI‘¢
z
> ~ð¾:„åt2Íó++=nJJJJ®=n:‚ýâk/Ñ«é~:u°"J¬$iâkcä’¬]aû/̺_þx±Ì7q³=@
kž<+R^–nÊ⪛JJâ¸[¨NA–—d,­\Ä\=Ië0×=n*•ynA˜Ä«ï0MuŠ­Šû¤’­j`̬ë
ä(ў<=@«„›kÍwGaª`kx@9=nFÜÍì/“0‘8Dj§S/¸^z2^ŽŽý¹ë0««=@437×¢5=J¬Ýr-k=MêJê<w½ë/«çxÀ¬ÿ¬¥ë€9>A<•Ê/JO/íøß¬ëÿ¬ëÓ/í«z„
óè²V7Jåˆpø!JûÝI’‰Ì7EM‡ÛÍòÊä,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2J;qŽB1BˆM›ISúÊþ®FâÒ5Ôré;é'±O{ëVwÈ\p±¿›
> ­ùcÂþb•­û=nŒÊø9H‹òkÞoÂòxHŠ5êú2f†ˆ;"“uF7¥QÄ´Æ1±E3)*Tk‹&¹FÈk
“e¤¬ié=nDò3ä¹ÏÊÃù¹?Eëjÿá¸Éìҍ»Ùä=n`ºÌÞjk1«ª­õ`þ÷hõð}'
¿qNé¥êDE:£8^V{†¸c³Q´4ããÕÄ6òAÒÌ«¾¨jôbã=I>6·f3!¾<M—’ê¬ë¿Ýjk_ÿ=n|«k,º*-¬3jjjj^0Ò[¼
Úú@zQºÉ6j¹~E±7ËkJ¬žRPç:pz¡2T=n¨/vQ°|
> ­anpÉ
Ò]W˜ðë:pk÷=n@ŸkCz€ºS=nJJJ¬+J¶ßÜ0zq~>V­Ô4Vç–˜­€Ú吼­îò¦ú“º€Ø›kšð192häÊû·ÙŽ=nDàÙw$Jûä:bJÿä<aÎAŠ/ä®D0`ê*¦:’=@7Ÿ!Jå…Ò=M
÷/Ü“ê(²Cx¦z/r/¤›k‘Ú@Jîñ—{MŒ¬¬J7I0뮨2N^0Ù]ï1fÜÞ‡”¢JXN"³çkCáDü/‰~Aö–º_=J¬‚/«_¤NA9?Ít5±8-x’XH:†Gz’‚kŠfz‚e¯Jè•¬k
ÿ=n5àqa·¸r`Ž«'9NAjjjjjjjjjjjjjjjjjjjk@cÊJ¾=n=n=n=n=n=n=n=n=n=n=n=n=n=n:«Ä0‹÷=n‘™^;_=n¡Ë=nC¬4Ã$Ê÷ªaœ8Þ=n=n=n=n=n=n=n=n=n=n=n?
> mïGºñBM¨ñôû0®J=JïõsÄ[)*`¸gq?{í^—Ãá~”›Fì8‚P
E;ÂEE;öJÃäà¢x±zqû1míeu5¿=I²0z£7¯"¦•DÕˆh@ÌçҞ¼›ó)*ÊkXc†œK1m²÷×Jð"ƒÈUĨ”Íè
> ]—=n4T2Jµ=nJ7l88‹
@â=Mõ¹þ/{_#Ë¥0ø&kkŒÆ/Þ‡½Ô´jkR2>«rPÕ«Á±>4üú\Ê;«¾Ê´k^ªoJ®4Þ>»ÿÌ8q"¢z}^Ùd‰tk
1gëÙaØË1u‚D*‰^D=n=n=n=n
=n,Y§§zzîíÌ4Fe¢I´4BFb¦:zïØ(¬ÐQk|ñ82MS¬RÊ|2jjk’ÈŒºdÖ›2g`Æ=J:o;Ì5|3G:ƒàkÎD*…j9¬7D=@°²_’ý!kŠ`Aé=nA™!~Dᩜ7’7ákÍ–;¨A—zÔË÷=n«õ
¹=n:Ü2ŠaÒ!Êþ-îÿ¬5—ä=IâJö6øL'zm–Š˜œ2cŽÇ,`-ª2[ôjëj*7ñï=nª+ÚY¬/¢ŸPúr¹¨ªTÞN7kaŠÊº•t/‚=Iž@8­pæ¼_O/í¹gakš1~@•äÊâd—Ô5Ú¬
VJºz„kÕO×GkÔ3jjjjjjjjjjjjjjjjk5?Ô4¡«RG&=IN;¿&ì18è5½Á÷-eñ-jI#yë=nC²^žRG'›2MéFì1¨c®8&2I’IÂJ¸)*Ô1©ÿ-ègzq¤=Mâ%´0‘É‹=I=n5
> ¾%1:\ô§É³jù³jˆ¡º¦:y#òœ3B
›ö§t3:pgª§Ÿkš=@áŠ1ÊkÌ,,,,,,,,,,,,4ã·¢Ñ5k€A-»$=@ø¬îJ[¢¨ΎÈëÔb³¼±,Ü9Z'qn>ìŒe³6\qkúƒí
> —Ñzq>GqHd;M^»ä$RΩ!}¸£yó/Ï@ì:–x
^@+Ú­ÁAÆl€?E[6žVÜ_årk=@ÌÏ+/…žk=Jzµ—Îè,(DÌh¨[»þ§¼¨éäÍõð´¾H‹kø´JÄkŠ97º\ÈiEkW˜±n@õò^RQ
Sfd42C¡aÔ3ôrçVJ¬íwz\Çr'ºplakc2N€ÁàLÔ#?–¬8ÏJÍÞDÊë$8À­Æ¶øöž@¬HxíuJ2àòþ­Šcʾ=n=n=n=n=n=n=n=n=}è¯/eàšà$J¬ñšW¡Òkl*ðqz¬-M¡¿ë=n
Fiç0˜®¸2RM¬27ë=n°>GB“6‘Uæ±­ÞáwTºõ´7Np];ï/C²£*ÄçòÎGÚóÂ5?¦l8°µkÍoÎD_̲¬î8-ˆÒ^’a„­÷0×cp=@t5«Ž-
¬=MÒk ½ÅÐXU¬°M ûÐ%ÊÝœ»Ó-ÂR
V2?öJÇ®<£’cµY•k|=Ik„Þ7–zo›F¤J¬^Õ0º9éÔ/»Ì*L·ªˆså@b˜¬”7®<ýÙx//ëèRVûf(Ò^•ÙxÒX*^ÿ0«Xƒú†bü3•âJÚœ5­’^¸l8Ë0=J¬V–¬z:::::
::::::::::kk222222222K,ÞÎ4jÎ=n=n=n=n=n=n=n=n=n=n7ºnVtê£A/{½åm4=I'ug+Re>{++++++++++++/NŠ»ÏÑ=Mó/‚G¼ya-÷/Æú=Jk@81½´íˆúýl(«&
ÑÌÒÃÇŽ«¿÷`ß™­vfË%fð±Üy,­rN¨<¦Ñ•=Mkýˆe·ê=n€Ë/‡Ü´Âwî1UI^3³íÂTÍf+ÐÀjº­æE@ÌÏ+=n›k8*¬8ï1øòôžÅ7ÇúÔ¹aDWÊ«ž­³orkŠ8Í”¬Dÿ„3õí
¬ëß第£®=}Á…=J¬ëÁ’QKüù><åøòMP^?ŸD¤JÓM{Ô4:2çdü4?“Aä6Ž›Q{Ê­1i[d:Ž!7¬5júxŽk=@,,,,,,,,3Î=}rN`$J´¬`¬/¤Jµk/¶
ÿ/¥Ñ9MùËk|
> E¸‹=nßö©J£JBk0!=n!_ŸÔ2VDGñn<u®‹ã¸}èÒ[2=n7òkÍM*­ƒžkÿ5”â“¥J-mz
R_-ìl5›?îJÀå}ó/¡­€E™Z­pÇy\­ká>D^€À7&ºr͍¹~AA~pæú„­â„47^15
2]î‡^%º‹Àù,¬ÐeÝêÊÓ¹x-~?VÔ¬ÎEúï/uq+‘É=n?MïrJ‡”Yn-Ñe¬EËd—÷*ºE×JÅJRQ_&:r¨Ä“õ~A•â•ä5àkçkʨk¦
a#ÊâšËï/(D¦z†i—z‚e¬5Þä7Œ½KÍÛ
> 1l3jjjjjjjjjjjjjjk/=nJJJJJJJJJJJJJ®:_è‘+z›Z7¹)*º?CåI¯˜9šO0˜vZç·kq
æMõF±=@¬6ÇIÀ;¡­Q îñôêO0˜vu¸¼+û×2]bæmáÃ)*&Ó0˜¥Ç
> ›hÐú€úW1ÿÒÌ,,,,,,,,,,,,,6
âÿ=noPª]ž¬·ÜZÛ¡k=MʼS–•JÉ!Eò?Fî`‚Þ?¦‚©ŽG7M=}Iž=n×½ñÌ7Z‚±_ïØ7Fc®Gø’J@”ìYû?;48zuò*½ß|Ò
íåXO=Mk0±êÊ„–RÕJJ­âjRf–†ƒ›Šåô„qØ=Io{=MŒÃ¿¸á“Ì­«orŽ@-~D0Ñû0¾k>^k–Ðì5{Þ@7Ëà'zr=}rPªfžkXÌY‡:pçX!/‡qýÄ6ì*݇:jHäÊëú¬­Ç8?
> ¤§zç$úD–¬ûjˆkRdö̬3Íó+=nJJJÄkc£ÊÆÈ)*n<//ÄbšjõpñêJ´úžkHn?d%ú~´^ªª^k
àÒVŒßW@¬hùÊW›RCHúu«gzjEý»jb@Ü4hMōÜ5[È:pÈÒdŒ²&,8Àà
> ²kŠ5s1±><^§Y¬3Qn=}£ra„¬=JÇc¸RXñÇ_=IžE_ cHÒ^˜þ`':“
ŸD˜¬=I‡“/ªÍî(ÒQl*K0<ÉG˜,4ÿ5×ú\8I=n:›åk†ÇR,­aZ5F#JӐåJË‘µt؏/5žèRTpÇ42L!Ù
„=nE=I„"Ê·ð«=nåQ°òJaáÌ31ˆrQZÔú’Æÿ¤¤J⼸¸#Êús¬½_•ë0¶ŸžkÊ¡‰¬51é›kåxÒdŠÀ&Në0O++++++++++++++/HÛÏøJ+ãRKÜ[ìql¬–HRO++++
> 0BÖ~‚rôw=}j+ŽÔ¹gàGŒb§œ6ǽá =IpÊò
¸S=I$î¤*:{Óæ©RRH)*]}’UÌ0²Jº¬5±N;ź2*JÄ2P=n2Mbjø:pš­¿ÝpHíŠÒ×:::::::::::::::ù;h`
£°ÐèÍÔ5íZ¾ß‰>;fWÃÇË;âfú¢ÂÂN°l*¥q·Í‘8‹~}ì"íßê(mòk“N›V½S+:ak‹Ñô-çÁ”¤J^ýЇñÔ+@UÄU¾Þ]?HàFýàç{H®ŽÅ霬Ók—Ž–¬z£çÎìkš¢±å)
*/~¢'Ðê‡Çèƒ/®H{=nÇá{€*ìú†hÏ/Ù-†:†”Y‹÷/¯{@¬«Êi>=}Äÿ¬kÝ÷*c΁>5a…JИ@“0y¢˜ÊzŽdü
Ü­Qgê<”úsPŠpʝRZXYc‚`kð¡*=}nAO)*¿ÎR[
Y»ÑŒ:p¡"¾<N¾©Iuk›^!€9Ô7nùÛ=J=nJû½ˆÏ®8ŠÊûÜpyÂá°ò^*fmû/µŸÌoŸkÞµÀ²W~`2R¦:{…MˆrTx=J¦—/9ÏJJ+’V=@Ôgz–E¤A’¬#b':’=@ÇXÓ/íkqÔ2[
> ^g=JJîïxJ¦:~Ú-‘pü5Ûà^FžkÖwFáDÊÿ×Cë
ÒLj…PÅJÉ’r/«úJ¬Ÿ7äÊÆêD2XGÿ0Ö›J«kÕH¦ÍnE_3z’F¡ÛÜ2\D!÷0«=MW½Š”­EQ}ˆÒO*(z‚5—ó/œÊÓ™=}Ô
2V1¬6=I¹Ì6õ^ʨRTƒØ=@¬¸þžkCqã/xª8m¬2^sý~;Øò=n=@¬¬38Ín–¬bJÚúÄÔk»„GcÊâ¨Î«¨Ò_Ž«0·¨Îˆ^9û/Äk͉…=}ç­àc-45­’O=nÊJJJJJJJJJJJJ±*º
o­âkŒZ׸yRÍÛk¸¹¯aÊ›?D^dît=I}’^-;âîDfêRNi?¤r=I'ö'´4ÃÛAå3¢k8îtýx[-=@Œ:~öExHJx2#Êëpsà6­÷Ü®Ce*cÅ„Cå/²1íE²*'z~›m)*n&z8
E;(õºqIç*ÑéíM:hõc)*ý#®:šÝ·=M)*:zëM”íqÕ¬4Àb¥v)*iž?Xõ-kk—£&¹¬2©*:x}î«k„=@Ù=J«ÁŪt9˧=J\Þ§õ¹^¥QÄ´•­ÄFü2e:¬ò222222222
> 22222c‘®Þ!»=I\1þJü3]pèTé~?îî÷FH„tÍîÄQj!g×ËÞ»ÉòW>Ê^;d•íÌ8à`·­
­‚Î6c‰iNDxàM½ˆrcQO¸· f-IÜ9p\u³an9"kÜ´¾;ë=n-—2cÛ¶öˆ©T
> Íîï^å+Cׄ’¸~­òÕŠ`cRÕ±‰Z«
/%/ÅôúƒÐâÊÅ?ÓkŠ˜ªÜt2“_Ô3è*JÅËÓËkâPªkCãzkq`ïè²Z¥­_(®FÙ½Z݋ʬ®^+ÙÔ7Ͱ¯â•ó0¾«rPº\‚çz‰âFz‚j3¬…±
> ‹PaÞ<Zˆ_>ªZ÷Nzh=} Š/á=MrJê
»Ñ~@öxÁ:q¨ýË8Aë-eG͇Ž¬Ð¸árR£ºh2Jª/¬“d¥àkՍN¨‹kΖÊckҏ«o/í
AÒkšôN:9|¬ëÐòû0Oäkqîª,5°–r
> #JåEØßÚÿ0ã*©7zU˜©£JØ që=n–8à¬Îº–˜:j¡Wl5,+i]’_•à×0«•ÎE±‚­pé´3
ÊÄH¬Ã¯ÄúJÚ›Pº‚‡ë0ª=}kL¯¬r=I~?Õ¬Fþ?W=I¼4@=n¾>™›kÅÂ2Û
> kÚ»R]WØE2Sq‡o2J¸iÌ2Ê0Ѭ4Ç ^¬”°êÄÊÆ
÷=n_êᔬmÙŒ¬$gz”ñ/µ:”½öGú‡ÙH¯/=Mùû1x@ŠIÁ«kG×JÚdJÅjkR22222222222]Ä[VÏ1ÁÅVÐC^º”
> cb2Y¿,²dJÚ¥ñ>@<ÈW2Nt8RTnxÍW0Fc)*ý¶)*Î>
<EÚ*›'ÿ?%MYl)*CG%Ê­±×ÏÁ)*>:Z÷e[Mû±=Mi)*?³i%ô2 8T&¦{)*z}º·6ÂÁ¤ã/855#Oi%ºkìð
> ûi©®?xHJV\çkgêäþœÿ/¥µéæh&J§Â=}‡=M(M
kIޏóOñ؎9Ýj3àÉ£RX^˜ª~In„2JµGz›Ûñ+Z·ñ(Çê©S­ç=nÊJJJJJJJJJJJJJJ=MÈ=}=}åØášFd®EmZ¿åµï
0¢æa¦]`®ªzç²?q±^XíòˆðÈĝy8¯0£Ü_Ï=I°¹NGŸ²_°p°!™H=}ÊiÌ6Ûû»-!J:—0£5Å;:o¸©ú­Þ–ÌÏ+/q:­cÄ3—–¦z¢ýµ¬’óá‘`§í#?H>Mq`ß1Ÿ?œ5jýzk-Ï$
> ÊÚåܤJbØº‰Ž5Ñ™ðºYÏjXM¸ÒJº’e}í¬4õÒ×bÊÕÆsÛ~a`­SIË’_ÞF=}vŽ
{j˜‘º=@#qL­ÐbîŒâÊä*“!JÚ¶úR^•YÔ7EG—¥kší kKĹ8ÒN\÷›kŠ÷_Ü:‚4ükKÊ7
> /Èæzk?~¢Ê÷=J;Òk¾¶·«­Ãàø>CfyIÁ{’T[=nD¦Ž¤Jû¼\mšèo1m„kkÍ…ÐÑr_*
z–z­€Ý|¢¸2VB`fz’MDfzrŠÔ× kŘEÊÍÃÏ7ù>Aóß=J¬öŠX=Iz_kЉBc
“0<¹è·&º‘ºþ¥Jó=@üñÌ411‡G—*{1±=n<^ÔÎD‡H²^•ÓGz”z=Mk͇Ì7F+÷)*¾C^áñ~DÞÎD_Ÿû/=J“=n«„¬ê´çcÊÛD‚#J¬dÊÓ—<¬5
dJːægòTdJË
> ¹wçï0x´H>Ve>Cãæ•Ž:j0ÒJÓô…á>?7Ì^kEH¾«ÄÕ—bʬ^=Iÿ=n¬xñ8rVF8A«Ùç0ÖºÎD_
1Ì7‚ÍÅ…k\v=nGú’45ßÊ߸2Pú:t,,,,,,,,,,8Hüë6~>3–·ÿ¸E
> ¬­ïì Õ;ÛíN·ýa,Ôg€º
±^¬9:Ìд/>;r>¬œ=I=n=}eɬ2#yë*ìæÐºäšPÞ!Ê¡œ@:\éµl2Vf…kÅÂ=J`H­Q­(QÏÊïùKî<Y¿Jöø”Ö«÷/vßÅk{cAâ??%oˆ{}
Þ¸O+Ý:^Úx=MqÿÒUV—Àap—šÿ1XDBƒ÷)*à8ˆÒeº::::::::::::::‘VÌKÃÁ³­¼rî©§±ŸðŸc§ÈÒd̾r¦ÿkÀU6N/÷’XLÆ9Þi¨ÔÍò['Çþøí捀É/!‹Ž;t
˜a£Ië1{kÝN9‘ŸR/ØCz~Zê-x׍«“çnGÖdRÕJ¾?¬Ü#Yw2k=MÃ葇,‚)*·Þ'?qùð5›|áÓû0±…ä”TÎ%º+«Êe¦
jMl8溂+¦_ý|¬3J•=J¬5¬Ðáçºz…Õî\·
k9½MsQû1>ÜC8€äk7®’òøð“1}M•C¿ä*¬ëÎû#JÝC×HrXMÍàÉ^E0H?¥Êà…¬þ¬m¦€–*zuRÄN»…82Nâª0ÄG/é±òJAfDJ¤4k1a@e¬®½Ý‡kݱ1ª­Ar¡²z~æÅ+
> f kx·á¨r+=@Wi~8QšJÎE\Qßþ¼cJ®ªmä8À
Í}ó0@•±Ì7„ú­€Ú­/û)*¾,õ×ßeÊζNR]¤zåk¦­$:u…xÞA ¸?ßÊÂ8'/2Ëk½êQ‡“1fû’•öškº¿û
> —k›PDdÊÚ
=J·¨r_•Ò­€â€(Ò^<0w|6=IS©&pªJåI×ɤ7mßz”ˆäJûЫû/–“k›èÏ/±Ô3-|¬jkC–Ç:k™Ô4@Ü4ãä“Ì4@¥Jːº‚`Íû0‡ݞrkËDIœ4?I~?
> õÓËÒ^zo?{"ʤ<pòLß=M÷,êÚ§ºD¡Eœ2VH–ã0¬wâ8r_<—Óg:¡‹Oöìü
kþGÐÉ~D_ú‚eÔ5,:‚><¬z:::::::::k@RÊi&­Ü(ûI§BÓ…îJZ‚°7=nŸJ”¹˜8«ê3ÄD£ª
> ­èSµÄ~D*’9âJ­Q6Ñ¬6®Á¬]幬+»¼4¡J¬Gô2c¹<¬¯Øe6ö©^>W
^¬¹•¹EkµÂ9=nCãÉ=Mr\šÍ„®CgßþJËCk'ºw‰±ü¿mæ•pòhÿo:´íá=};‹ú·„êÊù
1²››í^ÃÉ'±Z­Û+++++++++++++=n:F2LëkŒŠÅ,XCñåe¸r[±BûROϪÑÑx´Í=@°‹RÍͱùÒ{ƒŒìpâÞ‡¹=}©aÔfà}iÑÍEæÑ»k[rfÇî즹':žãÊ´eHR_íù§öê‘
˜ñÄ8Ò°jEõnDÒÓkšfº€{›åû1Q’Úi+[ËÅKÍ'?qóãí«íj=J9ó0e¸TUa£žÿ/sG£JºÏHäÊ<žM¼*Üg%J±?çz5¯=}ý~?eƒa¬5­
2cÎOý„>0qqMköqë0²[Ë×F_R_–ž
ŸÜl5åfU¼5ßĤkʶ´úÊà„9œ3V-q>6ïìêHÒOÚãgskP`ˆÙNÊڰܸò*ä²ÚRkų=nÞØr[jI›k½ظšÔ4¡¹D±eÈò[]b“—²kÉ¢‚[¬xJ¬çº=JxÄJ»P}éï0À
> Í:’‚N]„þ®E[G©žDßʵõo1nêÙÔ8Â9Äê­Ë¶z†]n:
{—>;M/šÿ0y˜±Ô50úHÆ:{座ë/3MÁÔ8–jM;Ù0Êò”ú—/FTãkÅêØ0úô÷Á>FΎ­r-mí—akѦ=@
/Þ<[—ˈLªò݇:•EÖ-¦£J¸ú=nE[íû/'VʐáÐÆt5^¼$üºžŽÛê$J77><:x)*º„ÖJÔ4»qÔ4À$ÊÐ~>[òT•áï/6‹ôºŽJ$Jó$ú/\DMÂkÅ«äËÌ4À½íû/w^¬
> _åÚz^-|7Jœý«‘—ºƒÜÅ=I‡úŸ‹Óq{rg:(¤H/0·£Êå‡kÊšeÇú†bJÚ
²W’2O++++++++/NŠ¥rM›rhyàåZ_W>Géz¢"¦n·/¸Lë×zŸÜ£Â—×Müÿq†gײµšÌåL=Jž¿®J
> ¹àšÙúÄküö C%r­€÷5àºJè=}ÍÄzwaÂjôíÚél¬£JÓ¯¿Ü4ÂEn>Z_/‡±—–­]±™Ì6ǯ‘:z
•mnCe8ìrõ0X³Ã²7@­QÜZ*J|Íþ=n=nFâe±ðœö÷‚û/Ú‚Û²‹8C
> ¹™L­Ó+++++++++++++=n:2ÍÒkåeS\lff„b¤JíõX?íh‘mòœžTͬ
öûà”ç`MÂ{†"&:øžŠ‘¢)*TÍ÷MxA>R3><óìfoSö=IŽÉ’Jü“CJ•Âr§ÿ›k®î³Å¿=I²0
> ÍÉ~G×`>~ÊGºjþ,­1]`GûÇ—ÏÒhSõJÛÒŸT¸Õ=n-ûo?ìèr[
²EÄj=Jr0ú*NGY´5£Çä4wEý¬5+wÜW0}</zá=J:mKßnÅÊ9ÿ0ë†kÒ¶=@Ë/î¤Ü7EBe¬\jÑÔ5J
E/Gãôžúv›cíÓkҍŒúrJï-©~?ÐàÜ·yï=n<0ùÔ4gᔬ¸Ë×|6‡€k+0y@­A9&Êöâh>óq·>ABœx’X˜^2_–j7ú”MM—•Ä7Äì*=n>EßáÒ!J·?¡r_•žbJÀX
¸²a•ðëH²WJ/à44b¢…Ì6ÆS®¸RV_>zŒ1E=J­s^W-tRc›QV×ç¸ÇzŽû–//IÃÙ¼6!=@ì6Õw|8£D•„'z›v\«­PâD̞û0ûâèæº˜ñÓü’­Ìeö`û0š×`kÝ3WÎE^NÊæ
Ê^ã1mEtÛÿ0ûÄd­ÌÄ=JV‰Ô6=I2*ÀÊÌ5á~=}rLÞ2T„czk/䬯äJÓ˜à¬ÃwÊÍÂ_ÛkÙ>Cä[~zŽdAä6rcžç¢JÓ*Hk/je4b-вJ8K/sÚt31·­rÇÀjkú:­ý•ò­
> z%2_•'l7D=MÜ5±§cÊâ¨Æº†e~@çz‚>=n<ªªªªªªª­¹G±=}noškÇ×­
E:PŠÐâýçzxHvFì4è‘Û#sWî>>}y„?A˜Nº-ÃkÊÃäH1& kÒîp=nïç7Êÿâá´õ]9ÓÎDáEµ’
>>=@â¤ÒÕ¸þïa}1êÔQ'”‹«òµ8šQ=nA™˜ç2Èz…'“¨5(21àŽP%щ&z~
ÞΨC"JÕåx¡–ü´ö=MŸÆÄO/G²ÁY*bÒ¨V+ܲ'RÅj)
> =yend size=101704 crc32=0d72f868
Subject: Re: HELP!!!! - 1 attachment
Date: 29 Jun 2003 08:28:14
Message: <3efedb5e$1@news.povray.org>
Ah ok then plz old way ty,
Martin Belair wrote:
> Martin Belair <bad### [at] hotmailDOTcom> wrote in
>>This file was encoded with the new yEnc encoding scheme, designed to
>>save bandwidth by dramatically reducing the 30%+ overhead incurred by
>>UU and Base64. For more info, see http://www.yenc.org/
> Oh yes.... The attachement is yEnc encoded. If you can't decode it, and have
> enough request, I can re-send it the old fashion way....
> Ciao!
> Mart
Date: 29 Jun 2003 08:30:05
Message: <3efedbcd$1@news.povray.org>
So what do you think of it artisticaly?
Flaming Monarch wrote:
> I killed povray!!!
> Can someone help me render a scene,
> I am working on this abstract thing and i am trying to render it but its
> taking forever.
> Will someone with a fast processor or way of rendering help me...
> Or maybe some help taking time off rendering...
> I like the scene as is so anything that is not destructive to the way it
> looks or renders would be great.
> I would love it so much if it could be 1024-768 aa 0.3
> Thanks Tonnes!!!!
> Source
> #declare Radiosity=on
> global_settings {
>   assumed_gamma 1.0
>   //max_trace_level 25
>   #if (Radiosity)
>     radiosity {
>       pretrace_start 0.08           // start pretrace at this size
>       pretrace_end   0.04           // end pretrace at this size
>       count 35                      // higher -> higher quality
> (1..1600) [35]
>       nearest_count 5               // higher -> higher quality (1..10) [5]
>       error_bound 1.8               // higher -> smoother, less accurate
> [1.8]
>       recursion_limit 3             // how much interreflections are
> calculated (1..5+) [3]
>       low_error_factor .5           // reduce error_bound during last
> pretrace step
>       gray_threshold 0.0            // increase for weakening colors
> (0..1) [0]
>       minimum_reuse 0.015           // reuse of old radiosity samples
> [0.015]
>       brightness 1                  // brightness of radiosity effects
> (0..1) [1]
>       adc_bailout 0.01/2
>       //normal on                   // take surface normals into account
> [off]
>       //media on                    // take media into account [off]
>       //save_file "file_name"       // save radiosity data
>       //load_file "file_name"       // load saved radiosity data
>       //always_sample off           // turn sampling in final trace off
> [on]
>       //max_sample 1.0              // maximum brightness of samples
>   #end
> //-------------- Includes
> #include "colors.inc"
> #include "textures.inc"
> #include "metals.inc"
> //----------------------------      Variables for size and seed
>    #declare R = seed(12);
>    #declare num_spheres = 40;
>    #declare area=10;
>    #declare min_size = .15;
>    #declare max_size = .35;
> #declare thing = sphere_sweep {
>    //linear_spline | b_spline | cubic_spline
>    cubic_spline
>    num_spheres,
>    #declare i = 0;
>    #declare start_pos = <rand(R)*area-(area/2), rand(R)*area-(area/2),
> rand(R)*area-(area/2)>;
>    start_pos, rand(R)*(max_size - min_size)+min_size,
>    #while (i<num_spheres - 2)
>       #declare s_size = rand(R)*(max_size - min_size)+min_size;
> rand(R)*area-(area/2)>, s_size,
>       #declare i = i + 1;
>    #end
>    //no_shadow
> object {thing  texture {T_Chrome_2E }}
> /*light_source {
>   0*x
>   color rgb <1,1,1>
>   translate <0, 10, -10>
> light_source {
>   0*x                 // light's position (translated below)
>   color rgb 1.0       // light's color
>   area_light
>   <8, 0, 0> <0, 0, 8> // lights spread out across this distance (x * z)
>   4, 4                // total number of lights in grid (4x*4z = 16 lights)
>   adaptive 4          // 0,1,2,3...
>   jitter              // adds random softening of light
>   circular            // make the shape of the light circular
>   orient              // orient light
>   translate <40, 80, -40>   // <x y z> position of light
> camera {
>     location  <0,1.5,-8.5>
>    look_at <0, 0, 0>
> //--------------------------------------------        Extra Scene objects
> sky_sphere {  pigment {   White} }
> //    gradient y
> //    color_map {
> //      [0.0 rgb <0.6,0.7,1.0>]
> //      [0.7 rgb <0.0,0.1,0.8>]
> plane {
>   y, -1.5
>   pigment { color rgb <0.7,0.5,0.5> }
>    plane {
>   y, -3.5
> //pigment{White}
>     texture {
>     pigment { rgb <1,1,1 > }
>     finish {
>         ambient 0
>         diffuse 0
>         reflection .3
>         brilliance 0
>         specular 1
>         roughness 1
> #declare thin = union {
> torus {
>   0.8,
>   0.2
> scale y*1
> torus {
>   0.8,
>   0.2
> scale z*2
> rotate x*90
>   #declare thig2 = union {
> object{thin scale 1 texture {T_Chrome_2D}//no_shadow
> rotate z*0}
> object{thin scale 1.2 texture {T_Chrome_2E}//no_shadow
> rotate z*45}
> object{thin scale 1.4 texture {T_Chrome_3A}//no_shadow
> rotate z*90}
> object{thin scale 1.6 texture {T_Chrome_4B}//no_shadow
> rotate z*135}
> object{thin scale 1.8 texture {T_Chrome_4C}// no_shadow
> rotate z*180}
> object{thin scale 2 texture {T_Chrome_2A}//no_shadow
> rotate z*225}
> object{thin scale 2.2 texture {T_Chrome_2B}//no_shadow
> rotate z*270}
> object{thin scale 2.4 texture {T_Chrome_2C}//no_shadow
> rotate z*315}
> object {thig2  }
>  //sphere { <0, -2.5, 5>, 1 pigment {Red}}
Subject: Re: HELP!!!! - 1 attachment - 1 attachment
Date: 29 Jun 2003 08:42:46
Message: <Xns93A957E94DF00badhabit07hotmaildot@204.213.191.226>
Flaming Monarch <fla### [at] gatescom> wrote in
news:3efedb5e$1@news.povray.org:
Well....That was not very long.... Here it is.....
Download 'test3.jpg' (100 KB)
Preview of image 'test3.jpg'
Date: 29 Jun 2003 08:50:20
Message: <Xns93A9593362414badhabit07hotmaildot@204.213.191.226>
news:3efedb20@news.povray.org:
> Cool, Ty for the help, but I dont think that the image attached very
> well. its all weird like when u open an image in notepad.
Like I wrote in my previous message, the file is yEnc encoded. MUCH better
that the common way files are encoded in the newsgroup. Just to compare,
check the size of my first post, around 900 lines, it was yEnc encoded. If
you look at the repost of THE same image, under the normal way, it is more
than 2200 lines. You can grab a news reader that can decode en encode with
yEnc. I use XNews that you can find here: http://xnews.newsguy.com/
Ciao!
Mart
Date: 29 Jun 2003 13:06:01
Message: <3eff1c79$1@news.povray.org>
Well I updated mozilla and it works now, Kool
Thankz sooo much!
It looks great!
> Ciao!
> Mart
Date: 29 Jun 2003 13:08:07
Message: <3eff1cf7$1@news.povray.org>
hmmm... I don't think your image is encoded in a better way. I cannot see
it!
Date: 29 Jun 2003 13:11:53
Message: <3eff1dd9$1@news.povray.org>
Update to mozilla 1.4 it will work
> it!
Date: 29 Jun 2003 15:52:56
Message: <Xns93A9E00864156torolavkhotmailcom@204.213.191.226>
news:3efecac3$1@news.povray.org:
> Thanks dude, Email me at
> Fla### [at] fentraxcom
I just came home from a fishing trip with some friends.
And I noticed that Martin has already posted your image
to this group.
Before I went fishing, I tried to send the image in an
email to you at fla### [at] gatescom (as your email
address appear in your posts to the POV-Ray news server).
But the message bounced back  =(
Now I see that you use this email address: Flamingmonarch
[at]fentrax.com
I just wonder why are you using a non working email
address in your posts (?)
Tor Olav
> Tor Olav Kristensen wrote:
>> I let my PC render your image during the night. It is finished now.
>> (4 hours @ 2 GHz Athlon)
>> How do you me to send it to you ?
>> E.g.:
>> .jpg -> By email
>> .jpg -> Posted to povray.binaries.images
>> .png or .bmp -> Uploaded temporarily to my home page server
Date: 29 Jun 2003 16:14:54
Message: <3eff48be@news.povray.org>
Spammers have bots that scan news groups for email addys.
I had a previous email monoalphabeticsubstitution
and it got spammed off the net after i posted on several message groups.
I'm not saying that povray people are all spamming hackers, i'm just
saying that i have had bad results.
So now I just give my email to people i know.
Plus now I have my own website I have my own real email addys.
Did ya catch lots?
You should render a pic of a fish you caught, :)
> to this group.
> [at]fentrax.com
> Tor Olav
>>>E.g.:
>>>.jpg -> By email
Date: 29 Jun 2003 18:29:03
Message: <3eff682f@news.povray.org>
I use the Outlook Express that came with WinXP and I won't change to another
newsreader, so is this a freeware yEnc plugin for OE ?
Hugo
Date: 30 Jun 2003 01:05:53
Message: <3effc531@news.povray.org>
I like it, its now my background.
Gary
"Flaming Monarch" <fla### [at] gatescom> wrote in message
news:3efedbcd$1@news.povray.org...
> > I killed povray!!!
> > taking forever.
> > Thanks Tonnes!!!!
> > Source
> > global_settings {
> >   assumed_gamma 1.0
> >   #if (Radiosity)
> >     radiosity {
> > (1..1600) [35]
[5]
> > [1.8]
> > pretrace step
> > (0..1) [0]
> > [0.015]
> > (0..1) [1]
> >       adc_bailout 0.01/2
> > [off]
> > [on]
> >   #end
> >    #declare area=10;
> >    cubic_spline
> >    num_spheres,
> >    #declare i = 0;
> >       #declare i = i + 1;
> >    #end
> >    //no_shadow
> > /*light_source {
> >   0*x
> >   color rgb <1,1,1>
> > light_source {
> >   area_light
lights)
> > camera {
> >    look_at <0, 0, 0>
objects
> > //    gradient y
> > //    color_map {
> > plane {
> >   y, -1.5
> >    plane {
> >   y, -3.5
> > //pigment{White}
> >     texture {
> >     finish {
> >         ambient 0
> >         diffuse 0
> >         reflection .3
> >         brilliance 0
> >         specular 1
> >         roughness 1
> > torus {
> >   0.8,
> >   0.2
> > scale y*1
> > torus {
> >   0.8,
> >   0.2
> > scale z*2
> > rotate x*90
> > rotate z*0}
> > rotate z*45}
> > rotate z*90}
> > rotate z*135}
> > rotate z*180}
> > rotate z*225}
> > rotate z*270}
> > rotate z*315}
> > object {thig2  }
