POV-Ray : Newsgroups : povray.binaries.images : Media Wheel Server Time
30 Nov 2026 07:32:42 EST (-0500)
  Media Wheel (Message 1 to 18 of 18)
Subject: Media Wheel
Date: 1 May 2003 23:07:23
Message: <3eb1e0eb@news.povray.org>
Probably could arrange it in a prettier way...
Tim Cook
Version: 3.12
Download 'mediawheel.jpg' (110 KB)
Preview of image 'mediawheel.jpg'
Subject: Re: Media Wheel
Date: 2 May 2003 01:34:54
Message: <3eb2037e$1@news.povray.org>
Very nice, Tim! This should go directly into the POV-Ray manual!
George
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:3eb1e0eb@news.povray.org...
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 2 May 2003 03:09:21
Message: <3eb219a1@news.povray.org>
i suppose there is a light in the middle? If so, this is realy usefull.
JWV
> Tim Cook
> Version: 3.12
Date: 2 May 2003 03:19:05
Message: <3eb21be9@news.povray.org>
Very nice idea! But I need more information to decode the wheel. Perhaps
because my media knowledge is small. Those spheres probably represent more
than the type of media. Also the strength of parameters? And what does the
white "cross" to the upper right represent?
Regards
Hugo
Date: 2 May 2003 04:38:10
Message: <3EB22E70.1070004@informatik.uni-freiburg.de>
How about a cube? One axis for each of scattering, emission, and absoption.
Maybe with five or seven values each (instead of just three). This would
allow for things like "much scattering, less absorption and still less but
negative emission".
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 2 May 2003 08:18:50
Message: <3eb2622a$1@news.povray.org>
Clever idea!
Date: 2 May 2003 10:06:39
Message: <3eb27b6f$1@news.povray.org>
Cube doesn't lend itself to quick-glance interpretation.
Tim Cook
Version: 3.12
Date: 2 May 2003 10:11:07
Message: <3eb27c7b@news.povray.org>
The white cross to the upper right represents a slice of the
circle, with the dot/line/three dots accompanying each slice.
The innermost dot represents the absorption amount, the middle
dot emission, the outer dot scattering.  Red dot is a value of
-0.5, white dot is 0.0, green dot is +0.5.  Wheel designed to
show the difference between positive and negative values in
any given combination of media elements.
Tim Cook
Version: 3.12
Date: 2 May 2003 10:35:06
Message: <web.3eb281e874c2221f592a91630@news.povray.org>
Very nice!
It is supposed to be like the color wheel right?  maybe the map key should
use RGB instead of RG and White then.  Just to make the image nicer, maybe
the media should be colored too.
So does the combination of attributes dettermine the values of a slice?
Like RRG is two thirds absorption, and one third scattering.  If so don't
you need one more value to compliet the chart... zero!  You are counting
from one to three, but there is no point where there is no media.  going
back to the color wheel analogy in the color wheel tone values are usualy
shown as black in the center, and white toward the rim of the wheel.
I think this wheel is the best discription I have ever seen on the different
types of media.  I look forward to seeing how you finish it.
Date: 2 May 2003 11:16:57
Message: <3eb28be9@news.povray.org>
Very nice tool. And I was thinking negative emission would be the same
as absorption... tsssss ;-)
The order is quite nice too, with the "symmetries" well chosen. I'll
suggest another order which might be easier to read (or might not):
starting from 12 o'clock and going clockwise, I'd go
  0, 0, 0
  0, 0,.5
  0,.5, 0
.5, 0, 0
.5,.5, 0
.5, 0,.5
  0,.5,.5
.5,.5,.5
(if I understood correctly, symmetries will take care of the rest.)
To improve readability, you might carve small S, E, A letters in the
spheres or use letters directly. Other ideas, which are rather personal
taste, include using white/gray/black instead of green/gray/red and
keeping the spheres horizontal everywhere, always in the same order (SEA).
I do not fully understand the setting. Is the the wheel of constant
depth and are the media of uniform densities? How is the light located?
Is the wheel in front of (over) the spheres? Where do the glows come? Is
there media outside the wheel?
Povingly,
Philippe
Date: 2 May 2003 12:03:31
Message: <3eb296d3$1@news.povray.org>
> (0, 0, 0),(0, 0,.5),(0,.5, 0),(.5, 0, 0),(.5,.5, 0),
> (.5, 0,.5),(0,.5,.5),(.5,.5,.5),...
I'm playing around with rearranging them myself now, if it
doesn't turn out well I'll try your variation...or I could
do both. ;)
> Is the the wheel of constant depth and are the media of uniform densities?
Yes.  The wheel is a cylinder with radius of 4 height 1 at 0,0,0,
the media having only the properties of scattering, emission, and/or
absorption with rgb values -0.5, 0.0, or 0.5.
The scattered light is located at 0,0,0.5 with fade distance of 1.0
and fade power of 2.0.  There is an additional non-scattering light
at 0,0,20 to provide ambient illumination, with fade distance of 0
and fade power of 1.
The dot/lines are located 0.5 units over the origin at a distance
of 3.5 units.  The coloured spheres lie at z=0.
The scattering light is the only light source affected by media,
all glows are properties of the media through which the light is
travelling.
> Is there media outside the wheel?
No.
Tim Cook
Version: 3.12
Date: 2 May 2003 13:00:42
Message: <3eb2a43a@news.povray.org>
Nice. Maybe something like "+/-S", "+/-E" ...etc  instead of the spheres
would be clearer.
Date: 2 May 2003 15:21:37
Message: <3eb2c541@news.povray.org>
Arranged in a prettier way.
Tim Cook
Version: 3.12
Download 'mediawheel.jpg' (108 KB)
Date: 2 May 2003 15:22:34
Message: <3eb2c57a$1@news.povray.org>
Good god that's some hideous compression artifacting...
Tim Cook
Version: 3.12
Date: 2 May 2003 16:02:49
Message: <3eb2cee9$1@news.povray.org>
That's pretty damn cool.
 -Shay
Date: 3 May 2003 00:38:34
Message: <3eb347ca@news.povray.org>
Thank you, Tim! Seeing this is helping me understand media.
One thing I don't understand, though, is the way some of the wedges show
pronounced variations from the center outward. Especially noticeable in
red-white-red and red-green-red. Does this have something to do with the
placement of the light source?
Will Woodhull
Thornhenge, SW Oregon, USA
willl.at.thornhenge.net
news:3eb2c541@news.povray.org...
<snip>
Date: 3 May 2003 00:58:32
Message: <3eb34c78@news.povray.org>
the light source is placed at the exact centre of the wheel, providing
the same illuminative properties to each wedge.  the red/*/red areas
are unique in the amount they increase the light that passes through
them, because they are scattering rgb -0.5 AND absorbing rbg -0.5.
what sets those three pieces apart from each other is the emission
value; green is emitting rgb 0.5, white nothing, red emitting rgb -0.5.
Tim Cook
Version: 3.12
Date: 4 May 2003 11:24:21
Message: <3eb530a5@news.povray.org>
news:3eb34c78@news.povray.org...
> Will W wrote:
<snip>
Ok, that helps me correct my mental model of what is going on. So what we
are seeing in this are the effects as viewed from outside the plane of the
light rays that cause the effects. Neat!
