POV-Ray : Newsgroups : povray.binaries.images : Balcony sans scattering media Server Time
30 Nov 2026 07:32:41 EST (-0500)
  Balcony sans scattering media (Message 1 to 15 of 15)
Subject: Balcony sans scattering media
Date: 1 May 2003 16:42:46
Message: <3eb186c6@news.povray.org>
1 h 50 m 58 s render time without the excessive light funness,
though the primary spotlight is an area light.
Please submit any suggestions/comments before I embark on
another week-long attempt to render it with the scattering
media and photons.
Tim Cook
Version: 3.12
Download 'balcony2.jpg' (105 KB)
Preview of image 'balcony2.jpg'
Subject: Re: Balcony sans scattering media
Date: 1 May 2003 17:08:54
Message: <3eb18ce6$1@news.povray.org>
I suggest that you brighten it up even more and attempt to make the colors
more vibrant, especially because the media will reduce the amount of
color/light that reaches the camera.
I especially suggest that you brighten the angel itself, as that seems to be
the focus of the picture, and she's sort of grey colored.
Consider adding another light (without media interaction, perhaps even
shadowless) to fill in the dark areas. I would suggest placing it
asymmetrically, too.
Overall, the image just seems to dark for the subject matter. Maybe you
intended that, but if not, keep working on the lighting.
 - Slime
[ http://www.slimeland.com/ ]
Date: 1 May 2003 17:13:46
Message: <3eb18e0a@news.povray.org>
Not if you have the media absorbtion be -0.05 to its
scattering 0.05 it won't. ;)
See attached image as what most of the pic looks like WITH
the fancy scattering media.  (Since most of your comments have
to do with the lighting which is considerably different once
the scattering media with photons comes into play)
Tim Cook
Version: 3.12
Download 'untitled.jpg' (70 KB)
Preview of image 'untitled.jpg'
Date: 1 May 2003 17:49:24
Message: <3eb19664$1@news.povray.org>
Wow, yeah, that *is* brighter. I guess the negative absorption does it.
Is negative absorption the same as emission?
 - Slime
Date: 1 May 2003 18:11:03
Message: <3eb19b77@news.povray.org>
Nope.  Emission simulates the media actually generating
energy, whereas absorption simulates removal of energy;
removal of negative energy isn't exactly the same as
generating energy, it's more of a cancelling force than
an additive force.
Tim Cook
Version: 3.12
Date: 1 May 2003 18:51:59
Message: <3eb1a50f$1@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:3eb19b77@news.povray.org...
> an additive force.
Surely it's more of a multiplying force? so things viewed through negative
absorption will have their colour increased by it, multiplicitavely. i.e. black
things will stay black which they won't with emission.
It's a nice effect in any case :)
Tek
http://www.evilsuperbrain.com
Date: 1 May 2003 18:57:41
Message: <3eb1a665$1@news.povray.org>
black
Is that how it works? I know that emission is additive, but i never figured
out how absorption works. I imagine it involves some sort of complicated
integral, since it seems to be sort of like an infinite number of
nearly-transparent thin layers.
I always wonder about the math behind these things.
 - Slime
Date: 1 May 2003 19:11:06
Message: <3eb1a98a$1@news.povray.org>
Well absorption works exactly the same as black fog. I worked the maths out for
fog once:
For example, if visibility at 1 metre is 90%, then at 2 metres it will be 90% of
90%, i.e. 81%. Basically  visibility = pow( visibility at distance of 1,
distance )
Absorption is kind of the other way round, so if you have 10% absorption you
have 90% visibility (though don't ask me how pov's density and stuf comes into
it). So, negative absorption actually increases visibility!
Tek
"Slime" <slm### [at] slimelandcom> wrote in message news:3eb1a665$1@news.povray.org...
> black
>  - Slime
Date: 1 May 2003 20:24:38
Message: <3eb1bac6@news.povray.org>
Looks nice.  Makes me think of Anne Rice for some reason.  Maybe the mix
of balcony and metaphysics.
Date: 2 May 2003 16:05:38
Message: <3eb2cf92$1@news.povray.org>
news:3eb186c6@news.povray.org...
The balcony railing looks to me to be conspicuosly non-detailed when
compared to the nice detail level of the rest of the image.
 -Shay
Date: 7 May 2003 04:49:58
Message: <04ihbvo340hco2t7mo01u2mpkbl978ehg8@4ax.com>
On Thu, 01 May 2003 16:42:33 -0400, Tim Cook <z99### [at] bellsouthnet>
>media and photons.
I don't know how you did this, but this is the best computer-generated
hair I've seen second only to Final Reality (the movie).
Peter Popov ICQ : 15002700
Date: 7 May 2003 13:00:32
Message: <3eb93bb0@news.povray.org>
Final Fantasy, perhaps?  Actually the hair I'm using is pretty cheap,
it needs tweaking yet, I doubt it'd hold up to a close-up.
Tim Cook
Version: 3.12
Date: 7 May 2003 14:06:45
Message: <3eb94b35@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> a écrit dans le message de news:
3eb93bb0@news.povray.org...
It's Kozaburo's Alice hair, right? Kozaburo's hair holds up quite nicely in
close-up :)
http://www.oyonale.com/ldc/images/fermeture_detail5.jpg
I think Kozaburo has a photoshop tutorial about painting hair on his site.
G.
- Graphic experiments
- Posters
Date: 7 May 2003 14:50:11
Message: <3eb95563$1@news.povray.org>
 > nicely in close-up :)
It might hold up nicely in close-up, but probably not just dumped
directly over from Poser with no correcting of the texture's
properties inside of POV...as it is I already did some tweaking,
but will go in later and see how much better I can make it.  I
think one thing I did that makes it look better is using a bump
map (which I just slapped the texture map on as a bump map too).
Tim Cook
Version: 3.12
Date: 8 May 2003 03:13:48
Message: <7r0kbvcr90ku1dctg544l48sogds2r6asr@4ax.com>
On Wed, 07 May 2003 13:00:36 -0400, Tim Cook <z99### [at] bellsouthnet>
That, too :)
I'd really appreciate some insights into how you did it anyway, if you
feel like putting up the time to do that.
