POV-Ray : Newsgroups : povray.binaries.images : Glasses Server Time
30 Nov 2026 07:32:39 EST (-0500)
  Glasses (Message 1 to 15 of 15)
Subject: Glasses
Date: 28 Apr 2003 10:41:53
Message: <3ead3db1@news.povray.org>
I made this scene some months ago, and decided to re-render it with higher
settings and different textures and tweakings.
It has some focal blur, I might retry it with a higher focal blur.
Time to render 29 hours.
I hope you like it. Comments/suggestions are welcomed.
Fernando.
Download 'VasoFinal.JPG' (256 KB)
Preview of image 'VasoFinal.JPG'
Subject: Re: Glasses
Date: 28 Apr 2003 11:17:11
Message: <3ead45f7$1@news.povray.org>
Great! Wonderful job on modeling the cut glass.
I like this a lot and it makes good use of POV-Ray's
capabilities. I would say, not as a criticism, but
observation, that the caustics seem too bright, too
intense. However, that may be intentional. Another
point is that this type of glass has a more sharply
defined outer rim. I have noticed that it is not easy to
model with something like sPatch or Hammapatch.
I think the rim needs to be modeled
 _
with two points close together rather than
with one point, because of the way spline patch
normals are rendered. Although, I have not tried
this yet.
Harold
"Fernando Gonzalez del Cueto" <fgd### [at] hotmailcom> wrote in message
news:3ead3db1@news.povray.org...
> Fernando.
Date: 28 Apr 2003 12:26:28
Message: <3EAD5633.FE2C5CAE@gmx.de>
Good modelling work on the glass but the ground shows all indications for
poor usage of image maps.  Don't take this too seriously, it is very
difficult to make well and i have seen a lot of pictures by professionals
that were much worse, none the less i like to point it out.
The main problems about image maps for rough surfaces like this are:
- the inherent lighting of the image maps does not harmonize with the
scene.  Possible solutions are to either use an image map with a lighting
very similar to that in the scene (quite impossible for caustics like
this) or to remove the lighting from the image map.  For very rough
surfaces this is nearly impossible, in any case it usually requires a lot
of handwork and experience (Kari Kivisalo did some quite impressive tests
for that).
- when the image map is only applied to a flat surface, possibly with a
bump map derived from it, the surface lacks self shadowing effects which
are quite important for realistic appearance.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 28 Apr 2003 16:39:07
Message: <slrnbar28n.gva.steve@zeropps.org.uk>
That concrete is beautiful.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 28 Apr 2003 16:39:08
Message: <slrnbar2in.gva.steve@zeropps.org.uk>
Hmm, I must be loosing my touch, I thought the ground was great.
I havn't been in p.b.i for quite a long time.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 28 Apr 2003 16:52:36
Message: <3ead9494$1@news.povray.org>
Hey, this is fantastic!
Andrew.
Date: 28 Apr 2003 17:22:42
Message: <3ead9ba2$1@news.povray.org>
Hi Harold,
Perhaps I'm not understanding you very well, because according to me, the
outer rim is quite rounded. Or perhaps you're saying that it should be less
smooth? Or even more rounded?
Thanks for your comments!
Fernando.
"Harold" <bai### [at] 3dculturecom> escribió en el mensaje
news:3ead45f7$1@news.povray.org...
>  _
> this yet.
> Harold
Date: 28 Apr 2003 18:37:16
Message: <3eadad1c$1@news.povray.org>
Thanks Andrew :)
"Andrew Coppin" <orp### [at] btinternetcom> escribió en el mensaje
news:3ead9494$1@news.povray.org...
> Andrew.
Date: 28 Apr 2003 18:37:40
Message: <3eadad34$1@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> escribió en el mensaje
news:slr### [at] zeroppsorguk...
higher
Thanks Steve, I'm glad you liked it :)
Subject: RE: Glasses
Date: 28 Apr 2003 18:48:25
Message: <3eadafb9@news.povray.org>
Fernando Gonzalez del Cueto <fgd### [at] hotmailcom> escribió en el mensaje
de noticias 3ead3db1@news.povray.org...
Muy bueno Fernando!!!
It's a great image, and I also think the ground is great
(my daughters also do so), and the glasses are very well
modelled, with a lot of detail (Rhino?).
The caustics are a bit exagerated but I love photons ;-).
Don't keep such beauties in your HD.
Show us more.
Bye
Txemi Jendrix
http://www.txemijendrix.com
Date: 28 Apr 2003 20:08:10
Message: <3eadc26a$1@news.povray.org>
Yes, I am saying it should look less rounded. When rendered the glass
appears very thick, as if it becomes a little thicker near the rim, which is
not true of a real glass, actually the opposite is true. I have seen this
as an artifact when I render glasses modeled in sPatch or Hammapatch.
How did you model these?
Harold
news:3ead9ba2$1@news.povray.org...
> Hi Harold,
less
> Fernando.
> >  _
> > this yet.
> > Harold
Date: 28 Apr 2003 20:14:30
Message: <3eadc3e6@news.povray.org>
Hi Christoph,
Actually the lighting of the bitmap was quite uniform. I manipulated the
imagemap to make it a bumpmap, highlighting only the cracks and fissures of
the stone.
But you're right, it is not flawless. Also, you can see that the tiles are
the same. Fortunately, it is not quite evident until you begin to inspect
the image more carefully.
Thanks for your comments,
Fernando.
"Christoph Hormann" <chr### [at] gmxde> escribió en el mensaje
news:3EAD5633.FE2C5CAE@gmx.de...
higher
> for that).
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 29 Apr 2003 05:43:39
Message: <3eae494b$1@news.povray.org>
Very nice - esp the floor, nice touch.
PGP Public Key
Date: 29 Apr 2003 06:05:01
Message: <3EAE4E4C.F4FEDD1@gmx.de>
> Hi Christoph,
> the stone.
Uniform lighting does not help in this scene, the caustics result in very
non-uniform illumination.  I think it much looks as if the ground is a
photo of a rough cracked concrete ground and not the material itself.
Date: 30 Apr 2003 01:00:11
Message: <3eaf585b$1@news.povray.org>
Hola Txemi,
Thanks! No, I didn't model them in Rhino, but in the lathe editor built in
Moray.
Yes, I think the caustics are also a bit too strong, and in my current
render I'm using lower settings.
The bad thing is it takes forever in each render, so I cannot tweak very
often :)
Thanks again,
Fernando.
"Txemi Jendrix" <tji### [at] euskalnetnet> escribió en el mensaje
news:3eadafb9@news.povray.org...
mensaje
higher
> Show us more.
> Bye
> Txemi Jendrix
