POV-Ray : Newsgroups : povray.binaries.images : tcb spline Server Time
13 Aug 2024 11:20:29 EDT (-0400)
  tcb spline (Message 1 to 5 of 5)
Subject: tcb spline
Date: 11 Apr 2003 07:50:45
Message: <ltad9voejvpq5fc1j1i0h5fq73t0l3a48t@4ax.com>
red line has tcb (tension, continuity and bias) parameters set constant for
whole spline while black spline has the same control points with different tcb
parameters for incoming and outgoing tangent vectors. additional control points
before and after spline required to control first and last segment.
ABX
Download 'tcb_spline.png' (33 KB)
Preview of image 'tcb_spline.png'
Subject: Re: tcb spline
Date: 11 Apr 2003 09:35:32
Message: <3e96c4a4$1@news.povray.org>
More power to splines.  Is this going to be in the MegaPOV source?  :o)
Chris Colefax's old spline macro has it in SDL.
Hugo
Date: 11 Apr 2003 09:42:33
Message: <f8hd9vk1b3srps3r4b6l455n8ouidbtl8h@4ax.com>
On Fri, 11 Apr 2003 15:35:58 +0200, "Hugo Asm" <hua### [at] post3teledk> wrote:
Maybe. Who knows... Since x_spline is as powerfull as is who need tcb... ;-)
Yes. But as I studied his macro I did not noticed separated control of all
parameters on both sides of each control point.
ABX
Date: 11 Apr 2003 11:11:47
Message: <Xns935AAF5DA4351seed7@povray.org>
sounds promising!
thanks,
Ingo
Date: 11 Apr 2003 11:13:41
Message: <Xns935AAFAFA4seed7@povray.org>
in news:ltad9voejvpq5fc1j1i0h5fq73t0l3a48t@4ax.com ABX wrote:
> red line has tcb [...]
Looks promising!
Thanks,
Ingo
