POV-Ray : Newsgroups : povray.binaries.images : SISRay Server Time
16 Oct 2026 16:35:55 EDT (-0400)
  SISRay (Message 1 to 16 of 16)
Subject: SISRay
Date: 1 Feb 2003 21:43:36
Message: <3e3c85d8@news.povray.org>
This is an idea I've been working on ( off and on ) since September 2001.
It's a single image stereogram done with a pigment function. The formulas are
derived from the SISgen technical page:
    http://www.techmind.org/stereo/stech.html
by W.A. Steer, Ph.D..
This image came out ok, but I've discovered other depthmaps haven't worked out
so well. The problem seems to be in using the full 0-1 range of the grayscale
image. It causes the perspective to be overly exaggerated and where the white
parts compress so much it throws you out of the image. I've just about worked
out how to compensate for it, but it introduces another problem in the middle
where the function changes directions. I haven't figured out where to adjust for
that yet. I'll post the code to p.b.s.f if anyone's interested. I'm sure it
could use many other optimizations as well.
A couple of interesting points about it as is now though. You can choose to
render at any arbitrary render size and it will maintain a constant eye
separation. Also, with one tiny change you can make cross-eyed versions! I've
never seen those before done in this style. I'll post an example as a reply here
and a small version of the depthmap used for those who have trouble making these
things out.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Download 'SIS800x600CenterTest.jpg' (190 KB)
Preview of image 'SIS800x600CenterTest.jpg'
Subject: Re: SISRay (Cross-eyed)
Date: 1 Feb 2003 21:47:18
Message: <3e3c86b6@news.povray.org>
Here's the cross-eyed version. It has some depth-issues that make it kind of
hard to maintain focus, but it essentially works. When I get that one bug
figured out it shouldn't be too hard to compensate for this as well. . .
hopefully. :)
Download 'SIS800x600CenterTestCrossEye.jpg' (190 KB)
Preview of image 'SIS800x600CenterTestCrossEye.jpg'
Subject: Re: SISRay (Depthmap)
Date: 1 Feb 2003 21:49:58
Message: <3e3c8756$1@news.povray.org>
Here is the depthmap used for both of these.
Download 'SISTestIMG.jpg' (6 KB)
Preview of image 'SISTestIMG.jpg'
Subject: Re: SISRay
Date: 1 Feb 2003 22:26:51
Message: <Xns93162D566857Fraf256com@204.213.191.226>
"Batronyx" <bat### [at] alliancecablenet> wrote in
news:3e3c85d8@news.povray.org
> 2001. It's a single image stereogram done with a pigment function. The
> formulas are derived from the SISgen technical page:
Wow, beautifull :)
Date: 1 Feb 2003 22:30:04
Message: <Xns93162DE213D04raf256com@204.213.191.226>
news:3e3c8756$1@news.povray.org
Hmm but on niether image I didn't saw that right cone, only left one, and
sphere :-/
Date: 1 Feb 2003 22:45:03
Message: <3e3c943f$1@news.povray.org>
> sphere :-/
I think it was just you, I saw it all fine =)
Although, I think the depth map needs to be compressed so that we get more
depth information about the objects. They seemed very flat to me.
 - Slime
[ http://www.slimeland.com/ ]
Date: 1 Feb 2003 23:15:11
Message: <Xns93163588771E5raf256com@204.213.191.226>
"Slime" <slm### [at] slimelandcom> wrote in news:3e3c943f$1@news.povray.org
>> and sphere :-/
> more depth information about the objects. They seemed very flat to me.
I agree, and maybe problem iwth 3-rd object (right one) was that it is too
big (especialy on my 19") - I would try decreasing it's height
Date: 2 Feb 2003 01:00:45
Message: <1pkm2egyle5l4$.2w7y3dmtxjsr$.dlg@40tude.net>
I think that maybe increasing the seperation for each pattern repeat might
make viewing it easier. This might mean increasing the max depth?
Date: 2 Feb 2003 09:12:13
Message: <3e3d273d@news.povray.org>
I couldn't see anything really.
And I know the trick. I guess I am 'too' sober.  ;o)
Hugo
Date: 2 Feb 2003 10:21:15
Message: <3e3d376b$1@news.povray.org>
Like I said, this one has some depth issues that make it hard to maintain focus.
It's easier if you try to 'get' the focus by looking at the bottom of the image
where the pattern is wider. If you can't do it don't worry about it. This
particular render was a happy accident. Once I get a bug or two worked out I'll
post some better ones.
"Hugo Asm" <hua### [at] post3teledk> wrote in message
news:3e3d273d@news.povray.org...
> Regards,
> Hugo
Date: 2 Feb 2003 10:59:51
Message: <3e3d4077$1@news.povray.org>
The flattened look and the foreshortening effect are controllable to some
extent. This wasn't perhaps the best example to post. I was just eager to share.
Subject: Re: SISRay
Date: 2 Feb 2003 11:41:32
Message: <3e3d4a3c$1@news.povray.org>
Thanks.
Date: 2 Feb 2003 11:48:58
Message: <3e3d4bfa$1@news.povray.org>
I've just posted the source to p.b.s-f along with some recommendations for use.
I think increasing the dpi variable will do what you want, and yeah, that
affects max depth.
Batronyx ^"^
"Greg Edwards" <edw### [at] hotmailcomremovethis> wrote in message
news:1pkm2egyle5l4$.2w7y3dmtxjsr$.dlg@40tude.net...
Date: 2 Feb 2003 14:28:03
Message: <3e3d7143@news.povray.org>
Thanks for posting the depth map. I was able to see
the objects clearly :-)
I agree with Slime, also the floor looked curved to me,
like it was a cylinder. That illusion may also be due to
the stretched depth map gradient, ie. too much white
in the foreground.
HB
"Slime" <slm### [at] slimelandcom> wrote in message
news:3e3c943f$1@news.povray.org...
and
> > sphere :-/
>  - Slime
Subject: Re: SISRay
Date: 2 Feb 2003 14:28:06
Message: <3e3d7146@news.povray.org>
Is it just an amazing coincidence that just the day before
(1-31-03) QuadHall requested exactly what you have
shared?! This will revive my interest in SIS (aka, random
dot stereograms).
Thank you Barrett!
Harolddd
"Batronyx" <bat### [at] alliancecablenet> wrote in message
news:3e3c85d8@news.povray.org...
are
Subject: Re: SISRay
Date: 2 Feb 2003 21:30:55
Message: <3e3dd45f@news.povray.org>
"Harold Baize" <bai### [at] itsaucsfedu> wrote in message
news:3e3d7146@news.povray.org...
> dot stereograms).
> Thank you Barrett!
> Harolddd
It must be, because I wasn't aware of it.
Your welcome :)
