something I'm working on for my irtc entry. 5000 blades of grass, less than
20 minutes to render. comments, criticisms, suggestions?
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshil
acefg",r,1))-97;disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4
pigment{rgb 10}}_(r+1)#end#end _(1)//KL
Download 'grass.jpg' (236 KB)
Preview of image 'grass.jpg'
Will you be making this macro available?
"Kevin Loney" <klo### [at] pt2m com> wrote in message
news:3e2cdf5f@news.povray.org...
than
> Kevin
> http://www.geocities.com/qsquared_1999/
Yess great :)
May we have an idea of the features of your macro (use of trace? image_map
mask? anyelse?)
Marc
"Kevin Loney" <klo### [at] pt2m com> a écrit dans le message de news:
than
> Kevin
Yes I plan on making it available.
features (at the moment):
-Two methods of placement (random scatter and grid)
-Use of pigment for placement
-All blades are unique with random bend and length
-Everything is traced
features (I plan on adding):
-more control over the properties of the blades (At the moment it's only
setup for my irtc entry)
-color control
-wind
-I'm taking suggestions
Kevin
Mnnn smells good :)
suggestion: soil fertility based on pigment determining color and growth.
Marc
3e2d602e@news.povray.org...
> -color control
> -wind
> Kevin
Looks very nice.
Something that I've been experimenting with using GT's grass macro is to
create a set of green grass, and then a set of dead grass within it, by
simply making them both occupy the same space. The end result seems to look
much more realistic. Probably by adding some yellowish, some brown, etc.,
the realism could even be enhanced further.
I could post an example, if I can ever figure out how to get my newsreader
working... :-/
Slash
-Animatable wind
-Animatable growth, seasonal colors and geometry
-One of those solar powered automatic mowers
Slashdolt <nomail@nomail> wrote in message
news:web.3e2d7cd28cb0cca55543301f0@news.povray.org...
> Looks very nice.
look
> working... :-/
> Slash
thats a good idea. it seems shorter, young blades of grass are whitish-green
in color. the random length that is in this macro would be accentuated with
color variation, i think.
ross
than
Looks very nice. How many triangles per blade of grass?
-Shay
> -Shay
Who said anything about triangles =) Each blade is a union of four cones, I
plan on changing it to meshes however, cones were easier to implement at
the time.
Kevin
On Tue, 21 Jan 2003 15:45:22 EST, Carn wrote:
>> -Shay
> the time.
Try sphere_sweeps. It would be slow but look great!
than
Very nice. What's the memory usage?
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)///GS
these are the stats for 5000 blades of grass without rad or the isosurface
that
I used for the ground
Ray->Shape Intersection Tests Succeeded Percentage
Cone/Cylinder 454979 38580 8.48
Isosurface 109192 109192 100.00
Isosurface Container 109192 109192 100.00
Bounding Box 6009716 800041 13.31
Vista Buffer 14963855 10388767 69.43
Smallest Alloc: 25 bytes Largest: 786456
Peak memory used: 21574535 bytes
Time For Parse: 0 hours 3 minutes 33.0 seconds (213 seconds)
Time For Trace: 0 hours 0 minutes 6.0 seconds (5 seconds)
Total Time: 0 hours 3 minutes 38.0 seconds (218 seconds)
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg"
Well, I'm impressed!
Nice work.
Andrew.
